      Thomas Braun Most Active @ichderarnd last edited by
      @ichderarnd sagte in Test Adapter ioBroker.backitup v2.8.x:
      Merkwürdig.
      Mit einer schiefen Installation ist da gar nix merkwürdig. Höchstens verbesserungswürdig.
      • I
        ichderarnd @Thomas Braun last edited by
        Der erste Lauf für die nodejs 16 war schon aus dem History Buffer raus. Hier der zweite Aufruf mit Update auf die 18.18.1:
        ioBroker nodejs fixer 2023-10-09
        Recommended nodejs-version is: 18.18.1
        Checking your installation now. Please be patient!
        Your current setup is:
        /usr/bin/nodejs         v16.20.2
        /usr/bin/node           v16.20.2
        /usr/bin/npm            8.19.4
        /usr/bin/npx            8.19.4
        /usr/bin/corepack       0.17.0
        We found these nodejs versions available for installation:
        nodejs:
          Installed: 16.20.2-deb-1nodesource1
          Candidate: 16.20.2-deb-1nodesource1
          Version table:
         *** 16.20.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        Nothing to do - Your installation is using the correct paths.
        You are running nodejs v16.20.2. Do you want to install recommended version 18.18.1?
        Press <y> to continue or any other key to quit
        Trying to fix your installation now. Please be patient.
        Waiting for ioBroker to shut down - Give me a minute...
        *** These repos are active on your system:
        Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
        Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
        Get:3 https://apt.pivccu.de/piVCCU testing InRelease [13.6 kB]
        Get:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB]
        Get:5 http://raspbian.raspberrypi.org/raspbian buster/non-free Sources [139 kB]
        Get:6 https://apt.pivccu.de/piVCCU testing/main armhf Packages [13.8 kB]
        Get:7 http://raspbian.raspberrypi.org/raspbian buster/main Sources [11.4 MB]
        Get:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
        Get:9 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [110 kB]
        Fetched 25.1 MB in 11s (2383 kB/s)
        Reading package lists... Done
        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
        Package: nodejs
        Pin: origin deb.nodesource.com
        Pin-Priority: 1001
        *** These repos are active after the adjustments:
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://apt.pivccu.de/piVCCU testing InRelease
        Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
        Get:5 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5529 B]
        Fetched 17.7 kB in 1s (13.3 kB/s)
        Installing the recommended nodejs version now!
        Extracting templates from packages: 100%
        (Reading database ... 266527 files and directories currently installed.)
        Preparing to unpack .../ncurses-bin_6.1+20181013-2+deb10u4_armhf.deb ...
        Unpacking ncurses-bin (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
        Setting up ncurses-bin (6.1+20181013-2+deb10u4) ...
        Preparing to unpack .../ncurses-base_6.1+20181013-2+deb10u4_all.deb ...
        Unpacking ncurses-base (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
        Setting up ncurses-base (6.1+20181013-2+deb10u4) ...
        Preparing to unpack .../0-python2.7-dev_2.7.16-2+deb10u3_armhf.deb ...
        Unpacking python2.7-dev (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
        Preparing to unpack .../1-libpython2.7-dev_2.7.16-2+deb10u3_armhf.deb ...
        Unpacking libpython2.7-dev:armhf (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
        Preparing to unpack .../2-libpython2.7_2.7.16-2+deb10u3_armhf.deb ...
        Unpacking libpython2.7:armhf (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
        Preparing to unpack .../3-python2.7_2.7.16-2+deb10u3_armhf.deb ...
        Unpacking python2.7 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
        Preparing to unpack .../4-libpython2.7-stdlib_2.7.16-2+deb10u3_armhf.deb ...
        Unpacking libpython2.7-stdlib:armhf (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
        Preparing to unpack .../5-python2.7-minimal_2.7.16-2+deb10u3_armhf.deb ...
        Unpacking python2.7-minimal (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
        Preparing to unpack .../6-libpython2.7-minimal_2.7.16-2+deb10u3_armhf.deb ...
        Unpacking libpython2.7-minimal:armhf (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
        Preparing to unpack .../7-libncurses6_6.1+20181013-2+deb10u4_armhf.deb ...
        Unpacking libncurses6:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
        Preparing to unpack .../8-libtinfo6_6.1+20181013-2+deb10u4_armhf.deb ...
        Unpacking libtinfo6:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
        Setting up libtinfo6:armhf (6.1+20181013-2+deb10u4) ...
        Preparing to unpack .../libncursesw6_6.1+20181013-2+deb10u4_armhf.deb ...
        Unpacking libncursesw6:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
        Setting up libncursesw6:armhf (6.1+20181013-2+deb10u4) ...
        Preparing to unpack .../00-vim-tiny_2%3a8.1.0875-5+deb10u6_armhf.deb ...
        Unpacking vim-tiny (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5+deb10u5) ...
        Preparing to unpack .../01-xxd_2%3a8.1.0875-5+deb10u6_armhf.deb ...
        Unpacking xxd (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5+deb10u5) ...
        Preparing to unpack .../02-vim-common_2%3a8.1.0875-5+deb10u6_all.deb ...
        Unpacking vim-common (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5+deb10u5) ...
        Preparing to unpack .../03-ncurses-term_6.1+20181013-2+deb10u4_all.deb ...
        Unpacking ncurses-term (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
        Preparing to unpack .../04-ghostscript_9.27~dfsg-2+deb10u9_armhf.deb ...
        Unpacking ghostscript (9.27~dfsg-2+deb10u9) over (9.27~dfsg-2+deb10u8) ...
        Preparing to unpack .../05-libgs9_9.27~dfsg-2+deb10u9_armhf.deb ...
        Unpacking libgs9:armhf (9.27~dfsg-2+deb10u9) over (9.27~dfsg-2+deb10u8) ...
        Preparing to unpack .../06-libgs9-common_9.27~dfsg-2+deb10u9_all.deb ...
        Unpacking libgs9-common (9.27~dfsg-2+deb10u9) over (9.27~dfsg-2+deb10u8) ...
        Preparing to unpack .../07-libdw1_0.176-1.1+deb10u1_armhf.deb ...
        Unpacking libdw1:armhf (0.176-1.1+deb10u1) over (0.176-1.1) ...
        Preparing to unpack .../08-libelf1_0.176-1.1+deb10u1_armhf.deb ...
        Unpacking libelf1:armhf (0.176-1.1+deb10u1) over (0.176-1.1) ...
        Preparing to unpack .../09-libflac-dev_1.3.2-3+deb10u3_armhf.deb ...
        Unpacking libflac-dev:armhf (1.3.2-3+deb10u3) over (1.3.2-3+deb10u2) ...
        Preparing to unpack .../10-libflac8_1.3.2-3+deb10u3_armhf.deb ...
        Unpacking libflac8:armhf (1.3.2-3+deb10u3) over (1.3.2-3+deb10u2) ...
        Preparing to unpack .../11-libncursesw5_6.1+20181013-2+deb10u4_armhf.deb ...
        Unpacking libncursesw5:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
        Preparing to unpack .../12-libncurses5_6.1+20181013-2+deb10u4_armhf.deb ...
