    4. Shelly 2 Pro PM integration via MQTT geht nicht
    • BananaJoe
      BananaJoe Most Active @stoeffels last edited by
      @stoeffels der ist da manchmal zickig - vor dem Löschen von Datenpunkten am besten den Adapter vorher anhalten.
      So oft sollte das ja nicht vorkommen.
      Soundy 1 Reply Last reply Reply Quote 0
      • Soundy
        Soundy @BananaJoe last edited by
        @bananajoe
        Konnte das Problem eigentlich abschließend geklärt worden, denn ich habe das selbe Problemchen...
        Auszug aus dem Logfile:
        2023-09-23 23:40:38.160 - info: host.niedernpi "system.adapter.shelly.1" enabled
        2023-09-23 23:40:39.421 - info: host.niedernpi instance system.adapter.shelly.1 started with pid 3514
        2023-09-23 23:40:44.150 - info: shelly.1 (3514) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-09-23 23:40:50.497 - info: shelly.1 (3514) starting. Version 6.4.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.17.1, js-controller: 5.0.12
        2023-09-23 23:40:51.553 - info: shelly.1 (3514) Starting in MQTT mode. Listening on 0.0.0.0:1883 (QoS 0)
        2023-09-23 23:41:06.866 - info: shelly.1 (3514) [MQTT] Device with client id "shellypro2-30c6f78119c0" connected!
        2023-09-23 23:41:16.807 - info: shelly.1 (3514) [MQTT] Client Close: (shellypro2 / shellypro2-30c6f78119c0 / shellypro2#30c6f78119c0#1) (false)
        2023-09-23 23:42:04.207 - info: shelly.1 (3514) [MQTT] Device with client id "shellypro2-30c6f78119c0" connected!
        2023-09-23 23:42:14.191 - info: shelly.1 (3514) [MQTT] Client Close: (shellypro2 / shellypro2-30c6f78119c0 / shellypro2#30c6f78119c0#1) (false)
        2023-09-23 23:42:40.762 - error: shelly.1 (3514) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
        2023-09-23 23:42:41.043 - error: shelly.1 (3514) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
        2023-09-23 23:43:08.894 - info: shelly.1 (3514) [MQTT] Device with client id "shellypro2-30c6f78119c0" connected!
        2023-09-23 23:43:18.885 - info: shelly.1 (3514) [MQTT] Client Close: (shellypro2 / shellypro2-30c6f78119c0 / shellypro2#30c6f78119c0#1) (false)
        2023-09-23 23:43:45.341 - error: shelly.1 (3514) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
        2023-09-23 23:44:13.515 - info: shelly.1 (3514) [MQTT] Device with client id "shellypro2-30c6f78119c0" connected!
        2023-09-23 23:44:23.495 - info: shelly.1 (3514) [MQTT] Client Close: (shellypro2 / shellypro2-30c6f78119c0 / shellypro2#30c6f78119c0#1) (false)
        2023-09-23 23:44:49.340 - error: shelly.1 (3514) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
        Ich habe den Adapter gestoppt, dann den ganzen Baum von shelly.1 gelöscht. Den Shelly 2 Pro neugestartet, dann den Adapter wieder gestartet und es kommt weiterhin zu diesem Fehler. Die Daten bei den Objekten sind nur teilweise vorhanden, meist nur der Zweig/Baum - aber die Daten selbst fehlen...
        Vor der Neuinstallation meines ioBrokers hat es funktioniert, jetzt leider nichtmehr...
        Wer hat eine Idee oder eine Lösung? seufz
          flispy @Soundy last edited by
          @soundy ich habe dasselbe Problem. Wäre über Hilfe sehr dankbar!
          • MichaelF
            MichaelF last edited by MichaelF
            ich glaube das ist das Firmware Problem :
            Firmware
            Die Antwort von Shelly Werkseinstellung im Shelly laden und neu in IoBroker anmelden, ging aber leider bei mir nicht.
            Daher alte Firmware und alles war sofort wieder gut.
            • Soundy
              Soundy @MichaelF last edited by Soundy
              @michaelf
              Nunja, das klingt ja alles interessant.
              Zurücksetzen möchte ich den Shelly 2 Pro eigentlich nicht so gerne, weil ich wieder alles einrichten müßte.
