    4. Node-Red
    5. Schrittwerk mit einer Bedingung begrenzen
      hawell @mickym last edited by
      @mickym
      es ist frustrierend zu sehen, dass man immer vieeeeel zu kompliziert denkt 😉
      ich habe nun mal deinen Code in meinen Flow eingebettet.
      anbei das Ergebniss. sicher auch zu komliziert ?
              "id": "a4df471f006c7c29",
              "type": "switch",
              "z": "555a0da86fcbd59e",
              "name": "",
              "property": "payload",
              "propertyType": "msg",
              "rules": [
                      "t": "eq",
                      "v": "0",
                      "vt": "num"
                      "t": "eq",
                      "v": "1",
                      "vt": "num"
                      "t": "eq",
                      "v": "2",
                      "vt": "num"
                      "t": "eq",
                      "v": "3",
                      "vt": "num"
                      "t": "eq",
                      "v": "4",
                      "vt": "num"
                      "t": "eq",
                      "v": "5",
                      "vt": "num"
                      "t": "eq",
                      "v": "6",
                      "vt": "num"
                      "t": "eq",
                      "v": "7",
                      "vt": "num"
                      "t": "eq",
                      "v": "8",
                      "vt": "num"
                      "t": "eq",
                      "v": "9",
                      "vt": "num"
                      "t": "eq",
                      "v": "10",
                      "vt": "num"
                      "t": "eq",
                      "v": "11",
                      "vt": "num"
                      "t": "eq",
                      "v": "12",
                      "vt": "num"
                      "t": "eq",
                      "v": "13",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 14,
              "x": 2130,
              "y": 400,
              "wires": [
                      "398312eeeb8ccd46",
                      "3ff1604bf5bca832",
                      "5fc2d946dd666aca",
                      "28762e0360464d57"
                      "b93d2ce896558684",
                      "3ff1604bf5bca832",
                      "5fc2d946dd666aca",
                      "28762e0360464d57"
                      "398312eeeb8ccd46",
                      "a48f000b08ef6896",
                      "5fc2d946dd666aca",
                      "28762e0360464d57"
                      "b93d2ce896558684",
                      "a48f000b08ef6896",
                      "5fc2d946dd666aca",
                      "28762e0360464d57"
                      "398312eeeb8ccd46",
                      "3ff1604bf5bca832",
                      "5a78c3af30a68905",
                      "28762e0360464d57"
                      "b93d2ce896558684",
                      "3ff1604bf5bca832",
                      "5a78c3af30a68905",
                      "28762e0360464d57"
                      "398312eeeb8ccd46",
                      "a48f000b08ef6896",
                      "5a78c3af30a68905",
                      "28762e0360464d57"
                      "b93d2ce896558684",
                      "a48f000b08ef6896",
                      "5a78c3af30a68905",
                      "28762e0360464d57"
                      "398312eeeb8ccd46",
                      "a48f000b08ef6896",
                      "5fc2d946dd666aca",
                      "210fe10072b7d40a"
                      "b93d2ce896558684",
                      "a48f000b08ef6896",
                      "5fc2d946dd666aca",
                      "210fe10072b7d40a"
                      "398312eeeb8ccd46",
                      "3ff1604bf5bca832",
                      "5a78c3af30a68905",
                      "210fe10072b7d40a"
                      "b93d2ce896558684",
                      "3ff1604bf5bca832",
                      "5a78c3af30a68905",
                      "210fe10072b7d40a"
                      "398312eeeb8ccd46",
                      "a48f000b08ef6896",
                      "5a78c3af30a68905",
                      "210fe10072b7d40a"
                      "b93d2ce896558684",
                      "a48f000b08ef6896",
                      "5a78c3af30a68905",
                      "210fe10072b7d40a"
              "id": "310bc8c1fa0df514",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "reset",
                      "pt": "msg",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 640,
              "y": 460,
              "wires": [
                      "de5c12b8131d105f",
                      "1614f195f326e63e"
              "id": "4fbf3fe3e30e859d",
              "type": "trigger",
              "name": "",
              "op1": "1",
              "op2": "0",
              "op1type": "str",
              "op2type": "str",
              "duration": "0",
              "extend": false,
              "overrideDelay": false,
              "units": "ms",
              "reset": "",
              "bytopic": "all",
              "topic": "topic",
              "outputs": 1,
