    4. Update ioBroker klappt nicht - gelöst durch neuinstallation
      Thomas Braun Most Active @DLaurenz last edited by
      @dlaurenz
      Zeig mal das ganze.
        DLaurenz @Thomas Braun last edited by DLaurenz
        gern
        pi@io-fhem:~ $ iob fix
        library: loaded
        Library version=2023-10-10
            Welcome to the ioBroker installation fixer!
            Script version: 2023-04-02
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
        OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        OK:2 http://archive.raspberrypi.org/debian buster InRelease
        OK:3 https://repo.saltproject.io/py3/debian/10/amd64/latest buster InRelease
        OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Ign:5 https://download.webmin.com/download/repository sarge InRelease
        OK:6 https://download.webmin.com/download/repository sarge Release
        E: Paket gcc-c+ kann nicht gefunden werden.
        E: Mittels regulärem Ausdruck »gcc-c+« konnte kein Paket gefunden werden.
        Installed gcc-c++
            Checking ioBroker user and directory permissions (2/5)
        Created /etc/sudoers.d/iobroker
        Fixing directory permissions...
            Check and cleanup npm temporary directories (3/5)
        Done.
            Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        No relevant JSONL files found to compress, skip
            Checking autostart (5/5)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        und danach iob diag:
        pi@io-fhem:~ $ iob diag
        *** iob diag is starting up, please wait ***
        The state system.host.io-fhem.versions.nodeNewestNext was not found!
        The state system.host.io-fhem.versions.npmNewestNext was not found!
        The state system.host.io-fhem.versions.nodeCurrent was not found!
        *** ioBroker Diagnosis ***
        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
        https://forum.iobroker.net
        Just copy and paste the Summary Page, including the ``` characters at start and end.
        It helps us to help you!
        Press any key to continue
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: io-fhem
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7+
              Architecture: arm
        Model           : Raspberry Pi 3 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         05:49:13 up 11:03,  1 user,  load average: 0.74, 0.52, 0.35
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Thu 2023-10-12 05:49:13 CEST
                   Universal time: Thu 2023-10-12 03:49:13 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:           972M        142M        222M        3.0M        607M        762M
        Swap:           99M         57M         42M
        Total:         1.1G        200M        265M
                  972 M total memory
                  142 M used memory
                  458 M active memory
                  168 M inactive memory
                  222 M free memory
                  130 M buffer memory
                  476 M swap cache
                   99 M total swap
                   57 M used swap
                   42 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
        * iobroker.service loaded failed failed ioBroker Server
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        Filesystem                         Type      Size  Used Avail Use% Mounted on
        /dev/root                          ext4       30G  7.6G   20G  28% /
        devtmpfs                           devtmpfs  454M     0  454M   0% /dev
        tmpfs                              tmpfs     487M  8.0K  487M   1% /dev/shm
        tmpfs                              tmpfs     487M   13M  474M   3% /run
        tmpfs                              tmpfs     5.0M  4.0K  5.0M   1% /run/lock
        tmpfs                              tmpfs     487M     0  487M   0% /sys/fs/cgroup
        /dev/mmcblk0p1                     vfat       43M   25M   18M  59% /boot
        tmpfs                              tmpfs      98M     0   98M   0% /run/user/0
        fs01.samba.laurenz.ws:/BACKUPS     nfs        11T  7.2T  3.4T  69% /autofs/backup
        fs04.samba.laurenz.ws:/SOFTWARE    nfs       8.2T  5.9T  2.3T  73% /autofs/software
        fs04.samba.laurenz.ws:/MAILFUJITSU nfs       8.2T  5.9T  2.3T  73% /autofs/mailfujitsu
        fs01.samba.laurenz.ws:/NFS         nfs        11T  7.2T  3.4T  69% /autofs/nfs
        [Wed Oct 11 18:45:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=1bf224e2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Wed Oct 11 18:45:43 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Wed Oct 11 18:45:43 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Oct 11 18:45:45 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        [Wed Oct 11 23:32:51 2023] [<802b0ee8>] (filemap_fault) from [<8042d260>] (ext4_filemap_fault+0x38/0x4c)
        [Wed Oct 11 23:32:51 2023] [<8042d228>] (ext4_filemap_fault) from [<802e8900>] (__do_fault+0x48/0x14c)
        TARGET                SOURCE                             FSTYPE OPTIONS
        /                     /dev/mmcblk0p2                     ext4   rw,noatime
        |-/sys/fs/bpf         none                               bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        |-/boot               /dev/mmcblk0p1                     vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        |-/autofs/software    fs04.samba.laurenz.ws:/SOFTWARE    nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.74,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.74
        |-/autofs/mailfujitsu fs04.samba.laurenz.ws:/MAILFUJITSU nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.74,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.74
        |-/autofs/backup      fs01.samba.laurenz.ws:/BACKUPS     nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.72,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.72
        `-/autofs/nfs         fs01.samba.laurenz.ws:/NFS         nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.72,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.72
        /var:
        1.7G    /var/
        881M    /var/cache
        705M    /var/cache/apt
        645M    /var/cache/apt/archives
        583M    /var/mail
        Archived and active journals take up 12.1M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        5.2M    /opt/iobroker/iobroker-data/
        776K    /opt/iobroker/iobroker-data/backup-objects
