      liv-in-sky @Michael Roling last edited by
      @michael-roling
      mache gerade iob fix - dauert immer ein paar minuten bis iob wieder gestartet ist
        @michael-roling
        da ist was ?
        Instance Name: Calendar
        emit.js:40 Instance Name: Cloud connection
        emit.js:40 Instance Name: contact
        emit.js:40 Instance Name: DasWetter.com
        emit.js:40 Instance Name: device-reminder
        emit.js:40 Instance Name: Manage devices
        emit.js:40 Instance Name: DWD
        emit.js:40 Instance Name: Send emails
        emit.js:40 Instance Name: Control ESPHome managed devices
        emit.js:40 Instance Name: Event list
        emit.js:40 Instance Name: Holidays (AT, CH, DE, IT)
        emit.js:40 Instance Name: Flot Charts
        3emit.js:40 Instance Name: fritzbox dect
        emit.js:40 Instance Name: fullyBrowser
        emit.js:40 Instance Name: History
        5emit.js:40 Instance Name: iCal Calendar
        emit.js:40  Uncaught TypeError: Cannot read properties of undefined (reading 'en')
           at emit.js:40:74
           at SocketClient.findAnswer (socket.io.js:303:20)
           at socket.onmessage (socket.io.js:212:22)
        (anonymous) @ emit.js:40
        SocketClient.findAnswer @ socket.io.js:303
        socket.onmessage @ socket.io.js:212
        index_m.html?0&newReact=true&0&react=colored:54 Telegram Instance: null
        translate.js:24 "Switch
           									": {"en": "Switch
           									", "de": "Switch
           									", "ru": "Switch
           									", "pt": "Switch
           									", "nl": "Switch
           									", "fr": "Switch
           									", "es": "Switch
           									", "pl": "Switch
           									", "it": "Switch
           									", "zh-cn": "Switch
        translate.js:24 "content_copy": {"en": "content_copy", "de": "content_copy", "ru": "content_copy", "pt": "content_copy", "nl": "content_copy", "fr": "content_copy", "es": "content_copy", "pl": "content_copy", "it": "content_copy", "zh-cn": "content_copy"},
        translate.js:24 "add": {"en": "add", "de": "add", "ru": "add", "pt": "add", "nl": "add", "fr": "add", "es": "add", "pl": "add", "it": "add", "zh-cn": "add"},
        translate.js:24 "This triggers are used multiple times": {"en": "This triggers are used multiple times", "de": "This triggers are used multiple times", "ru": "This triggers are used multiple times", "pt": "This triggers are used multiple times", "nl": "This triggers are used multiple times", "fr": "This triggers are used multiple times", "es": "This triggers are used multiple times", "pl": "This triggers are used multiple times", "it": "This triggers are used multiple times", "zh-cn": "This triggers are used multiple times"},
        translate.js:24 "Call
           									Text
           								": {"en": "Call
           									Text
           								", "de": "Call
           									Text
           								", "ru": "Call
           									Text
           								", "pt": "Call
           									Text
           								", "nl": "Call
           									Text
           								", "fr": "Call
           									Text
           								", "es": "Call
           									Text
           								", "pl": "Call
           									Text
           								", "it": "Call
           									Text
           								", "zh-cn": "Call
           									Text
        2translate.js:24 "Ok": {"en": "Ok", "de": "Ok", "ru": "Ok", "pt": "Ok", "nl": "Ok", "fr": "Ok", "es": "Ok", "pl": "Ok", "it": "Ok", "zh-cn": "Ok"},
        translate.js:24 "Copy Data": {"en": "Copy Data", "de": "Copy Data", "ru": "Copy Data", "pt": "Copy Data", "nl": "Copy Data", "fr": "Copy Data", "es": "Copy Data", "pl": "Copy Data", "it": "Copy Data", "zh-cn": "Copy Data"},
          @michael-roling
          die telegram instanzen habe ich auch gecheckt -die arbeiten und können in iob genutzt werden
          • Michael Roling
            Michael Roling Developer @liv-in-sky last edited by
            @liv-in-sky update noch mal von github und wir schauen uns die ausgabe nochmal an, habe sie angepasst