              Aktuell habe ich folgende Firmware (laut Webinterface) drauf:
              20230912-082331/1.0.3-g6176478
              Downgrade selbst gefunden, hier für andere:
              Infos sind zu finden unter:
              https://www.shelly-support.eu/forum/thread/21566-firmware-1-0-0-für-geräte-der-2-generation-wird-offiziell-bereitgestellt/?postID=227817#post227817
              (Benutzerkonto muss vorhanden sein, soweit ich das noch weiß!)
              Hier sind auch die Direktlinks zu diversen Gen2-Geräten zu finden:
              PlugUS
              Plus1
              Plus1PM
              Plus2PM
              PlusHT
              PlusI4
              PlusPlugIT
              PlusPlugS
              PlusPlugUK
              PlusSmoke
              PlusWallDimmer
              Pro1
              Pro1PM
              Pro2
              Pro2PM
              Pro3
              Pro3EM
              Pro4PM
              Während ich das Downgrade laufen habe ...
              Ich frage mich ja wirklich, wieso es bei Shelly immer wieder Probleme mit der Firmware gibt? Ich hätte schon mit einem einfachen Shelly 1 (UP-Modul) richtige Probleme und mußte dann auf Tasmota wechseln, damit die Hardware für mich nutzbar war. Jetzt und hier ein Versionssprung von 0.14 auf 1.x - alles nicht ganz klar. Eigentlich denkt man bei einem solchen Sprung, dass hier vieles getan wurde, aber eher verschlimmbessert kommt mir vor.
              Irgendwie werde ich immer mehr enttäuscht von Shelly Produkten. 😞
              Nach dem Downgrade:
              Ich habe nur die Instanz im ioBroker neu gestartet und es funktioniert.
              Aber wo ist nun der Fehler in der neuen Firmware? Irgendwelche fehlt mir das Wissen, dass ich tiefer in die Materie einsteige und bin eher der Anwender mit einem gewissen technischen Verständnis. Hmm... vielleicht findet ja jemand was raus.
              FAZIT: Das Downgrade auf 0.14 funktioniert! 😉
              DANKE für diesen goldreichen Tipp, der wahrscheinlich nicht nur mir geholfen hat! TOP TOP TOP!
              D W 2 Replies Last reply Reply Quote 0
                Diamand2k22 @Soundy last edited by Diamand2k22
                @soundy
                jetzt gibt es sogar die 1.0.7-beta1.
                rei übersetzt aus der engl. Facebook-Gruppe (beschwert euch bei Deepl 🙂 ) :
                Liebe Gruppe,
                heute haben wir Gen2 1.07-beta1 für Shelly Plus und Pro Geräte veröffentlicht, auf die Sie über das lokale Web des Gerätes aktualisieren können.
                Änderungen:
                Geändert:
                PlusPM Mini Entfernen der Null-Last-Bedingung
                Überarbeiteter mDNS-Responder
                Entfernt:
                Skripting Begrenzung der Skriptgröße auf 15kB entfernt
                Hinzugefügt:
                Plus2PM, Pro2, Pro2PM Unterstützung des Zyklusmodus (Cycle-Mode) hinzugefügt
                Behoben:
                BLE MAC in BLE MFD ist in der falschen Endianness
                MQTT Fix Parsing von fragmentierten Nachrichten
                Der MQTT-Befehl status_update schaltet den Zustand des Schalters um
                Plus1PM Mini, PlusPM Mini Verbesserte Ausfallsicherheit des BL0942 Leistungsmessertreibers
                Helligkeitsargument in Light.Set wird falsch geparst
                Scripting Phantom-Script-Inhalte beim Aufruf von Script.Delete / Script.Create
                Abdeckung/Cover/Rollo Verbesserte Kalibrierungsprozedur
                Lokales Web:
                Hinzugefügt:
                Localweb sammelt Protokolle, wenn es geöffnet ist (nicht nur auf der Diagnoseseite)
                Verbundener Status für das Wolkensymbol in der Statusleiste hinzugefügt
                Caching-Mechanismus für Skript-Beispiele und Snippets
                Modbus-Unterstützung für ProXEM
                Vollständige Cron-Unterstützung für Zeitpläne
                Hinzufügen von Macadressen für eth, ble und wifi
                Erweiterter Link für kvs und Diagnose
                Geändert:
                Strategie zur Wiederherstellung der Debug-Logs
                Verbesserungen am KVS-Manager
                Firmware-Seite UI
                Begrenzung von Anrufen zur Planung von Anrufen
                Countdown-Animation beim automatischen Einschalten und Ausschalten
                Wenn Sie Probleme mit der Beta-Version haben, können Sie über das lokale Web des Geräts auf die letzte stabile Version zurückkehren.
