    4. iobroker zeschossen
    iobroker zeschossen
    • Krisiun
      Krisiun @Thomas Braun last edited by
      Die ausgabe ist zu groß kann ich nicht schicken aber ich schicke Die die letzte Zeile da ist denke ich ein fehler
      Errors were encountered while processing:
       /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb
      needrestart is being skipped since dpkg has failed
      E: Sub-process /usr/bin/dpkg returned an error code (1)
        Thomas Braun Most Active @Krisiun last edited by
        @krisiun
        Nee, kann ich nicht.
        sudo apt purge libnode72
        Krisiun 1 Reply Last reply Reply Quote 0
        • Krisiun
          @thomas-braun sagte in iobroker zeschossen:
          Leider
          • OliverIO
            OliverIO @Krisiun last edited by
            @krisiun
            zu wsl unter windows würde gern auf die faq von microsoft hinweisen.
            du kannst da gern experimentieren, allerdings ist wsl eigentlich nur zu linux-entwicklung unter windows gedacht und nicht um da einen server dauerhaft laufen zu lassen.
            https://learn.microsoft.com/en-us/windows/wsl/faq#can-i-use-wsl-for-production-scenarios--
            • Krisiun
              Krisiun @OliverIO last edited by
              @oliverio
              OK also es wird nix?
                @krisiun sagte in iobroker zeschossen:
                Leider
                ...nicht vollständig.
                • Krisiun
                  krisiun@Marek2:~$ sudo apt purge libnode72
                  Reading package lists... Done
                  Building dependency tree... Done
                  The following package was automatically installed and is no longer required:
                    libc-ares2
                  Use 'sudo apt autoremove' to remove it.
                  The following additional packages will be installed:
                    nodejs
                  The following packages will be REMOVED:
                    libnode72*
                  The following packages will be upgraded:
                    nodejs
                  1 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                  Need to get 0 B/29.5 MB of archives.
                  After this operation, 147 MB of additional disk space will be used.
                  Do you want to continue? [Y/n] y
                  (Reading database ... 47321 files and directories currently installed.)
                  Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
                  Unpacking nodejs (18.18.0-1nodesource1) over (12.22.9~dfsg-1ubuntu3) ...
                  dpkg: error processing archive /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb (--unpack):
                   trying to overwrite '/usr/share/systemtap/tapset/node.stp', which is also in package libnode72:amd64 12.22.9~dfsg-1ubuntu3
                    libnode72
                    sudo apt remove libnode72
                    • OliverIO
                      @krisiun
                      zum probieren schon,
                      aber wenn ich sehe, das der thread hier schon 124 beiträge lang ist, dann hapert es ein wenig an den skills und dann ist es nochmal schwerer das in so einem szenario zum laufen zu bringen.
                      daher, kauf dir lieber eine raspi.
                      die sind nicht so teuer.
                      denk dran, die anzahl der adapter gehen direkt auf den hauptspeicher.
                      wenn du dir einen mit 1MB ram holst, dann ist das nur für ein paar Adapter sinnvoll. wenn du vor hast, mehrere Sorten von Geräte anzubinden, dann hol dir einen mit 4MB, da bist du erst einmal save
                      und kannst dich langsam in das thema linux einlesen.
                      ein rapsi schluckt auch nicht soviel strom (<10W) wie ein ganzer PC der dauerhalft läuft (womöglich noch mit einer eigenen Grafikkarte)
                      da kommen dann eher 100W und höher auf.
                      10w24h=240W, bei 30 cent/1Kw, dann ca 7cent pro Tag
                      100w
                      24=2400W, bei 30 cent/1Kw, dann ca 70cent pro Tag und höher.
                      Fürs Jahr kannst dir das ja selber ausrechnen.