              "x": 640,
              "y": 260,
              "wires": [
                      "310bc8c1fa0df514",
                      "a4be58efb147f789"
              "id": "4aecd62772296f97",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "reset",
                      "pt": "msg",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 640,
              "y": 340,
              "wires": [
                      "4fbf3fe3e30e859d",
                      "a4be58efb147f789"
              "id": "de5c12b8131d105f",
              "type": "trigger",
              "name": "",
              "op1": "",
              "op2": "1",
              "op1type": "nul",
              "op2type": "str",
              "duration": "5",
              "extend": false,
              "units": "s",
              "reset": "",
              "bytopic": "all",
              "topic": "topic",
              "outputs": 1,
              "x": 860,
              "y": 540,
              "wires": [
                      "310bc8c1fa0df514",
                      "07f087d511c8b3e2"
              "id": "a4be58efb147f789",
              "type": "trigger",
              "name": "",
              "op1": "",
              "op2": "1",
              "op1type": "nul",
              "op2type": "str",
              "duration": "5",
              "extend": false,
              "units": "s",
              "reset": "",
              "bytopic": "all",
              "topic": "topic",
              "outputs": 1,
              "x": 860,
              "y": 260,
              "wires": [
                      "4aecd62772296f97",
                      "034c5314770775c6"
              "id": "1614f195f326e63e",
              "type": "trigger",
              "name": "",
              "op1": "1",
              "op2": "1",
              "op1type": "str",
              "op2type": "str",
              "duration": "0",
              "extend": false,
              "units": "s",
              "reset": "",
              "bytopic": "all",
              "topic": "topic",
              "outputs": 1,
              "x": 640,
              "y": 540,
              "wires": [
                      "de5c12b8131d105f",
                      "4aecd62772296f97"
              "id": "4bbe3cb139220b42",
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "gte",
                      "v": "2",
                      "vt": "num"
                      "t": "btwn",
                      "v": "-699",
                      "vt": "num",
                      "v2": "1",
                      "v2t": "num"
                      "t": "lt",
                      "v": "-700",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 3,
              "x": 330,
              "y": 400,
              "wires": [
                      "4fbf3fe3e30e859d"
                      "4aecd62772296f97",
                      "310bc8c1fa0df514"
                      "1614f195f326e63e"
              "id": "034c5314770775c6",
              "type": "change",
              "name": "-1",
              "rules": [
                      "t": "delete",
                      "p": "payload",
                      "pt": "msg"
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "-1",
                      "tot": "num"
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "action",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1050,
              "y": 260,
              "wires": [
                      "e16d9f5e94d3229f"
              "id": "2a3e252e4ffab885",
              "type": "inject",
              "name": "0",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "1",
              "payloadType": "num",
              "x": 1050,
              "y": 720,
              "wires": [
                      "63bd6c3bb3e651dc"
              "id": "75c57efdef71160f",
              "type": "ha-button",
              "name": "Heizstäbe ausschalten",
              "version": 0,
              "debugenabled": false,
              "outputs": 1,
              "entityConfig": "f3f4583ca540c2a8",
              "outputProperties": [
                      "value": "1",
                      "valueType": "num"
              "x": 1000,
              "y": 660,
              "wires": [
                      "63bd6c3bb3e651dc"
              "id": "4471327821c29be8",
              "type": "range",
              "minin": "0",
              "maxin": "7",
              "minout": "0",
              "maxout": "7",
              "action": "clamp",
              "round": false,
              "name": "",
              "x": 1610,
              "y": 380,
              "wires": [
                      "aaf51c77abf2d92b"
              "id": "c9e90412a78aa937",
              "type": "range",
              "minin": "0",
              "maxin": "13",
              "minout": "0",
              "maxout": "13",
              "action": "clamp",
              "round": false,
              "name": "",
              "x": 1610,
              "y": 420,
              "wires": [
                      "aaf51c77abf2d92b"
              "id": "0ba84e543119bf12",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "action",