                Ich wünsche Ihnen einen schönen Tag und bedanke mich nochmals für die proaktive Berichterstattung und Hilfe!
                Changelog: https://shelly-api-docs.shelly.cloud/gen2/changelog
                ich werde mal testen 😄
                • Soundy
                  Soundy @Diamand2k22 last edited by Soundy
                  @diamand2k22
                  Danke für die Info...
                  Ich habe gleich mal getestet und erhalte wie mit der 1.0.3 wieder Fehler im iob-Log:
                  2023-10-10 23:40:19.816 - info: shelly.1 (29468) [MQTT] Device with client id "shellypro2-30c6f78119c0" connected!
                  2023-10-10 23:40:29.790 - info: shelly.1 (29468) [MQTT] Client Close: (shellypro2 / shellypro2-30c6f78119c0 / shellypro2#30c6f78119c0#1) (false)
                  2023-10-10 23:40:33.157 - info: shelly.1 (29468) [MQTT] Device with client id "shellypro2-30c6f78119c0" connected!
                  2023-10-10 23:40:43.137 - info: shelly.1 (29468) [MQTT] Client Close: (shellypro2 / shellypro2-30c6f78119c0 / shellypro2#30c6f78119c0#1) (false)
                  2023-10-10 23:40:47.188 - info: shelly.1 (29468) [MQTT] Device with client id "shellypro2-30c6f78119c0" connected!
                  2023-10-10 23:40:57.170 - info: shelly.1 (29468) [MQTT] Client Close: (shellypro2 / shellypro2-30c6f78119c0 / shellypro2#30c6f78119c0#1) (false)
                  Und dann noch:
                  2023-10-10 23:42:54.755 - error: shelly.1 (29468) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
                  2023-10-10 23:42:54.913 - error: shelly.1 (29468) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
                  2023-10-10 23:42:54.914 - error: shelly.1 (29468) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
                  2023-10-10 23:42:54.915 - error: shelly.1 (29468) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
                  2023-10-10 23:42:55.270 - error: shelly.1 (29468) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
                  2023-10-10 23:42:55.272 - error: shelly.1 (29468) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
                  2023-10-10 23:42:55.273 - error: shelly.1 (29468) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
                  2023-10-10 23:42:55.497 - error: shelly.1 (29468) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f78119c0"
                  Auch werden die MQTT Daten nicht vollständig und korrekt übertragen:
                  Ich nutze das aktuelle Shelly Plugin (v6.4.5) von ioBroker. Keine Ahnung, wo das Problem herkommt. Dazu bin ich leider zu wenig tief in der Materie und eher nur Anwender ... 😞
                  Also doch wieder zurück zur 0.14 ... 😉
                  (Anmerkung: Downgrade wieder erfolgreich und funktioniert wieder!)
                    @soundy
                    kann ich bestätigen!
                    wie machst du den downgrade auf die 0.14?
                    wird bei mir nicht mehr angezeigt!
                    muss ich die alte firmware separat runterladen?
                      Wildbill @Soundy last edited by
                      @soundy Und mir stellt sich die Frage, warum man bei Geräten wie Shelly oder auch welchen Tasmota unbedingt immer die aktuell(st)e Firmware haben will/muss. Wenn es zufriedenstellend läuft, sehe ich überhaupt keinen Anlass, hier irgendwie tätig zu werden. Einzig, wenn dadurch ein für mich vorhandenes Problem behoben wird, oder ein Feature dazu kommt, welches ich unbedingt haben muss, führe ich mal ein Update aus.
                      Da meine Smarthome-Geräte ansonsten nur innerhalb des internen Netzes senden können/dürfen, stellt sich auch kein Problem dar, dass man aus Angst vor Sicherheitslücken unbedingt updaten will/muss.
                      Gruss, Jürgen
                        @wildbill
                        ein Grund von Firmware Updates z.B. Sicherheitslückenschließen, aber auch erweiterte Umfänge.
                        Bin nun wieder auf die 0.14 zurück gegangen.