        Unpacking libncurses5:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
        Preparing to unpack .../13-libtinfo5_6.1+20181013-2+deb10u4_armhf.deb ...
        Unpacking libtinfo5:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
        Preparing to unpack .../14-libpq-dev_11.21-0+deb10u2_armhf.deb ...
        Unpacking libpq-dev (11.21-0+deb10u2) over (11.19-0+deb10u1) ...
        Preparing to unpack .../15-libpq5_11.21-0+deb10u2_armhf.deb ...
        Unpacking libpq5:armhf (11.21-0+deb10u2) over (11.19-0+deb10u1) ...
        Preparing to unpack .../16-libvpx-dev_1.7.0-3+deb10u2_armhf.deb ...
        Unpacking libvpx-dev:armhf (1.7.0-3+deb10u2) over (1.7.0-3+deb10u1) ...
        Preparing to unpack .../17-libvpx5_1.7.0-3+deb10u2_armhf.deb ...
        Unpacking libvpx5:armhf (1.7.0-3+deb10u2) over (1.7.0-3+deb10u1) ...
        Preparing to unpack .../18-libwebp-dev_0.6.1-2+deb10u3_armhf.deb ...
        Unpacking libwebp-dev:armhf (0.6.1-2+deb10u3) over (0.6.1-2+deb10u2) ...
        Preparing to unpack .../19-libwebp6_0.6.1-2+deb10u3_armhf.deb ...
        Unpacking libwebp6:armhf (0.6.1-2+deb10u3) over (0.6.1-2+deb10u2) ...
        Preparing to unpack .../20-libwebpmux3_0.6.1-2+deb10u3_armhf.deb ...
        Unpacking libwebpmux3:armhf (0.6.1-2+deb10u3) over (0.6.1-2+deb10u2) ...
        Preparing to unpack .../21-libwebpdemux2_0.6.1-2+deb10u3_armhf.deb ...
        Unpacking libwebpdemux2:armhf (0.6.1-2+deb10u3) over (0.6.1-2+deb10u2) ...
        Preparing to unpack .../22-libx11-dev_2%3a1.6.7-1+deb10u4_armhf.deb ...
        Unpacking libx11-dev:armhf (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u3) ...
        Preparing to unpack .../23-libx11-data_2%3a1.6.7-1+deb10u4_all.deb ...
        Unpacking libx11-data (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u3) ...
        Preparing to unpack .../24-libx11-6_2%3a1.6.7-1+deb10u4_armhf.deb ...
        Unpacking libx11-6:armhf (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u3) ...
        Preparing to unpack .../25-libx11-xcb-dev_2%3a1.6.7-1+deb10u4_armhf.deb ...
        Unpacking libx11-xcb-dev:armhf (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u3) ...
        Preparing to unpack .../26-libx11-xcb1_2%3a1.6.7-1+deb10u4_armhf.deb ...
        Unpacking libx11-xcb1:armhf (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u3) ...
        Preparing to unpack .../27-libxpm4_1%3a3.5.12-1+deb10u2_armhf.deb ...
        Unpacking libxpm4:armhf (1:3.5.12-1+deb10u2) over (1:3.5.12-1+deb10u1) ...
        Preparing to unpack .../28-nodejs_18.18.1-1nodesource1_armhf.deb ...
        Detected old npm client, removing...
        Unpacking nodejs (18.18.1-1nodesource1) over (16.20.2-deb-1nodesource1) ...
        Preparing to unpack .../29-openjdk-11-jdk_11.0.20+8-1~deb10u1_armhf.deb ...
        Unpacking openjdk-11-jdk:armhf (11.0.20+8-1~deb10u1) over (11.0.18+10-1~deb10u1) ...
        Preparing to unpack .../30-openjdk-11-jdk-headless_11.0.20+8-1~deb10u1_armhf.deb ...
        Unpacking openjdk-11-jdk-headless:armhf (11.0.20+8-1~deb10u1) over (11.0.18+10-1~deb10u1) ...
        Preparing to unpack .../31-openjdk-11-jre_11.0.20+8-1~deb10u1_armhf.deb ...
        Unpacking openjdk-11-jre:armhf (11.0.20+8-1~deb10u1) over (11.0.18+10-1~deb10u1) ...
        Preparing to unpack .../32-openjdk-11-jre-headless_11.0.20+8-1~deb10u1_armhf.deb ...
        Unpacking openjdk-11-jre-headless:armhf (11.0.20+8-1~deb10u1) over (11.0.18+10-1~deb10u1) ...
        Preparing to unpack .../33-python-urllib3_1.24.1-1+deb10u1_all.deb ...
        Unpacking python-urllib3 (1.24.1-1+deb10u1) over (1.24.1-1) ...
        Preparing to unpack .../34-python3-renderpm_3.5.13-1+deb10u2_armhf.deb ...
        Unpacking python3-renderpm:armhf (3.5.13-1+deb10u2) over (3.5.13-1+deb10u1) ...
        Preparing to unpack .../35-python3-reportlab-accel_3.5.13-1+deb10u2_armhf.deb ...
        Unpacking python3-reportlab-accel:armhf (3.5.13-1+deb10u2) over (3.5.13-1+deb10u1) ...
        Preparing to unpack .../36-python3-reportlab_3.5.13-1+deb10u2_all.deb ...
        Unpacking python3-reportlab (3.5.13-1+deb10u2) over (3.5.13-1+deb10u1) ...
        Preparing to unpack .../37-python3-urllib3_1.24.1-1+deb10u1_all.deb ...
        Unpacking python3-urllib3 (1.24.1-1+deb10u1) over (1.24.1-1) ...
        Preparing to unpack .../38-qemu-utils_1%3a3.1+dfsg-8+deb10u11_armhf.deb ...
        Unpacking qemu-utils (1:3.1+dfsg-8+deb10u11) over (1:3.1+dfsg-8+deb10u9) ...
        Setting up libgs9-common (9.27~dfsg-2+deb10u9) ...
        Setting up python-urllib3 (1.24.1-1+deb10u1) ...
        Setting up libx11-xcb1:armhf (2:1.6.7-1+deb10u4) ...
        Setting up python3-renderpm:armhf (3.5.13-1+deb10u2) ...
        Setting up libgs9:armhf (9.27~dfsg-2+deb10u9) ...
        Setting up openjdk-11-jre-headless:armhf (11.0.20+8-1~deb10u1) ...
        Installing new version of config file /etc/java-11-openjdk/security/java.policy ...
        Installing new version of config file /etc/java-11-openjdk/security/java.security ...
        Setting up libpq5:armhf (11.21-0+deb10u2) ...
        Setting up libpq-dev (11.21-0+deb10u2) ...
        Setting up openjdk-11-jdk-headless:armhf (11.0.20+8-1~deb10u1) ...
        Setting up ghostscript (9.27~dfsg-2+deb10u9) ...
        Setting up nodejs (18.18.1-1nodesource1) ...
        Setting up xxd (2:8.1.0875-5+deb10u6) ...
        Setting up libflac8:armhf (1.3.2-3+deb10u3) ...
        Setting up libpython2.7-minimal:armhf (2.7.16-2+deb10u3) ...
        Setting up vim-common (2:8.1.0875-5+deb10u6) ...
