    4. iob node fix - Skript
    • JoJo58
      JoJo58 @Thomas Braun last edited by
      @thomas-braun Das Ergebnis:
      smarthome@vm-iobroker:~$ sudo find / -path /proc -o -path /dev -o -path /sys -o -path /lost+found -o -path /mnt -prune -false -o -name nodesource.[gk]* -print
      /usr/share/keyrings/nodesource.gpg
      find: ‘/run/user/1000/gvfs’: Keine Berechtigung
        Thomas Braun Most Active @JoJo58 last edited by
        @jojo58
        Okay.
        Lad das Skript jetzt nochmal frisch runter.
        JoJo58 1 Reply Last reply Reply Quote 0
        • JoJo58
          @thomas-braun Das sieht schon besser aus. Wie soll ich weitermachen?
          ioBroker nodejs fixer 2023-10-07
          Recommended nodejs-version is: 18.18.0
          Checking your installation now. Please be patient!
          Your current setup is:
          /usr/bin/nodejs         v18.17.1
          /usr/bin/node           v18.17.1
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          /usr/bin/corepack       0.18.0
          We found these nodejs versions available for installation:
          nodejs:
            Installed: 18.17.1-deb-1nodesource1
            Candidate: 18.17.1-deb-1nodesource1
            Version table:
           *** 18.17.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.13.0+dfsg1-1 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
          Press <y> to continue or any other key to quit
          Trying to fix your installation now. Please be patient.
          find: '/run/user/1000/gvfs': Permission denied
          Virtualization: kvm
          Waiting for ioBroker to shut down - Give me a minute...
          *** These repos are active on your system:
          Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Reading package lists... Done
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
          Get:6 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5247 B]
          Fetched 17.4 kB in 0s (40.2 kB/s)
          Installing the recommended nodejs version now!
          Installing the recommended nodejs version!
          (Reading database ... 100420 files and directories currently installed.)
          Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
          Detected old npm client, removing...
          Unpacking nodejs (18.18.0-1nodesource1) over (18.17.1-deb-1nodesource1) ...
          Setting up nodejs (18.18.0-1nodesource1) ...
          Processing triggers for man-db (2.11.2-2) ...
          *** You need to manually restart your container/virtual machine now! ***
          We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
            @jojo58 sagte in iob node fix - Skript:
            VM/Container neustarten. Und dann nochmal das Skript. Sollte dann mit doppeltem 'Nothing to do' verkünden, das alles i. O. ist.
            • JoJo58
              @thomas-braun Super, hat jetzt funktioniert. Danke dir. 👍
              /usr/bin/nodejs         v18.18.0
              /usr/bin/node           v18.18.0
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              /usr/bin/corepack       0.19.0
              nodejs:
               Installed: 18.18.0-1nodesource1
               Candidate: 18.18.0-1nodesource1
               Version table:
              *** 18.18.0-1nodesource1 1001
                     500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  18.17.1-1nodesource1 1001
                  18.17.0-1nodesource1 1001
                  18.16.1-1nodesource1 1001
                  18.16.0-1nodesource1 1001
                  18.15.0-1nodesource1 1001
                  18.14.2-1nodesource1 1001
                  18.14.1-1nodesource1 1001
                  18.14.0-1nodesource1 1001
                  18.13.0+dfsg1-1 500
                  18.13.0-1nodesource1 1001
                  18.12.0-1nodesource1 1001
                  18.11.0-1nodesource1 1001
                  18.10.0-1nodesource1 1001
                  18.9.1-1nodesource1 1001
                  18.9.0-1nodesource1 1001
                  18.8.0-1nodesource1 1001
                  18.7.0-1nodesource1 1001
                  18.6.0-1nodesource1 1001
                  18.5.0-1nodesource1 1001
                  18.4.0-1nodesource1 1001
                  18.3.0-1nodesource1 1001
                  18.2.0-1nodesource1 1001
                  18.1.0-1nodesource1 1001
                  18.0.0-1nodesource1 1001
              Nothing to do - Your version is the recommended one.
              You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
              Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
              Jetzt kann ich mich meinem JavaScript Adapter Problem zuwenden.
                @jojo58
                Okay. Danke für die Hilfe beim Debuggen.
                Allerdings auch hier nochmal der Hinweise bzw. die dringende Empfehlung:
                Server NIE mit Desktop/graphischer Oberfläche betreiben!
                Da rumpelt nämlich ein gnome oder etwas davon abgeleitetes mit über dein System. Komplett unnötig. Und vermutlich mit der Auslöser für das Verhalten des Skripts.