              "payload": "-1",
              "x": 1040,
              "y": 340,
              "wires": [
                      "e16d9f5e94d3229f"
              "id": "80c924d4eb2de24c",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "action",
              "payload": "1",
              "x": 1050,
              "y": 460,
              "wires": [
                      "e16d9f5e94d3229f"
              "id": "27d4c6a16dae68c3",
              "type": "debug",
              "name": "Ausgabe",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": true,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "payload",
              "statusType": "auto",
              "x": 1960,
              "y": 240,
              "wires": []
              "id": "e16d9f5e94d3229f",
              "type": "change",
              "name": "modify counter",
              "rules": [
                      "t": "set",
                      "p": "counter",
                      "pt": "msg",
                      "to": "counter",
                      "tot": "flow"
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "payload + (counter ? counter : 0)",
                      "tot": "jsonata"
                      "t": "delete",
                      "p": "counter",
                      "pt": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1300,
              "y": 400,
              "wires": [
                      "f1bea7b4b7a79206"
              "id": "f1bea7b4b7a79206",
              "type": "switch",
              "name": "",
              "property": "Begrenzung",
              "propertyType": "flow",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 1470,
              "y": 400,
              "wires": [
                      "4471327821c29be8"
                      "c9e90412a78aa937"
              "id": "aaf51c77abf2d92b",
              "type": "rbe",
              "name": "",
              "func": "rbe",
              "gap": "",
              "start": "",
              "inout": "out",
              "septopics": true,
              "topi": "topic",
              "x": 1750,
              "y": 400,
              "wires": [
                      "3556052e013cfd33",
                      "27d4c6a16dae68c3"
              "id": "3556052e013cfd33",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "counter",
                      "pt": "flow",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1930,
              "y": 400,
              "wires": [
                      "a4df471f006c7c29"
              "id": "07f087d511c8b3e2",
              "type": "change",
              "name": "+1",
              "rules": [
                      "t": "delete",
                      "p": "payload",
                      "pt": "msg"
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "1",
                      "tot": "num"
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "action",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1050,
              "y": 540,
              "wires": [
                      "e16d9f5e94d3229f"
              "id": "63bd6c3bb3e651dc",
              "type": "change",
              "name": "set 0 counter",
              "rules": [
                      "t": "set",
                      "p": "counter",
                      "pt": "msg",
                      "to": "counter",
                      "tot": "flow"
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "0",
                      "tot": "num"
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "action",
                      "tot": "str"
                      "t": "delete",
                      "p": "counter",
                      "pt": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1310,
              "y": 660,
              "wires": [
                      "f1bea7b4b7a79206"
              "id": "458ecde97817f777",
              "type": "inject",
              "name": "100",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "100",
              "x": 110,
              "y": 360,
              "wires": [
                      "4bbe3cb139220b42"
              "id": "9a176b2bfce3c5bc",
              "type": "inject",
              "name": "-500",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "-500",
              "x": 110,
              "y": 420,
              "wires": [
                      "4bbe3cb139220b42"
              "id": "dbb92ef2ecce8bdb",
              "type": "inject",
              "name": "-2000",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "-2000",
              "x": 110,
              "y": 480,
              "wires": [
                      "4bbe3cb139220b42"
              "id": "95d26de77e9ff6c8",
              "type": "comment",
              "name": "Werte kommen sekündlich über vom Energiemanager",
              "info": "",
              "x": 200,
              "y": 220,
              "wires": []
              "id": "3652f840e6df66c4",
              "type": "comment",
              "name": "FlipFlop um schnelles hin/her Flippen zu vermeiden",
              "info": "",
              "x": 790,
              "y": 220,
              "wires": []
              "id": "28056265e702d35a",