        532K    /opt/iobroker/iobroker-data/files
        440K    /opt/iobroker/iobroker-data/files/discovery.admin
        88K     /opt/iobroker/iobroker-data/files/admin.admin
        1.5M    /opt/iobroker/iobroker-data/objects.jsonl
        1.5M    /opt/iobroker/iobroker-data/objects.json.migrated
        964K    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        448K    /opt/iobroker/iobroker-data/backup-objects/2020-08-24_00-13_objects.json.gz
        288K    /opt/iobroker/iobroker-data/backup-objects/2019-05-10_23-20_objects.json.gz
        USB-Devices by-id:
        /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DJ00TW49-if00-port0
        /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014B93EF0-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.1
        /usr/bin/node           v18.18.1
        /usr/bin/npm            10.2.0
        /usr/bin/npx            10.2.0
        /usr/bin/corepack       0.21.0
        nodejs:
          Installed: 18.18.1-1nodesource1
          Candidate: 18.18.1-1nodesource1
          Version table:
         *** 18.18.1-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! invalid: iobroker.js-controller@5.0.13 /opt/iobroker/node_modules/iobroker.js-controller
        npm ERR! invalid: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
        npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-12T03_49_27_265Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        At least one iobroker host is running.
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.13
        admin:          6.2.23
        javascript:     "javascript" not found
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-12T03_49_54_984Z-debug-0.log
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : io-master                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.1                  : admin                 : io-vis                                   - disabled, port: 8081, bind: 127.0.0.1, run as: admin
          system.adapter.admin.2                  : admin                 : io-blegw02                               - disabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.3                  : admin                 : io-influxdb                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : io-master                                -  enabled
          system.adapter.backitup.1               : backitup              : io-fhem                                  - disabled
        + system.adapter.ble.0                    : ble                   : io-blegw02                               -  enabled
          system.adapter.daswetter.0              : daswetter             : io-vis                                   -  enabled
        + system.adapter.discovery.0              : discovery             : io-master                                -  enabled
          system.adapter.dwd.0                    : dwd                   : io-vis                                   -  enabled
          system.adapter.fhem.0                   : fhem                  : io-fhem                                  -  enabled, port: 7072
          system.adapter.flot.0                   : flot                  : io-vis                                   -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : io-master                                -  enabled
        + system.adapter.hmip.0                   : hmip                  : io-master                                -  enabled
          system.adapter.homeconnect.0            : homeconnect           : io-master                                - disabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: io-vis                                   -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : io-vis                                   -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : io-vis                                   -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : io-vis                                   -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : io-vis                                   -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : io-vis                                   -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: io-vis                                   -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : io-vis                                   -  enabled
        + system.adapter.influxdb.0               : influxdb              : io-influxdb                              -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : io-master                                -  enabled
        + system.adapter.meross.0                 : meross                : io-master                                -  enabled
          system.adapter.smartgarden.0            : smartgarden           : io-master                                - disabled
          system.adapter.vis-bars.0               : vis-bars              : io-vis                                   -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : io-vis                                   -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : io-vis                                   -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : io-vis                                   -  enabled
          system.adapter.vis-history.0            : vis-history           : io-vis                                   -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : io-vis                                   -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : io-vis                                   -  enabled
          system.adapter.vis-lcars.0              : vis-lcars             : io-vis                                   -  enabled
          system.adapter.vis-material.0           : vis-material          : io-vis                                   -  enabled
          system.adapter.vis-metro.0              : vis-metro             : io-vis                                   -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : io-vis                                   -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : io-vis                                   -  enabled
          system.adapter.vis-weather.0            : vis-weather           : io-vis                                   -  enabled
          system.adapter.vis.0                    : vis                   : io-vis                                   -  enabled
        + system.adapter.web.0                    : web                   : io-vis                                   -  enabled, port: 8082, bind: 192.168.2.112, run as: admin
