    4. iobroker zeschossen
    iobroker zeschossen
    • bahnuhr
      bahnuhr Forum Testing Most Active @Krisiun last edited by
      @krisiun sagte in iobroker zeschossen:
      @bahnuhr
      Ja das passt schon. Danke
      Und wat für einen ?
      Krisiun 1 Reply Last reply Reply Quote 0
      • Krisiun
        Krisiun @Thomas Braun last edited by
        krisiun@Marek2:~$ apt policy nodejs
        nodejs:
          Installed: 12.22.9~dfsg-1ubuntu3
          Candidate: 18.18.0-1nodesource1
          Version table:
             18.18.0-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
         *** 12.22.9~dfsg-1ubuntu3 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                100 /var/lib/dpkg/status
          Thomas Braun Most Active @Krisiun last edited by
          @krisiun
          sudo apt remove nodejs libnode72
          • Krisiun
            Krisiun @bahnuhr last edited by
            @bahnuhr sagte in iobroker zeschossen:
            @bahnuhr
            Und wat für einen ?
            Es geht da nicht um den raspi der geht doch einwandfrei. Keine probleme.
            • Krisiun
              nodejs:
                Version table:
              (Reading database ... 47321 files and directories currently installed.)
              Removing nodejs (12.22.9~dfsg-1ubuntu3) ...
              Removing libnode72:amd64 (12.22.9~dfsg-1ubuntu3) ...
              Processing triggers for man-db (2.10.2-1) ...
              Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
              Scanning processes...
              Scanning candidates...
              Scanning processor microcode...
              Scanning linux images...
              Building dependency tree... Done
              Failed to retrieve available kernel versions.
              The following package was automatically installed and is no longer required:
              Failed to check for processor microcode upgrades.
              Use 'sudo apt autoremove' to remove it.
              No services need to be restarted.MOVED:
                libnode72 nodejs
              No containers need to be restarted. remove and 0 not upgraded.
              After this operation, 42.1 MB disk space will be freed.
              User sessions running outdated binaries:
               krisiun @ /dev/tty1: bash[5843]
               root @ /dev/pts/0: apt[7094,7146], sh[7151]
               root @ /dev/tty1: bash[5801], init[5800], su[5842]
              No VM guests are running outdated hypervisor (qemu) binaries on this host.
              • bahnuhr
                @bahnuhr
                Und wat für einen ?
                Musst es ja nicht verraten.
                War nur neugierig.
                • Krisiun
                  @bahnuhr
                  Und wat für einen ?
                  War nur neugierig.
                  Nein du hast mich falsch verstanden das ist doch kein Geheimnis aber ich bin jetzt wo anders beschäftigt und die daten habe ich doch nicht im kopf
                    Thomas Braun Most Active @Krisiun last edited by Thomas Braun
                    @krisiun
                    sudo apt update
                    sudo apt full-upgrade
                    • Krisiun
                      krisiun@Marek2:~$ sudo apt update
                      Get:1 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                      Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
                      Get:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
                      Get:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease [109 kB]
                      Fetched 338 kB in 3s (98.9 kB/s)
                      Reading package lists... Done
                      All packages are up to date.
                      krisiun@Marek2:~$ sudo apt full-upgrade
                      Calculating upgrade... Done
                        libc-ares2
                      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                      • Great SUN
                        Great SUN @OliverIO last edited by
                        @oliverio Ich kann auch noch einen HP Mini-PC empfehlen 8GB Ram, 256GB SSD, 2,9Ghz CPU. Der maximale gemessene Verbrauch unter Last lag bei dem bei 25W. Durchschnitt eher bei 5W 😉
                        Krisiun DJMarc75 2 Replies Last reply Reply Quote 0
                          @krisiun
                          Dann jetzt nodejs installieren.
                          sudo apt install nodejs
                          • Krisiun
                            Krisiun @Great SUN last edited by
                            @great-sun
                            Klingt verlockend aber momentan nicht. Bin zu arm 😞
                            Great SUN 1 Reply Last reply Reply Quote 0
                            • Great SUN
                              Great SUN @Krisiun last edited by
                              @krisiun Kostet bei Amazon gerade 89 EUR
                              • Krisiun
                                krisiun@Marek2:~$ sudo apt install nodejs
                                  libc-ares2
                                The following NEW packages will be installed:
                                  nodejs
                                0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                Need to get 0 B/29.5 MB of archives.
                                After this operation, 189 MB of additional disk space will be used.
                                Selecting previously unselected package nodejs.
                                (Reading database ... 47253 files and directories currently installed.)
                                Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
                                Unpacking nodejs (18.18.0-1nodesource1) ...
                                Setting up nodejs (18.18.0-1nodesource1) ...
                                 root @ /dev/pts/0: apt[7531,7603], sh[7608]
                                • DJMarc75
                                  DJMarc75 @Great SUN last edited by
                                  @great-sun sagte in iobroker zeschossen:
                                  Ich kann auch noch einen HP Mini-PC empfehlen........usw
                                  Ist das jetzt die ungewollte Werbepause in diesem amüsantem Popcornbeitrag ?
                                  • bahnuhr
                                    @Krisiun
                                    @Thomas-Braun
                                    Danke für euren regen Austausch hier.
                                    Hat mir Spaß gemacht.
                                    Und wieder einmal von @Thomas-Braun viel gelernt.
                                    Ich geh jetzt ins Bett.
                                    • Great SUN
                                      Great SUN @DJMarc75 last edited by
                                      @djmarc75 Ja, ich wollt auch mal was (sinnvolles) beitragen 😄
                                      • Krisiun
                                        @great-sun
                                        für einen sind das nur 89€ für die anderen viel Geld. Nicht böse sein bitte
                                        • Krisiun
                                          @Krisiun
                                          @Thomas-Braun
                                          Gute Nacht
                                          • Great SUN
                                            @great-sun
                                            Wieso? Ich wollte nur sichergehen, dass Du nicht denkst, das Ding kostet mega viel Kohle.
                                            23993