              "type": "group",
              "style": {
                  "stroke": "#999999",
                  "stroke-opacity": "1",
                  "fill": "none",
                  "fill-opacity": "1",
                  "label": true,
                  "label-position": "nw",
                  "color": "#a4a4a4"
              "nodes": [
                  "47e4b4c1a5719f97",
                  "2cbf219ba70e288d",
                  "dbca6aa2a28f48cc",
                  "f41294d7e6bd742a",
                  "23d944158c2afb9d",
                  "2c066e034e22725f",
                  "93c130968fd0aff6",
                  "56baed6c9d62d302",
                  "73503abeceb4a948",
                  "2434e456aab4e422",
                  "698c0b8feeb927ab",
                  "dca67830bec17864",
                  "e9c9475635add4b0",
                  "5cb56a40dbb6fe16",
                  "6d5b8d54b80f3aec",
                  "ea9e0233a1fc4285",
                  "b6225626acfb1315"
              "x": 74,
              "y": 819,
              "w": 1712,
              "h": 402
              "id": "47e4b4c1a5719f97",
              "type": "switch",
              "g": "28056265e702d35a",
              "name": " WR-Leistung kleiner 3500W",
              "rules": [
                      "t": "lt",
                      "v": "3500",
                      "vt": "num"
                      "t": "gte",
                      "v": "3500",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 460,
              "y": 1040,
              "wires": [
                      "56baed6c9d62d302"
                      "dca67830bec17864"
              "id": "2cbf219ba70e288d",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "Begrenzung",
              "payload": "true",
              "payloadType": "bool",
              "x": 1180,
              "y": 1020,
              "wires": [
                      "f41294d7e6bd742a"
              "id": "dbca6aa2a28f48cc",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": true,
              "onceDelay": 0.1,
              "payload": "false",
              "x": 1170,
              "y": 1100,
              "wires": [
                      "f41294d7e6bd742a"
              "id": "f41294d7e6bd742a",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "Begrenzung",
                      "pt": "flow",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1440,
              "y": 1060,
              "wires": [
                      "ea9e0233a1fc4285"
              "id": "23d944158c2afb9d",
              "type": "change",
              "name": "false",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1210,
              "y": 1180,
              "wires": [
                      "f41294d7e6bd742a"
              "id": "2c066e034e22725f",
              "type": "change",
              "name": "true",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "true",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1210,
              "y": 920,
              "wires": [
                      "f41294d7e6bd742a"
              "id": "93c130968fd0aff6",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "reset",
                      "pt": "msg",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 780,
              "y": 1100,
              "wires": [
                      "2434e456aab4e422",
                      "dca67830bec17864"
              "id": "56baed6c9d62d302",
              "type": "trigger",
              "name": "",
              "op1": "1",
              "op2": "0",
              "op1type": "str",
              "op2type": "str",
              "duration": "0",
              "extend": false,
              "units": "ms",
              "reset": "",
              "bytopic": "all",
              "topic": "topic",
              "outputs": 1,
              "x": 780,
              "y": 920,
              "wires": [
                      "698c0b8feeb927ab",
                      "93c130968fd0aff6"
              "id": "73503abeceb4a948",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "reset",
                      "pt": "msg",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 780,
              "y": 1000,
              "wires": [
                      "56baed6c9d62d302",
                      "698c0b8feeb927ab"
              "id": "2434e456aab4e422",
              "type": "trigger",
              "name": "",
              "op1": "",
              "op2": "1",
              "op1type": "nul",
              "op2type": "str",
              "duration": "5",
              "extend": false,
              "units": "s",
              "reset": "",
              "bytopic": "all",
              "topic": "topic",
              "outputs": 1,
              "x": 1020,
              "y": 1180,
              "wires": [
                      "93c130968fd0aff6",
                      "23d944158c2afb9d"
              "id": "698c0b8feeb927ab",
              "type": "trigger",
              "name": "",
              "op1": "",
              "op2": "1",
              "op1type": "nul",
              "op2type": "str",
              "duration": "5",
