    4. iob node fix - Skript
      Thomas Braun Most Active @JoJo58 last edited by
      @jojo58
      Okay.
      Lad das Skript jetzt nochmal frisch runter.
      JoJo58 1 Reply Last reply Reply Quote 0
      • JoJo58
        JoJo58 @Thomas Braun last edited by
        @thomas-braun Das sieht schon besser aus. Wie soll ich weitermachen?
        ioBroker nodejs fixer 2023-10-07
        Recommended nodejs-version is: 18.18.0
        Checking your installation now. Please be patient!
        Your current setup is:
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        We found these nodejs versions available for installation:
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                100 /var/lib/dpkg/status
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
        Nothing to do - Your installation is using the correct paths.
        You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
        Press <y> to continue or any other key to quit
        Trying to fix your installation now. Please be patient.
        find: '/run/user/1000/gvfs': Permission denied
        Virtualization: kvm
        Waiting for ioBroker to shut down - Give me a minute...
        *** These repos are active on your system:
        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://repos.influxdata.com/debian stable InRelease
        Reading package lists... Done
        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
        Package: nodejs
        Pin: origin deb.nodesource.com
        Pin-Priority: 1001
        *** These repos are active after the adjustments:
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
        Get:6 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5247 B]
        Fetched 17.4 kB in 0s (40.2 kB/s)
        Installing the recommended nodejs version now!
        Installing the recommended nodejs version!
        (Reading database ... 100420 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
        Detected old npm client, removing...
        Unpacking nodejs (18.18.0-1nodesource1) over (18.17.1-deb-1nodesource1) ...
        Setting up nodejs (18.18.0-1nodesource1) ...
        Processing triggers for man-db (2.11.2-2) ...
        *** You need to manually restart your container/virtual machine now! ***
        We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
        smarthome@vm-iobroker:~$
          @jojo58 sagte in iob node fix - Skript:
          VM/Container neustarten. Und dann nochmal das Skript. Sollte dann mit doppeltem 'Nothing to do' verkünden, das alles i. O. ist.
          • JoJo58
            @thomas-braun Super, hat jetzt funktioniert. Danke dir. 👍
            /usr/bin/nodejs         v18.18.0
            /usr/bin/node           v18.18.0
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            /usr/bin/corepack       0.19.0
            nodejs:
             Installed: 18.18.0-1nodesource1
             Candidate: 18.18.0-1nodesource1
             Version table:
            *** 18.18.0-1nodesource1 1001
                   500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                18.17.1-1nodesource1 1001
                18.17.0-1nodesource1 1001
                18.16.1-1nodesource1 1001
                18.16.0-1nodesource1 1001
                18.15.0-1nodesource1 1001
                18.14.2-1nodesource1 1001
                18.14.1-1nodesource1 1001
                18.14.0-1nodesource1 1001
                18.13.0+dfsg1-1 500
                18.13.0-1nodesource1 1001
                18.12.0-1nodesource1 1001
                18.11.0-1nodesource1 1001
                18.10.0-1nodesource1 1001
                18.9.1-1nodesource1 1001
                18.9.0-1nodesource1 1001
                18.8.0-1nodesource1 1001
                18.7.0-1nodesource1 1001
                18.6.0-1nodesource1 1001
                18.5.0-1nodesource1 1001
                18.4.0-1nodesource1 1001
                18.3.0-1nodesource1 1001
                18.2.0-1nodesource1 1001
                18.1.0-1nodesource1 1001
                18.0.0-1nodesource1 1001
            Nothing to do - Your version is the recommended one.
            You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
            Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
            Jetzt kann ich mich meinem JavaScript Adapter Problem zuwenden.
              @jojo58
              Okay. Danke für die Hilfe beim Debuggen.
              Allerdings auch hier nochmal der Hinweise bzw. die dringende Empfehlung:
              Server NIE mit Desktop/graphischer Oberfläche betreiben!
              Da rumpelt nämlich ein gnome oder etwas davon abgeleitetes mit über dein System. Komplett unnötig. Und vermutlich mit der Auslöser für das Verhalten des Skripts.
              • JoJo58
                @thomas-braun Die grafische Oberfläche habe ich doch schon vor 4 Wochen runtergeschmissen? Wahrscheinlich hat das nicht sauber geklappt. Mist aber auch...
                  runtergeschmissen?
                  Komplett runtergeschmissen oder lediglich deaktiviert?