              liv-in-sky @Michael Roling last edited by liv-in-sky
              @michael-roling
              seltsam - der telegram.3 ist nicht aufgelistet - den nutze ich eigentlich dafür
              der telegram.4 ist jetzt wieder sichtbar und auswählbar (der neue 4er - ist halt nicht konfiguriert) - die anderen sind nicht sichtbar in der auswahl
              iobroker.admin@6.10.4
              instrument.ts:144 [2023-10-09T07:24:48.293Z] Try to connect
              instrument.ts:144 Stored version: , new version: 6.10.4
              instrument.ts:144 Connected: true
              instrument.ts:144 Translate: esphome
              instrument.ts:144 system.adapter.admin.0
              instrument.ts:144 system.adapter.admin.1
              instrument.ts:144 system.adapter.alexa2.0
              instrument.ts:144 system.adapter.alexa2.1
              instrument.ts:144 system.adapter.alias-manager.0
              instrument.ts:144 system.adapter.backitup.0
              instrument.ts:144 system.adapter.backitup.1
              instrument.ts:144 system.adapter.backitup.2
              instrument.ts:144 system.adapter.backitup.3
              instrument.ts:144 system.adapter.backitup.4
              instrument.ts:144 system.adapter.broadlink2.0
              instrument.ts:144 system.adapter.calendar.0
              instrument.ts:144 system.adapter.cloud.0
              instrument.ts:144 system.adapter.contact.0
              instrument.ts:144 system.adapter.daswetter.0
              instrument.ts:144 system.adapter.device-reminder.0
              instrument.ts:144 system.adapter.devices.0
              instrument.ts:144 system.adapter.dwd.0
              instrument.ts:144 system.adapter.email.0
              instrument.ts:144 system.adapter.esphome.0
              instrument.ts:144 system.adapter.eventlist.0
              instrument.ts:144 system.adapter.feiertage.0
              instrument.ts:144 system.adapter.flot.0
              instrument.ts:144 system.adapter.fritzdect.0
              instrument.ts:144 system.adapter.fritzdect.1
              instrument.ts:144 system.adapter.fritzdect.2
              instrument.ts:144 system.adapter.fuelpricemonitor.0
              instrument.ts:144 system.adapter.fullybrowser.0
              instrument.ts:144 system.adapter.gotify.0
              instrument.ts:144 system.adapter.history.0
              instrument.ts:144 system.adapter.ical.0
              instrument.ts:144 system.adapter.ical.1
              instrument.ts:144 system.adapter.ical.2
              instrument.ts:144 system.adapter.ical.3
              instrument.ts:144 system.adapter.ical.4
              instrument.ts:144 system.adapter.iceroad.0
              instrument.ts:144 system.adapter.icons-addictive-flavour-png.0
              instrument.ts:144 system.adapter.icons-icons8.0
              instrument.ts:144 system.adapter.icons-material-svg.0
              instrument.ts:144 system.adapter.icons-mfd-png.0
              instrument.ts:144 system.adapter.icons-mfd-svg.0
              instrument.ts:144 system.adapter.icons-open-icon-library-png.0
              instrument.ts:144 system.adapter.icons-ultimate-png.0
              instrument.ts:144 system.adapter.imap.0
              instrument.ts:144 system.adapter.info.0
              instrument.ts:144 system.adapter.iot.0
              instrument.ts:144 system.adapter.iqontrol.0
              instrument.ts:144 system.adapter.javascript.0
              instrument.ts:144 system.adapter.javascript.1
              instrument.ts:144 system.adapter.javascript.2
              instrument.ts:144 system.adapter.lgtv.0
              instrument.ts:144 system.adapter.linux-control.0
              instrument.ts:144 system.adapter.meross.0
              instrument.ts:144 system.adapter.meteoalarm.0
              instrument.ts:144 system.adapter.mihome.0
              instrument.ts:144 system.adapter.mpd.0
              instrument.ts:144 system.adapter.mqtt.0
              instrument.ts:144 system.adapter.mqtt.1
              instrument.ts:144 system.adapter.netatmo-crawler.0