              "extend": false,
              "units": "s",
              "reset": "",
              "bytopic": "all",
              "topic": "topic",
              "outputs": 1,
              "x": 1020,
              "y": 920,
              "wires": [
                      "73503abeceb4a948",
                      "2c066e034e22725f"
              "id": "dca67830bec17864",
              "type": "trigger",
              "name": "",
              "op1": "1",
              "op2": "1",
              "op1type": "str",
              "op2type": "str",
              "duration": "0",
              "extend": false,
              "units": "s",
              "reset": "",
              "bytopic": "all",
              "topic": "topic",
              "outputs": 1,
              "x": 780,
              "y": 1180,
              "wires": [
                      "2434e456aab4e422",
                      "73503abeceb4a948"
              "id": "e9c9475635add4b0",
              "type": "link in",
              "name": "link in 6",
              "links": [
                  "e4d0d17794144fa6"
              "x": 205,
              "y": 1100,
              "wires": [
                      "47e4b4c1a5719f97"
              "id": "5cb56a40dbb6fe16",
              "type": "inject",
              "name": "4000",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "4000",
              "x": 170,
              "y": 980,
              "wires": [
                      "47e4b4c1a5719f97"
              "id": "6d5b8d54b80f3aec",
              "type": "inject",
              "name": "2000",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "2000",
              "x": 170,
              "y": 1040,
              "wires": [
                      "47e4b4c1a5719f97"
              "id": "ea9e0233a1fc4285",
              "type": "debug",
              "name": "Ausgabe",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": true,
              "x": 1680,
              "y": 1060,
              "wires": []
              "id": "b6225626acfb1315",
              "type": "comment",
              "name": "WR hatte für eine Dauer von 5 sec mehr als 3500W Leistung ",
              "info": "",
              "x": 480,
              "y": 860,
              "wires": []
              "id": "f3f4583ca540c2a8",
              "type": "ha-entity-config",
              "server": "6da5c76fec0d359c",
              "deviceConfig": "",
              "version": "6",
              "entityType": "button",
              "haConfig": [
                      "property": "name",
                      "value": "Heizstäbe ausschalten"
                      "property": "icon",
                      "value": ""
                      "property": "entity_category",
                      "value": ""
                      "property": "entity_picture",
                      "value": ""
                      "property": "device_class",
                      "value": ""
              "resend": false,
              "debugEnabled": false
              "id": "6da5c76fec0d359c",
              "type": "server",
              "name": "Home Assistant",
              "version": 5,
              "addon": true,
              "rejectUnauthorizedCerts": true,
              "ha_boolean": "y|yes|true|on|home|open",
              "connectionDelay": true,
              "cacheJson": true,
              "heartbeat": false,
              "heartbeatInterval": "30",
              "areaSelector": "friendlyName",
              "deviceSelector": "friendlyName",
              "entitySelector": "friendlyName",
              "statusSeparator": ": ",
              "statusYear": "hidden",
              "statusMonth": "short",
              "statusDay": "numeric",
              "statusHourCycle": "default",
              "statusTimeFormat": "h:m",
              "enableGlobalContextStore": false
      ich bin in der Funktion Node hängen geblieben wegen dem if/else - dass es aber auch anders geht - hatte ich noch nicht gewusst.
      danke schon mal - fürs helfen
      Gruß Rico
      • mickym
        mickym Most Active @hawell last edited by mickym
        @hawell Nun dieses Gewirr in der Mitte - geht es darum dass für 5s stabil ist?
          @mickym
          korrekt, poduktiv sind es aber 60Sek. anstatt 5
          es soll der flippen zwischen 2 Zuständen verhindern,
          die Eingangswerte kommen von einen Energiezähler, und diese Werte können bekanntlich durch eine PV-Anlage auf dem Dach etwas schwanken.
          • mickym
            @hawell Aber wenn der gleiche Ast kommt soll alle 5s (bzw. 60s) der counter eines hochgezählt werden?
              @mickym
              ja, wenn die die Bedingung zum hochzählen 5 sec gegeben ist, dann einen Schritt hochzählen (am Schrittwerk hängen Heizstäbe, welche dann den Eingangswert (Stromüberschuss) reduzieren).
              wenn Bedingung nicht erfüllt, dann nichts machen.
              die Britte Bedingung ist runterzählen und somit Leistung abschalten.
              • mickym
                @hawell Ok - ich meine es funktioniert bei Dir ja. Insofern ist es doch OK. Ich mach mal eine Alternative ohne 100% sicher zu sein, ob das dann tut.