          system.adapter.zigbee.0                 : zigbee                : io-fhem                                  - disabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.10.7   , installed 6.2.23 [Updatable]
        Adapter    "backitup"     : 2.8.4    , installed 2.5.6  [Updatable]
        Adapter    "ble"          : 0.13.4   , installed 0.13.4
        Adapter    "discovery"    : 4.2.0    , installed 3.2.0  [Updatable]
        Adapter    "fhem"         : 2.0.5    , installed 2.0.3  [Updatable]
        Adapter    "fritzdect"    : 2.4.1    , installed 2.3.1  [Updatable]
        Adapter    "homeconnect"  : 1.1.1    , installed 1.0.1  [Updatable]
        Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
        Controller "js-controller": 5.0.13   , installed 5.0.13
        Adapter    "socketio"     : 6.5.8    , installed 6.5.2  [Updatable]
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "web"          : 6.1.5    , installed 5.5.3  [Updatable]
        Adapter    "ws"           : 2.5.8    , installed 2.5.3  [Updatable]
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
        Objects and States
        Objects:        4796
        States:         4194
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://repo.saltproject.io/py3/debian/10/amd64/latest buster InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:6 https://download.webmin.com/download/repository sarge Release
        Reading package lists...
        Pending Updates: 2
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          23649      1/init
        tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          515393     4086/perl
        tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        520728     4302/perl
        tcp        0      0 0.0.0.0:48531           0.0.0.0:*               LISTEN      106        514537     4093/rpc.statd
        tcp        0      0 0.0.0.0:43957           0.0.0.0:*               LISTEN      0          165832     -
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17133      679/sshd
        tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        518479     4302/perl
        tcp6       0      0 :::42983                :::*                    LISTEN      0          165834     -
        tcp6       0      0 :::111                  :::*                    LISTEN      0          23655      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17135      679/sshd
        tcp6       0      0 :::6556                 :::*                    LISTEN      998        657078     5951/cmk-agent-ctl
        tcp6       0      0 :::47389                :::*                    LISTEN      106        514541     4093/rpc.statd
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15128      512/dhcpcd
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          23651      1/init
        udp        0      0 192.168.2.113:123       0.0.0.0:*                           109        20456      583/ntpd
        udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          16992      583/ntpd
        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          16988      583/ntpd
        udp        0      0 0.0.0.0:56477           0.0.0.0:*                           108        12093      362/avahi-daemon: r
        udp        0      0 0.0.0.0:51910           0.0.0.0:*                           0          165831     -
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12091      362/avahi-daemon: r
        udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          515394     4086/perl
        udp        0      0 127.0.0.1:877           0.0.0.0:*                           0          514531     4093/rpc.statd
        udp        0      0 0.0.0.0:56857           0.0.0.0:*                           106        514535     4093/rpc.statd
        udp6       0      0 :::35385                :::*                                108        12094      362/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          21979      1/init
        udp6       0      0 :::53872                :::*                                106        514539     4093/rpc.statd
        udp6       0      0 :::123                  :::*                                0          16985      583/ntpd
        udp6       0      0 :::5353                 :::*                                108        12092      362/avahi-daemon: r
        udp6       0      0 :::53242                :::*                                0          165833     -
        2023-10-12 04:42:14.144  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 04:47:14.127  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 04:52:14.129  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 04:57:14.131  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 05:02:14.132  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 05:07:14.134  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 05:12:14.137  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 05:17:14.136  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 05:22:14.140  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 05:27:14.141  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 05:32:14.143  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 05:37:14.146  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 05:42:14.147  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2023-10-12 05:44:01.807  - info: host.io-fhem received SIGTERM
        2023-10-12 05:44:01.820  - info: host.io-fhem stopInstance system.adapter.fhem.0 (force=false, process=true)
        2023-10-12 05:44:01.824  - info: host.io-fhem stopInstance system.adapter.zigbee.0 (force=false, process=false)
        2023-10-12 05:44:01.825  - info: host.io-fhem stopInstance system.adapter.backitup.1 (force=false, process=false)
        2023-10-12 05:44:01.830  - info: fhem.0 (5908) terminating
        2023-10-12 05:44:01.834  - info: host.io-fhem stopInstance system.adapter.fhem.0 send kill signal
        2023-10-12 05:44:01.833  - info: fhem.0 (5908) Terminated (NO_ERROR): Without reason
        2023-10-12 05:44:01.837  - info: fhem.0 (5908) Got terminate signal TERMINATE_YOURSELF
        2023-10-12 05:44:02.327  - info: fhem.0 (5908) terminating
        2023-10-12 05:44:02.638  - info: host.io-fhem instance system.adapter.fhem.0 terminated with code 0 (NO_ERROR)
        2023-10-12 05:44:02.640  - info: host.io-fhem All instances are stopped.
