    4. JavaScript
    5. IP Devices im Netzwerk - HTML Tabelle vis, Iqontrol
    • O
      Oli @liv-in-sky last edited by
      @liv-in-sky
      danke für das geniale Script, bin gerade erst darauf gestoßen und es funktioniert wie es soll.
      Allerdings habe ich meinen ioBroker über Docker installiert und habe das Problem, dass nicht alle Geräte über das Skript angezeigt werden und die MAC Adressen fehlen.
      @Glasfaser werden bei dir mittlerweile alle Geräte angezeigt und wenn ja, wie hast du das hinbekommen?
      Ausgabe aus dem Skript:
      javascript.0 (235) script.js.common.System.Skript_1: Starting Nmap 7.80 ( https://nmap.org ) at 2023-10-09 13:57 CEST Nmap scan report for speedport.ip (192.168.2.1) Host is up (0.0042s latency). Nmap scan report for 192.168.2.101 Host is up (0.00064s latency). Nmap scan report for 192.168.2.103 Host is up (0.00054s latency). Nmap scan report for 192.168.2.106 Host is up (0.0024s latency). Nmap scan report for 192.168.2.107 Host is up (0.025s latency). Nmap scan report for 192.168.2.108 Host is up (0.0031s latency). Nmap scan report for 192.168.2.112 Host is up (0.0029s latency). Nmap scan report for 192.168.2.115 Host is up (0.0026s latency). Nmap scan report for ioBroker (192.168.2.120) Host is up (0.00019s latency). Nmap scan report for 192.168.2.126 Host is up (0.033s latency). Nmap scan report for 192.168.2.140 Host is up (0.0044s latency). Nmap scan report for 192.168.2.150 Host is up (0.085s latency). Nmap scan report for 192.168.2.155 Host is up (0.0057s latency). Nmap scan report for 192.168.2.176 Host is up (0.070s latency). Nmap done: 256 IP addresses (14 hosts up) scanned in 16.03 seconds
      Ausgabe über die Konsole im Docker:
      root@ioBroker:/opt/iobroker# nmap -sPR --dns-servers 192.168.2.1 192.168.2.0/24
      WARNING: -sR is now an alias for -sV and activates version detection as well as RPC scan.
      Starting Nmap 7.80 ( https://nmap.org ) at 2023-10-09 13:25 CEST
      Host is up (0.0040s latency).
      MAC Address: 64:CC:22:39:A1:98 (Arcadyan)
      Host is up (0.00032s latency).
      MAC Address: 00:08:9B:EA:9B:3A (ICP Electronics)
      MAC Address: F4:06:8D:38:61:92 (devolo AG)
      Host is up (0.0011s latency).
      MAC Address: 60:6D:3C:10:49:B1 (Luxshare Precision Industry Company Limited)
      Host is up (0.015s latency).
      MAC Address: 88:87:17:96:28:12 (Canon)
      Nmap scan report for 192.168.2.110
      Host is up (0.0025s latency).
      MAC Address: 94:C6:91:59:C1:3C (EliteGroup Computer Systems)
      Host is up (0.0023s latency).
      MAC Address: 00:05:CD:94:48:C9 (D&M Holdings)
      Host is up (0.000035s latency).
      MAC Address: 00:08:9B:EA:9B:39 (ICP Electronics)
      Host is up (0.094s latency).
      MAC Address: 00:05:51:10:A3:06 (F & S Elektronik Systeme GmbH)
      Nmap scan report for 192.168.2.139
      Host is up (0.11s latency).
      MAC Address: 70:EE:50:6B:5F:4E (Netatmo)
      MAC Address: C8:DB:26:0A:8D:15 (Logitech)
      Nmap scan report for 192.168.2.145
      Host is up (0.023s latency).
      MAC Address: 94:3A:91:81:88:66 (Unknown)
      Host is up (1.4s latency).
      MAC Address: A6:BF:DC:19:1C:41 (Unknown)
      Host is up (0.010s latency).
      MAC Address: 00:0B:3B:9C:96:CD (devolo AG)
      Host is up (0.13s latency).
      MAC Address: EC:2B:EB:23:7E:22 (Unknown)
      Nmap scan report for 192.168.2.186
      Host is up (0.0045s latency).
      MAC Address: 6C:A9:36:FD:1B:7F (DisplayLink (UK))
      Nmap scan report for 192.168.2.211
      Host is up (0.014s latency).
      MAC Address: 50:D4:5C:9B:AA:1E (Unknown)
      Host is up.
      Nmap done: 256 IP addresses (18 hosts up) scanned in 7.34 seconds
        liv-in-sky @Oli last edited by
        @oli
        probiere mal ein blockly mit exec block - kopiere dort denn befehl und aktiviere das log bzw. den return wert z.b. https://forum.iobroker.net/post/761180 nutzt anderen befehl
        evtl kannst du einen syntax für den befehl finden, indem der befehl mit mac angezeigt wird - habe leider keine docker erfahrung
          @oli
          nebenbei
          bei mir war es wichtig, dass der root user die abfrage macht - sonst macht das linux netwerk device probleme
          • O
            @liv-in-sky
            Also mit folgendem Befehl bekomme ich die reduzierten Geräte ohne MAC
            Bei folgenden Befehl kommt gar nichts zurück
            sudo -u root /usr/bin/nmap -sPR --dns-servers 192.168.2.1 192.168.2.0/24
            Ich dachte eigentlich, dass man bei Docker immer mit 'root' unterwegs ist
              @oli
              hat docker einen root oder evtl einen admin user ?
              hast du die sueders datei im server angeglichen ?
              beispiel von mir:
                @oli
                wenn ich das lese, sieht es noicht so toll aus:
                https://stackoverflow.com/questions/71997736/docker-why-sudo-doesnt-work-as-expected
                  @oli
                  hier kam mal eine lösung https://forum.iobroker.net/post/600999 - fang ein wenig weiter oben an zu lesen - viel glück
                  • O
                    @liv-in-sky
                    Erstmal danke für deine Mühe, werde es mal testen
                      @oli
                      das problem findest du auch des öfteren bei einer google suche - ohne iobroker
                      "nmap root docker" suche
                      O 2 Replies Last reply Reply Quote 0
                      • O
                        @liv-in-sky
                        Ja, aber leider ohne Lösung
                        • O
                          @liv-in-sky
                          leider finde ich keine Lösung, dass es im Docker richtig läuft und gebe jetzt auf.
                          Kannst du mir sagen, wie ich NMAP wieder deinstallieren kann?
                            @oli leider nein - ich nutze kein docker und habe daher keine ahnung davon 😞
                            • O
                              @liv-in-sky
                              Wie ist den der Befehl unter Linux zum deinstallieren?
                                @oli
                                sudo apt purge nmap
                                https://www.howtogeek.com/229699/how-to-uninstall-software-using-the-command-line-in-linux/
                                • O
                                  @liv-in-sky
                                  Super, danke dir
                                  81.1k
                                  javascript template
                                  26
                                  493
                                  94461
