    4. BackItUp kein WOL an Buffalo NAS LinkStation
    • Glasfaser
      Glasfaser @ToK last edited by Glasfaser
      @tok
      ist natürlich richtig - laut DEBUGLog sendet BackItUp ????
      das ist kein Debug Log
      Stelle die Logstufe bei der Instanz auf DEBUG .
      Dann nochmal ... und das Ergebnis hier posten.
      EDIT:
        Thomas Braun Most Active @ToK last edited by
        @tok
        SMB V1 wird hoffentlich nicht mehr verwendet.
          ToK @Glasfaser last edited by Homoran
          @glasfaser
          Bitte von unten nach oben lesen:
          backitup.0
          2023-10-09 19:19:00.381	error	[iobroker] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backupsmount error(113): could not connect to 192.168.115.200Unable to find suitable address.
          backitup.0
          2023-10-09 19:19:00.381	error	[iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
          backitup.0
          2023-10-09 19:19:00.380	error	[iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
          backitup.0
          2023-10-09 19:19:00.380	error	[iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
          backitup.0
          2023-10-09 19:19:00.379	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
          backitup.0
          2023-10-09 19:18:54.244	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
          backitup.0
          2023-10-09 19:18:54.242	debug	[iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
          backitup.0
          2023-10-09 19:18:48.054	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
          backitup.0
          2023-10-09 19:18:48.054	debug	[iobroker/mount] noserverino option: false
          backitup.0
          2023-10-09 19:16:48.053	debug	Backup has started ...
          backitup.0
          2023-10-09 19:16:48.052	debug	[iobroker/mount] Wake on LAN wait 120 Seconds for NAS!
          Thomas Braun Glasfaser 3 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @ToK last edited by Thomas Braun
            @tok sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
            Schau in das 'richtige' Log:
            iob logs --watch
            Und poste den Text in CodeTags eingebettet.
            • Glasfaser
              @tok
              was davor ist , ist Interessant
              und jetzt Logstufe Silly
              • Glasfaser
                Kannst du von ioBroker aus die IP anpingen !?
                bzw.
                was du nicht geschrieben hast , funktioniert das normale Backup , also NAS dauer an und dann ein Backup ohne die Option WOL
                  ToK @Glasfaser last edited by ToK
                  @glasfaser
                  2023-10-09 19:14:52.022  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
                  2023-10-09 19:16:42.124  - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.115.1
                  2023-10-09 19:16:42.206  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
                  2023-10-09 19:16:48.044  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
                  2023-10-09 19:16:48.052  - debug: backitup.0 (94212) [iobroker/mount] Wake on LAN wait 120 Seconds for NAS!
                  2023-10-09 19:16:48.053  - debug: backitup.0 (94212) Backup has started ...
                  2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] noserverino option: false
                  2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
                  2023-10-09 19:18:54.242  - debug: backitup.0 (94212) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                  2023-10-09 19:18:54.244  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
                  2023-10-09 19:19:00.379  - error: backitup.0 (94212) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                  2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                  2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                  2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                  2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                  2023-10-09 19:19:18.000  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
                  die MAC Adresse sehe ich hier nicht
                    @glasfaser
                    wenn die NAS "schläft" kann ich sie nicht anpingen - wenn sie über "sudo /usr/sbin/etherwake -i eth0 <Mac Adresse>" läuft schon.
                    Das normale Backup funktioniert ohne WOL (bei laufender NAS) einwandfrei.
                      Homoran Global Moderator Administrators @ToK last edited by
                      wieso auch?
                      ich frage mich sowieso schon die ganze Zeit warum du dauernd die MAC Adresse ins Spiel bringst.
                        @homoran sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                        Weil das 'magic packet' an die MAC-Adresse gesendet wird, weil der Host ja schläft.
                        T Homoran 2 Replies Last reply Reply Quote 0
                          ToK @Thomas Braun last edited by
                          ja genau ....
                            @thomas-braun sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                            macht das nicht der Router?
                              ToK @Homoran last edited by
                              @homoran said in BackItUp kein WOL an Buffalo NAS LinkStation:
                              Als Router wird eine FritzBox 7590 verwendet
                              Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                                Keine Ahnung ob das noch relevant ist:
                                https://www.ip-phone-forum.de/threads/fritzbox-7490-wake-on-lan-über-udp-port-9-klappt-nicht-mehr.284397/
                                • Glasfaser
                                  @tok
                                  Kannst du das mal testen
                                  sudo -H -u iobroker /usr/sbin/etherwake -i eth0 <Mac Adresse>
                                  @Thomas-Braun
                                  Welche Rechte braucht dann
                                  Thomas Braun T 2 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active @Glasfaser last edited by
                                    @glasfaser sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                                    @Thomas-Braun
                                    Keine Ahnung, denn:
                                    echad@chet:/opt/iobroker $ type -p etherwake
                                      @glasfaser said in BackItUp kein WOL an Buffalo NAS LinkStation:
                                      @tok
                                      @Thomas-Braun
                                      • Glasfaser
                                        Glasfaser @Thomas Braun last edited by
                                        etherwake
                                        Das ist mit diesem NPM Paket !?
                                        https://github.com/simatec/ioBroker.backitup/issues/978
                                        flwilk created this issue in simatec/ioBroker.backitup
                                        closed WOL options configurable #978
                                          @glasfaser
                                          Wollte ich gerade schreiben. Das läuft nicht über das binairy, sondern über das node-Modul 'node-wol'. Und das ist schon Jahre nicht mehr angepackt worden.
                                            etherwake
                                            verwende seit soeben die Version 2.8.2 - die Konfig im BackItUp sind ident wie zuvor - ob das NPM Paket aktiv ist (sollte seit 2.8.0 so sein) kann ich nicht beurteilen - es funktioniert leider noch immer nicht.
                                            1876