                Die erste Regel kannst Dir natürlich sparen - da Du ja mit der nächsten Regel die payload neu setzt - damit ist das was vorher in der payload war sowieso egal. 😉
                  @mickym sagte in Schrittwerk mit einer Bedingung begrenzen:
                  ich bin mit dem Konstruckt auch nicht glücklich, da ich atkuell auch an einem "Doppelsprung" arbeite - wenn genug leistung ansteht, dann kann um "2" gesprugen werden.
                  Übersichtlicher wird es damit aber nicht
                  • mickym
                    @hawell Schau mal, ob das tut was Du brauchst:
                           "type": "switch",
                           "z": "fbeffc2c8bcc1d00",
                           "name": "",
                           "rules": [
                                   "t": "gte",
                                   "v": "2",
                                   "vt": "num"
                                   "t": "btwn",
                                   "v": "-699",
                                   "vt": "num",
                                   "v2": "1",
                                   "v2t": "num"
                                   "t": "lt",
                                   "v": "-700",
                                   "vt": "num"
                           "checkall": "true",
                           "repair": false,
                           "outputs": 3,
                           "x": 330,
                           "y": 400,
                           "wires": [
                                   "034c5314770775c6"
                                   "b554f04062367f31"
                                   "07f087d511c8b3e2"
                           "type": "change",
                           "name": "-1",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "-1",
                                   "tot": "num"
                                   "t": "set",
                                   "p": "topic",
                                   "pt": "msg",
                                   "to": "action",
                                   "tot": "str"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 490,
                           "y": 340,
                           "wires": [
                                   "95c9633ab4777657"
                           "type": "change",
                           "name": "+1",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "1",
                                   "tot": "num"
                                   "t": "set",
                                   "p": "topic",
                                   "pt": "msg",
                                   "to": "action",
                                   "tot": "str"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 490,
                           "y": 460,
                           "wires": [
                                   "95c9633ab4777657"
                           "type": "inject",
                           "name": "100",
                           "props": [
                                   "p": "payload"
                           "repeat": "",
                           "crontab": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "payload": "100",
                           "x": 110,
                           "y": 360,
                           "wires": [
                                   "4bbe3cb139220b42"
                           "type": "inject",
                           "name": "-500",
                           "props": [
                                   "p": "payload"
                           "repeat": "",
                           "crontab": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "payload": "-500",
                           "x": 110,
                           "y": 420,
                           "wires": [
                                   "4bbe3cb139220b42"
                           "type": "inject",
                           "name": "-2000",
                           "props": [
                                   "p": "payload"
                           "repeat": "",
                           "crontab": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "payload": "-2000",
                           "x": 110,
                           "y": 480,
                           "wires": [
                                   "4bbe3cb139220b42"
                           "id": "b554f04062367f31",
                           "type": "change",
                           "name": "0",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "0",
                                   "tot": "num"
                                   "t": "set",
                                   "p": "topic",
                                   "pt": "msg",
                                   "to": "action",
                                   "tot": "str"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 490,
                           "y": 400,
                           "wires": [
                                   "95c9633ab4777657"
                           "id": "95c9633ab4777657",
                           "type": "rbe",
                           "name": "",
                           "func": "rbe",
                           "gap": "",
                           "start": "",
                           "inout": "out",
                           "septopics": false,
                           "topi": "topic",
                           "x": 630,
                           "y": 400,
                           "wires": [
                                   "85d35cf6ea80789b"
                           "id": "85d35cf6ea80789b",
                           "type": "trigger",
                           "name": "",
                           "op1": "",
                           "op2": "",
                           "op1type": "nul",
                           "op2type": "payl",
                           "duration": "5",
                           "extend": true,
                           "units": "s",
                           "reset": "",
                           "bytopic": "all",
                           "topic": "topic",
                           "outputs": 1,
                           "x": 780,
                           "y": 400,
                           "wires": [
                                   "712d4e4919ac7f2d"
                           "id": "712d4e4919ac7f2d",
                           "type": "trigger",
                           "name": "",
                           "op1": "",
                           "op2": "0",
                           "op1type": "pay",
                           "op2type": "str",
                           "duration": "-5",
                           "extend": false,
                           "units": "s",
                           "reset": "0",
                           "bytopic": "all",
                           "topic": "topic",
                           "outputs": 1,
                           "x": 980,
                           "y": 400,
                           "wires": [
                                   "f21d6c44133561ef",
                                   "e16d9f5e94d3229f"
                           "id": "f21d6c44133561ef",
                           "type": "debug",
                           "name": "action",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 970,
                           "y": 460,
                           "wires": []
                    Falls der Energiemanager aus irgendeinem Grund gar nicht mehr tut - kannst Du das periodische Senden ja dann auch unterbinden.