              instrument.ts:144 system.adapter.node-red.0
              instrument.ts:144 system.adapter.nut.0
              instrument.ts:144 system.adapter.odl.0
              instrument.ts:144 system.adapter.openuv.0
              instrument.ts:144 system.adapter.openweathermap.0
              instrument.ts:144 system.adapter.pi-hole.0
              instrument.ts:144 system.adapter.ping.0
              instrument.ts:144 system.adapter.ping.1
              instrument.ts:144 system.adapter.pixelit.0
              instrument.ts:144 system.adapter.plex.0
              instrument.ts:144 system.adapter.puppeteer.0
              instrument.ts:144 system.adapter.pushbullet.0
              instrument.ts:144 system.adapter.pushbullet.1
              instrument.ts:144 system.adapter.pushover.0
              instrument.ts:144 system.adapter.pushover.1
              instrument.ts:144 system.adapter.scenes.0
              instrument.ts:144 system.adapter.simple-api.0
              instrument.ts:144 system.adapter.socketio.0
              instrument.ts:144 system.adapter.sonoff.0
              instrument.ts:144 system.adapter.sonoff.1
              instrument.ts:144 system.adapter.sonoff.2
              instrument.ts:144 system.adapter.sonoff.3
              instrument.ts:144 system.adapter.sonoff.4
              instrument.ts:144 system.adapter.sourceanalytix.0
              instrument.ts:144 system.adapter.spotify-premium.0
              instrument.ts:144 system.adapter.sql.0
              instrument.ts:144 system.adapter.sql.1
              instrument.ts:144 system.adapter.tankerkoenig.0
              instrument.ts:144 system.adapter.telegram.0
              instrument.ts:144 system.adapter.telegram.1
              instrument.ts:144 system.adapter.telegram.2
              instrument.ts:144 system.adapter.telegram.3
              instrument.ts:144 system.adapter.telegram.4
              instrument.ts:144 system.adapter.telegram-menu.0
              instrument.ts:144 system.adapter.tr-064.0
              instrument.ts:144 system.adapter.traccar.0
              instrument.ts:144 system.adapter.trashschedule.0
              instrument.ts:144 system.adapter.trashschedule.1
              instrument.ts:144 system.adapter.upnp.0
              instrument.ts:144 system.adapter.vis.0
              instrument.ts:144 system.adapter.vis-bars.0
              instrument.ts:144 system.adapter.vis-canvas-gauges.0
              instrument.ts:144 system.adapter.vis-colorpicker.0
              instrument.ts:144 system.adapter.vis-fancyswitch.0
              instrument.ts:144 system.adapter.vis-google-fonts.0
              instrument.ts:144 system.adapter.vis-history.0
              instrument.ts:144 system.adapter.vis-hqwidgets.0
              instrument.ts:144 system.adapter.vis-icontwo.0
              instrument.ts:144 system.adapter.vis-inventwo.0
              instrument.ts:144 system.adapter.vis-jqui-mfd.0
              instrument.ts:144 system.adapter.vis-justgage.0
              instrument.ts:144 system.adapter.vis-map.0
              instrument.ts:144 system.adapter.vis-material-advanced.0
              instrument.ts:144 system.adapter.vis-materialdesign.0
              instrument.ts:144 system.adapter.vis-metro.0
              instrument.ts:144 system.adapter.vis-owl.0
              instrument.ts:144 system.adapter.vis-players.0
              instrument.ts:144 system.adapter.vis-plumb.0
              instrument.ts:144 system.adapter.vis-rgraph.0
              instrument.ts:144 system.adapter.vis-timeandweather.0
              instrument.ts:144 system.adapter.vis-weather.0
              instrument.ts:144 system.adapter.web.0
              instrument.ts:144 system.adapter.web.1
              instrument.ts:144 system.adapter.web.2
              instrument.ts:144 system.adapter.webcal.0
              instrument.ts:144 system.adapter.webcal.1
              instrument.ts:144 system.adapter.webcal.2
              instrument.ts:144 system.adapter.windows-control.0
              instrument.ts:144 system.adapter.wled.0
              instrument.ts:144 system.adapter.ws.0