        2023-10-12 05:44:02.664  - info: host.io-fhem terminated
                                v.2023-10-10
                 Icon name: computer
              Architecture: arm
        Installation:           native
        Kernel:                 armv7l
        Userland:               armhf
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     2
        Pending iob updates:    11
        Nodejs-Installation:    /usr/bin/nodejs         v18.18.1
                                /usr/bin/npm            10.2.0
                                /usr/bin/npx            10.2.0
        Recommended versions are nodejs  and npm
        MEMORY:
        Mem:           972M        142M        214M        3.0M        616M        763M
        Swap:           99M         57M         42M
        Total:         1.1G        199M        256M
        Active iob-Instances:   11
        ioBroker Core:          js-controller           5.0.13
                                admin                   6.2.23
        ioBroker Status:        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects:                4796
        States:                 4194
        Size of iob-Database:
        8.0K    /opt/iobroker/iobroker-data/states.jsonl
        8.0K    /opt/iobroker/iobroker-data/states.json.migrated
        8.0K    /opt/iobroker/iobroker-data/states.json.bak.migrated
        D DJMarc75 2 Replies Last reply Reply Quote 0
          DLaurenz @DLaurenz last edited by
          @dlaurenz
          ich hatte dann noch mal ein upgrade self gemacht... nun stehe ich hier (iob diag habe ich danach nochmal gemacht)
          irgendwie ist da noch irgendwas in den files verdreht
          root@io-fhem:/opt/iobroker# npm ls
          iobroker.inst@2.0.3 /opt/iobroker
          ├── colors@1.4.0
          ├── fs-extra@7.0.1
          ├── iobroker.admin@6.2.23
          ├── iobroker.backitup@2.5.6
          ├── iobroker.ble@0.13.4
          ├── iobroker.discovery@3.2.0
          ├── iobroker.fhem@2.0.3
          ├── iobroker.flot@1.12.0
          ├── iobroker.fritzdect@2.3.1
          ├── iobroker.homeconnect@1.0.1
          ├── iobroker.info@1.9.26
          ├── iobroker.js-controller@5.0.13 invalid: "4.0.24" from the root project
          ├── iobroker.simple-api@2.7.2
          ├── iobroker.socketio@6.5.2
          ├── iobroker.vis@1.4.16
          ├── iobroker.web@5.5.3
          ├── iobroker.ws@2.5.3
          ├── iobroker.zigbee@1.8.10
          ├── iobroker@2.0.3
          ├── semver@5.7.2
          ├── serialport@7.1.5
          └── yargs@7.1.2
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T04_02_07_902Z-debug-0.log
            @dlaurenz
            root@io-fhem:~# find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
            root@io-fhem:~#
            root@io-fhem:~# cd /opt/iobroker/
            root@io-fhem:/opt/iobroker# npm list
            ├── colors@1.4.0
            ├── fs-extra@7.0.1
            ├── iobroker.js-controller@4.0.24
            ├── iobroker@2.0.3
            ├── semver@5.7.2
            └── yargs@7.1.2
            root@io-fhem:/opt/iobroker# iob upgrade fritzdect --debug
            This upgrade of "fritzdect" will introduce the following changes:
            -> 2.4.1:
            correctionts reported by adapter-checker
            -> 2.4.0:
            new function for routines, correction for templates
            Would you like to upgrade fritzdect from @2.3.1 to @2.4.1 now? [(y)es, (n)o]: y
            Update fritzdect from @2.3.1 to @2.4.1
            NPM version: 10.2.0
            Installing iobroker.fritzdect@2.4.1... (System call)
            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            npm WARN cleanup Failed to remove some directories [
            npm WARN cleanup   [
            npm WARN cleanup     '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket',
            npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build/Release'] {
            npm WARN cleanup       errno: -39,
            npm WARN cleanup       code: 'ENOTEMPTY',
            npm WARN cleanup       syscall: 'rmdir',
            npm WARN cleanup       path: '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build/Release'
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ]
            npm WARN cleanup ]
            npm ERR! code 1
            npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
            npm ERR! command failed
            npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
            npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
            npm ERR!   CXX(target) Release/obj.target/bindings/src/serialport.o
            npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
            npm ERR! gyp info it worked if it ends with ok
            npm ERR! gyp info using node-gyp@9.4.0
            npm ERR! gyp info using node@18.18.1 | linux | arm
            npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
            npm ERR! gyp info spawn /usr/bin/python3
            npm ERR! gyp info spawn args [
            npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
            npm ERR! gyp info spawn args   'binding.gyp',
            npm ERR! gyp info spawn args   '-f',
            npm ERR! gyp info spawn args   'make',
            npm ERR! gyp info spawn args   '-I',
            npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',
            npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
            npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.1/include/node/common.gypi',
            npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
            npm ERR! gyp info spawn args   '-Dvisibility=default',
            npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.1',
            npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
            npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.1/<(target_arch)/node.lib',
            npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',
            npm ERR! gyp info spawn args   '-Dnode_engine=v8',
            npm ERR! gyp info spawn args   '--depth=.',
            npm ERR! gyp info spawn args   '--no-parallel',
            npm ERR! gyp info spawn args   '--generator-output',
            npm ERR! gyp info spawn args   'build',
            npm ERR! gyp info spawn args   '-Goutput_dir=.'
