    4. MQTT ack=false forcieren?
      Highpressure last edited by
      Hi zusammen
      Ich habe aktuell den MQTT adapter in version 4.1.1 auf meiner QNAP basierenden ioBroker instanz laufen.
      Der Adapter verbindet sich als Client/Subscriber via IP zu meinem SolarAssistant MQTT Server um die Wechselrichter und Batteriewerte zu subscriben
      das Funktioniert soweit auch:
      mqtt-packet:writeToStream generate called +7ms
      mqtt-packet:writeToStream generate: packet.cmd: publish +0ms
      mqtt-packet:writeToStream publish: packet: { cmd: 'publish', topic: 'PVGrid/battery_1/state_of_charge/state', payload: '46', qos: 0, retain: false, messageId: 0, dup: false } +0ms
      mqtt-packet:writeToStream writeVarByteInt: writing to stream: <Buffer 2a> +0ms
      mqtt-packet:writeToStream writeNumberCached: number: 38 +1ms
      mqtt-packet:writeToStream writeNumberCached: <Buffer 00 26> +0ms
      mqtt-packet:writeToStream publish: payload: '46' +0ms
      2023-10-11 12:20:38.128 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.inverter_2.ac_output_voltage.state: {"val":229,"ack":true,"ts":1697019638104,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019638104}
      2023-10-11 12:20:38.129 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.inverter_2.load_power.state: {"val":1396,"ack":true,"ts":1697019638104,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019638104}
      2023-10-11 12:20:38.129 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.battery_1.power.state: {"val":1078,"ack":true,"ts":1697019638104,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019638104}
      2023-10-11 12:20:38.130 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.battery_1.state_of_charge.state: {"val":46,"ack":true,"ts":1697019638104,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019494681}
      2023-10-11 12:20:38.131 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.battery_1.voltage.state: {"val":53.9,"ack":true,"ts":1697019638104,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019638104}
      2023-10-11 12:20:38.132 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.total.battery_power.state: {"val":1078,"ack":true,"ts":1697019638112,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019638112}
      2023-10-11 12:20:38.132 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.total.load_percentage.state: {"val":26,"ack":true,"ts":1697019638112,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019604919}
      Mein Problem ist allerdings das ack:true welches ich abstellen muss, da mein Go-E Adapter damit nicht umgehen kann.
      Die MQTT Einstellungen habe ich soweit alle standard gelassen.
      Sprich "Nur bei Änderungen publizieren" und "Eigene States beim Verbinden publizieren" ist gewählt.
      Wie bekomme ich es hin das ack:false ist?
      Auf der SolarAssistant Seite gibt es nichts einzustellen, was den wert ändert.
      Vielen lieben Dank!
      arteck haus-automatisierung 2 Replies Last reply Reply Quote 0
        arteck Developer Most Active @Highpressure last edited by
        @highpressure sagte in MQTT ack=false forcieren?:
        verstehe ich nicht ??
        • haus-automatisierung
          haus-automatisierung Developer Most Active @Highpressure last edited by
          Das wird ja auch nicht von der anderen Seite per MQTT mitgesendet, sondern so wird der State vom MQTT-Adapter geschrieben. Und da der Wert von extern so reinkam, ist er logischerweise auch bestätigt.
          Was genau ist denn die Problemstellung?
            Highpressure @arteck last edited by
            ich muss ack=false - warum auch immer - dem go-e bereitstellen, da der - warum auch immer - nicht damit umgehen kann.
            Ich hatte eigentlich nicht vor den erst in history oder sonst wo nochmals unnötig zu schreiben.
            Gibt es da keinen anderen Weg?
              @highpressure Wie hast Du denn MQTT und den anderen Adapter miteinander verknüpft?
                Highpressure @haus-automatisierung last edited by
                via einstellungen des go-e adapter
                haus-automatisierung mcm1957 2 Replies Last reply Reply Quote 0
                  haus-automatisierung Developer Most Active @Highpressure last edited by haus-automatisierung
                  Und wenn Du only Ack anhakst? Dann sollte doch genau das gewünschte Verhalten erreicht werden (oder ich verstehe die Option in den Einstellungen falsch).
                  Ist auch hier erklärt: https://github.com/MK-2001/ioBroker.go-e/issues/168#issuecomment-1639802038
                  Normalerweise sollten von einem System immer nur bestätigte Werte geliefert werden. Unbestätigte werden zu steuern verwendet und dann vom Zielgerät nachträglich bestätigt.
                  Je nachdem welchen Adapter du verwendest, kommen ggf. auch unbestätigte werte aus dem Adapter zurück, dann muss der Haken bei OnlyAck raus.
                  FranzKillig created this issue in MK-2001/ioBroker.go-e
                  closed Ich benötige eine kurze Erklärung zum PV-Überschussladen #168
                  • mcm1957
                    mcm1957 @Highpressure last edited by
                    @highpressure
                    Adapter setzen ihre AUSGANGS-State, d.h. jene States die einen Wert VOM Gerät liefern IMMER mit ack=true. Alles andere wäre falsch.
                    Schau mal in die go-e Dokumentation, dort gibts ein Beispiel für Fronius
                    https://github.com/MK-2001/ioBroker.go-e/blob/main/docs/Readme.md#foreign-objects
                      Highpressure @haus-automatisierung last edited by Highpressure
                      hab ich schon alles durch 😞
                      Die Beschreibung im screenshot sagt auch: "This Adapter is currently consuming only ack = false states."