                • JoJo58
                  @thomas-braun Die grafische Oberfläche habe ich doch schon vor 4 Wochen runtergeschmissen? Wahrscheinlich hat das nicht sauber geklappt. Mist aber auch...
                    runtergeschmissen?
                    Komplett runtergeschmissen oder lediglich deaktiviert?
                    • JoJo58
                      @thomas-braun Komplett runtergeschmissen. Hoffe das war richtig so:
                      sudo apt-get autoremove gdm3
                      und
                      sudo apt-get autoremove --purge gnome*
                        Das weiß ich nicht. Kenne dein System ja nicht.
                        • U
                          UV-on-fire last edited by
                          Ich habe am Sonntag mit dem Script auf V18.18.0 upgedatet. Hat auch alles geklappt. Allerdings besteht da ja das Problem das Backitup nicht sauber läuft.
                          Siehe Hier
                          Jetzt wollte ich eben auf 18.18.1 updaten aber das funktioniert nicht. Ausgabe des Skripts:
                           You are running nodejs v18.18.0. Do you want to install recommended version 18.18.1?
                          [sudo] password for uviob:
                          Sorry, try again.
                          Virtualization: lxc
                          Hit:1 http://security.debian.org bullseye-security InRelease
                          Hit:2 http://ftp.debian.org/debian bullseye InRelease
                          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                          Package: nodejs
                          Pin-Priority: 1001
                          Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                          Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5540 B]
                          Err:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                            File has unexpected size (5247 != 5540). Mirror sync in progress? [IP: 2606:4700:10::6816:41a 443]
                            Hashes of expected file:
                             - Filesize:5540 [weak]
                             - SHA512:42fc03dd54ad0876c94818799e4c58fe6b1f55a39d99237e22eea4b127f782f1b893ed734c5d80c1c7fec87e88ece4373920aaa4792d1f25b28b398c093fd63c
                             - SHA256:38b78587e1a99e9c1b861ea8dd3a29e192dfae63e108aafd17b7f60bd6acd23f
                             - SHA1:d31595d3ddf7337cec92847e9ed8551f4addc693 [weak]
                             - MD5Sum:d69fd7a6e53a348af97ca66bf65317bf [weak]
                            Release file created at: Tue, 10 Oct 2023 17:30:21 +0000
                          Fetched 12.1 kB in 1s (22.5 kB/s)
                          E: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/main/binary-amd64/Packages.bz2  File has unexpected size (5247 != 5540). Mirror sync in progress? [IP: 2606:4700:10::6816:41a 443]
                          E: Some index files failed to download. They have been ignored, or old ones used instead.
                          Hier noch die Ausgabe von Diag
                          Lang:
                          Skript v.2023-06-20
                          *** BASE SYSTEM ***
                             Static hostname: iobroker
                                   Icon name: computer-container
                                     Chassis: container
                                  Machine ID: c337b259b2a44b9da1e2356e14b395e6
                                     Boot ID: 9fcb0b446bb94c388a463a906e17bdf2
                              Virtualization: lxc
                            Operating System: Debian GNU/Linux 11 (bullseye)
                                      Kernel: Linux 6.2.16-14-pve
                                Architecture: x86-64
                          model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                          Docker          : false
                          Virtualization  : lxc
                          Kernel          : x86_64
                          Userland        : amd64
                          Systemuptime and Load:
                           19:49:54 up 0 min,  1 user,  load average: 1.05, 0.62, 0.74
                          CPU threads: 1
                          *** Time and Time Zones ***
                                         Local time: Tue 2023-10-10 19:49:54 CEST
                                     Universal time: Tue 2023-10-10 17:49:54 UTC
                                           RTC time: n/a
                                        NTP service: inactive
                                    RTC in local TZ: no
                          *** User and Groups ***
                          uviob
                          /home/uviob
                          uviob sudo iobroker
                          *** X-Server-Setup ***
                          X-Server:       false
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Mem:            4.1G        1.3G        2.6G        0.0K        222M        2.8G
                          Swap:           512M          0B        512M
                          Total:          4.6G        1.3G        3.1G
                                   4096 M total memory
                                   1288 M used memory
                                     62 M active memory
                                   1385 M inactive memory
                                   2584 M free memory
                                      0 M buffer memory
                                    222 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    512 M free swap
                          *** FILESYSTEM ***
                          Filesystem                       Type   Size  Used Avail Use% Mounted on
                          /dev/mapper/pve-vm--210--disk--1 ext4   9.8G  7.1G  2.2G  77% /
                          none                             tmpfs  492K  4.0K  488K   1% /dev
                          tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
                          tmpfs                            tmpfs  3.1G  104K  3.1G   1% /run
                          tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                          [Tue Oct  3 12:06:53 2023] EXT4-fs (dm-1): mounted filesystem 1192067b-46b8-4ac5-a608-5f91cdfb985a with ordered data mode. Quota mode: none.