        Setting up libx11-data (2:1.6.7-1+deb10u4) ...
        Setting up python2.7-minimal (2.7.16-2+deb10u3) ...
        Setting up libncurses6:armhf (6.1+20181013-2+deb10u4) ...
        Setting up python3-reportlab-accel:armhf (3.5.13-1+deb10u2) ...
        Setting up libwebp6:armhf (0.6.1-2+deb10u3) ...
        Setting up python3-urllib3 (1.24.1-1+deb10u1) ...
        Setting up python3-reportlab (3.5.13-1+deb10u2) ...
        Setting up libx11-6:armhf (2:1.6.7-1+deb10u4) ...
        Setting up qemu-utils (1:3.1+dfsg-8+deb10u11) ...
        Setting up libwebpmux3:armhf (0.6.1-2+deb10u3) ...
        Setting up libtinfo5:armhf (6.1+20181013-2+deb10u4) ...
        Setting up libelf1:armhf (0.176-1.1+deb10u1) ...
        Setting up libvpx5:armhf (1.7.0-3+deb10u2) ...
        Setting up ncurses-term (6.1+20181013-2+deb10u4) ...
        Setting up libdw1:armhf (0.176-1.1+deb10u1) ...
        Setting up libflac-dev:armhf (1.3.2-3+deb10u3) ...
        Setting up libxpm4:armhf (1:3.5.12-1+deb10u2) ...
        Setting up libwebpdemux2:armhf (0.6.1-2+deb10u3) ...
        Setting up libx11-dev:armhf (2:1.6.7-1+deb10u4) ...
        Setting up openjdk-11-jre:armhf (11.0.20+8-1~deb10u1) ...
        Setting up vim-tiny (2:8.1.0875-5+deb10u6) ...
        Setting up libncurses5:armhf (6.1+20181013-2+deb10u4) ...
        Setting up libpython2.7-stdlib:armhf (2.7.16-2+deb10u3) ...
        Setting up libwebp-dev:armhf (0.6.1-2+deb10u3) ...
        Setting up libvpx-dev:armhf (1.7.0-3+deb10u2) ...
        Setting up openjdk-11-jdk:armhf (11.0.20+8-1~deb10u1) ...
        Setting up libncursesw5:armhf (6.1+20181013-2+deb10u4) ...
        Setting up libx11-xcb-dev:armhf (2:1.6.7-1+deb10u4) ...
        Setting up libpython2.7:armhf (2.7.16-2+deb10u3) ...
        Setting up libpython2.7-dev:armhf (2.7.16-2+deb10u3) ...
        Setting up python2.7 (2.7.16-2+deb10u3) ...
        Setting up python2.7-dev (2.7.16-2+deb10u3) ...
        Processing triggers for mime-support (3.62) ...
        Processing triggers for hicolor-icon-theme (0.17-2) ...
        Processing triggers for gnome-menus (3.31.4-3) ...
        Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u2) ...
        Processing triggers for man-db (2.8.5-2) ...
        Processing triggers for desktop-file-utils (0.23-4) ...
        Installing the recommended nodejs version!
        We tried our best to fix your nodejs. Please run iob diag again to verify.
        *** RESTARTING ioBroker NOW! ***
         Please refresh or restart your browser in a few moments.
        "iob diag" findet folgende Fehler:
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @types/caseless@0.12.3 /opt/iobroker/node_modules/@types/caseless
        npm ERR! extraneous: @types/request@2.48.9 /opt/iobroker/node_modules/@types/request
        npm ERR! extraneous: @types/tough-cookie@4.0.3 /opt/iobroker/node_modules/@types/tough-cookie
        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
        npm ERR! invalid: iobroker.energiefluss@3.5.0 /opt/iobroker/node_modules/iobroker.energiefluss
        npm ERR! invalid: iobroker.sourceanalytix@0.4.12 /opt/iobroker/node_modules/iobroker.sourceanalytix
        npm ERR! invalid: iobroker.vr200@1.1.0 /opt/iobroker/node_modules/iobroker.vr200
        npm ERR! invalid: iobroker.vw-connect@0.1.3 /opt/iobroker/node_modules/iobroker.vw-connect
        npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
        npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
        npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
        npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
        npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-10T21_14_39_557Z-debug-0.log
        • I
          ichderarnd @Thomas Braun last edited by ichderarnd
          Mit der schiefen Installation hat's funktioniert...
          Nodejs 18 scheint eine neue Javascript Engine zu haben. An dem npm icmp scheint sich seit 3 Jahren nichts geändert zu haben. Da muss ich morgen weiter suchen.
          Die Raw Sockets sind aktiviert. Daran liegt's nicht.
            @ichderarnd
            Da ist/war aber auch noch wesentlich mehr schief installiert.
            sudo apt update
            sudo apt full-upgrade
            liefert?
            • I
              Das liefert nachfolgenden Output. Die oben gezeigten Fehlerausgaben mit "iob diag" bleiben danach bestehen.
              Sollten wir einen anderen Thread nehmen? Das ist zu OT hier...
              ~ $ sudo apt update
              Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
              Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
              OK:3 https://deb.nodesource.com/node_18.x nodistro InRelease
              OK:4 https://apt.pivccu.de/piVCCU testing InRelease
              Holen:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB]
              Es wurden 447 kB in 1 s geholt (357 kB/s).
              Alle Pakete sind aktuell.
              N: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »oldstable« in »oldoldstable« geändert.