                      Wenn ich onlyAck wähle habe ich im log einen error:
                      wähle ich gar nichts von beiden - verhalten wie vorher
                      ich hab eben ins github repo geschaut und die main.js geöffnet:
                      EDIT sorry, screenshot ist ein paar zeilen zu hoch, weiter unte ist quasi derselbe text nochmals für die ack=true in Zeile 284
                      https://github.com/MK-2001/ioBroker.go-e/blob/main/main.js11-10-2023_14-04-22.png
                      scheinbar wird nur die house consumption geprüft, wie ich das sehe, oder?
                      mcm1957 haus-automatisierung 2 Replies Last reply Reply Quote 0
                      • mcm1957
                        @highpressure said in MQTT ack=false forcieren?:
                        Dann poste das Problem entweder im go-e Wartungstopic (so es das gibt) und / oder mach ein Issue beim Adapter auf.
                        Wie oben geschrieben, States die der Adapter xyz mit Werten aus dem Gerät befüllt werden IMMER ack=true haben.
                        Nur States die DU als Input in den Adapter schreibts müssen ack=false haben. Das kann dann aber nur States des GO-E betreffen, die DU (z.b. via script) beschreibts.
                          Highpressure @mcm1957 last edited by Highpressure
                          @mcm57
                          Vielen Dank, dann werde ich das im GitHub so tun 🙂
                          DANKE EUCH FÜR DIE HILFE!
                          PS: habe ChatGPT4 den link zur main.js gegeben und um erklärung gebeten weshalb das so ist:
                          In the code, checking for ack = false is crucial as it helps ensure that only state changes initiated by external inputs are processed further in the onStateChange method. When ack is false, it indicates that the state change is new or unacknowledged, prompting action to handle this change. If ack were true, it would signify an acknowledged or system-generated state change, which doesn't require further action in this context​1.
                          mcm1957 M 2 Replies Last reply Reply Quote 0
                          • mcm1957
                            @highpressure
                            Möglicherweise hat der Adapzter den (in meinen Augen falschen Ansatz) dass hier ein vom User beschreibarer State in der Config eingetragen wird, z.B. 0_userdate.xxxxx. Wenn du diesen eigenen State per Skript beschreibts kann da natürlich ack=false stehen.
                            Der Ansatz ist aber m.E. falsch, da für das Bearbeiten des States als Input bei einem Adapter gilt:
                            • Input State === eigener State der Instanz -> ack=false
                            • Input State === foreign State einer fremden Instanz -> ack=true
                            Es mag Ausnahmen geben - hier seh ich aber keine.
                              Gerade nochmal den Code genauer angeschaut. Wenn state.ack = true, dann geht es ja hier weiter:
                              https://github.com/MK-2001/ioBroker.go-e/blob/fe2afea205c73c870473201012e9755ba9fc23a6/main.js#L285-L296
                              Und dann wird geprüft, ob onlyAck auch auf true steht. Sollte also funktionieren.
                              Nein, werden alle geprüft. Siehe 3x case da drüber. Code passt aus meiner Sicht.
                              Teil doch am besten nochmal ein Log, wenn Du überall onlyAck angehakt hast.
                              @mcm57 sagte in MQTT ack=false forcieren?:
                              Der Adapter bietet doch in den Instanzeinstellungen die Option, ob man jeweils ack: true oder ack: false verarbeiten möchte. Mehr Optionen braucht man ja nicht. Damit ist alles abgedeckt. Auch dieser MQTT-Fall hier.
                              • mcm1957
                                mcm1957 @haus-automatisierung last edited by
                                @haus-automatisierung said in MQTT ack=false forcieren?:
                                Wenn er das tut ist das voll in Ordnung.
                                Ich hatte nur - ohne den Code zu analysieren - nach dem hier geschriebenen einen anderen Einsruck.
                                  mk2001 @Highpressure last edited by mk2001
                                  @highpressure
                                  Die gezeigt Fehlermeldung erscheint, wenn eines der auszulesenden Objekte keinen Wert, bzw. Keinen numerischen Wert beinhaltet.
                                  Bitte stelle sicher, dass alle Objekte eingetragen sind. Und in deren Values auch reale Werte eingetragen sind. Welche Werte bei der Berechnung berücksichtigt werden ist in der Formel bei den Einstellungen ersichtlich.
                                  M.E. Hat die Fehlermeldung nichts mit ack zu tun.
                                    Highpressure @mk2001 last edited by
                                    @mk2001
                                    go-e.0
                                    12309 2023-10-11 14:03:26.539 silly States user redis pmessage io.mqtt.0.PVGrid.total.pv_power.state/io.mqtt.0.PVGrid.total.pv_power.state:{"val":5288,"ack":true,"ts":1697025806536,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697025806536}
                                    go-e.0
                                    12309 2023-10-11 14:03:26.537 silly States user redis pmessage io.mqtt.0.PVGrid.total.load_power.state/io.mqtt.0.PVGrid.total.load_power.state:{"val":5770,"ack":true,"ts":1697025806536,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697025806536}
                                    go-e.0
                                    12309 2023-10-11 14:03:26.529 silly States user redis pmessage io.mqtt.0.PVGrid.total.battery_power.state/io.mqtt.0.PVGrid.total.battery_power.state:{"val":-208,"ack":true,"ts":1697025806528,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697025806528}
                                    Das sind auch die Foreign Objects aus dem Setup, die liest er ja scheinbar auch aus und wie im silly log zu lesen sind sie nicht 0.
                                      @highpressure Du hast onlyAck ja immernoch nicht angehakt 🙂
                                      1037