                          [Tue Oct  3 12:06:53 2023] EXT4-fs (dm-1): re-mounted 1192067b-46b8-4ac5-a608-5f91cdfb985a. Quota mode: none.
                          [Tue Oct  3 12:06:55 2023] EXT4-fs (sda): mounted filesystem 52b7d67a-b075-47cb-8f0d-78dafd5f3aa1 with ordered data mode. Quota mode: none.
                          [Tue Oct  3 12:07:08 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                          [Tue Oct  3 12:07:29 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                          [Tue Oct  3 12:07:29 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                          [Tue Oct  3 12:07:30 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                          [Tue Oct  3 12:07:30 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                          [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                          [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                          [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                          [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                          [Tue Oct  3 13:23:08 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                          [Tue Oct  3 13:23:21 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                          [Tue Oct  3 13:28:39 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                          [Tue Oct  3 13:28:39 2023] EXT4-fs (dm-10): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 without journal. Quota mode: none.
                          [Tue Oct  3 13:32:47 2023] EXT4-fs (dm-10): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                          [Tue Oct  3 13:32:48 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                          [Tue Oct  3 13:33:04 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                          [Mon Oct  9 03:05:42 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                          [Mon Oct  9 03:05:55 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                          [Mon Oct  9 03:11:33 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                          [Mon Oct  9 03:11:33 2023] EXT4-fs (dm-10): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 without journal. Quota mode: none.
                          [Mon Oct  9 03:15:42 2023] EXT4-fs (dm-10): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                          [Mon Oct  9 03:15:42 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                          [Mon Oct  9 03:15:59 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                          [Tue Oct 10 19:31:24 2023] EXT4-fs (dm-8): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                          [Tue Oct 10 19:31:25 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                          [Tue Oct 10 19:38:50 2023] EXT4-fs (dm-8): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                          [Tue Oct 10 19:39:03 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                          [Tue Oct 10 19:48:54 2023] EXT4-fs (dm-8): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                          [Tue Oct 10 19:48:55 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                          Show mounted filesystems (real ones only):
                          TARGET SOURCE                           FSTYPE OPTIONS
                          /      /dev/mapper/pve-vm--210--disk--1 ext4   rw,relatime,stripe=16
                          /var:
                          919M    /var/
                          402M    /var/log
                          401M    /var/log/journal/c337b259b2a44b9da1e2356e14b395e6
                          376M    /var/cache
                          Archived and active journals take up 96.0M in the file system.
                          /opt/iobroker/backups:
                          69M     /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          563M    /opt/iobroker/iobroker-data/
                          454M    /opt/iobroker/iobroker-data/files
                          80M     /opt/iobroker/iobroker-data/files/vis
                          80M     /opt/iobroker/iobroker-data/backup-objects
                          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.eafddf6f.js.map
                          21M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.22196004.js.map
                          20M     /opt/iobroker/iobroker-data/objects.jsonl
                          18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                          11M     /opt/iobroker/iobroker-data/states.jsonl
                          *** NodeJS-Installation ***
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                               12.22.12~dfsg-1~deb11u4 500
                                  500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                                  500 http://security.debian.org bullseye-security/main amd64 Packages
                          No problems detected
                          Errors in npm tree: 0
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          No configuration change needed.