              ~ $ sudo apt full-upgrade
              Paketaktualisierung (Upgrade) wird berechnet... Fertig
              Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                alsa-base gconf-service gconf2-common gstreamer0.10-alsa
                gstreamer0.10-plugins-base gyp libc-ares2 libexiv2-14 libgconf-2-4
                libgfortran3 libgmime-2.6-0 libgstreamer-plugins-base0.10-0
                libgstreamer0.10-0 libjs-inherits libjs-is-typedarray libllvm6.0
                libmicrodns0 libncurses5 libuv1-dev libva-wayland2 libxfce4util-bin
                libxfce4util-common libxfce4util7 libxfconf-0-2 lockfile-progs lxplug-volume
                node-abbrev node-ajv node-ansi node-ansi-align node-ansi-regex
                node-ansi-styles node-ansistyles node-aproba node-archy
                node-are-we-there-yet node-asn1 node-assert-plus node-asynckit
                node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf node-bluebird
                node-boxen node-brace-expansion node-builtin-modules node-builtins
                node-cacache node-call-limit node-camelcase node-caseless node-chalk
                node-chownr node-cli-boxes node-cliui node-clone node-co node-color-convert
                node-color-name node-combined-stream node-concat-map node-concat-stream
                node-config-chain node-console-control-strings node-copy-concurrently
                node-core-util-is node-cross-spawn node-cyclist node-dashdash
                node-decamelize node-decompress-response node-deep-extend node-defaults
                node-delayed-stream node-delegates node-detect-indent node-detect-newline
                node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding
                node-end-of-stream node-errno node-escape-string-regexp node-execa
                node-extend node-extsprintf node-find-up node-flush-write-stream
                node-forever-agent node-form-data node-from2 node-fs-vacuum
                node-fs-write-stream-atomic node-fs.realpath node-gauge node-get-caller-file
                node-get-stream node-getpass node-glob node-got node-graceful-fs
                node-har-schema node-har-validator node-has-flag node-has-symbol-support-x
                node-has-to-string-tag-x node-has-unicode node-hosted-git-info
                node-http-signature node-iconv-lite node-iferr node-import-lazy
                node-imurmurhash node-inflight node-inherits node-ini node-invert-kv
                node-is-builtin-module node-is-npm node-is-object node-is-plain-obj
                node-is-retry-allowed node-is-stream node-is-typedarray node-isarray
                node-isexe node-isstream node-isurl node-jsbn node-json-parse-better-errors
                node-json-schema node-json-stable-stringify node-json-stringify-safe
                node-jsonify node-jsonparse node-jsonstream node-jsprim node-latest-version
                node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile
                node-lowercase-keys node-lru-cache node-mem node-mime-types node-mimic-fn
                node-mimic-response node-minimatch node-minimist node-mississippi
                node-mkdirp node-move-concurrently node-mute-stream node-node-uuid node-nopt
                node-normalize-package-data node-npm-package-arg node-npm-run-path
                node-npmlog node-oauth-sign node-object-assign node-once node-opener
                node-os-locale node-osenv node-p-cancelable node-p-finally node-p-limit
                node-p-locate node-p-timeout node-package-json node-parallel-transform
                node-path-exists node-path-is-absolute node-path-is-inside
                node-performance-now node-prepend-http node-process-nextick-args
                node-promise-inflight node-promzard node-proto-list node-prr node-pump
                node-pumpify node-punycode node-qs node-qw node-rc node-read
                node-read-package-json node-readable-stream node-registry-auth-token
                node-registry-url node-request node-require-directory
                node-require-main-filename node-resolve-from node-retry node-rimraf
                node-run-queue node-safe-buffer node-semver node-semver-diff
                node-set-blocking node-sha node-shebang-command node-shebang-regex
                node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct
                node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri
                node-stream-each node-stream-iterate node-stream-shift node-string-decoder
                node-string-width node-strip-ansi node-strip-eof node-strip-json-comments
                node-supports-color node-tar node-term-size node-text-table node-through
                node-through2 node-timed-out node-tough-cookie node-tunnel-agent
                node-tweetnacl node-typedarray node-uid-number node-unique-filename
                node-unpipe node-url-parse-lax node-url-to-options node-util-deprecate
                node-uuid node-validate-npm-package-license node-validate-npm-package-name
                node-verror node-wcwidth.js node-which node-which-module node-wide-align
                node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic
                node-xdg-basedir node-xtend node-y18n node-yallist node-yargs
                node-yargs-parser pimixer pmount point-rpi python-colorzero
                python3-pyperclip python3-thonny rtimucli xfconf
              Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
              0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                Upgraden. Buster ist damit 'TOT'.
                • I
                  OK... Nach welcher Anleitung sollte ich vorgehen? Da gibt's ja mehrere Quellen...
                  Sollte das "apt autoremove" vorher ausgeführt werden?
                    Ich hab mir seinerzeit meine eigene Anleitung geschrieben. Schau durch meine Themen durch.
                    • I
                      Danke, gefunden. Tolle Arbeit ❕ 👍
                      Ich muss es auf's Wochenende verschieben. Leider steht noch Arbeit an.
                      Bin gespannt!
                      • Feuersturm
                        Feuersturm last edited by Feuersturm
                        Ich hab ein Master/Slave Testsystem und habe gerade mal testweise auf dem Master ein Backup ausgeführt und wollte es danach wiederherstellen.
                        Das Backup wurde auch angeblich erfolgreich durchgeführt.
                        Wenn ich dann das Backup wiederherstellen will, erscheint nur folgendes Bild. ioBroker wurde im Hintergrund gestoppt und läuft nicht mehr und der Restore wird nicht durchgeführt
                        Hat noch jemand dieses Verhalten?
                        Im web Adapter ist folgendes eingestellt
                        Ausführung von Backup welches erfolgreich war
                        Started iobroker ...
                        [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Master","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                        [DEBUG] [iobroker] - host.ioBrokerTestsystem 11794 states saved
                        [DEBUG] [iobroker] - host.ioBrokerTestsystem 13146 objects saved
                        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_10_11-21_41_40_backupiobroker.tar.gz
                        [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
                        [DEBUG] [iobroker] - done
                        [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
                        [DEBUG] [clean] - done
                        [DEBUG] [historyHTML] - new history html values created
                        [DEBUG] [historyHTML] - done
                        [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Master","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"11. Oktober 2023 um 21:41 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                        [DEBUG] [historyJSON] - new history json values created
                        [DEBUG] [historyJSON] - done
                        [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Master","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"11. Oktober 2023 um 21:42 Uhr"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                        [EXIT] 0
                        iob diag
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                         Static hostname: ioBrokerTestsystem
                               Icon name: computer-container
                                 Chassis: container
                          Virtualization: lxc
                        Operating System: Ubuntu 22.04.3 LTS
                                  Kernel: Linux 6.2.16-14-pve
                            Architecture: x86-64
                        model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
                        Docker          : false
                        Virtualization  : lxc
                        Kernel          : x86_64
                        Userland        : amd64
                        Systemuptime and Load:
                         21:37:36 up 3 min,  2 users,  load average: 9.68, 5.20, 4.05
                        CPU threads: 4
                        *** Time and Time Zones ***
                                       Local time: Wed 2023-10-11 21:37:36 CEST
                                   Universal time: Wed 2023-10-11 19:37:36 UTC
                                         RTC time: n/a
                                      NTP service: inactive
                                  RTC in local TZ: no
                        *** User and Groups ***
                        proxmox
                        /home/proxmox
                        proxmox sudo iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            6.0G        1.9G        3.6G        0.0K        543M        4.1G
                        Swap:           1.5G          0B        1.5G
                        Total:          7.5G        1.9G        5.1G
                                 6000 M total memory
                                 1876 M used memory
                                  179 M active memory
                                 2129 M inactive memory
                                 3579 M free memory
                                    0 M buffer memory
                                  544 M swap cache
                                 1512 M total swap
                                    0 M used swap
                                 1512 M free swap
                        *** FAILED SERVICES ***
                          UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
                        * run-rpc_pipefs.mount   loaded failed failed RPC Pipe File System
                        * sys-kernel-debug.mount loaded failed failed Kernel Debug File System
                        LOAD   = Reflects whether the unit definition was properly loaded.
                        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                        SUB    = The low-level unit activation state, values depend on unit type.
                        2 loaded units listed.
                        *** FILESYSTEM ***
                        Filesystem                          Type   Size  Used Avail Use% Mounted on
                        /dev/mapper/data2-vm--3108--disk--1 ext4    20G   14G  4.6G  76% /
                        none                                tmpfs  492K  4.0K  488K   1% /dev
                        tmpfs                               tmpfs  7.7G     0  7.7G   0% /dev/shm
                        tmpfs                               tmpfs  3.1G  152K  3.1G   1% /run
                        tmpfs                               tmpfs  5.0M     0  5.0M   0% /run/lock
                        tmpfs                               tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
                        tmpfs                               tmpfs  1.6G     0  1.6G   0% /run/user/1001
                        dmesg: read kernel buffer failed: Operation not permitted
                        TARGET SOURCE                              FSTYPE OPTIONS
                        /      /dev/mapper/data2-vm--3108--disk--1 ext4   rw,relatime,stripe=16
                        /var:
                        1.2G    /var/
                        478M    /var/lib
                        387M    /var/log
                        377M    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
                        Archived and active journals take up 40.0M in the file system.