              instrument.ts:144 system.adapter.ws.1
              instrument.ts:144 system.adapter.ws.2
              instrument.ts:144 system.adapter.zigbee2mqtt.0
              instrument.ts:144 getInstances: 317
              socket.io.js:66 [2023-10-09T07:24:53.912Z] Try to connect
              emit.js:29 getAllTelegramInstances
              emit.js:40 {id: 'system.adapter.admin.0', value: {…}}
              emit.js:40 {id: 'system.adapter.backitup.0', value: {…}}
              emit.js:40 {id: 'system.adapter.backitup.1', value: {…}}
              emit.js:40 {id: 'system.adapter.web.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis.0', value: {…}}
              emit.js:40 {id: 'system.adapter.admin.1', value: {…}}
              emit.js:40 {id: 'system.adapter.alexa2.0', value: {…}}
              emit.js:40 {id: 'system.adapter.alexa2.1', value: {…}}
              emit.js:40 {id: 'system.adapter.alias-manager.0', value: {…}}
              emit.js:40 {id: 'system.adapter.backitup.2', value: {…}}
              emit.js:40 {id: 'system.adapter.backitup.3', value: {…}}
              emit.js:40 {id: 'system.adapter.backitup.4', value: {…}}
              emit.js:40 {id: 'system.adapter.broadlink2.0', value: {…}}
              emit.js:40 {id: 'system.adapter.calendar.0', value: {…}}
              emit.js:40 {id: 'system.adapter.cloud.0', value: {…}}
              emit.js:40 {id: 'system.adapter.contact.0', value: {…}}
              emit.js:40 {id: 'system.adapter.daswetter.0', value: {…}}
              emit.js:40 {id: 'system.adapter.device-reminder.0', value: {…}}
              emit.js:40 {id: 'system.adapter.devices.0', value: {…}}
              emit.js:40 {id: 'system.adapter.dwd.0', value: {…}}
              emit.js:40 {id: 'system.adapter.email.0', value: {…}}
              emit.js:40 {id: 'system.adapter.esphome.0', value: {…}}
              emit.js:40 {id: 'system.adapter.eventlist.0', value: {…}}
              emit.js:40 {id: 'system.adapter.feiertage.0', value: {…}}
              emit.js:40 {id: 'system.adapter.flot.0', value: {…}}
              emit.js:40 {id: 'system.adapter.fritzdect.0', value: {…}}
              emit.js:40 {id: 'system.adapter.fritzdect.1', value: {…}}
              emit.js:40 {id: 'system.adapter.fritzdect.2', value: {…}}
              emit.js:40 {id: 'system.adapter.fullybrowser.0', value: {…}}
              emit.js:40 {id: 'system.adapter.history.0', value: {…}}
              emit.js:40 {id: 'system.adapter.ical.0', value: {…}}
              emit.js:40 {id: 'system.adapter.ical.1', value: {…}}
              emit.js:40 {id: 'system.adapter.ical.2', value: {…}}
              emit.js:40 {id: 'system.adapter.ical.3', value: {…}}
              emit.js:40 {id: 'system.adapter.ical.4', value: {…}}
              emit.js:40 {id: 'system.adapter.icons-addictive-flavour-png.0', value: {…}}
              emit.js:40 {id: 'system.adapter.icons-icons8.0', value: {…}}
              emit.js:40 {id: 'system.adapter.icons-mfd-png.0', value: {…}}
              emit.js:40 {id: 'system.adapter.icons-mfd-svg.0', value: {…}}
              emit.js:40 {id: 'system.adapter.icons-open-icon-library-png.0', value: {…}}
              emit.js:40 {id: 'system.adapter.icons-ultimate-png.0', value: {…}}
              emit.js:40 {id: 'system.adapter.info.0', value: {…}}
              emit.js:40 {id: 'system.adapter.iot.0', value: {…}}
              emit.js:40 {id: 'system.adapter.iqontrol.0', value: {…}}
              emit.js:40 {id: 'system.adapter.javascript.0', value: {…}}
              emit.js:40 {id: 'system.adapter.javascript.1', value: {…}}
              emit.js:40 {id: 'system.adapter.javascript.2', value: {…}}
              emit.js:40 {id: 'system.adapter.lgtv.0', value: {…}}
              emit.js:40 {id: 'system.adapter.linux-control.0', value: {…}}
              emit.js:40 {id: 'system.adapter.meross.0', value: {…}}
              emit.js:40 {id: 'system.adapter.meteoalarm.0', value: {…}}
              emit.js:40 {id: 'system.adapter.mihome.0', value: {…}}
              emit.js:40 {id: 'system.adapter.mpd.0', value: {…}}