                          Multihost discovery server: disabled
                          Discovery authentication:   enabled
                          Persistent activation:      disabled
                          Objects:                    jsonl on 127.0.0.1
                          States:                     jsonl on 127.0.0.1
                          Core adapters versions
                          js-controller:  5.0.13
                          admin:          6.10.5
                          javascript:     7.1.5
                          Adapters from github:   0
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.213, run as: admin
                            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                            system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                            system.adapter.bmw.0                    : bmw                   : iobroker                                 - disabled
                            system.adapter.cameras.0                : cameras               : iobroker                                 - disabled, port: 8200, bind: 127.0.0.1
                            system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                            system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                            system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                            system.adapter.fitbit-fitness.0         : fitbit-fitness        : iobroker                                 -  enabled
                            system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                            system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                            system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
                          + system.adapter.history.0                : history               : iobroker                                 -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                          + system.adapter.hm-rpc.4                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                            system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                            system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
                            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
                            system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                            system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                            system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                            system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.213
                            system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                          + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                            system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                            system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                            system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                            system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 -  enabled
                            system.adapter.tahoma.0                 : tahoma                : iobroker                                 -  enabled
                          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                            system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                            system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                            system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
                            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                            system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                            system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
                            system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                            system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Stable (default): http://download.iobroker.net/sources-dist.json
                          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                          Active repo(s): Beta (latest)
                          Installed ioBroker-Instances
                          Used repository: Beta (latest)
                          Adapter    "admin"        : 6.10.5   , installed 6.10.5
                          Adapter    "backitup"     : 2.8.3    , installed 2.8.3
                          Adapter    "bmw"          : 2.6.2    , installed 2.6.2
                          Adapter    "cameras"      : 1.3.0    , installed 1.3.0
                          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                          Adapter    "fitbit-fitness": 0.4.11  , installed 0.4.11
                          Adapter    "fritzdect"    : 2.4.1    , installed 2.4.1
                          Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                          Adapter    "history"      : 3.0.0    , installed 3.0.0
                          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                          Adapter    "javascript"   : 7.1.5    , installed 7.1.5
                          Controller "js-controller": 5.0.13   , installed 5.0.13
                          Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                          Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                          Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                          Adapter    "proxmox"      : 2.1.0    , installed 2.1.0
                          Adapter    "socketio"     : 6.5.7    , installed 6.5.7
                          Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                          Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                          Adapter    "telegram"     : 2.0.0    , installed 2.0.0
                          Adapter    "text2command" : 3.0.2    , installed 3.0.2
                          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                          Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
                          Adapter    "vis"          : 1.4.16   , installed 1.4.16
                          Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
                          Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                          Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
                          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                          Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                          Adapter    "web"          : 6.1.4    , installed 6.1.4
                          Adapter    "wled"         : 0.7.1    , installed 0.7.1
                          Adapter    "ws"           : 2.5.7    , installed 2.5.7
                          Objects and States
                          Objects:        19069
                          States:         17076
                          E: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/main/binary-amd64/Packages.bz2  File has unexpected size (5247 != 5540). Mirror sync in progress? [IP: 2606:4700:10::6816:51a 443]
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        23619139   103/systemd-resolve
                          tcp        0      0 192.168.178.213:8701    0.0.0.0:*               LISTEN      1001       23620337   471/io.hm-rpc.4
                          tcp        0      0 192.168.178.213:9292    0.0.0.0:*               LISTEN      1001       23620124   434/io.hm-rpc.1
                          tcp        0      0 192.168.178.213:2010    0.0.0.0:*               LISTEN      1001       23620183   449/io.hm-rpc.2
                          tcp        0      0 192.168.178.213:2001    0.0.0.0:*               LISTEN      1001       23620043   409/io.hm-rpc.0
                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        23619146   103/systemd-resolve
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          23618692   1/init