                        /opt/iobroker/backups:
                        99M     /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        998M    /opt/iobroker/iobroker-data/
                        770M    /opt/iobroker/iobroker-data/files
                        179M    /opt/iobroker/iobroker-data/files/vis-2
                        163M    /opt/iobroker/iobroker-data/backup-objects
                        162M    /opt/iobroker/iobroker-data/files/vis
                        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
                        24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
                        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.eafddf6f.js.map
                        USB-Devices by-id:
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.18.1
                        /usr/bin/node           v18.18.1
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        /usr/bin/corepack       0.19.0
                        nodejs:
                          Installed: 18.18.1-1nodesource1
                          Candidate: 18.18.1-1nodesource1
                          Version table:
                         *** 18.18.1-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                             12.22.9~dfsg-1ubuntu3 500
                                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  5.0.13
                        admin:          6.10.7
                        javascript:     7.1.5
                        Adapters from github:   5
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : ioBrokerTestsystem                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.backitup.0               : backitup              : ioBrokerTestsystem                       -  enabled
                          system.adapter.benchmark.0              : benchmark             : ioBrokerTestsystem                       - disabled
                          system.adapter.daswetter.0              : daswetter             : ioBrokerTestsystem                       -  enabled
                          system.adapter.device-watcher.0         : device-watcher        : ioBrokerTestsystem                       - disabled
                          system.adapter.devices.0                : devices               : ioBrokerTestsystem                       - disabled
                          system.adapter.discovery.0              : discovery             : ioBrokerNew                              - disabled
                          system.adapter.dwd.0                    : dwd                   : ioBrokerTestsystem                       -  enabled
                        + system.adapter.echarts.0                : echarts               : ioBrokerTestsystem                       -  enabled
                        + system.adapter.fritzbox.0               : fritzbox              : ioBrokerTestsystem                       -  enabled
                        + system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioBrokerTestsystem                       -  enabled
                          system.adapter.history.1                : history               : ioBrokerNew                              - disabled
                        + system.adapter.hm-rega.0                : hm-rega               : ioBrokerTestsystem                       -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       -  enabled, port: 0
                          system.adapter.hue.0                    : hue                   : ioBrokerTestsystem                       - disabled, port: 443
                          system.adapter.ical.0                   : ical                  : ioBrokerTestsystem                       -  enabled
                          system.adapter.ical.1                   : ical                  : ioBrokerTestsystem                       -  enabled
                          system.adapter.ical.2                   : ical                  : ioBrokerTestsystem                       -  enabled
                          system.adapter.ical.3                   : ical                  : ioBrokerTestsystem                       -  enabled
                          system.adapter.ical.4                   : ical                  : ioBrokerTestsystem                       -  enabled
                          system.adapter.ical.5                   : ical                  : ioBrokerTestsystem                       -  enabled
                          system.adapter.icons-material-png.0     : icons-material-png    : ioBrokerTestsystem                       - disabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerTestsystem                       - disabled
                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBrokerTestsystem                       - disabled
                        + system.adapter.influxdb.0               : influxdb              : ioBrokerTestsystem                       -  enabled, port: 8086
                        + system.adapter.info.0                   : info                  : ioBrokerTestsystem                       -  enabled
                        + system.adapter.javascript.0             : javascript            : ioBrokerTestsystem                       -  enabled
                          system.adapter.mqtt.0                   : mqtt                  : ioBrokerTestsystem                       - disabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.nina.0                   : nina                  : ioBrokerTestsystem                       -  enabled
                          system.adapter.openweathermap.0         : openweathermap        : ioBrokerTestsystem                       -  enabled
                          system.adapter.proxmox.0                : proxmox               : ioBrokerTestsystem                       -  enabled, port: 8006
                          system.adapter.rainbird.0               : rainbird              : ioBrokerTestsystem                       - disabled
                          system.adapter.samsung-community.0      : samsung-community     : ioBrokerTestsystem                       - disabled
                          system.adapter.sayit.0                  : sayit                 : ioBrokerTestsystem                       - disabled, port: 0
                        + system.adapter.scenes.0                 : scenes                : ioBrokerTestsystem                       -  enabled
                          system.adapter.scheduler.0              : scheduler             : ioBrokerTestsystem                       - disabled
                          system.adapter.simple-api.0             : simple-api            : ioBrokerTestsystem                       - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                          system.adapter.socketio.0               : socketio              : ioBrokerTestsystem                       - disabled, port: 8084, bind: 192.168.178.77, run as: admin
                          system.adapter.spotify-premium.0        : spotify-premium       : ioBrokerTestsystem                       - disabled
                          system.adapter.sql.0                    : sql                   : ioBrokerNew                              - disabled, port: 3306
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBrokerTestsystem                       -  enabled
                          system.adapter.telegram.0               : telegram              : ioBrokerTestsystem                       - disabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.tr-064.0                 : tr-064                : ioBrokerTestsystem                       -  enabled
                        + system.adapter.trashschedule.0          : trashschedule         : ioBrokerTestsystem                       -  enabled
                        + system.adapter.unifi.0                  : unifi                 : ioBrokerTestsystem                       -  enabled
                        + system.adapter.valloxmv.0               : valloxmv              : ioBrokerTestsystem                       -  enabled, port: 80
                          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBrokerTestsystem                       - disabled
                          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBrokerTestsystem                       - disabled
                          system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBrokerTestsystem                       - disabled
                          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBrokerTestsystem                       - disabled
                        + system.adapter.vis-2.0                  : vis-2                 : ioBrokerTestsystem                       -  enabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBrokerTestsystem                       - disabled
                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBrokerTestsystem                       -  enabled
                          system.adapter.vis-history.0            : vis-history           : ioBrokerTestsystem                       - disabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBrokerTestsystem                       -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerTestsystem                       - disabled
                          system.adapter.vis-justgage.0           : vis-justgage          : ioBrokerTestsystem                       - disabled
                          system.adapter.vis-map.0                : vis-map               : ioBrokerTestsystem                       - disabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBrokerTestsystem                       - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerTestsystem                       - disabled
                          system.adapter.vis.0                    : vis                   : ioBrokerTestsystem                       - disabled
                        + system.adapter.web.0                    : web                   : ioBrokerTestsystem                       -  enabled, port: 8082, bind: 192.168.178.77, run as: admin
                          system.adapter.worx.0                   : worx                  : ioBrokerTestsystem                       - disabled
                        + instance is alive
                        + system.adapter.proxmox.0                : proxmox               : ioBrokerTestsystem                       -  enabled, port: 8006
                        ioBroker-Repositories
                        Active repo(s): beta
                        Installed ioBroker-Instances
                        Used repository: beta
