    4. BackItUp kein WOL an Buffalo NAS LinkStation
      ToK @Glasfaser last edited by Homoran
      @glasfaser
      Bitte von unten nach oben lesen:
      backitup.0
      2023-10-09 19:19:00.381	error	[iobroker] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backupsmount error(113): could not connect to 192.168.115.200Unable to find suitable address.
      backitup.0
      2023-10-09 19:19:00.381	error	[iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
      backitup.0
      2023-10-09 19:19:00.380	error	[iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
      backitup.0
      2023-10-09 19:19:00.380	error	[iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
      backitup.0
      2023-10-09 19:19:00.379	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
      backitup.0
      2023-10-09 19:18:54.244	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
      backitup.0
      2023-10-09 19:18:54.242	debug	[iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
      backitup.0
      2023-10-09 19:18:48.054	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
      backitup.0
      2023-10-09 19:18:48.054	debug	[iobroker/mount] noserverino option: false
      backitup.0
      2023-10-09 19:16:48.053	debug	Backup has started ...
      backitup.0
      2023-10-09 19:16:48.052	debug	[iobroker/mount] Wake on LAN wait 120 Seconds for NAS!
      Thomas Braun Glasfaser 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @ToK last edited by Thomas Braun
        @tok sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
        Schau in das 'richtige' Log:
        iob logs --watch
        Und poste den Text in CodeTags eingebettet.
        • Glasfaser
          Glasfaser @ToK last edited by
          @tok
          was davor ist , ist Interessant
          und jetzt Logstufe Silly
          • Glasfaser
            Glasfaser @ToK last edited by Glasfaser
            Kannst du von ioBroker aus die IP anpingen !?
            bzw.
            was du nicht geschrieben hast , funktioniert das normale Backup , also NAS dauer an und dann ein Backup ohne die Option WOL
              ToK @Glasfaser last edited by ToK
              @glasfaser
              2023-10-09 19:14:52.022  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
              2023-10-09 19:16:42.124  - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.115.1
              2023-10-09 19:16:42.206  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
              2023-10-09 19:16:48.044  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
              2023-10-09 19:16:48.052  - debug: backitup.0 (94212) [iobroker/mount] Wake on LAN wait 120 Seconds for NAS!
              2023-10-09 19:16:48.053  - debug: backitup.0 (94212) Backup has started ...
              2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] noserverino option: false
              2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
              2023-10-09 19:18:54.242  - debug: backitup.0 (94212) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
              2023-10-09 19:18:54.244  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
              2023-10-09 19:19:00.379  - error: backitup.0 (94212) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
              2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
              2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
              2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
              2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
              2023-10-09 19:19:18.000  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
              die MAC Adresse sehe ich hier nicht
                @glasfaser
                wenn die NAS "schläft" kann ich sie nicht anpingen - wenn sie über "sudo /usr/sbin/etherwake -i eth0 <Mac Adresse>" läuft schon.
                Das normale Backup funktioniert ohne WOL (bei laufender NAS) einwandfrei.
                  Homoran Global Moderator Administrators @ToK last edited by
                  wieso auch?
                  ich frage mich sowieso schon die ganze Zeit warum du dauernd die MAC Adresse ins Spiel bringst.
                    @homoran sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                    Weil das 'magic packet' an die MAC-Adresse gesendet wird, weil der Host ja schläft.
                    T Homoran 2 Replies Last reply Reply Quote 0
                      ToK @Thomas Braun last edited by
                      ja genau ....
                        @thomas-braun sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                        macht das nicht der Router?
                          ToK @Homoran last edited by
                          @homoran said in BackItUp kein WOL an Buffalo NAS LinkStation:
                          Als Router wird eine FritzBox 7590 verwendet
                          Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                            Keine Ahnung ob das noch relevant ist:
                            https://www.ip-phone-forum.de/threads/fritzbox-7490-wake-on-lan-über-udp-port-9-klappt-nicht-mehr.284397/
                            • Glasfaser
                              @tok
                              Kannst du das mal testen
                              sudo -H -u iobroker /usr/sbin/etherwake -i eth0 <Mac Adresse>
                              @Thomas-Braun
                              Welche Rechte braucht dann
                              Thomas Braun T 2 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @Glasfaser last edited by
                                @glasfaser sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                                @Thomas-Braun
                                Keine Ahnung, denn:
                                echad@chet:/opt/iobroker $ type -p etherwake
                                  @glasfaser said in BackItUp kein WOL an Buffalo NAS LinkStation:
                                  @tok
                                  @Thomas-Braun
                                  • Glasfaser
                                    Glasfaser @Thomas Braun last edited by
                                    etherwake
                                    Das ist mit diesem NPM Paket !?
                                    https://github.com/simatec/ioBroker.backitup/issues/978
                                    flwilk created this issue in simatec/ioBroker.backitup
                                    closed WOL options configurable #978
                                      @glasfaser
                                      Wollte ich gerade schreiben. Das läuft nicht über das binairy, sondern über das node-Modul 'node-wol'. Und das ist schon Jahre nicht mehr angepackt worden.
                                        etherwake
                                        verwende seit soeben die Version 2.8.2 - die Konfig im BackItUp sind ident wie zuvor - ob das NPM Paket aktiv ist (sollte seit 2.8.0 so sein) kann ich nicht beurteilen - es funktioniert leider noch immer nicht.
                                          kann da auch der arp-cache in die Suppe spucken?
                                            Nein, der ist IP-basiert.
                                            1888
