    4. iobroker zeschossen
    iobroker zeschossen
    • Krisiun
      Krisiun @Thomas Braun last edited by
      krisiun@Marek2:~$ sudo apt install nodejs
      Reading package lists... Done
      Building dependency tree... Done
      The following package was automatically installed and is no longer required:
        libc-ares2
      Use 'sudo apt autoremove' to remove it.
      The following NEW packages will be installed:
        nodejs
      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
      Need to get 0 B/29.5 MB of archives.
      After this operation, 189 MB of additional disk space will be used.
      Selecting previously unselected package nodejs.
      (Reading database ... 47253 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
      Unpacking nodejs (18.18.0-1nodesource1) ...
      Setting up nodejs (18.18.0-1nodesource1) ...
      Processing triggers for man-db (2.10.2-1) ...
      Scanning processes...
      Scanning candidates...
      Scanning processor microcode...
      Scanning linux images...
      Failed to retrieve available kernel versions.
      Failed to check for processor microcode upgrades.
      No services need to be restarted.
      No containers need to be restarted.
      User sessions running outdated binaries:
       krisiun @ /dev/tty1: bash[5843]
       root @ /dev/pts/0: apt[7531,7603], sh[7608]
       root @ /dev/tty1: bash[5801], init[5800], su[5842]
      (Reading database ... 52877 files and directories currently installed.)st.
      Removing libc-ares2:amd64 (1.18.1-1ubuntu0.22.04.2) ...
      Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
      krisiun@Marek2:~$ sudo reboot
      System has not been booted with systemd as init system (PID 1). Can't operate.
      Failed to connect to bus: Host is down
      Failed to talk to init daemon.
      krisiun@Marek2:~$ yytree... Done
      The following packages will be REMOVED:
        libc-ares2
      0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
      After this operation, 115 kB disk space will be freed.
      Do you want to continue? [Y/n] y
      • Krisiun
        Krisiun @Great SUN last edited by
        @great-sun sagte in iobroker zeschossen:
        @krisiun sagte in iobroker zeschossen:
        @great-sun
        für einen sind das nur 89€ für die anderen viel Geld. Nicht böse sein bitte
        Wieso? Ich wollte nur sichergehen, dass Du nicht denkst, das Ding kostet mega viel Kohle.
        Danke, sehr nett aber ich habe die preise nicht verglichen weil ich das im moment nicht für relevant halte
        Great SUN 1 Reply Last reply Reply Quote 0
        • Great SUN
          Great SUN @Krisiun last edited by
          @krisiun Verglichen hab ich sie auch nicht. Hab nur gerade selbst so ein Teil gekauft, deswegen wusste ich es noch 😉
          Krisiun 1 Reply Last reply Reply Quote 0
          • Krisiun
            @great-sun
            Ist OK. Danke
              Thomas Braun Most Active @Krisiun last edited by
              @krisiun
              System neugestartet?
              • Krisiun
                krisiun@Marek2:/root$ reboot
                • Great SUN
                  Wie ich sagte, Du hast WSL, das ist ein Service in Deinem Windows. Damit das sauber neu gestartet ist, Rechner neu starten.
                  Krisiun Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Krisiun
                    @great-sun
                    OK dann bin ich kurz weg
                      Thomas Braun Most Active @Great SUN last edited by
                      @great-sun
                      https://www.how2shout.com/how-to/how-to-reboot-wsl-windows-subsystem-linux-in-windows-10.html
                      • Krisiun
                        Ihr seid einfach die BESTEN !!!
                        Danke vielmals. Danke Thomas du bist ein echte Profi aber das weißt Du ja selbst.
                        Es geht wieder.
                        Nur beim konsolen start bin ich immer als root. Muss dann su krisiun immer eingeben. Ist das so normal?
                          Ist das so normal?
                          Nein. Auf einem 'richtigen' Linux meldet man sich mit user/passwort an.
                          Bei dem Ersatz-Linux da ist man wohl direkt als root angemeldet. Was natürlich hochgradiger Schwachsinn ist. Ob man das anders einstellen kann?
                          Weiß ich nicht, vermutlich schon. Musste mal irgendwo nachlesen.
                          • Krisiun
                            Ist ok Thomas. Mach Dir jetzt kein Kopf deswegen. Ich bin Dir unendlich dankbar für alles. Und wünsche eine Gute Nacht
                            • Krisiun
                              Hallo nochmal , eine Frage hätte ich noch. Wie soll ich jetzt richtig nadje auf meinem Raspberry updaten damit ich nicht nochmal so ein Horror wie gestern erleben muss?
                                @krisiun
                                Auf dem Raspberry wird das node-fix-Skript aus meiner Signatur funktionieren.
                                • Krisiun
                                  Danke Thomas werde ich mich wagen 😀
                                    A Former User @Krisiun last edited by A Former User
                                    Moin,
                                    hoffe noch nicht zu spät 😉
                                    An das Backup vorher denken, nicht nur BackitUP, sondern vielleicht auch mal die SD-Karte klonen.
                                    VG
                                    Bernd
                                    Homoran Krisiun 2 Replies Last reply Reply Quote 0
                                      Homoran Global Moderator Administrators @Guest last edited by Homoran
                                      @dp20eic sagte in iobroker zeschossen:
                                      CD-Karte
                                      Kenn ich!
                                      CDs im Visitenkartenformat
                                      • Krisiun
                                        Krisiun @Guest last edited by
                                        @dp20eic
                                        Vielen dank. Es war schon zu spät aber nach der Anleitung von Thomas hat natürlich alles super geklappt.
                                        Da hatte ich niemals zweifeln.
                                        Und Backup war sowieso vorhanden.
                                        Danke nochmal
                                          A Former User @Homoran last edited by
                                          @homoran sagte in iobroker zeschossen:
                                          Moin,
                                          ja manchmal macht die Autokorrektur schon lustige Sachen 🙂
                                          Korrigiere ich gleich mal 🙂
                                          VG
                                          Bernd
                                          23838