                        Adapter    "admin"        : 6.10.6   , installed 6.10.7
                        Adapter    "backitup"     : 2.8.4    , installed 2.8.4
                        Adapter    "benchmark"    : 1.1.4    , installed 1.1.4
                        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                        Adapter    "device-watcher": 2.9.3   , installed 2.9.3
                        Adapter    "echarts"      : 1.5.4    , installed 1.5.4
                        Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                        Adapter    "hue"          : 3.10.0   , installed 3.10.0
                        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                        Adapter    "javascript"   : 7.1.5    , installed 7.1.5
                        Controller "js-controller": 5.0.13   , installed 5.0.13
                        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                        Adapter    "nina"         : 0.0.25   , installed 0.0.25
                        Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                        Adapter    "proxmox"      : 2.1.0    , installed 2.1.0
                        Adapter    "rainbird"     : 0.2.2    , installed 0.2.3
                        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                        Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
                        Adapter    "socketio"     : 6.5.7    , installed 6.5.7
                        Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
                        Adapter    "telegram"     : 2.0.1    , installed 2.0.1
                        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                        Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                        Adapter    "valloxmv"     : 1.2.0    , installed 1.2.0
                        Adapter    "vis"          : 1.4.16   , installed 1.4.16
                        Adapter    "vis-2"        : 2.3.0    , installed 2.3.0
                        Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
                        Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                        Adapter    "vis-2-widgets-jaeger-design": 1.0.4, installed 1.0.4
                        Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
                        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                        Adapter    "web"          : 6.1.4    , installed 6.1.4
                        Adapter    "worx"         : 2.3.3    , installed 2.3.3
                        Adapter    "ws"           : 2.5.7    , installed 2.5.7
                        Objects and States
                        Objects:        13136
                        States:         11795
                        Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                        Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                        Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          96948094   130/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          96947834   1/init
                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        96948831   87/systemd-resolved
                        tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       96966280   938/io.web.0
                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       96949593   110/iobroker.js-con
                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       96949587   110/iobroker.js-con
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          96949002   300/master
                        tcp        0      0 192.168.178.77:2010     0.0.0.0:*               LISTEN      1000       96960268   666/io.hm-rpc.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          96948096   130/sshd: /usr/sbin
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          96947836   1/init
                        tcp6       0      0 :::3000                 :::*                    LISTEN      108        96949149   109/grafana-server
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          96949003   300/master
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       96954033   525/io.admin.0
                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        96948830   87/systemd-resolved
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          96947835   1/init
                        udp6       0      0 :::111                  :::*                                0          96947837   1/init
                        xxx
                        Log in der Browser Konsole beim Starten der Wiederherstellung
                        [2023-10-11T19:25:55.789Z] ws connection error: CLOSE_GOING_AWAY socket.io.js:68:32
                        [2023-10-11T19:25:55.790Z] Start reconnect 0 socket.io.js:66:41
                        [2023-10-11T19:25:55.790Z] Try to connect socket.io.js:66:41
                        [2023-10-11T19:25:55.791Z] ws connection error: CLOSE_GOING_AWAY 8571.7d32213d.chunk.js:2:116526
                        [2023-10-11T19:25:55.792Z] Start reconnect 0 8571.7d32213d.chunk.js:2:116526
                        [2023-10-11T19:25:55.862Z] Try to connect 8571.7d32213d.chunk.js:2:116526
                        Diese Seite verwendet die nicht standardisierte Eigenschaft "zoom". Stattdessen sollte calc() in den entsprechenden Eigenschaftswerten oder "transform" zusammen mit "transform-origin: 0 0" verwendet werden. 192.168.178.77:8081
                        iobroker.admin@6.10.7 bootstrap.jsx:20:8
                        [2023-10-11T19:25:56.455Z] Try to connect instrument.ts:144
                        Stored version: , new version: 6.10.7 instrument.ts:144
                        Connected: true instrument.ts:144
                        Diese Seite befindet sich im Kompatibilitätsmodus (Quirks). Das Seitenlayout kann beeinflusst werden. Verwenden Sie für den Standardmodus "<!DOCTYPE html>". tab_m.html
                        Layout-Darstellung wurde erzwungen, bevor die Seite vollständig geladen war. Falls Stylesheet noch nicht geladen sind, kann dies zu einem kurzzeitigen Darstellung des Inhalts ohne Formatierung führen. stylesheets-manager.js:545:10
                        [2023-10-11T19:26:00.824Z] Try to connect socket.io.js:66:41
                        "Backitup": {"en": "Backitup", "de": "Backitup", "ru": "Backitup", "pt": "Backitup", "nl": "Backitup", "fr": "Backitup", "es": "Backitup", "pl": "Backitup", "it": "Backitup", "zh-cn": "Backitup"}, translate.js:24:17
                        current theme: react-colored tab_m.js:102:13
                        "ioBroker": {"en": "ioBroker", "de": "ioBroker", "ru": "ioBroker", "pt": "ioBroker", "nl": "ioBroker", "fr": "ioBroker", "es": "ioBroker", "pl": "ioBroker", "it": "ioBroker", "zh-cn": "ioBroker"}, translate.js:24:17
                        system.adapter.admin.0 instrument.ts:144
                        system.adapter.backitup.0 instrument.ts:144
                        system.adapter.benchmark.0 instrument.ts:144
                        system.adapter.daswetter.0 instrument.ts:144
                        system.adapter.device-watcher.0 instrument.ts:144
                        system.adapter.devices.0 instrument.ts:144
                        system.adapter.discovery.0 instrument.ts:144
                        system.adapter.dwd.0 instrument.ts:144
                        system.adapter.echarts.0 instrument.ts:144
                        system.adapter.fritzbox.0 instrument.ts:144
                        system.adapter.fully-tablet-control.0 instrument.ts:144
                        system.adapter.history.1 instrument.ts:144
                        system.adapter.hm-rega.0 instrument.ts:144
                        system.adapter.hm-rpc.0 instrument.ts:144
                        system.adapter.hue.0 instrument.ts:144
                        system.adapter.ical.0 instrument.ts:144
                        system.adapter.ical.1 instrument.ts:144
                        system.adapter.ical.2 instrument.ts:144
                        system.adapter.ical.3 instrument.ts:144
                        system.adapter.ical.4 instrument.ts:144
                        system.adapter.ical.5 instrument.ts:144
                        system.adapter.icons-material-png.0 instrument.ts:144
                        system.adapter.icons-mfd-svg.0 instrument.ts:144
                        system.adapter.icons-ultimate-png.0 instrument.ts:144
                        system.adapter.influxdb.0 instrument.ts:144
                        system.adapter.info.0 instrument.ts:144
                        system.adapter.javascript.0 instrument.ts:144
                        system.adapter.mqtt.0 instrument.ts:144
                        system.adapter.nina.0 instrument.ts:144
                        system.adapter.openweathermap.0 instrument.ts:144
                        system.adapter.proxmox.0 instrument.ts:144
                        system.adapter.rainbird.0 instrument.ts:144
                        system.adapter.samsung-community.0 instrument.ts:144
                        system.adapter.sayit.0 instrument.ts:144
                        system.adapter.scenes.0 instrument.ts:144
                        system.adapter.scheduler.0 instrument.ts:144
                        system.adapter.simple-api.0 instrument.ts:144
                        system.adapter.socketio.0 instrument.ts:144
                        system.adapter.spotify-premium.0 instrument.ts:144
                        system.adapter.sql.0 instrument.ts:144
                        system.adapter.tankerkoenig.0 instrument.ts:144
                        system.adapter.telegram.0 instrument.ts:144
                        system.adapter.tr-064.0 instrument.ts:144
                        system.adapter.trashschedule.0 instrument.ts:144
                        system.adapter.unifi.0 instrument.ts:144
                        system.adapter.valloxmv.0 instrument.ts:144
                        system.adapter.vis.0 instrument.ts:144
                        system.adapter.vis-2.0 instrument.ts:144
                        system.adapter.vis-2-widgets-energy.0 instrument.ts:144
                        system.adapter.vis-2-widgets-gauges.0 instrument.ts:144
                        system.adapter.vis-2-widgets-jaeger-design.0 instrument.ts:144
                        system.adapter.vis-2-widgets-material.0 instrument.ts:144
                        system.adapter.vis-fancyswitch.0 instrument.ts:144
                        system.adapter.vis-google-fonts.0 instrument.ts:144
