    4. iobroker zeschossen
    iobroker zeschossen
    • Krisiun
      Krisiun @Thomas Braun last edited by
      krisiun@Marek2:~$ apt policy nodejs
      nodejs:
        Installed: 12.22.9~dfsg-1ubuntu3
        Candidate: 18.18.0-1nodesource1
        Version table:
           18.18.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
       *** 12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
              100 /var/lib/dpkg/status
        Thomas Braun Most Active @Krisiun last edited by
        @krisiun
        sudo apt remove nodejs libnode72
        Krisiun 1 Reply Last reply Reply Quote 0
        • Krisiun
          Krisiun @bahnuhr last edited by
          @bahnuhr sagte in iobroker zeschossen:
          @krisiun sagte in iobroker zeschossen:
          @bahnuhr
          Ja das passt schon. Danke
          Und wat für einen ?
          Es geht da nicht um den raspi der geht doch einwandfrei. Keine probleme.
          • Krisiun
            nodejs:
              Version table:
            (Reading database ... 47321 files and directories currently installed.)
            Removing nodejs (12.22.9~dfsg-1ubuntu3) ...
            Removing libnode72:amd64 (12.22.9~dfsg-1ubuntu3) ...
            Processing triggers for man-db (2.10.2-1) ...
            Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
            Scanning processes...
            Scanning candidates...
            Scanning processor microcode...
            Scanning linux images...
            Building dependency tree... Done
            Failed to retrieve available kernel versions.
            The following package was automatically installed and is no longer required:
            Failed to check for processor microcode upgrades.
            Use 'sudo apt autoremove' to remove it.
            No services need to be restarted.MOVED:
              libnode72 nodejs
            No containers need to be restarted. remove and 0 not upgraded.
            After this operation, 42.1 MB disk space will be freed.
            User sessions running outdated binaries:
             krisiun @ /dev/tty1: bash[5843]
             root @ /dev/pts/0: apt[7094,7146], sh[7151]
             root @ /dev/tty1: bash[5801], init[5800], su[5842]
            No VM guests are running outdated hypervisor (qemu) binaries on this host.
            • bahnuhr
              bahnuhr Forum Testing Most Active @Krisiun last edited by
              @bahnuhr
              Und wat für einen ?
              Musst es ja nicht verraten.
              War nur neugierig.
              • Krisiun
                @bahnuhr
                Und wat für einen ?
                War nur neugierig.
                Nein du hast mich falsch verstanden das ist doch kein Geheimnis aber ich bin jetzt wo anders beschäftigt und die daten habe ich doch nicht im kopf
                  Thomas Braun Most Active @Krisiun last edited by Thomas Braun
                  @krisiun
                  sudo apt update
                  sudo apt full-upgrade
                  • Krisiun
                    krisiun@Marek2:~$ sudo apt update
                    Get:1 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                    Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
                    Get:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
                    Get:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease [109 kB]
                    Fetched 338 kB in 3s (98.9 kB/s)
                    Reading package lists... Done
                    All packages are up to date.
                    krisiun@Marek2:~$ sudo apt full-upgrade
                    Calculating upgrade... Done
                      libc-ares2
                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    • Great SUN
                      Great SUN @OliverIO last edited by
                      @oliverio Ich kann auch noch einen HP Mini-PC empfehlen 8GB Ram, 256GB SSD, 2,9Ghz CPU. Der maximale gemessene Verbrauch unter Last lag bei dem bei 25W. Durchschnitt eher bei 5W 😉
                      Krisiun DJMarc75 2 Replies Last reply Reply Quote 0
                        @krisiun
                        Dann jetzt nodejs installieren.
                        sudo apt install nodejs
                        • Krisiun
                          Krisiun @Great SUN last edited by
                          @great-sun
                          Klingt verlockend aber momentan nicht. Bin zu arm 😞
                          Great SUN 1 Reply Last reply Reply Quote 0
                          • Great SUN
                            Great SUN @Krisiun last edited by
                            @krisiun Kostet bei Amazon gerade 89 EUR
                            • Krisiun
                              krisiun@Marek2:~$ sudo apt install nodejs
                                libc-ares2
                              The following NEW packages will be installed:
                                nodejs
                              0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                              Need to get 0 B/29.5 MB of archives.
                              After this operation, 189 MB of additional disk space will be used.
                              Selecting previously unselected package nodejs.
                              (Reading database ... 47253 files and directories currently installed.)
                              Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
                              Unpacking nodejs (18.18.0-1nodesource1) ...
                              Setting up nodejs (18.18.0-1nodesource1) ...
                               root @ /dev/pts/0: apt[7531,7603], sh[7608]
                              • DJMarc75
                                DJMarc75 @Great SUN last edited by
                                @great-sun sagte in iobroker zeschossen:
                                Ich kann auch noch einen HP Mini-PC empfehlen........usw
                                Ist das jetzt die ungewollte Werbepause in diesem amüsantem Popcornbeitrag ?
                                • bahnuhr
                                  @Krisiun
                                  @Thomas-Braun
                                  Danke für euren regen Austausch hier.
                                  Hat mir Spaß gemacht.
                                  Und wieder einmal von @Thomas-Braun viel gelernt.
                                  Ich geh jetzt ins Bett.
                                  • Great SUN
                                    Great SUN @DJMarc75 last edited by
                                    @djmarc75 Ja, ich wollt auch mal was (sinnvolles) beitragen 😄
                                    • Krisiun
                                      @great-sun
                                      für einen sind das nur 89€ für die anderen viel Geld. Nicht böse sein bitte
                                      • Krisiun
                                        @Krisiun
                                        @Thomas-Braun
                                        Gute Nacht
                                        • Great SUN
                                          @great-sun
                                          Wieso? Ich wollte nur sichergehen, dass Du nicht denkst, das Ding kostet mega viel Kohle.
                                            sudo apt autoremove
                                            Und dann die Kiste mal neustarten. Wie auch immer das bei dem WSL-Ding geht.
                                            sudo reboot
                                            vielleicht?
                                            Great SUN Krisiun 2 Replies Last reply Reply Quote 0
                                            24034