                          tcp        0      0 192.168.178.213:8081    0.0.0.0:*               LISTEN      1001       23619680   307/io.admin.0
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23619215   118/iobroker.js-con
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23619280   118/iobroker.js-con
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          23619401   302/master
                          tcp6       0      0 :::5355                 :::*                    LISTEN      104        23619142   103/systemd-resolve
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          23619402   302/master
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          23618700   1/init
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          23619008   1/init
                          udp        0      0 192.168.178.213:5353    0.0.0.0:*                           1001       23623327   937/io.tr-064.0
                          udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        23619138   103/systemd-resolve
                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        23619145   103/systemd-resolve
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          23618695   1/init
                          udp6       0      0 :::5355                 :::*                                104        23619141   103/systemd-resolve
                          udp6       0      0 :::111                  :::*                                0          23618705   1/init
                          2023-10-10 19:50:10.452  - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                          2023-10-10 19:50:11.595  - info: netatmo.0 (772) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v18.18.0, js-controller: 5.0.13
                          2023-10-10 19:50:11.622  - info: netatmo.0 (772) Using stored tokens to initialize ... {"access_token":"5d0fe99722ab74000d32a982|ebceb12208f5b85bfcf8ae32b0258629","refresh_token":"5d0fe99722ab74000d32a982|46128978a77b62a4c13e6bf878f065da","scope":"read_station","client_id":"60156be20bbeae26d976880d"}
                          2023-10-10 19:50:11.623  - info: netatmo.0 (772) Authenticating with Netatmo using individual client-ID 60156be20bbeae26d976880d
                          2023-10-10 19:50:11.985  - info: netatmo.0 (772) Successfully authenticated with Netatmo with individual client-ID 60156be20bbeae26d976880d
                          2023-10-10 19:50:13.803  - info: host.iobroker instance system.adapter.ping.0 started with pid 833
                          2023-10-10 19:50:15.528  - info: ping.0 (833) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.ping, node: v18.18.0, js-controller: 5.0.13
                          2023-10-10 19:50:15.895  - info: ical.2 (728) Terminated (NO_ERROR): Without reason
                          2023-10-10 19:50:16.472  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
                          2023-10-10 19:50:17.806  - info: host.iobroker instance system.adapter.tahoma.0 started with pid 906
                          2023-10-10 19:50:19.137  - info: tahoma.0 (906) starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.tahoma, node: v18.18.0, js-controller: 5.0.13
                          2023-10-10 19:50:19.152  - info: tahoma.0 (906) [START] Starting adapter tahoma v0.10.2.3
                          2023-10-10 19:50:19.152  - info: tahoma.0 (906) Configured polling interval: 20000
                          2023-10-10 19:50:21.298  - info: tahoma.0 (906) eventRegisterID = 1ab61062-0a19-0481-73a9-10cb0635bd01
                          2023-10-10 19:50:21.737  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 937
                          2023-10-10 19:50:23.041  - info: tr-064.0 (937) starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.18.0, js-controller: 5.0.13
                          2023-10-10 19:50:25.717  - info: host.iobroker instance scheduled system.adapter.openweathermap.0 37 * * * *
                          2023-10-10 19:50:25.739  - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 972
                          2023-10-10 19:50:26.975  - info: openweathermap.0 (972) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.18.0, js-controller: 5.0.13
                          2023-10-10 19:50:29.900  - info: host.iobroker instance scheduled system.adapter.tvspielfilm.0 */5 * * * *
                          2023-10-10 19:50:29.933  - info: host.iobroker instance system.adapter.tvspielfilm.0 started with pid 1016
                          2023-10-10 19:50:31.735  - info: tvspielfilm.0 (1016) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.13
                          2023-10-10 19:50:33.806  - info: host.iobroker instance system.adapter.mqtt.0 started with pid 1317
                          2023-10-10 19:50:33.810  - info: tvspielfilm.0 (1016) objects written
                          2023-10-10 19:50:35.323  - info: mqtt.0 (1317) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v18.18.0, js-controller: 5.0.13
                          Und kurz
                          Copy text starting here:
                                               v.2023-06-20
                                     Chassis: container
                              Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               amd64
                          Timezone:               Europe/Berlin (CEST, +0200)
                          User-ID:                1000
                          X-Server:               false
                          Boot Target:            graphical.target
                          Pending OS-Updates:     0
                          Pending iob updates:    0
                          Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                                                  /usr/bin/npm            9.8.1
                                                  /usr/bin/npx            9.8.1
                          Recommended versions are nodejs 18.x.y and npm 9.x.y
                          MEMORY:
                          Mem:            4.1G        2.1G        1.4G        0.0K        578M        1.9G
                          Swap:           512M          0B        512M
                          Total:          4.6G        2.1G        1.9G
                          Active iob-Instances:   31
                          ioBroker Core:          js-controller           5.0.13
                                                  admin                   6.10.5
                          Objects type: jsonl
                          States  type: jsonl
                          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          Objects:                19069
                          States:                 17076
                          Size of iob-Database:
                          21M     /opt/iobroker/iobroker-data/objects.jsonl
                          13M     /opt/iobroker/iobroker-data/states.jsonl
                          === Mark text until here for copying ===
                          Jemand ne Idee worans harpert?
                            Thomas Braun Most Active @UV-on-fire last edited by
                            @uv-on-fire sagte in iob node fix - Skript:
                            Ja, der 'Mirror sync' läuft gerade.
                            Und noch so als Hinweis: Wenn die Quelle einmal richtig auf das richtige Repo inkl. nodejs@18 umgestellt wurde braucht man das Skript / den 'iob node-upgrade' nicht mehr, das läuft dann über das übliche
                            sudo apt update
                            ganz normal mit. Das Skript ist nur für die einmalige Umstellung gedacht, nicht für 0815-Updates.
                            • U
                              UV-on-fire @Thomas Braun last edited by
                              Super, danke.
                              Und danke für den Hinweis. 👍
                                apollon77 last edited by
                                Sooo... Danke für Alle die Hier unterstützt haben und mit getestet haben! Das Skript ist nun offizieller Bestandhteil vom iobroker CLI Kommando.
                                Daher ... weiter unter https://forum.iobroker.net/topic/69067/neuer-befehl-iob-nodejs-update
                                198
                                37880