                        system.adapter.vis-history.0 instrument.ts:144
                        system.adapter.vis-inventwo.0 instrument.ts:144
                        system.adapter.vis-jqui-mfd.0 instrument.ts:144
                        system.adapter.vis-justgage.0 instrument.ts:144
                        system.adapter.vis-map.0 instrument.ts:144
                        system.adapter.vis-materialdesign.0 instrument.ts:144
                        system.adapter.vis-timeandweather.0 instrument.ts:144
                        system.adapter.web.0 instrument.ts:144
                        system.adapter.worx.0 instrument.ts:144
                        getInstances: 75 instrument.ts:144
                        Diese Seite befindet sich im Kompatibilitätsmodus (Quirks). Das Seitenlayout kann beeinflusst werden. Verwenden Sie für den Standardmodus "<!DOCTYPE html>". index_m.html
                        [2023-10-11T19:26:52.015Z] Try to connect socket.io.js:66:41
                        Passwort-Felder sind in einem unsicheren (http://) Iframe vorhanden. Dies ist ein Sicherheitsrisiko, durch das Zugangsdaten gestohlen werden können. index_m.html
                        "Signal": {"en": "Signal", "de": "Signal", "ru": "Signal", "pt": "Signal", "nl": "Signal", "fr": "Signal", "es": "Signal", "pl": "Signal", "it": "Signal", "zh-cn": "Signal"}, translate.js:24:17
                        "Discord": {"en": "Discord", "de": "Discord", "ru": "Discord", "pt": "Discord", "nl": "Discord", "fr": "Discord", "es": "Discord", "pl": "Discord", "it": "Discord", "zh-cn": "Discord"}, translate.js:24:17
                        "http": {"en": "http", "de": "http", "ru": "http", "pt": "http", "nl": "http", "fr": "http", "es": "http", "pl": "http", "it": "http", "zh-cn": "http"}, translate.js:24:17
                        "https": {"en": "https", "de": "https", "ru": "https", "pt": "https", "nl": "https", "fr": "https", "es": "https", "pl": "https", "it": "https", "zh-cn": "https"}, translate.js:24:17
                        "1.x": {"en": "1.x", "de": "1.x", "ru": "1.x", "pt": "1.x", "nl": "1.x", "fr": "1.x", "es": "1.x", "pl": "1.x", "it": "1.x", "zh-cn": "1.x"}, translate.js:24:17
                        "2.x": {"en": "2.x", "de": "2.x", "ru": "2.x", "pt": "2.x", "nl": "2.x", "fr": "2.x", "es": "2.x", "pl": "2.x", "it": "2.x", "zh-cn": "2.x"}, translate.js:24:17
                        Restore Type: local index_m.js:722:25
                        Object { data: {…} }
                        index_m.js:725:29
                        Object { local: {…} }
                        index_m.js:736:33
                        "OK": {"en": "OK", "de": "OK", "ru": "OK", "pt": "OK", "nl": "OK", "fr": "OK", "es": "OK", "pl": "OK", "it": "OK", "zh-cn": "OK"}, translate.js:24:17
                        "Started restore ...": {"en": "Started restore ...", "de": "Started restore ...", "ru": "Started restore ...", "pt": "Started restore ...", "nl": "Started restore ...", "fr": "Started restore ...", "es": "Started restore ...", "pl": "Started restore ...", "it": "Started restore ...", "zh-cn": "Started restore ..."}, translate.js:24:17
                        "ioBroker will be stopped and started again. Please wait": {"en": "ioBroker will be stopped and started again. Please wait", "de": "ioBroker will be stopped and started again. Please wait", "ru": "ioBroker will be stopped and started again. Please wait", "pt": "ioBroker will be stopped and started again. Please wait", "nl": "ioBroker will be stopped and started again. Please wait", "fr": "ioBroker will be stopped and started again. Please wait", "es": "ioBroker will be stopped and started again. Please wait", "pl": "ioBroker will be stopped and started again. Please wait", "it": "ioBroker will be stopped and started again. Please wait", "zh-cn": "ioBroker will be stopped and started again. Please wait"}, translate.js:24:17
                        Speicherverbrauch von "will-change" ist zu hoch. Die Budget-Grenze ist die Fläche des Dokuments multipliziert mit 3 (869076 px). Vorkommen von "will-change", die das Budget überschreiten, werden ignoriert. index_m.html
                        Restore finish! index_m.js:849:53
                        Restore Url: http://192.168.178.77:8091/backitup-restore.html index_m.js:852:57
                        [2023-10-11T19:27:40.593Z] ws connection error: CLOSE_ABNORMAL socket.io.js:68:32
                        [2023-10-11T19:27:40.594Z] Start reconnect 0 socket.io.js:66:41
                        [2023-10-11T19:27:40.594Z] Try to connect socket.io.js:66:41
                        [2023-10-11T19:27:40.595Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:27:40.596Z] Start reconnect 0 instrument.ts:144
                        [2023-10-11T19:27:40.661Z] Try to connect instrument.ts:144
                        [2023-10-11T19:27:43.601Z] No READY flag received in 3 seconds. Re-init socket.io.js:67:32
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081//adapter/backitup?sid=1697052460594 aufbauen. socket.io.js:140:21
                        [2023-10-11T19:27:43.602Z] Start reconnect 1 socket.io.js:66:41
                        Die Verbindung zu ws://192.168.178.77:8081//adapter/backitup?sid=1697052460594 wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:27:43.608Z] Reconnect is already running 1 socket.io.js:66:41
                        [2023-10-11T19:27:43.608Z] ws connection error: CLOSE_ABNORMAL socket.io.js:68:32
                        [2023-10-11T19:27:43.693Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052460662&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:27:43.694Z] Start reconnect 1 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052460662&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:27:43.697Z] Reconnect is already running 1 instrument.ts:144
                        [2023-10-11T19:27:43.697Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:27:44.610Z] Try to connect socket.io.js:66:41
                        [2023-10-11T19:27:44.706Z] Try to connect instrument.ts:144
                        [2023-10-11T19:27:45.751Z] ws connection error: CLOSE_ABNORMAL socket.io.js:68:32
                        [2023-10-11T19:27:45.751Z] Start reconnect 2 socket.io.js:66:41
                        [2023-10-11T19:27:47.717Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052464707&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:27:47.718Z] Start reconnect 2 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052464707&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:27:47.725Z] Reconnect is already running 2 instrument.ts:144
                        [2023-10-11T19:27:47.727Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:27:47.729Z] Reconnect is already running 2 instrument.ts:144
                        [2023-10-11T19:27:49.720Z] Try to connect instrument.ts:144
                        [2023-10-11T19:27:52.738Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052469720&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:27:52.738Z] Start reconnect 3 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052469720&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:27:52.744Z] Reconnect is already running 3 instrument.ts:144
                        [2023-10-11T19:27:52.745Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:27:52.746Z] Reconnect is already running 3 instrument.ts:144
                        [2023-10-11T19:27:55.805Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052475811&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:27:57.881Z] Start reconnect 4 instrument.ts:144
                        [2023-10-11T19:27:57.881Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:27:57.882Z] Reconnect is already running 4 instrument.ts:144
                        [2023-10-11T19:28:01.888Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052481894&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:28:03.962Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:28:03.963Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:28:03.964Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:28:08.968Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052488968&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:28:11.022Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:28:11.023Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:28:11.025Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:28:16.076Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052496077&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:28:18.138Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:28:18.139Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:28:18.141Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:28:23.147Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052503147&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:28:25.202Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:28:25.203Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:28:25.204Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:28:30.235Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052510236&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:28:32.291Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:28:32.291Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:28:32.292Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:28:37.296Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052517298&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:28:39.395Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:28:39.396Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:28:39.397Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:28:44.436Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052524436&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:28:47.063Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:28:47.063Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:28:47.064Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:28:52.065Z] Try to connect instrument.ts:144
                        [2023-10-11T19:28:55.080Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052532066&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:28:55.081Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052532066&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:28:55.085Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:28:55.086Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:28:55.087Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:00.130Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052540133&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:29:02.185Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:29:02.186Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:29:02.189Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:07.203Z] Try to connect instrument.ts:144
