    4. iobroker zeschossen
    iobroker zeschossen
      Thomas Braun Most Active @Krisiun last edited by
      @krisiun sagte in iobroker zeschossen:
      libnode72
      sudo apt purge libnode72 node-*
      Krisiun 1 Reply Last reply Reply Quote 0
      • Krisiun
        Krisiun @Thomas Braun last edited by
        Die ausgabe ist zu groß kann ich nicht schicken aber ich schicke Die die letzte Zeile da ist denke ich ein fehler
        Errors were encountered while processing:
         /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb
        needrestart is being skipped since dpkg has failed
        E: Sub-process /usr/bin/dpkg returned an error code (1)
          @krisiun
          Nee, kann ich nicht.
          • Krisiun
            @thomas-braun sagte in iobroker zeschossen:
            Leider
            • OliverIO
              OliverIO @Krisiun last edited by
              @krisiun
              zu wsl unter windows würde gern auf die faq von microsoft hinweisen.
              du kannst da gern experimentieren, allerdings ist wsl eigentlich nur zu linux-entwicklung unter windows gedacht und nicht um da einen server dauerhaft laufen zu lassen.
              https://learn.microsoft.com/en-us/windows/wsl/faq#can-i-use-wsl-for-production-scenarios--
              • Krisiun
                Krisiun @OliverIO last edited by
                @oliverio
                OK also es wird nix?
                  Leider
                  ...nicht vollständig.
                  • Krisiun
                    krisiun@Marek2:~$ sudo apt purge libnode72
                    Reading package lists... Done
                    Building dependency tree... Done
                    The following package was automatically installed and is no longer required:
                      libc-ares2
                    Use 'sudo apt autoremove' to remove it.
                    The following additional packages will be installed:
                      nodejs
                    The following packages will be REMOVED:
                      libnode72*
                    The following packages will be upgraded:
                      nodejs
                    1 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                    Need to get 0 B/29.5 MB of archives.
                    After this operation, 147 MB of additional disk space will be used.
                    Do you want to continue? [Y/n] y
                    (Reading database ... 47321 files and directories currently installed.)
                    Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
                    Unpacking nodejs (18.18.0-1nodesource1) over (12.22.9~dfsg-1ubuntu3) ...
                    dpkg: error processing archive /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb (--unpack):
                     trying to overwrite '/usr/share/systemtap/tapset/node.stp', which is also in package libnode72:amd64 12.22.9~dfsg-1ubuntu3
                      libnode72
                      sudo apt remove libnode72
                      • OliverIO
                        @krisiun
                        zum probieren schon,
                        aber wenn ich sehe, das der thread hier schon 124 beiträge lang ist, dann hapert es ein wenig an den skills und dann ist es nochmal schwerer das in so einem szenario zum laufen zu bringen.
                        daher, kauf dir lieber eine raspi.
                        die sind nicht so teuer.
                        denk dran, die anzahl der adapter gehen direkt auf den hauptspeicher.
                        wenn du dir einen mit 1MB ram holst, dann ist das nur für ein paar Adapter sinnvoll. wenn du vor hast, mehrere Sorten von Geräte anzubinden, dann hol dir einen mit 4MB, da bist du erst einmal save
                        und kannst dich langsam in das thema linux einlesen.
                        ein rapsi schluckt auch nicht soviel strom (<10W) wie ein ganzer PC der dauerhalft läuft (womöglich noch mit einer eigenen Grafikkarte)
                        da kommen dann eher 100W und höher auf.
                        10w24h=240W, bei 30 cent/1Kw, dann ca 7cent pro Tag
                        100w
                        24=2400W, bei 30 cent/1Kw, dann ca 70cent pro Tag und höher.
                        Fürs Jahr kannst dir das ja selber ausrechnen.
                        Krisiun Great SUN 2 Replies Last reply Reply Quote 0
                        • Krisiun
                          krisiun@Marek2:~$ sudo apt remove libnode72
                            libc-ares2
                            nodejs
                            libnode72
                            nodejs
                          • Krisiun
                            @oliverio sagte in iobroker zeschossen:
                            @krisiun
                            100w
                            Danke für den Tipp aber ich habe schon einen
                            Krisiun bahnuhr 2 Replies Last reply Reply Quote 0
                            • Krisiun
                              Krisiun @Krisiun last edited by
                              @krisiun
                              100w
                              Das hier läuft nur sporadisch nicht ständig
                              • bahnuhr
                                bahnuhr Forum Testing Most Active @Krisiun last edited by
                                habe schon einen
                                hoffentlich was ordentliches mit viel Speicher
                                  @krisiun
                                  apt policy nodejs
                                  • Krisiun
                                    Krisiun @bahnuhr last edited by
                                    @bahnuhr
                                    Ja das passt schon. Danke
                                    bahnuhr Thomas Braun 2 Replies Last reply Reply Quote 0
                                    • bahnuhr
                                      @bahnuhr
                                      Und wat für einen ?
                                      • Krisiun
                                        krisiun@Marek2:~$ apt policy nodejs
                                        nodejs:
                                          Installed: 12.22.9~dfsg-1ubuntu3
                                          Candidate: 18.18.0-1nodesource1
                                          Version table:
                                             18.18.0-1nodesource1 500
                                                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                             18.17.1-1nodesource1 500
                                             18.17.0-1nodesource1 500
                                             18.16.1-1nodesource1 500
                                             18.16.0-1nodesource1 500
                                             18.15.0-1nodesource1 500
                                             18.14.2-1nodesource1 500
                                             18.14.1-1nodesource1 500
                                             18.14.0-1nodesource1 500
                                             18.13.0-1nodesource1 500
                                             18.12.0-1nodesource1 500
                                             18.11.0-1nodesource1 500
                                             18.10.0-1nodesource1 500
                                             18.9.1-1nodesource1 500
                                             18.9.0-1nodesource1 500
                                             18.8.0-1nodesource1 500
                                             18.7.0-1nodesource1 500
                                             18.6.0-1nodesource1 500
                                             18.5.0-1nodesource1 500
                                             18.4.0-1nodesource1 500
                                             18.3.0-1nodesource1 500
                                             18.2.0-1nodesource1 500
                                             18.1.0-1nodesource1 500
                                             18.0.0-1nodesource1 500
                                         *** 12.22.9~dfsg-1ubuntu3 500
                                                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                                100 /var/lib/dpkg/status
                                          @krisiun
                                          sudo apt remove nodejs libnode72
                                          • Krisiun
                                            @bahnuhr sagte in iobroker zeschossen:
                                            @bahnuhr
                                            Und wat für einen ?
                                            Es geht da nicht um den raspi der geht doch einwandfrei. Keine probleme.
                                            23934
