    4. Binding mehrere Werte vergleichen
    • N
      Nordischerjung @Stefan_NK last edited by
      @stefan_nk Ändert sich dann der Wert in OPENING oder so? Zeigt doch mal die Datenpunkte
      • N
        Nordischerjung @Stefan_NK last edited by Nordischerjung
        @stefan_nk Hier dieses Widget funktioniert bei mir
        [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"class":"","html":"{wert:ford.0.xxx.statususv4.vehiclestatus.doorStatus.driverDoor.value; wert1:ford.0.xxx.statususv4.vehiclestatus.doorStatus.hoodDoor.value; wert2:ford.0.xxx.statususv4.vehiclestatus.doorStatus.leftRearDoor.value; wert3:ford.0.xxx.statususv4.vehiclestatus.doorStatus.rightRearDoor.value; wert == \"Closed\" && wert1==\"Closed\" && wert2==\"Closed\" && wert3==\"Closed\"? \"zu\" : \"offen\"}","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"274px","top":"170px","width":"183px","height":"22px","z-index":"2","text-align":"center","color":"{wert:ford.0.xxx.statususv4.vehiclestatus.doorStatus.driverDoor.value; wert1:ford.0.xxx.statususv4.vehiclestatus.doorStatus.hoodDoor.value; wert2:ford.0.xxx.statususv4.vehiclestatus.doorStatus.leftRearDoor.value; wert3:ford.0.xxx.statususv4.vehiclestatus.doorStatus.rightRearDoor.value; wert == \"Closed\" && wert1==\"Closed\" && wert2==\"Closed\" && wert3==\"Closed\"?  \"#11c03a\" :: \"#fa2e33\"}","background-color":""},"widgetSet":"basic"}]
          Stefan_NK @Nordischerjung last edited by
          @nordischerjung
          Ich verstehe es nicht, wenn ich Die VIN durch xxx ersetzte wird offen engezeigt, wenn ich den richtigen Pfad mit der VIN nehme, wird der Code im HTML angezeigt
          [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"class":"","html":"{wert3:ford.0.xxx.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus03.value; wert4:ford.0.xxx.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus04.value; wert2:ford.0.xxx.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus02.value; wert1:ford.0.xxx.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus01.value; wert1==\"CLOSED\" && wert2==\"CLOSED\" && wert3==\"CLOSED\" && wert4==\"CLOSED\"?\"zu\":\"offen\"} ","g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"47px","top":"608px","width":"183px","height":"22px","z-index":"2"},"widgetSet":"basic"}]
          In den Datenpunten steht definitiv "CLOSED"
          N OliverIO 3 Replies Last reply Reply Quote 0
          • N
            @stefan_nk du musst schon deinen Datenpunkt nehmen. Am besten hier klicken und kopieren
            das ist dann dein kompletter Datenpunkt
            • N
              @stefan_nk So muss das mit deinem Datenpunkt funktionieren,
              Wenn meiner da überall drin steht, geht das bei mir
              [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"class":"","html":"{wert:ford.0.WF0TK1E75NMA50668.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus01.value; wert1:ford.0.WF0TK1E75NMA50668.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus02.value; wert2:ford.0.WF0TK1E75NMA50668.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus03.value; wert3:ford.0.WF0TK1E75NMA50668.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus04.value; wert == \"CLOSED\" && wert1==\"CLOSED\" && wert2==\"CLOSED\" && wert3==\"CLOSED\"? \"zu\" : \"offen\"}","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"274px","top":"170px","width":"183px","height":"22px","z-index":"2","text-align":"center","color":"{wert:ford.0.WF0TK1E75NMA50668.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus01.value; wert1:ford.0.WF0TK1E75NMA50668.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus02.value; wert2:ford.0.WF0TK1E75NMA50668.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus03.value; wert3:ford.0.WF0TK1E75NMA50668.statusQuery.events.doorEvent.conditions.doorStatusChanged.doorStatus04.value; wert == \"CLOSED\" && wert1==\"CLOSED\" && wert2==\"CLOSED\" && wert3==\"CLOSED\"? \"#11c03a\" :: \"#fa2e33\"}","background-color":""},"widgetSet":"basic"}]
                Stefan_NK @Nordischerjung last edited by Stefan_NK
                @nordischerjung
                äh... ich bin über jede Hilfe dankbar aber dumm bin ich auch nicht (übersehen kann man immer was....)
                Du wolltest die Datenpunkte von mir sehen und wenn du im ersten Post mein Script anschaust dann siehst du, dass ich die Datenpunkte abfrage.
                Die einzelnen Türen lassen sich auch abfragen, aber nicht alle 4 in einem Script
                • N
                  @stefan_nk wenn du das letzte Widget importierst muss es so funktionieren. Mit meinen DPs geht es genau so.
                    @nordischerjung
                    Vielen Dank, das funktioniert 👍
                    Nur für's Verständnis:
                    Inhaltlich war es der geleiche Code, wie ich ihn gehabt habe (die wert-Nummerierung muss ja egal sein), nur habe ich Leerzeichen gehabt, wo du keine hast.
                    1. Zeile von mir
                    2. Zeile von dir.
                    wert == "CLOSED" && wert1=="CLOSED" && wert2=="CLOSED" && wert3=="CLOSED"? "zu" : "offen"}
                    wert1=="CLOSED" && wert2=="CLOSED" && wert3=="CLOSED" && wert4=="CLOSED"?"zu":"offen"}
                    kann das damit zusammen hängen?
                    • OliverIO
                      OliverIO @Stefan_NK last edited by
                      @stefan_nk said in Binding mehrere Werte vergleichen:
                      wenn der datenpunkt bestimmte zeichen enthält, wird er vom scanner nicht als datenpunkt erkannt. eine # war auf jeden fall dabei. das macht bei anderen geräten auch immer probleme.
                      dann muss man mit einem alias arbeiten
                        Stefan_NK @Stefan_NK last edited by
                        @OliverIO Naja, Sonderzeichen waren ja in der VIN nicht dabei und es funktioniert ja jetzt auch.
                        Aber egal - Hauptsache es tut wie es soll 🙂
                        Vielen Dank!
                        688