                        [2023-10-11T19:29:10.219Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052547203&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:29:10.219Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052547203&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:29:10.223Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:10.223Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:29:10.224Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:15.290Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052555291&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:29:17.347Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:29:17.348Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:29:17.349Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:22.377Z] Try to connect instrument.ts:144
                        [2023-10-11T19:29:25.408Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052562378&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:29:25.409Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052562378&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:29:25.414Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:25.414Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:29:25.415Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:30.424Z] Try to connect instrument.ts:144
                        [2023-10-11T19:29:33.480Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052570424&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:29:33.480Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052570424&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:29:33.482Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:33.483Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:29:33.484Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:38.484Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052578484&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:29:40.532Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:29:40.533Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:29:40.534Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:45.537Z] Try to connect instrument.ts:144
                        [2023-10-11T19:29:48.553Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052585538&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:29:48.553Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052585538&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:29:48.559Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:48.559Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:29:48.560Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:53.564Z] Try to connect instrument.ts:144
                        [2023-10-11T19:29:56.569Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052593565&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:29:56.569Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052593565&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:29:56.571Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:29:56.571Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:29:56.572Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:01.572Z] Try to connect instrument.ts:144
                        [2023-10-11T19:30:04.589Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052601573&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:30:04.589Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052601573&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:30:04.670Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:04.671Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:30:04.671Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:09.597Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052609598&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:30:11.655Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:30:11.656Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:30:11.656Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:16.659Z] Try to connect instrument.ts:144
                        [2023-10-11T19:30:19.660Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052616659&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:30:19.661Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052616659&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:30:19.664Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:19.664Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:30:24.673Z] Try to connect instrument.ts:144
                        [2023-10-11T19:30:27.676Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052624673&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:30:27.676Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052624673&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:30:27.678Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:27.678Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:30:27.679Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:32.678Z] Try to connect instrument.ts:144
                        [2023-10-11T19:30:35.694Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052632678&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:30:35.695Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052632678&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:30:35.696Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:35.696Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:30:35.697Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:40.705Z] Try to connect instrument.ts:144
                        [2023-10-11T19:30:43.710Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052640705&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:30:43.711Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052640705&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:30:43.713Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:43.714Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:30:43.715Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:48.782Z] Try to connect instrument.ts:144
                        [2023-10-11T19:30:51.818Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052648782&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:30:51.819Z] Start reconnect 5 instrument.ts:144
                        Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052648782&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                        [2023-10-11T19:30:51.821Z] Reconnect is already running 5 instrument.ts:144
                        [2023-10-11T19:30:51.821Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:30:57.495Z] Try to connect instrument.ts:144
                        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052657496&name=admin aufbauen. socket.io.js:140:21
                        [2023-10-11T19:30:59.563Z] Start reconnect 5 instrument.ts:144
                        [2023-10-11T19:30:59.563Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                        [2023-10-11T19:30:59.564Z] Reconnect is already running 5 instrument.ts:144
                        Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @Feuersturm last edited by
                          @feuersturm sagte in Test Adapter ioBroker.backitup v2.8.x:
                          • run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                          Da klemmt es wohl beim mount irgendwo.
                          Wird das Backup auf eine Freigabe geschoben?
                          • Feuersturm
                            Feuersturm @Thomas Braun last edited by
                            @thomas-braun Nein, bei dem Testsystem wird das Backup lokal abgelegt
                            • simatec
                              simatec Developer Most Active @Feuersturm last edited by
                              @feuersturm socket hat hier keinen Einfluss, da ja iob komplett gestoppt ist. Backitup spannt einen eigenen Webserver für das restore Interface auf.
                              Auf welchen System hast du dein Testsystem laufen? Docker?
                              • simatec
                                @feuersturm Normal sollte es so aussehen ... Ist gerade mit aktueller Backitup Version getestet
                                • Feuersturm
                                  Feuersturm @simatec last edited by
                                  @simatec sagte in Test Adapter ioBroker.backitup v2.8.x:
                                  Nein, es läuft unter proxmox in einem lxc Container
                                  • simatec
                                    @feuersturm gut bei mir in dem test auch. Ein lxc mit debian12
                                    • Feuersturm
                                      @simatec Ich hab es mit meinem Firefoxbrowser getestet. Kann es nochmal mit meinem Chromebrowser testen ob es sich dort anders verhält.
                                      • mickym
                                        mickym Most Active last edited by mickym
                                        Ich hab mal ein neues Issue für das Node-Red Backup erstellt.
                                        https://github.com/simatec/ioBroker.backitup/issues/1005
                                        Im Prinzip ist das Backup für die 1. Instanz nun voll nutzbar - man muss aber manuell noch ein npm install ausführen.
                                        Zusätzliche Instanzen werden aber nicht erkannt.
                                        mickym2 created this issue in simatec/ioBroker.backitup
                                        closed Backitup NodeRed does not recognize additional instances of the adapter and some proposals after restore #1005
                                        • simatec
                                          @feuersturm ja das wäre gut. Eventuell blockt der Firefox Popups
                                          • simatec
                                            simatec Developer Most Active @mickym last edited by
                                            @mickym npm muss manuell ausgeführt werden. Wegen der unterschiedlichen Instanzen muss ich schauen. Bei mir waren die Tests alle in Ordnung
                                            170
                                            2779
                                            2301876
