    4. iobroker zeschossen
    iobroker zeschossen
    • Great SUN
      Great SUN @Thomas Braun last edited by
      @thomas-braun sagte in iobroker zeschossen:
      @krisiun sagte in iobroker zeschossen:
      sudo apt autoremove
      Und dann die Kiste mal neustarten. Wie auch immer das bei dem WSL-Ding geht.
      sudo reboot
      vielleicht?
      Windoze hat das als Windows-Service laufen. Kannste nicht direkt neu starten... Am Besten WinDoze neu starten:
      https://www.wikihow.com/Shut-Down-Your-PC-with-a-Shortcut-Key
      • Krisiun
        Krisiun @Thomas Braun last edited by
        krisiun@Marek2:~$ sudo apt install nodejs
        Reading package lists... Done
        Building dependency tree... Done
        The following package was automatically installed and is no longer required:
          libc-ares2
        Use 'sudo apt autoremove' to remove it.
        The following NEW packages will be installed:
          nodejs
        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
        Need to get 0 B/29.5 MB of archives.
        After this operation, 189 MB of additional disk space will be used.
        Selecting previously unselected package nodejs.
        (Reading database ... 47253 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
        Unpacking nodejs (18.18.0-1nodesource1) ...
        Setting up nodejs (18.18.0-1nodesource1) ...
        Processing triggers for man-db (2.10.2-1) ...
        Scanning processes...
        Scanning candidates...
        Scanning processor microcode...
        Scanning linux images...
        Failed to retrieve available kernel versions.
        Failed to check for processor microcode upgrades.
        No services need to be restarted.
        No containers need to be restarted.
        User sessions running outdated binaries:
         krisiun @ /dev/tty1: bash[5843]
         root @ /dev/pts/0: apt[7531,7603], sh[7608]
         root @ /dev/tty1: bash[5801], init[5800], su[5842]
        (Reading database ... 52877 files and directories currently installed.)st.
        Removing libc-ares2:amd64 (1.18.1-1ubuntu0.22.04.2) ...
        Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
        krisiun@Marek2:~$ sudo reboot
        System has not been booted with systemd as init system (PID 1). Can't operate.
        Failed to connect to bus: Host is down
        Failed to talk to init daemon.
        krisiun@Marek2:~$ yytree... Done
        The following packages will be REMOVED:
          libc-ares2
        0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
        After this operation, 115 kB disk space will be freed.
        Do you want to continue? [Y/n] y
        • Krisiun
          Krisiun @Great SUN last edited by
          @great-sun sagte in iobroker zeschossen:
          @great-sun
          für einen sind das nur 89€ für die anderen viel Geld. Nicht böse sein bitte
          Wieso? Ich wollte nur sichergehen, dass Du nicht denkst, das Ding kostet mega viel Kohle.
          Danke, sehr nett aber ich habe die preise nicht verglichen weil ich das im moment nicht für relevant halte
          Great SUN 1 Reply Last reply Reply Quote 0
          • Great SUN
            Great SUN @Krisiun last edited by
            @krisiun Verglichen hab ich sie auch nicht. Hab nur gerade selbst so ein Teil gekauft, deswegen wusste ich es noch 😉
            Krisiun 1 Reply Last reply Reply Quote 0
            • Krisiun
              @great-sun
              Ist OK. Danke
                Thomas Braun Most Active @Krisiun last edited by
                @krisiun
                System neugestartet?
                • Krisiun
                  krisiun@Marek2:/root$ reboot
                  • Great SUN
                    Wie ich sagte, Du hast WSL, das ist ein Service in Deinem Windows. Damit das sauber neu gestartet ist, Rechner neu starten.
                    Krisiun Thomas Braun 2 Replies Last reply Reply Quote 0
                    • Krisiun
                      @great-sun
                      OK dann bin ich kurz weg
                        Thomas Braun Most Active @Great SUN last edited by
                        @great-sun
                        https://www.how2shout.com/how-to/how-to-reboot-wsl-windows-subsystem-linux-in-windows-10.html
                        • Krisiun
                          Ihr seid einfach die BESTEN !!!
                          Danke vielmals. Danke Thomas du bist ein echte Profi aber das weißt Du ja selbst.
                          Es geht wieder.
                          Nur beim konsolen start bin ich immer als root. Muss dann su krisiun immer eingeben. Ist das so normal?
                            Ist das so normal?
                            Nein. Auf einem 'richtigen' Linux meldet man sich mit user/passwort an.
                            Bei dem Ersatz-Linux da ist man wohl direkt als root angemeldet. Was natürlich hochgradiger Schwachsinn ist. Ob man das anders einstellen kann?
                            Weiß ich nicht, vermutlich schon. Musste mal irgendwo nachlesen.
                            • Krisiun
                              Ist ok Thomas. Mach Dir jetzt kein Kopf deswegen. Ich bin Dir unendlich dankbar für alles. Und wünsche eine Gute Nacht
                              • Krisiun
                                Hallo nochmal , eine Frage hätte ich noch. Wie soll ich jetzt richtig nadje auf meinem Raspberry updaten damit ich nicht nochmal so ein Horror wie gestern erleben muss?
                                  @krisiun
                                  Auf dem Raspberry wird das node-fix-Skript aus meiner Signatur funktionieren.
                                  • Krisiun
                                    Danke Thomas werde ich mich wagen 😀
                                      A Former User @Krisiun last edited by A Former User
                                      Moin,
                                      hoffe noch nicht zu spät 😉
                                      An das Backup vorher denken, nicht nur BackitUP, sondern vielleicht auch mal die SD-Karte klonen.
                                      VG
                                      Bernd
                                      Homoran Krisiun 2 Replies Last reply Reply Quote 0
                                        Homoran Global Moderator Administrators @Guest last edited by Homoran
                                        @dp20eic sagte in iobroker zeschossen:
                                        CD-Karte
                                        Kenn ich!
                                        CDs im Visitenkartenformat
                                        • Krisiun
                                          Krisiun @Guest last edited by
                                          @dp20eic
                                          Vielen dank. Es war schon zu spät aber nach der Anleitung von Thomas hat natürlich alles super geklappt.
                                          Da hatte ich niemals zweifeln.
                                          Und Backup war sowieso vorhanden.
                                          Danke nochmal
                                            A Former User @Homoran last edited by
                                            @homoran sagte in iobroker zeschossen:
                                            Moin,
                                            ja manchmal macht die Autokorrektur schon lustige Sachen 🙂
                                            Korrigiere ich gleich mal 🙂
                                            VG
                                            Bernd
                                            23838