                  • JoJo58
                    @thomas-braun Komplett runtergeschmissen. Hoffe das war richtig so:
                    sudo apt-get autoremove gdm3
                    und
                    sudo apt-get autoremove --purge gnome*
                      Das weiß ich nicht. Kenne dein System ja nicht.
                      • U
                        UV-on-fire last edited by
                        Ich habe am Sonntag mit dem Script auf V18.18.0 upgedatet. Hat auch alles geklappt. Allerdings besteht da ja das Problem das Backitup nicht sauber läuft.
                        Siehe Hier
                        Jetzt wollte ich eben auf 18.18.1 updaten aber das funktioniert nicht. Ausgabe des Skripts:
                         You are running nodejs v18.18.0. Do you want to install recommended version 18.18.1?
                        [sudo] password for uviob:
                        Sorry, try again.
                        Virtualization: lxc
                        Hit:1 http://security.debian.org bullseye-security InRelease
                        Hit:2 http://ftp.debian.org/debian bullseye InRelease
                        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                        Package: nodejs
                        Pin-Priority: 1001
                        Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                        Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5540 B]
                        Err:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                          File has unexpected size (5247 != 5540). Mirror sync in progress? [IP: 2606:4700:10::6816:41a 443]
                          Hashes of expected file:
                           - Filesize:5540 [weak]
                           - SHA512:42fc03dd54ad0876c94818799e4c58fe6b1f55a39d99237e22eea4b127f782f1b893ed734c5d80c1c7fec87e88ece4373920aaa4792d1f25b28b398c093fd63c
                           - SHA256:38b78587e1a99e9c1b861ea8dd3a29e192dfae63e108aafd17b7f60bd6acd23f
                           - SHA1:d31595d3ddf7337cec92847e9ed8551f4addc693 [weak]
                           - MD5Sum:d69fd7a6e53a348af97ca66bf65317bf [weak]
                          Release file created at: Tue, 10 Oct 2023 17:30:21 +0000
                        Fetched 12.1 kB in 1s (22.5 kB/s)
                        E: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/main/binary-amd64/Packages.bz2  File has unexpected size (5247 != 5540). Mirror sync in progress? [IP: 2606:4700:10::6816:41a 443]
                        E: Some index files failed to download. They have been ignored, or old ones used instead.
                        Hier noch die Ausgabe von Diag
                        Lang:
                        Skript v.2023-06-20
                        *** BASE SYSTEM ***
                           Static hostname: iobroker
                                 Icon name: computer-container
                                   Chassis: container
                                Machine ID: c337b259b2a44b9da1e2356e14b395e6
                                   Boot ID: 9fcb0b446bb94c388a463a906e17bdf2
                            Virtualization: lxc
                          Operating System: Debian GNU/Linux 11 (bullseye)
                                    Kernel: Linux 6.2.16-14-pve
                              Architecture: x86-64
                        model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                        Docker          : false
                        Virtualization  : lxc
                        Kernel          : x86_64
                        Userland        : amd64
                        Systemuptime and Load:
                         19:49:54 up 0 min,  1 user,  load average: 1.05, 0.62, 0.74
                        CPU threads: 1
                        *** Time and Time Zones ***
                                       Local time: Tue 2023-10-10 19:49:54 CEST
                                   Universal time: Tue 2023-10-10 17:49:54 UTC
                                         RTC time: n/a
                                      NTP service: inactive
                                  RTC in local TZ: no
                        *** User and Groups ***
                        uviob
                        /home/uviob
                        uviob sudo iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Mem:            4.1G        1.3G        2.6G        0.0K        222M        2.8G
                        Swap:           512M          0B        512M
                        Total:          4.6G        1.3G        3.1G
                                 4096 M total memory
                                 1288 M used memory
                                   62 M active memory
                                 1385 M inactive memory
                                 2584 M free memory
                                    0 M buffer memory
                                  222 M swap cache
                                  512 M total swap
                                    0 M used swap
                                  512 M free swap
                        *** FILESYSTEM ***
                        Filesystem                       Type   Size  Used Avail Use% Mounted on
                        /dev/mapper/pve-vm--210--disk--1 ext4   9.8G  7.1G  2.2G  77% /
                        none                             tmpfs  492K  4.0K  488K   1% /dev
                        tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
                        tmpfs                            tmpfs  3.1G  104K  3.1G   1% /run
                        tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                        [Tue Oct  3 12:06:53 2023] EXT4-fs (dm-1): mounted filesystem 1192067b-46b8-4ac5-a608-5f91cdfb985a with ordered data mode. Quota mode: none.