              emit.js:40 {id: 'system.adapter.mqtt.0', value: {…}}
              emit.js:40 {id: 'system.adapter.mqtt.1', value: {…}}
              emit.js:40 {id: 'system.adapter.netatmo-crawler.0', value: {…}}
              emit.js:40 {id: 'system.adapter.node-red.0', value: {…}}
              emit.js:40 {id: 'system.adapter.nut.0', value: {…}}
              emit.js:40 {id: 'system.adapter.openuv.0', value: {…}}
              emit.js:40 {id: 'system.adapter.openweathermap.0', value: {…}}
              emit.js:40 {id: 'system.adapter.pi-hole.0', value: {…}}
              emit.js:40 {id: 'system.adapter.ping.0', value: {…}}
              emit.js:40 {id: 'system.adapter.ping.1', value: {…}}
              emit.js:40 {id: 'system.adapter.pixelit.0', value: {…}}
              emit.js:40 {id: 'system.adapter.plex.0', value: {…}}
              emit.js:40 {id: 'system.adapter.puppeteer.0', value: {…}}
              emit.js:40 {id: 'system.adapter.pushbullet.0', value: {…}}
              emit.js:40 {id: 'system.adapter.pushbullet.1', value: {…}}
              emit.js:40 {id: 'system.adapter.pushover.0', value: {…}}
              emit.js:40 {id: 'system.adapter.pushover.1', value: {…}}
              emit.js:40 {id: 'system.adapter.scenes.0', value: {…}}
              emit.js:40 {id: 'system.adapter.simple-api.0', value: {…}}
              emit.js:40 {id: 'system.adapter.socketio.0', value: {…}}
              emit.js:40 {id: 'system.adapter.sonoff.0', value: {…}}
              emit.js:40 {id: 'system.adapter.sonoff.1', value: {…}}
              emit.js:40 {id: 'system.adapter.sonoff.2', value: {…}}
              emit.js:40 {id: 'system.adapter.sonoff.3', value: {…}}
              emit.js:40 {id: 'system.adapter.sonoff.4', value: {…}}
              emit.js:40 {id: 'system.adapter.sourceanalytix.0', value: {…}}
              emit.js:40 {id: 'system.adapter.sql.0', value: {…}}
              emit.js:40 {id: 'system.adapter.telegram.0', value: {…}}
              emit.js:40 {id: 'system.adapter.telegram.1', value: {…}}
              emit.js:40 {id: 'system.adapter.telegram.2', value: {…}}
              emit.js:40 {id: 'system.adapter.tr-064.0', value: {…}}
              emit.js:40 {id: 'system.adapter.trashschedule.0', value: {…}}
              emit.js:40 {id: 'system.adapter.trashschedule.1', value: {…}}
              emit.js:40 {id: 'system.adapter.upnp.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-bars.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-canvas-gauges.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-colorpicker.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-fancyswitch.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-history.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-hqwidgets.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-jqui-mfd.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-justgage.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-map.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-metro.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-owl.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-players.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-plumb.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-rgraph.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-timeandweather.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-weather.0', value: {…}}
              emit.js:40 {id: 'system.adapter.web.1', value: {…}}
              emit.js:40 {id: 'system.adapter.web.2', value: {…}}
              emit.js:40 {id: 'system.adapter.windows-control.0', value: {…}}
              emit.js:40 {id: 'system.adapter.wled.0', value: {…}}
              emit.js:40 {id: 'system.adapter.icons-material-svg.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-google-fonts.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-materialdesign.0', value: {…}}
              emit.js:40 {id: 'system.adapter.ws.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-inventwo.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-icontwo.0', value: {…}}
              emit.js:40 {id: 'system.adapter.ws.1', value: {…}}