            npm ERR! gyp info spawn args ]
            npm ERR! gyp info spawn make
            npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
            npm ERR!        ^~~~~~~~~~~~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
            npm ERR!        ^~~~~~~~~~~~~~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
            npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
            npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
            npm ERR!      results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
            npm ERR!        ^
            npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-array-buffer.h:13,
            npm ERR!                  from /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8.h:24,
            npm ERR!                  from /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:73,
            npm ERR!                  from ../../../nan/nan.h:62,
            npm ERR!                  from ../src/./serialport.h:6,
            npm ERR!                  from ../src/serialport.cpp:1:
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
            npm ERR!    V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
            npm ERR!                                      ^~~
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:244:37: note:   candidate expects 3 arguments, 2 provided
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
            npm ERR!    V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
            npm ERR!                                      ^~~
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:247:37: note:   candidate expects 3 arguments, 2 provided
            npm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
            npm ERR!      results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
            npm ERR!        ^
            npm ERR!                                      ^~~
            npm ERR!                                      ^~~
            npm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
            npm ERR!      results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
            npm ERR!        ^
            npm ERR!                                      ^~~
            npm ERR!                                      ^~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
            npm ERR!        ^~~~~~~~~~~~~~~~~~~~
            npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
            npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
            npm ERR!      results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
            npm ERR!        ^
            npm ERR!                                      ^~~
            npm ERR!                                      ^~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
            npm ERR! ../src/serialport.cpp: At global scope:
            npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
            npm ERR!  SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
            npm ERR!                             ^
            npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
            npm ERR!  SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
            npm ERR!                               ^
            npm ERR! In file included from ../../../nan/nan.h:62,
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:1014:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
            npm ERR!        (node::addon_register_func) (regfunc),                          \
            npm ERR!                                            ^
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
            npm ERR!    NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
            npm ERR!  NODE_MODULE(serialport, init);
            npm ERR! make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/serialport.o] Fehler 1
            npm ERR! gyp ERR! build error
            npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
            npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
            npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
            npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
            npm ERR! gyp ERR! System Linux 5.10.103-v7+
            npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
            npm ERR! gyp ERR! node -v v18.18.1
            npm ERR! gyp ERR! node-gyp -v v9.4.0
            npm ERR! gyp ERR! not ok
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T04_24_27_413Z-debug-0.log
            Adapter "system.adapter.vis.0" restarted.
            upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
            upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
            upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
            upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
            upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
            Qix- created this issue in visionmedia/debug
            closed ReDos Vulnerability Regression Visibility Notice #797
              @dlaurenz
              Buster ist tot und du hampelst da als root herum und für 1GB läuft da auch viel zu viel komisches Zeug mit.
              Was ist saltprojext? Was macht webmin auf der Kiste? Was sind das für seltsame mounts?
              ? D 3 Replies Last reply Reply Quote 0
                A Former User @Thomas Braun last edited by
                @thomas-braun sagte in Update ioBroker klappt nicht:
                saltprojext
                Moin,
                das ist ein Automatisierungstool salt, mit Client/Server, Du schreibst Dir Kochbücher für die verschiedenen Nodes, die Du dann einfach von einer zentralen Stelle, verteilen kannst oder der Node holt sich die Informationen mittel Pull vom Server.