                        [Tue Oct  3 12:06:53 2023] EXT4-fs (dm-1): re-mounted 1192067b-46b8-4ac5-a608-5f91cdfb985a. Quota mode: none.
                        [Tue Oct  3 12:06:55 2023] EXT4-fs (sda): mounted filesystem 52b7d67a-b075-47cb-8f0d-78dafd5f3aa1 with ordered data mode. Quota mode: none.
                        [Tue Oct  3 12:07:08 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                        [Tue Oct  3 12:07:29 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                        [Tue Oct  3 12:07:29 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                        [Tue Oct  3 12:07:30 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                        [Tue Oct  3 12:07:30 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                        [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                        [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                        [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                        [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                        [Tue Oct  3 13:23:08 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                        [Tue Oct  3 13:23:21 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                        [Tue Oct  3 13:28:39 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                        [Tue Oct  3 13:28:39 2023] EXT4-fs (dm-10): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 without journal. Quota mode: none.
                        [Tue Oct  3 13:32:47 2023] EXT4-fs (dm-10): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                        [Tue Oct  3 13:32:48 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                        [Tue Oct  3 13:33:04 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                        [Mon Oct  9 03:05:42 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                        [Mon Oct  9 03:05:55 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                        [Mon Oct  9 03:11:33 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                        [Mon Oct  9 03:11:33 2023] EXT4-fs (dm-10): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 without journal. Quota mode: none.
                        [Mon Oct  9 03:15:42 2023] EXT4-fs (dm-10): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                        [Mon Oct  9 03:15:42 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                        [Mon Oct  9 03:15:59 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                        [Tue Oct 10 19:31:24 2023] EXT4-fs (dm-8): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                        [Tue Oct 10 19:31:25 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                        [Tue Oct 10 19:38:50 2023] EXT4-fs (dm-8): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                        [Tue Oct 10 19:39:03 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                        [Tue Oct 10 19:48:54 2023] EXT4-fs (dm-8): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                        [Tue Oct 10 19:48:55 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                        Show mounted filesystems (real ones only):
                        TARGET SOURCE                           FSTYPE OPTIONS
                        /      /dev/mapper/pve-vm--210--disk--1 ext4   rw,relatime,stripe=16
                        /var:
                        919M    /var/
                        402M    /var/log
                        401M    /var/log/journal/c337b259b2a44b9da1e2356e14b395e6
                        376M    /var/cache
                        Archived and active journals take up 96.0M in the file system.
                        /opt/iobroker/backups:
                        69M     /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        563M    /opt/iobroker/iobroker-data/
                        454M    /opt/iobroker/iobroker-data/files
                        80M     /opt/iobroker/iobroker-data/files/vis
                        80M     /opt/iobroker/iobroker-data/backup-objects
                        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.eafddf6f.js.map
                        21M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.22196004.js.map
                        20M     /opt/iobroker/iobroker-data/objects.jsonl
                        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                        11M     /opt/iobroker/iobroker-data/states.jsonl
                        *** NodeJS-Installation ***
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Version table:
                             12.22.12~dfsg-1~deb11u4 500
                                500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                                500 http://security.debian.org bullseye-security/main amd64 Packages
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        No configuration change needed.
