    4. TESTER gesucht / Backup auf Fritz.nas - node 18.18.0
      fastfoot @Thomas Braun last edited by
      @thomas-braun magst du mal die V3 testen, arbeitet mit pipeline() anstatt pipe()
      simatec Thomas Braun 2 Replies Last reply Reply Quote 0
      • simatec
        simatec Developer Most Active @fastfoot last edited by simatec
        @fastfoot Soweit ich das sehe, hat es am Ende damit aber nichts weiter zu tun. Weder js-controller noch pipe stehen da mit im Zusammenhang. Es ist ein Bug in node mit der aktuellen libuv
          Thomas Braun Most Active @fastfoot last edited by
          @fastfoot
          V3:
          umount not possible
          //fritz.box/fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet mounted into /opt/iobroker/backups
          file test_pipeline_compressed_tar.tar.gz created
          file test_pipeline_compressed_tar.tar.gz done
          number of files in test_pipeline_compressed_tar.tar.gz: 0
          file test_pipeline_compressed_zlib.tar.gz created
          file test_pipeline_compressed_zlib.tar.gz done
          number of files in test_pipeline_compressed_zlib.tar.gz: 0
          file test_pipeline_uncompressed.tar created
          file test_pipeline_uncompressed.tar done
          number of files in test_pipeline_uncompressed.tar: 0
          listing of created files in /opt/iobroker/backups
          -rwxrwxrwx 1 root root 252416 Oct  8 23:06 /opt/iobroker/backups/test_pipeline_uncompressed.tar
          -rwxrwxrwx 1 root root  16384 Oct  8 23:06 /opt/iobroker/backups/test_pipeline_compressed_zlib.tar.gz
          -rwxrwxrwx 1 root root  16384 Oct  8 23:06 /opt/iobroker/backups/test_pipeline_compressed_tar.tar.gz
          -rwxrwxrwx 1 root root 154384 Oct  4 22:42 /opt/iobroker/backups/test_alternative.tar.gz
          -rwxrwxrwx 1 root root 252928 Oct  4 22:42 /opt/iobroker/backups/test_nocompression.tar
          -rwxrwxrwx 1 root root  16384 Oct  4 22:42 /opt/iobroker/backups/test_standard.tar.gz
            fastfoot @Thomas Braun last edited by fastfoot
            @thomas-braun ach sch.... warten auf den node-fix 😞
              @fastfoot
              nodejs 18.18.1 ist für Dienstag geplant. Ich bin gespannt.
                @thomas-braun sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                @fastfoot
                Hau rein!
                  @fastfoot
                  Schon passiert.
                  Mit der 18.18.1 funktioniert das Backup wieder.
                  U F 2 Replies Last reply Reply Quote 2
                  • U
                    UV-on-fire @Thomas Braun last edited by
                    @thomas-braun Wollt ich auch gerade schreiben. Alles schick mit 18.18.1 CCU, javascript,iobroker passt👍
                      @thomas-braun bleibt node20, angeblich wurde das issue dort ja schon mit der 20.6 oder 20.7 gefixt. Oder hab ich das falsch gelesen?
                      Thomas Braun simatec 3 Replies Last reply Reply Quote 0
                        @fastfoot sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                        Da bin ich nicht ganz sicher, wie das bei nodejs.org gemeint ist. Jedenfalls hab ich das Verhalten unter 20.8.0 noch.
                          Thomas Braun Most Active @fastfoot last edited by Thomas Braun
                          @fastfoot
                          Dein Testskript V3 liefert jetzt auch:
                          umount not possible
                          number of files in test_pipeline_compressed_tar.tar.gz: 115
                          number of files in test_pipeline_compressed_zlib.tar.gz: 115
                          number of files in test_pipeline_uncompressed.tar: 115
                          -rwxrwxrwx 1 root root 821248 Oct 10 21:31 /opt/iobroker/backups/test_pipeline_uncompressed.tar
                          -rwxrwxrwx 1 root root 154692 Oct 10 21:31 /opt/iobroker/backups/test_pipeline_compressed_zlib.tar.gz
                          -rwxrwxrwx 1 root root 154692 Oct 10 21:31 /opt/iobroker/backups/test_pipeline_compressed_tar.tar.gz
                          • simatec
                            Node 20 steht noch aus... Das Issue wurde um das Label Node 20.x erweitert...
                            Also wer CIFS nutzt, sollte erstmal auf der 18 bleiben...
                              fastfoot @simatec last edited by
                              @simatec habe im geschlossenen issue nachgefragt, aus der Beschreibung des fix geht hervor dass er mit der 20.7.0 dort schon drin ist. Evtl. machen sie deinen issue ja wieder auf falls dem wirklich so wäre
                                @fastfoot
                                Also 20.8.0 funktioniert nicht:
                                /opt/iobroker/backups unmounted
                                -rwxrwxrwx 1 root root 252416 Oct 10 22:06 /opt/iobroker/backups/test_pipeline_uncompressed.tar
                                -rwxrwxrwx 1 root root  16384 Oct 10 22:06 /opt/iobroker/backups/test_pipeline_compressed_zlib.tar.gz
                                -rwxrwxrwx 1 root root  16384 Oct 10 22:06 /opt/iobroker/backups/test_pipeline_compressed_tar.tar.gz
                                  haben schon im issue reagiert und darauf hingewiesen. Aber gut dass es mit der LTS jetzt funktioniert
                                    Ja, das ist das wichtigste. Aber auch die nodejs@20 wird ja irgendwann LTS...
                                    Aber gut, dass ich dem lieben @simatec jetzt nicht mehr weiter mit meinen obskuren Issues gegen den Backitup-Adapter auf den Wecker fallen muss. 🙂
                                    • simatec
                                      simatec Developer Most Active @Thomas Braun last edited by
                                        @thomas-braun habe deinen Kommentar auf Github gelesen, kannst du das Skript mal genau so starten falls die env anders gesetzt wurde: UV_USE_IO_URING=0 node cifs.js
                                          Ja, so funktioniert es:
                                          echad@chet:/opt/iobroker $ UV_USE_IO_URING=0 node cifs.js
                                          Copy output from below
                                          umount not possible
                                          -rwxrwxrwx 1 root root 821248 Oct 12 19:26 /opt/iobroker/backups/test_pipeline_uncompressed.tar
                                          -rwxrwxrwx 1 root root 154691 Oct 12 19:26 /opt/iobroker/backups/test_pipeline_compressed_zlib.tar.gz
                                          -rwxrwxrwx 1 root root 154691 Oct 12 19:26 /opt/iobroker/backups/test_pipeline_compressed_tar.tar.gz
                                          End of output to copy
                                          echad@chet:/opt/iobroker $ UV_USE_IO_URING=1 node cifs.js
                                          -rwxrwxrwx 1 root root 253440 Oct 12 19:26 /opt/iobroker/backups/test_pipeline_uncompressed.tar
                                          -rwxrwxrwx 1 root root  16384 Oct 12 19:26 /opt/iobroker/backups/test_pipeline_compressed_zlib.tar.gz
                                          -rwxrwxrwx 1 root root  16384 Oct 12 19:26 /opt/iobroker/backups/test_pipeline_compressed_tar.tar.gz
                                            wie hattest du die denn vorher gesetzt? Ich hatte sowas Ähnliches mal in VS-Code, da wurde das environment beim Start überschrieben, etwas Ähnliches vermute ich hier auch
                                            F Thomas Braun 2 Replies Last reply Reply Quote 0
                                            204
                                            28221