              emit.js:40 {id: 'system.adapter.ws.2', value: {…}}
              emit.js:40 {id: 'system.adapter.iceroad.0', value: {…}}
              emit.js:40 {id: 'system.adapter.gotify.0', value: {…}}
              emit.js:40 {id: 'system.adapter.traccar.0', value: {…}}
              emit.js:40 {id: 'system.adapter.zigbee2mqtt.0', value: {…}}
              emit.js:40 {id: 'system.adapter.tankerkoenig.0', value: {…}}
              emit.js:40 {id: 'system.adapter.spotify-premium.0', value: {…}}
              emit.js:40 {id: 'system.adapter.webcal.0', value: {…}}
              emit.js:40 {id: 'system.adapter.fuelpricemonitor.0', value: {…}}
              emit.js:40 {id: 'system.adapter.vis-material-advanced.0', value: {…}}
              emit.js:40 {id: 'system.adapter.imap.0', value: {…}}
              emit.js:40 {id: 'system.adapter.telegram-menu.0', value: {…}}
              emit.js:40 {id: 'system.adapter.telegram.3', value: {…}}
              emit.js:40 {id: 'system.adapter.sql.1', value: {…}}
              emit.js:40 {id: 'system.adapter.webcal.1', value: {…}}
              emit.js:40 {id: 'system.adapter.webcal.2', value: {…}}
              emit.js:40 {id: 'system.adapter.odl.0', value: {…}}
              emit.js:40 {id: 'system.adapter.telegram.4', value: {…}}
              emit.js:49 Instance Name: Telegram
                 									": {"en": "Switch
                 									", "de": "Switch
                 									", "ru": "Switch
                 									", "pt": "Switch
                 									", "nl": "Switch
                 									", "fr": "Switch
                 									", "es": "Switch
                 									", "pl": "Switch
                 									", "it": "Switch
                 									", "zh-cn": "Switch
                 									Text
                 								": {"en": "Call
                 									Text
                 								", "de": "Call
                 									Text
                 								", "ru": "Call
                 									Text
                 								", "pt": "Call
                 									Text
                 								", "nl": "Call
                 									Text
                 								", "fr": "Call
                 									Text
                 								", "es": "Call
                 									Text
                 								", "pl": "Call
                 									Text
                 								", "it": "Call
                 									Text
                 								", "zh-cn": "Call
                 									Text
                 									": {"en": "Switch
                 									", "de": "Switch
                 									", "ru": "Switch
                 									", "pt": "Switch
                 									", "nl": "Switch
                 									", "fr": "Switch
                 									", "es": "Switch
                 									", "pl": "Switch
                 									", "it": "Switch
                 									", "zh-cn": "Switch
                 									Text
                 								": {"en": "Call
                 									Text
                 								", "de": "Call
                 									Text
                 								", "ru": "Call
                 									Text
                 								", "pt": "Call
                 									Text
                 								", "nl": "Call
                 									Text
                 								", "fr": "Call
                 									Text
                 								", "es": "Call
                 									Text
                 								", "pl": "Call
                 									Text
                 								", "it": "Call
                 									Text
                 								", "zh-cn": "Call
                 									Text
              • Michael Roling
                Michael Roling Developer @liv-in-sky last edited by Michael Roling
                @liv-in-sky du kannst ja diese auszüge ausklappen, zeig mal was bei dir bei telegram.3.value.common steht, bzw bei einem der nicht angezeigt wird
                  @michael-roling sagte in Test Adapter telegram-menu v.0.6.x:
                  sorry - wo genau finde ich das geforderte?