                        Multihost discovery server: disabled
                        Discovery authentication:   enabled
                        Persistent activation:      disabled
                        Objects:                    jsonl on 127.0.0.1
                        States:                     jsonl on 127.0.0.1
                        Core adapters versions
                        js-controller:  5.0.13
                        admin:          6.10.5
                        javascript:     7.1.5
                        Adapters from github:   0
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.213, run as: admin
                          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                          system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                          system.adapter.bmw.0                    : bmw                   : iobroker                                 - disabled
                          system.adapter.cameras.0                : cameras               : iobroker                                 - disabled, port: 8200, bind: 127.0.0.1
                          system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                          system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                          system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                          system.adapter.fitbit-fitness.0         : fitbit-fitness        : iobroker                                 -  enabled
                          system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                          system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                          system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
                        + system.adapter.history.0                : history               : iobroker                                 -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                        + system.adapter.hm-rpc.4                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                          system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
                          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
                          system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                          system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                          system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                          system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                          system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.213
                          system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                        + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                          system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                          system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 -  enabled
                          system.adapter.tahoma.0                 : tahoma                : iobroker                                 -  enabled
                        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                          system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                          system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                          system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                          system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
                          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                          system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                          system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
                          system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Stable (default): http://download.iobroker.net/sources-dist.json
                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                        Active repo(s): Beta (latest)
                        Installed ioBroker-Instances
                        Used repository: Beta (latest)
                        Adapter    "admin"        : 6.10.5   , installed 6.10.5
                        Adapter    "backitup"     : 2.8.3    , installed 2.8.3
                        Adapter    "bmw"          : 2.6.2    , installed 2.6.2
                        Adapter    "cameras"      : 1.3.0    , installed 1.3.0
                        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                        Adapter    "fitbit-fitness": 0.4.11  , installed 0.4.11
                        Adapter    "fritzdect"    : 2.4.1    , installed 2.4.1
                        Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                        Adapter    "history"      : 3.0.0    , installed 3.0.0
                        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                        Adapter    "javascript"   : 7.1.5    , installed 7.1.5
                        Controller "js-controller": 5.0.13   , installed 5.0.13
                        Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                        Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                        Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                        Adapter    "proxmox"      : 2.1.0    , installed 2.1.0
                        Adapter    "socketio"     : 6.5.7    , installed 6.5.7
                        Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                        Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                        Adapter    "telegram"     : 2.0.0    , installed 2.0.0
                        Adapter    "text2command" : 3.0.2    , installed 3.0.2
                        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                        Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
                        Adapter    "vis"          : 1.4.16   , installed 1.4.16
                        Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
                        Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                        Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
                        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                        Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                        Adapter    "web"          : 6.1.4    , installed 6.1.4
                        Adapter    "wled"         : 0.7.1    , installed 0.7.1
                        Adapter    "ws"           : 2.5.7    , installed 2.5.7
                        Objects and States
                        Objects:        19069
                        States:         17076
                        E: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/main/binary-amd64/Packages.bz2  File has unexpected size (5247 != 5540). Mirror sync in progress? [IP: 2606:4700:10::6816:51a 443]
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        23619139   103/systemd-resolve
                        tcp        0      0 192.168.178.213:8701    0.0.0.0:*               LISTEN      1001       23620337   471/io.hm-rpc.4
                        tcp        0      0 192.168.178.213:9292    0.0.0.0:*               LISTEN      1001       23620124   434/io.hm-rpc.1
                        tcp        0      0 192.168.178.213:2010    0.0.0.0:*               LISTEN      1001       23620183   449/io.hm-rpc.2
                        tcp        0      0 192.168.178.213:2001    0.0.0.0:*               LISTEN      1001       23620043   409/io.hm-rpc.0
                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        23619146   103/systemd-resolve
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          23618692   1/init
                        tcp        0      0 192.168.178.213:8081    0.0.0.0:*               LISTEN      1001       23619680   307/io.admin.0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23619215   118/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23619280   118/iobroker.js-con