                      Krisiun Great SUN 2 Replies Last reply Reply Quote 0
                      • Krisiun
                        krisiun@Marek2:~$ sudo apt remove libnode72
                          libc-ares2
                          nodejs
                          libnode72
                          nodejs
                        • Krisiun
                          @oliverio sagte in iobroker zeschossen:
                          @krisiun
                          100w
                          Danke für den Tipp aber ich habe schon einen
                          Krisiun bahnuhr 2 Replies Last reply Reply Quote 0
                          • Krisiun
                            Krisiun @Krisiun last edited by
                            @krisiun
                            100w
                            Das hier läuft nur sporadisch nicht ständig
                            • bahnuhr
                              bahnuhr Forum Testing Most Active @Krisiun last edited by
                              habe schon einen
                              hoffentlich was ordentliches mit viel Speicher
                                @krisiun
                                apt policy nodejs
                                • Krisiun
                                  Krisiun @bahnuhr last edited by
                                  @bahnuhr
                                  Ja das passt schon. Danke
                                  bahnuhr Thomas Braun 2 Replies Last reply Reply Quote 0
                                  • bahnuhr
                                    @bahnuhr
                                    Und wat für einen ?
                                    • Krisiun
                                      krisiun@Marek2:~$ apt policy nodejs
                                      nodejs:
                                        Installed: 12.22.9~dfsg-1ubuntu3
                                        Candidate: 18.18.0-1nodesource1
                                        Version table:
                                           18.18.0-1nodesource1 500
                                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                           18.17.1-1nodesource1 500
                                           18.17.0-1nodesource1 500
                                           18.16.1-1nodesource1 500
                                           18.16.0-1nodesource1 500
                                           18.15.0-1nodesource1 500
                                           18.14.2-1nodesource1 500
                                           18.14.1-1nodesource1 500
                                           18.14.0-1nodesource1 500
                                           18.13.0-1nodesource1 500
                                           18.12.0-1nodesource1 500
                                           18.11.0-1nodesource1 500
                                           18.10.0-1nodesource1 500
                                           18.9.1-1nodesource1 500
                                           18.9.0-1nodesource1 500
                                           18.8.0-1nodesource1 500
                                           18.7.0-1nodesource1 500
                                           18.6.0-1nodesource1 500
                                           18.5.0-1nodesource1 500
                                           18.4.0-1nodesource1 500
                                           18.3.0-1nodesource1 500
                                           18.2.0-1nodesource1 500
                                           18.1.0-1nodesource1 500
                                           18.0.0-1nodesource1 500
                                       *** 12.22.9~dfsg-1ubuntu3 500
                                              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                              100 /var/lib/dpkg/status
                                        @krisiun
                                        sudo apt remove nodejs libnode72
                                        • Krisiun
                                          @bahnuhr sagte in iobroker zeschossen:
                                          @bahnuhr
                                          Und wat für einen ?
                                          Es geht da nicht um den raspi der geht doch einwandfrei. Keine probleme.
                                          • Krisiun
                                            nodejs:
                                              Version table:
                                            Removing nodejs (12.22.9~dfsg-1ubuntu3) ...
                                            Removing libnode72:amd64 (12.22.9~dfsg-1ubuntu3) ...
                                            Processing triggers for man-db (2.10.2-1) ...
                                            Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
                                            Scanning processes...
                                            Scanning candidates...
                                            Scanning processor microcode...
                                            Scanning linux images...
                                            Failed to retrieve available kernel versions.
                                            Failed to check for processor microcode upgrades.
                                            No services need to be restarted.MOVED:
                                              libnode72 nodejs
                                            No containers need to be restarted. remove and 0 not upgraded.
                                            After this operation, 42.1 MB disk space will be freed.
                                            User sessions running outdated binaries:
                                             krisiun @ /dev/tty1: bash[5843]
                                             root @ /dev/pts/0: apt[7094,7146], sh[7151]
                                             root @ /dev/tty1: bash[5801], init[5800], su[5842]
                                            No VM guests are running outdated hypervisor (qemu) binaries on this host.
                                            23992