                Ansible, Terraform, Puppet, Chef und Salt
                VG
                Bernd
                  Salt ist eine Konfiguration Management und der RPI macht FHEM & Zigbee... die Mounts sind für Backups
                  willst du mir sagen dass ein update auf bulls-eye das problem behebt?
                  deine anmerkungen gehen überhaupt nicht in richtung lösungsfindung
                    Thomas Braun Most Active @DLaurenz last edited by Thomas Braun
                    @dlaurenz sagte in Update ioBroker klappt nicht:
                    Nö. Aber verschafft erstmal eine sinnvolle Basis für weiteres.
                    Warum nicht?
                      gut mache ich - melde mich
                        "hampelst"....
                        übirgens habe ich noch einen buster-pi, der lässt sich einwandfrei updaten und sieht genauso aus...
                        (salt, webmin, root)
                        ich betreibe das ganze schon seit den anfangstagen von iobroker
                          @dlaurenz
                          Und das bedeutet jetzt für den Patienten genau was?
                            2x raspbian, 2x debian buster, 2x iobroker, 2x Node 18, einer lässt sich updaten, der andere nicht.
                            Wie wahrscheinlich ist es, dass es am OS liegt?
                            • DJMarc75
                              DJMarc75 @DLaurenz last edited by
                              10.2.0
                              Die NPM passt nicht zu NODE 18.18.1
                                DLaurenz @DJMarc75 last edited by
                                @djmarc75
                                laut iob diag ok....
                                                        /usr/bin/npm            10.2.0
                                                        /usr/bin/npx            10.2.0
                                wie bekomme ich die hoch? bzw. welche version muss es sein?
                                  @dlaurenz
                                  ich muss gerade schmunzeln während das update zu bulls-eye läuft....
                                  ihr liefert selber ein Image mit buster aus?
                                  Image basiert auf dem aktuellen Raspberry Pi OS (Buster) Lite
                                  https://forum.iobroker.net/topic/41520/raspberry-os-lite-image-for-with-iobroker
                                    Egal. Die Version ist obsolet... TOT.
                                    sudo apt install --reinstall nodejs
                                    • Codierknecht
                                      Codierknecht Developer Most Active @DLaurenz last edited by
                                      Nö. Der sagt Dir lediglich, dass Node korrekt installiert ist.
                                      Der zur Node-Version passende NPM hat immer die "halbe" Versionsnummer.
                                      Node 18 also mit NPM 9. Node 20 dementsprechend NPM 10.
                                      Ohne @Thomas-Braun hier zu nahe treten oder seine Arbeit an der Ecke schmälern zu wollen: iob diag ist ein Hilfsmittel ... mehr nicht.
                                      Es nimmt einem nicht die Arbeit ab.
                                      "hampelst"....
                                      Das allererste was ein Linux-Admin lernt: Man agiert im System nicht als User "root".
                                      Alles was man mit der Hand am Arm im System treibt, wird allerhöchstens mit temporären Rechten per "sudo" ausgeführt. Da mit "root" unterwegs zu sein, ist reine Bequemlichkeit und führt in aller Regel zu Fehlern.
                                      Es gibt da so einen schönen Spruch, der sinngemäß lautet: "Nur ausgewiesene Profis sollten sich als root anmelden - und die werden es nicht tun"
                                      Ansonsten wurde ja schon erwähnt:
                                      Ein Pi3 mit 1 GB RAM ist die absolute Minimalausstattung und mittlerweile fast nicht mehr sinnvoll (produktiv) einsetzbar. Da noch zusätzliche Verwaltungstools einzusetzen verbietet sich fast von selbst.
                                      Debian "buster" liegt inzwischen 2 Versionen zurück und ist definitiv tot. Inzwischen gibt's auch offiziell "bookworm" für den Pi.
                                      Thomas Braun D 2 Replies Last reply Reply Quote 1
                                        Thomas Braun Most Active @Codierknecht last edited by
                                        @codierknecht sagte in Update ioBroker klappt nicht:
                                        Mehr soll es auch nicht sein.
                                          Homoran Global Moderator Administrators @DLaurenz last edited by
                                          datum gelesen?
                                          Das war 2021
                                          D 1 Reply Last reply Reply Quote 2
                                            DLaurenz @Homoran last edited by
                                            genau, deswegen ist es auch offiziell verlinkt.... wenn etwas nicht mehr freigegeben oder supported ist, gehört es entsprechend makiert, macht man so...
                                            3103