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          23619401   302/master
                        tcp6       0      0 :::5355                 :::*                    LISTEN      104        23619142   103/systemd-resolve
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          23619402   302/master
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          23618700   1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          23619008   1/init
                        udp        0      0 192.168.178.213:5353    0.0.0.0:*                           1001       23623327   937/io.tr-064.0
                        udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        23619138   103/systemd-resolve
                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        23619145   103/systemd-resolve
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          23618695   1/init
                        udp6       0      0 :::5355                 :::*                                104        23619141   103/systemd-resolve
                        udp6       0      0 :::111                  :::*                                0          23618705   1/init
                        2023-10-10 19:50:10.452  - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                        2023-10-10 19:50:11.595  - info: netatmo.0 (772) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v18.18.0, js-controller: 5.0.13
                        2023-10-10 19:50:11.622  - info: netatmo.0 (772) Using stored tokens to initialize ... {"access_token":"5d0fe99722ab74000d32a982|ebceb12208f5b85bfcf8ae32b0258629","refresh_token":"5d0fe99722ab74000d32a982|46128978a77b62a4c13e6bf878f065da","scope":"read_station","client_id":"60156be20bbeae26d976880d"}
                        2023-10-10 19:50:11.623  - info: netatmo.0 (772) Authenticating with Netatmo using individual client-ID 60156be20bbeae26d976880d
                        2023-10-10 19:50:11.985  - info: netatmo.0 (772) Successfully authenticated with Netatmo with individual client-ID 60156be20bbeae26d976880d
                        2023-10-10 19:50:13.803  - info: host.iobroker instance system.adapter.ping.0 started with pid 833
                        2023-10-10 19:50:15.528  - info: ping.0 (833) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.ping, node: v18.18.0, js-controller: 5.0.13
                        2023-10-10 19:50:15.895  - info: ical.2 (728) Terminated (NO_ERROR): Without reason
                        2023-10-10 19:50:16.472  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
                        2023-10-10 19:50:17.806  - info: host.iobroker instance system.adapter.tahoma.0 started with pid 906
                        2023-10-10 19:50:19.137  - info: tahoma.0 (906) starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.tahoma, node: v18.18.0, js-controller: 5.0.13
                        2023-10-10 19:50:19.152  - info: tahoma.0 (906) [START] Starting adapter tahoma v0.10.2.3
                        2023-10-10 19:50:19.152  - info: tahoma.0 (906) Configured polling interval: 20000
                        2023-10-10 19:50:21.298  - info: tahoma.0 (906) eventRegisterID = 1ab61062-0a19-0481-73a9-10cb0635bd01
                        2023-10-10 19:50:21.737  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 937
                        2023-10-10 19:50:23.041  - info: tr-064.0 (937) starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.18.0, js-controller: 5.0.13
                        2023-10-10 19:50:25.717  - info: host.iobroker instance scheduled system.adapter.openweathermap.0 37 * * * *
                        2023-10-10 19:50:25.739  - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 972
                        2023-10-10 19:50:26.975  - info: openweathermap.0 (972) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.18.0, js-controller: 5.0.13
                        2023-10-10 19:50:29.900  - info: host.iobroker instance scheduled system.adapter.tvspielfilm.0 */5 * * * *
                        2023-10-10 19:50:29.933  - info: host.iobroker instance system.adapter.tvspielfilm.0 started with pid 1016
                        2023-10-10 19:50:31.735  - info: tvspielfilm.0 (1016) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.13
                        2023-10-10 19:50:33.806  - info: host.iobroker instance system.adapter.mqtt.0 started with pid 1317
                        2023-10-10 19:50:33.810  - info: tvspielfilm.0 (1016) objects written
                        2023-10-10 19:50:35.323  - info: mqtt.0 (1317) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v18.18.0, js-controller: 5.0.13
                        Und kurz
                        Copy text starting here:
                                             v.2023-06-20
                                   Chassis: container
                            Virtualization: lxc
                        Installation:           lxc
                        Kernel:                 x86_64
                        Userland:               amd64
                        Timezone:               Europe/Berlin (CEST, +0200)
                        User-ID:                1000
                        X-Server:               false
                        Boot Target:            graphical.target
                        Pending OS-Updates:     0
                        Pending iob updates:    0
                        Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                                                /usr/bin/npm            9.8.1
                                                /usr/bin/npx            9.8.1
                        Recommended versions are nodejs 18.x.y and npm 9.x.y
                        MEMORY:
                        Mem:            4.1G        2.1G        1.4G        0.0K        578M        1.9G
                        Swap:           512M          0B        512M
                        Total:          4.6G        2.1G        1.9G
                        Active iob-Instances:   31
                        ioBroker Core:          js-controller           5.0.13
                                                admin                   6.10.5
                        Objects type: jsonl
                        States  type: jsonl
                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        Objects:                19069
                        States:                 17076
                        Size of iob-Database:
                        21M     /opt/iobroker/iobroker-data/objects.jsonl
                        13M     /opt/iobroker/iobroker-data/states.jsonl
                        === Mark text until here for copying ===
                        Jemand ne Idee worans harpert?
                          Thomas Braun Most Active @UV-on-fire last edited by
                          @uv-on-fire sagte in iob node fix - Skript:
                          Ja, der 'Mirror sync' läuft gerade.
                          Und noch so als Hinweis: Wenn die Quelle einmal richtig auf das richtige Repo inkl. nodejs@18 umgestellt wurde braucht man das Skript / den 'iob node-upgrade' nicht mehr, das läuft dann über das übliche
                          sudo apt update
                          ganz normal mit. Das Skript ist nur für die einmalige Umstellung gedacht, nicht für 0815-Updates.
                          • U
                            UV-on-fire @Thomas Braun last edited by
                            Super, danke.
                            Und danke für den Hinweis. 👍
                              apollon77 last edited by
                              Sooo... Danke für Alle die Hier unterstützt haben und mit getestet haben! Das Skript ist nun offizieller Bestandhteil vom iobroker CLI Kommando.
                              Daher ... weiter unter https://forum.iobroker.net/topic/69067/neuer-befehl-iob-nodejs-update
                              198
                              37761
