    4. iobroker zeschossen
    iobroker zeschossen
    • Great SUN
      Great SUN @OliverIO last edited by
      @oliverio Ich kann auch noch einen HP Mini-PC empfehlen 8GB Ram, 256GB SSD, 2,9Ghz CPU. Der maximale gemessene Verbrauch unter Last lag bei dem bei 25W. Durchschnitt eher bei 5W 😉
      Krisiun DJMarc75 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Krisiun last edited by
        @krisiun
        Dann jetzt nodejs installieren.
        sudo apt install nodejs
        Krisiun 1 Reply Last reply Reply Quote 0
        • Krisiun
          Krisiun @Great SUN last edited by
          @great-sun
          Klingt verlockend aber momentan nicht. Bin zu arm 😞
          Great SUN 1 Reply Last reply Reply Quote 0
          • Great SUN
            Great SUN @Krisiun last edited by
            @krisiun Kostet bei Amazon gerade 89 EUR
            • Krisiun
              Krisiun @Thomas Braun last edited by
              krisiun@Marek2:~$ sudo apt install nodejs
              Reading package lists... Done
              Building dependency tree... Done
              The following package was automatically installed and is no longer required:
                libc-ares2
              Use 'sudo apt autoremove' to remove it.
              The following NEW packages will be installed:
                nodejs
              0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
              Need to get 0 B/29.5 MB of archives.
              After this operation, 189 MB of additional disk space will be used.
              Selecting previously unselected package nodejs.
              (Reading database ... 47253 files and directories currently installed.)
              Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
              Unpacking nodejs (18.18.0-1nodesource1) ...
              Setting up nodejs (18.18.0-1nodesource1) ...
              Processing triggers for man-db (2.10.2-1) ...
              Scanning processes...
              Scanning candidates...
              Scanning processor microcode...
              Scanning linux images...
              Failed to retrieve available kernel versions.
              Failed to check for processor microcode upgrades.
              No services need to be restarted.
              No containers need to be restarted.
              User sessions running outdated binaries:
               krisiun @ /dev/tty1: bash[5843]
               root @ /dev/pts/0: apt[7531,7603], sh[7608]
               root @ /dev/tty1: bash[5801], init[5800], su[5842]
              No VM guests are running outdated hypervisor (qemu) binaries on this host.
              • DJMarc75
                DJMarc75 @Great SUN last edited by
                @great-sun sagte in iobroker zeschossen:
                Ich kann auch noch einen HP Mini-PC empfehlen........usw
                Ist das jetzt die ungewollte Werbepause in diesem amüsantem Popcornbeitrag ?
                • bahnuhr
                  @Krisiun
                  @Thomas-Braun
                  Danke für euren regen Austausch hier.
                  Hat mir Spaß gemacht.
                  Und wieder einmal von @Thomas-Braun viel gelernt.
                  Ich geh jetzt ins Bett.
                  • Great SUN
                    Great SUN @DJMarc75 last edited by
                    @djmarc75 Ja, ich wollt auch mal was (sinnvolles) beitragen 😄
                    • Krisiun
                      @great-sun
                      für einen sind das nur 89€ für die anderen viel Geld. Nicht böse sein bitte
                      • Krisiun
                        Krisiun @bahnuhr last edited by
                        @bahnuhr sagte in iobroker zeschossen:
                        @Krisiun
                        @Thomas-Braun
                        Gute Nacht
                        • Great SUN
                          @krisiun sagte in iobroker zeschossen:
                          @great-sun
                          Wieso? Ich wollte nur sichergehen, dass Du nicht denkst, das Ding kostet mega viel Kohle.
                            sudo apt autoremove
                            Und dann die Kiste mal neustarten. Wie auch immer das bei dem WSL-Ding geht.
                            sudo reboot
                            vielleicht?
                            Great SUN Krisiun 2 Replies Last reply Reply Quote 0
                            • Great SUN
                              Great SUN @Thomas Braun last edited by
                              @thomas-braun sagte in iobroker zeschossen:
                              sudo apt autoremove
                              sudo reboot
                              vielleicht?
                              Windoze hat das als Windows-Service laufen. Kannste nicht direkt neu starten... Am Besten WinDoze neu starten:
                              https://www.wikihow.com/Shut-Down-Your-PC-with-a-Shortcut-Key
                              • Krisiun
                                  libc-ares2
                                  nodejs
                                (Reading database ... 52877 files and directories currently installed.)st.
                                Removing libc-ares2:amd64 (1.18.1-1ubuntu0.22.04.2) ...
                                Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
                                krisiun@Marek2:~$ sudo reboot
                                System has not been booted with systemd as init system (PID 1). Can't operate.
                                Failed to connect to bus: Host is down
                                Failed to talk to init daemon.
                                krisiun@Marek2:~$ yytree... Done
                                The following packages will be REMOVED:
                                  libc-ares2
                                0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                                After this operation, 115 kB disk space will be freed.
                                Do you want to continue? [Y/n] y
                                • Krisiun
                                  @great-sun
                                  Danke, sehr nett aber ich habe die preise nicht verglichen weil ich das im moment nicht für relevant halte
                                  • Great SUN
                                    @krisiun Verglichen hab ich sie auch nicht. Hab nur gerade selbst so ein Teil gekauft, deswegen wusste ich es noch 😉
                                    • Krisiun
                                      @great-sun
                                      Ist OK. Danke
                                        @krisiun
                                        System neugestartet?
                                        • Krisiun
                                          krisiun@Marek2:/root$ reboot
                                          • Great SUN
                                            Wie ich sagte, Du hast WSL, das ist ein Service in Deinem Windows. Damit das sauber neu gestartet ist, Rechner neu starten.
                                            Krisiun Thomas Braun 2 Replies Last reply Reply Quote 0
                                            24113