                  • Michael Roling
                    das kann man öffnen
                    ich bin mal gespannt ob jetzt die adapter wieder gefunden werden
                    liv-in-sky 4 Replies Last reply Reply Quote 0
                      @michael-roling
                      ja- aber telegram.3 gibt es nicht
                        @michael-roling
                        ok - jetzt sind sie wieder in der auswahl
                          @michael-roling
                          läuft wieder - habe gerade getestet
                          • Michael Roling
                            @liv-in-sky dann werde ich nochmal etwas mit wieder rein nehmen und du musst nocheinmal testen, melde mich gleich
                              @michael-roling weißt du was es war - oder ist das bei mir ein sonderfall ?
                              auf jeden fall - danke erstmal für dein durchhalten
                                @michael-roling ich warte ... 🙂
                                • Michael Roling
                                  @liv-in-sky noch einmal testen
                                  liv-in-sky 1 Reply Last reply Reply Quote 1
                                    @michael-roling
                                    läuft noch
                                    emit.js:49 Instance Name: undefined
                                    emit.js:40 {id: 'system.adapter.telegram.3', value: {…}}id: "system.adapter.telegram.3"value: acl: {object: 1636, owner: 'system.user.admin', ownerGroup: 'system.group.administrator'}common: adminUI: {custom: 'json', config: 'json'}authors: (3) ['bluefox <dogafox@gmail.com>', 'apollon77 <iobroker@fischer-ka.de>', 'Matthias Kleine <info@haus-automatisierung.com>']blockly: truecompact: trueconnectionType: "cloud"dataSource: "poll"dependencies: [{…}]desc: {en: 'This adapter allows to send and receive telegram messages from ioBroker and to be a bot', de: 'Adapter ermöglicht eine Kommunikation mit dem telegram app und ist selbst ein bot', ru: 'Драйвер запускает Telegram бот, с которым можно общаться по App или через браузер', pt: 'Este adaptador permite enviar e receber mensagens de telegramas de ioBroker e ser um bot', nl: 'Met deze adapter kunt u telegramberichten van ioBroker verzenden en ontvangen en een bot zijn', …}docs: {en: Array(1), de: Array(1)}enabled: trueextIcon: "https://raw.githubusercontent.com/iobroker-community-adapters/ioBroker.telegram/master/admin/telegram.png"globalDependencies: [{…}]host: "iobroker59"icon: "telegram.png"installedFrom: "iobroker.telegram@1.16.0"installedVersion: "1.16.0"javascriptRules: {i18n: true, url: 'rules/customRuleBlocks.js', name: 'ActionTelegram'}keywords: (3) ['notification', 'telegram', 'message']license: "MIT"loglevel: "warn"messagebox: truemode: "daemon"name: "telegram"platform: "Javascript/Node.js"plugins: {sentry: {…}}readme: "https://github.com/iobroker-community-adapters/ioBroker.telegram/blob/master/README.md"restartSchedule: "4 5 * * *"stopBeforeUpdate: truesupportCustoms: truesupportedMessages: {custom: true, notifications: true}tier: 1title: "Telegram"titleLang: "iobsteuerung"type: "messaging"version: "1.16.0"[[Prototype]]: ObjectencryptedNative: (3) ['token', 'password', 'proxyPassword']from: "system.adapter.admin.1"instanceObjects: Array(16)0: {_id: 'info', type: 'channel', common: {…}, native: {…}}1: {_id: 'info.connection', type: 'state', common: {…}, native: {…}}2: {_id: 'communicate.request', type: 'state', common: {…}, native: {…}}3: {_id: 'communicate.requestRaw', type: 'state', common: {…}, native: {…}}4: {_id: 'communicate.requestChatId', type: 'state', common: {…}, native: {…}}5: {_id: 'communicate.requestMessageId', type: 'state', common: {…}, native: {…}}6: {_id: 'communicate.botSendChatId', type: 'state', common: {…}, native: {…}}7: {_id: 'communicate.botSendMessageId', type: 'state', common: {…}, native: {…}}8: {_id: 'communicate.botSendRaw', type: 'state', common: {…}, native: {…}}9: {_id: 'communicate.requestUserId', type: 'state', common: {…}, native: {…}}10: {_id: 'communicate.response', type: 'state', common: {…}, native: {…}}11: {_id: 'communicate.responseSilent', type: 'state', common: {…}, native: {…}}12: {_id: 'communicate.responseJson', type: 'state', common: {…}, native: {…}}13: {_id: 'communicate.responseSilentJson', type: 'state', common: {…}, native: {…}}14: {_id: 'communicate.users', type: 'state', common: {…}, native: {…}}15: {_id: 'communicate.pathFile', type: 'state', common: {…}, native: {…}}length: 16[[Prototype]]: Array(0)native: allowStates: truebaseApiUrl: "https://api.telegram.org"bind: "0.0.0.0"certChained: ""certPrivate: ""certPublic: ""doNotAcceptNewUsers: falsekeyboard: "/cmds"leCheckPort: 80leEnabled: falseleUpdate: falsepassword: "$/aes-192-cbc:73a4bb84ed3b058595ce6dda6a51aab6:4ced23b10ffb268a776c06f7ad9ce517"pollingInterval: 300port: 8443proxy: falseproxyHost: ""proxyLogin: ""proxyPassword: ""proxyPort: 1234rememberUsers: truerestarted: "_"restarting: "_"rooms: falsesaveFiles: falsesaveFilesQuality: "0"server: "false"storeRawRequest: falsetext2command: ""token: "$/aes-192-cbc:3229b3de5938b6efec7f67738be3f950:e0d4cbfccfb4e35d5000dd1647ea1fe5a2471807c4a6a7d88424eb476c25f86fa468d12617c300bc157c23a0e6d4d6ef"url: ""useUsername: false[[Prototype]]: Objectnotifications: []objects: []protectedNative: (4) ['token', 'password', 'proxyPassword', 'passwordRepeat']ts: 1696837586622type: "instance"user: "system.user.admin"_id: "system.adapter.telegram.3"[[Prototype]]: Object[[Prototype]]: Object
                                    emit.js:57 Instancen: telegram.0,telegram.1,telegram.2,telegram.3,telegram.4
                                    										": {"en": "Switch
                                    										", "de": "Switch
                                    										", "ru": "Switch
                                    										", "pt": "Switch
                                    										", "nl": "Switch
                                    										", "fr": "Switch
                                    										", "es": "Switch
                                    										", "pl": "Switch
                                    										", "it": "Switch
                                    										", "zh-cn": "Switch
                                    • Michael Roling
                                      @liv-in-sky sagte in Test Adapter telegram-menu v.0.6.x:
                                      öffne den mal in der console
                                        @michael-roling ist oben drin - ziemlich weit unten - post drüber
                                          @michael-roling
                                          zeile 131
                                          • Michael Roling
                                            @liv-in-sky ich muss aber sehen was unter common steht
                                            1801
                                            791226
