    4. BackItUp kein WOL an Buffalo NAS LinkStation
      ToK @Glasfaser last edited by ToK
      @glasfaser
      Hoffe es ist so besser lesbar ->
      2023-10-09 17:39:27.324 - error: backitup.0 (88902) Error: Command failed: sudo mount -t cifs -o username=XXXX,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
      mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
      2023-10-09 17:41:32.893 - error: backitup.0 (88902) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=XXXX,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
      2023-10-09 17:41:32.895 - error: backitup.0 (88902) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
      2023-10-09 17:41:32.896 - error: backitup.0 (88902) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=XXXX,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry
      2023-10-09 17:41:32.896 - error: backitup.0 (88902) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
      2023-10-09 17:41:32.897 - error: backitup.0 (88902) [iobroker] Error: Command failed: sudo mount -t cifs -o username=XXXX,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
      Instanz Einstellungen:
      Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @ToK last edited by
        @tok
        Hier ist ein aktuelles Issues dazu , sieht genau so aus ,
        kannst ja auch dort schreiben .
        https://github.com/simatec/ioBroker.backitup/issues/999
        Standarduser created this issue in simatec/ioBroker.backitup
        closed WOL funktioniert nicht mehr #999
          Thomas Braun Most Active @ToK last edited by
          @tok
          Lebt da was unter der Adresse?
            ToK @Thomas Braun last edited by
            ja schon, den diese NAS lässt sich aus dem Terminal Putty mit dem Befehl "sudo /usr/sbin/etherwake -i eth0 <Mac Adresse>" jederzeit starten.
              @tok
              Die Mac ist aber nicht die IP.
                ToK @Thomas Braun last edited by ToK
                ist natürlich richtig - laut DEBUGLog sendet BackItUp ????
                In der Konfig ist die entsprechende Mac hinterlegt:
                Der Befehl "sudo /usr/sbin/etherwake -i eth0 <Mac Adresse>" sendet definitiv die Mac Adresse.
                • Glasfaser
                  Glasfaser @ToK last edited by Glasfaser
                  @tok
                  das ist kein Debug Log
                  Stelle die Logstufe bei der Instanz auf DEBUG .
                  Dann nochmal ... und das Ergebnis hier posten.
                  EDIT:
                    @tok
                    SMB V1 wird hoffentlich nicht mehr verwendet.
                      ToK @Glasfaser last edited by Homoran
                      @glasfaser
                      Bitte von unten nach oben lesen:
                      backitup.0
                      2023-10-09 19:19:00.381	error	[iobroker] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backupsmount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                      backitup.0
                      2023-10-09 19:19:00.381	error	[iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                      backitup.0
                      2023-10-09 19:19:00.380	error	[iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                      backitup.0
                      2023-10-09 19:19:00.380	error	[iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                      backitup.0
                      2023-10-09 19:19:00.379	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                      backitup.0
                      2023-10-09 19:18:54.244	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
                      backitup.0
                      2023-10-09 19:18:54.242	debug	[iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                      backitup.0
                      2023-10-09 19:18:48.054	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
                      backitup.0
                      2023-10-09 19:18:48.054	debug	[iobroker/mount] noserverino option: false
                      backitup.0
                      2023-10-09 19:16:48.053	debug	Backup has started ...
                      backitup.0
                      2023-10-09 19:16:48.052	debug	[iobroker/mount] Wake on LAN wait 120 Seconds for NAS!
                      Thomas Braun Glasfaser 3 Replies Last reply Reply Quote 0
                        Thomas Braun Most Active @ToK last edited by Thomas Braun
                        @tok sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                        Schau in das 'richtige' Log:
                        iob logs --watch
                        Und poste den Text in CodeTags eingebettet.
                        • Glasfaser
                          @tok
                          was davor ist , ist Interessant
                          und jetzt Logstufe Silly
                          • Glasfaser
                            Kannst du von ioBroker aus die IP anpingen !?
                            bzw.
                            was du nicht geschrieben hast , funktioniert das normale Backup , also NAS dauer an und dann ein Backup ohne die Option WOL
                              @glasfaser
                              2023-10-09 19:14:52.022  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
                              2023-10-09 19:16:42.124  - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.115.1
                              2023-10-09 19:16:42.206  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
                              2023-10-09 19:16:48.044  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
                              2023-10-09 19:16:48.052  - debug: backitup.0 (94212) [iobroker/mount] Wake on LAN wait 120 Seconds for NAS!
                              2023-10-09 19:16:48.053  - debug: backitup.0 (94212) Backup has started ...
                              2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] noserverino option: false
                              2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
                              2023-10-09 19:18:54.242  - debug: backitup.0 (94212) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                              2023-10-09 19:18:54.244  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
                              2023-10-09 19:19:00.379  - error: backitup.0 (94212) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                              2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                              2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                              2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                              2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                              2023-10-09 19:19:18.000  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
                              die MAC Adresse sehe ich hier nicht
                                @glasfaser
                                wenn die NAS "schläft" kann ich sie nicht anpingen - wenn sie über "sudo /usr/sbin/etherwake -i eth0 <Mac Adresse>" läuft schon.
                                Das normale Backup funktioniert ohne WOL (bei laufender NAS) einwandfrei.
                                  Homoran Global Moderator Administrators @ToK last edited by
                                  wieso auch?
                                  ich frage mich sowieso schon die ganze Zeit warum du dauernd die MAC Adresse ins Spiel bringst.
                                    @homoran sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                                    Weil das 'magic packet' an die MAC-Adresse gesendet wird, weil der Host ja schläft.
                                    T Homoran 2 Replies Last reply Reply Quote 0
                                      ja genau ....
                                        @thomas-braun sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                                        macht das nicht der Router?
                                          ToK @Homoran last edited by
                                          @homoran said in BackItUp kein WOL an Buffalo NAS LinkStation:
                                          Als Router wird eine FritzBox 7590 verwendet
                                          Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                                            Keine Ahnung ob das noch relevant ist:
                                            https://www.ip-phone-forum.de/threads/fritzbox-7490-wake-on-lan-über-udp-port-9-klappt-nicht-mehr.284397/
                                            1876