                      erschreckenderweise tut es was es soll ...
                      bis auf, dass es immer die gleichen Zeiten nimmt, ich konnte schneller runterschalten, als hoch.
                      • mickym
                        @hawell Ja gut - die Zyklik bleibt gleich - aber Du könntest ja in der Switch Node noch andere Werte einsetzen, um schneller hoch und runter zu schalten.
                        Sobald Du an der Rändern bist - wird ja durch die hintere filter Node die Nachrichtenanzahl beschränkt.
                        Aber soweit ich verstanden habe - kommt aus dem Energiemanager ja alle Sekunden ein trigger - insofern ist es ja egal, ob Du einen eigenen Taktgeber verwendest und nicht den vom Energiemanager.
                        Aber ist ja nur ein Alternativvorschlag. Deines hat ja funktioniert.
                        • mickym
                          @hawell Wenn Du den Takt vom Energiemanager behalten willst - dann kannst Du dieses Mal auch eine function Node verwenden. Ich mach Dir mal einen Vorschlag.
                            @mickym
                            das skalieren mit größeren Schritten hatte ich schon getestet das geht super.
                            zwei Sachen verstehe ich aber nicht.
                            wieso sendet der letzte Trigger nur bei Zahlen außer "0" alle 5 sek ? und bei 0 Macht er nichts ??
                            und leider gibt der Trigger den Wert aus, welcher "auf den Weg bebracht wurde", auch wenn sich schon die Richtung geändert wurde.
                            also wenn +1 wiederholt wird, und dann auch 0 umspringt, wird trotzdem noch einmal hochgeschaltet und dann erst gestoppt.
                            man müsste den laufenden Tigger bei Wertänderung unterbrechen.
                            und zwei unterschiedliche zeitliche Trigger paralell laufen lassen (einen fürs hochschalten und einen fürs runter Schalten.
                            • mickym
                              @hawell sagte in Schrittwerk mit einer Bedingung begrenzen:
                              @mickym
                              Na das hatte ich aus Deinem alten Flow so verstanden, da alles rückgesetzt wurde - das dann nichts mehr gesendet werden soll.
                              Nun ja - da musst aber mal logisch überlegen - dass ja EXTRA eine Zeit abgewartet wird, bis eine Änderung registriert wird.
                              In dem Fall werde ich Dir mal mit einer function Node helfen, die Du dann wieder nur vom Energiemanager getriggert wird und nur bei +1 oder -1
                              Nein das ergibt Chaos.
                                @mickym
                                das ist auch richtig, aber wieso macht die Node das - ich ich finde die entsprechende Einstellung nicht. oder liegt es am dem Befehl "0" dieser Stoppt den Trigger?
                                geht das nicht so ? 0 hat immer Priorität und setzt die Laufenden Trigger zurück?
                                • mickym
                                  gelöscht
                                  • mickym
                                    mickym Most Active last edited by mickym
                                    Na ich glaube Du behälst Deinen ursprünglichen Flow.
                                      @mickym
                                      ich schau mir das morgen mal genauer an.
                                      aber der letzte flox ist buggy, der gibt teilweise nur 1 aus egal was man drückt (mit oder ohne warten; mit oder ohne 0 drücken)
                                      • mickym
                                        @mickym
                                        Ja bleib bei dem ursprünglichen Flow - ich glaube das ist wahrscheinlich am Besten.
                                          gar nicht so einfach .. 😉
                                          ich finde deinen ansatz mit der vereinfachten Form gut, evtl bau ich mir da was draus.
                                          aber heut nicht mehr -> morgen wieder ..
                                          ich danke dir vielmals für die Unterstützung !!!
                                          1.3k
                                          1440