                        Falls es jemanden interessiert,
                        hier die Übersicht über die Downgrade Links für die Shelly Geräte!
                        https://www.shelly-support.eu/forum/thread/21940-downgradelinks-zu-0-14-x/
                        • Samson71
                          Samson71 Global Moderator @Diamand2k22 last edited by Samson71
                          @diamand2k22 sagte in Shelly 2 Pro PM integration via MQTT geht nicht:
                          Solange die Teile nicht von außen erreichbar sind, ist das durchaus nicht so vordringlich.
                          Firmware reift bekanntlich oft erst beim Kunden. Da also immer und sofort das Neueste haben zu müssen ist oft kontraproduktiv.
                          Sind die "erweiterten Umfänge" hier z.B. so wichtig/wertvoll?
                          Ich würde immer erstmal eine Zeit verstreichen lassen und hier insbesondere das Shelly-Forum nach Meldungen zu neuer Firmware durchsuchen bevor ich mir das als Versuchskaninchen antue.
                          BananaJoe 1 Reply Last reply Reply Quote 1
                          • BananaJoe
                            BananaJoe Most Active @Samson71 last edited by
                            Und hier mein Senf dazu:
                            Man sollte immer einen Plan B haben. Wenn ich Shellys & Co aktualisiere (egal ob mit Shelly Firmware, Tasmota, ESPEasy und Co.) dann bitte nicht den wichtigsten und habt Ersatz da.
                            Bei mir im Beruf ist das wichtigste Plan B, und damit Plan B einfach ist nehmen wir Redundanzen, sprich wir haben alles mindestens doppelt. Und zusätzlich noch eine Option innerhalb weniger Stunden Ersatz zu bekommen.
                            Gleichwertig dazu: Backups. Für meine Tasmota-Geräte nutze ich zum Beispiel https://github.com/danmed/TasmoBackupV1
                            Fällt mal einer aus (einige meiner Shelly 1PM sind schnell hintereinander gestorben) mache ich den neuen fertig - direkt bei der Ersteinrichtung kann man das Backup einspielen, Shelly austauschen und fertig. (ggf. Zählerstände + Kalibrierung korrigieren)
                            • Soundy
                              Ups...
                              Also anscheinend besteht das Problem auch für das "Shelly i4" ... den hab ich seit Freitag hier zum Testen. Mit der neuesten Firmware (über Webupgrade) nur Fehler. Also zurück auf 0.14.X ... herrje... was macht Shelly nur. 😞 Oder ist das Problem der Shelly Adapter von ioBroker? Irgendwie bin ich mir da jetzt nichtmehr sicher...
                              • da_Woody
                                da_Woody @Soundy last edited by
                                @soundy hmm,
                                keine probleme.
                                  worxweis @da_Woody last edited by
                                  Hallo Leute!
                                  bei mir macht derzeit nur ein 1PM Probleme:
                                  shelly.0
                                  2023-11-14 18:45:31.369	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-4855199d777c"
                                  shelly.0
                                  2023-11-14 18:45:31.369	error	[MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
                                  Mein i4 funktioniert!
                                  MichaelF 1 Reply Last reply Reply Quote 0
                                  • MichaelF
                                    MichaelF @worxweis last edited by
                                    @worxweis said in Shelly 2 Pro PM integration via MQTT geht nicht:
                                    Hallo Leute!
                                    shelly.0
                                    shelly.0
                                    Hi, wurde die client ID geändert ?
                                    Grüsse
                                      worxweis @MichaelF last edited by
                                      @michaelf
                                      Also ich habe hier gar nichts geändert.
                                        @michaelf
                                        Ich hab jetzt mal die Beta FW vom 14.11.2023 raufgespielt, kann aber keinen Unterschied entdecken. Fehlermeldung kommt weiterhin im 1-2Minuten Takt!
                                        • MichaelF
                                          @michaelf
                                          Hi, mal die erste stable versucht? 0.14
                                          @michaelf
                                          Hi, mal die erste stable versucht 0.14
                                          • MichaelF
                                            Möglich das es das Firmware problem ist. Wobei ich auch sagen muss das ich mit der neuen noch kein Aktor zum laufen gebracht habe wenn er einmal bei iobroker angemeldet war. Selbst ein reset hatte kein Erfolg.
                                            Grüsse
                                            36
                                            3770
