    4. Update ioBroker klappt nicht - gelöst durch neuinstallation
      DLaurenz @DLaurenz last edited by
      @dlaurenz
      ich hatte dann noch mal ein upgrade self gemacht... nun stehe ich hier (iob diag habe ich danach nochmal gemacht)
      irgendwie ist da noch irgendwas in den files verdreht
      root@io-fhem:/opt/iobroker# npm ls
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: iobroker.js-controller@5.0.13 /opt/iobroker/node_modules/iobroker.js-controller
      iobroker.inst@2.0.3 /opt/iobroker
      ├── colors@1.4.0
      ├── fs-extra@7.0.1
      ├── iobroker.admin@6.2.23
      ├── iobroker.backitup@2.5.6
      ├── iobroker.ble@0.13.4
      ├── iobroker.discovery@3.2.0
      ├── iobroker.fhem@2.0.3
      ├── iobroker.flot@1.12.0
      ├── iobroker.fritzdect@2.3.1
      ├── iobroker.homeconnect@1.0.1
      ├── iobroker.info@1.9.26
      ├── iobroker.js-controller@5.0.13 invalid: "4.0.24" from the root project
      ├── iobroker.simple-api@2.7.2
      ├── iobroker.socketio@6.5.2
      ├── iobroker.vis@1.4.16
      ├── iobroker.web@5.5.3
      ├── iobroker.ws@2.5.3
      ├── iobroker.zigbee@1.8.10
      ├── iobroker@2.0.3
      ├── semver@5.7.2
      ├── serialport@7.1.5
      └── yargs@7.1.2
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T04_02_07_902Z-debug-0.log
        @dlaurenz
        root@io-fhem:~# find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
        root@io-fhem:~#
        root@io-fhem:~# cd /opt/iobroker/
        root@io-fhem:/opt/iobroker# npm list
        ├── colors@1.4.0
        ├── fs-extra@7.0.1
        ├── iobroker.js-controller@4.0.24
        ├── iobroker@2.0.3
        ├── semver@5.7.2
        └── yargs@7.1.2
        root@io-fhem:/opt/iobroker# iob upgrade fritzdect --debug
        This upgrade of "fritzdect" will introduce the following changes:
        -> 2.4.1:
        correctionts reported by adapter-checker
        -> 2.4.0:
        new function for routines, correction for templates
        Would you like to upgrade fritzdect from @2.3.1 to @2.4.1 now? [(y)es, (n)o]: y
        Update fritzdect from @2.3.1 to @2.4.1
        NPM version: 10.2.0
        Installing iobroker.fritzdect@2.4.1... (System call)
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN cleanup Failed to remove some directories [
        npm WARN cleanup   [
        npm WARN cleanup     '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket',
        npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build/Release'] {
        npm WARN cleanup       errno: -39,
        npm WARN cleanup       code: 'ENOTEMPTY',
        npm WARN cleanup       syscall: 'rmdir',
        npm WARN cleanup       path: '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build/Release'
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ]
        npm WARN cleanup ]
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
        npm ERR! command failed
        npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
        npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
        npm ERR!   CXX(target) Release/obj.target/bindings/src/serialport.o
        npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
        npm ERR! gyp info it worked if it ends with ok
        npm ERR! gyp info using node-gyp@9.4.0
        npm ERR! gyp info using node@18.18.1 | linux | arm
        npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
        npm ERR! gyp info spawn /usr/bin/python3
        npm ERR! gyp info spawn args [
        npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
        npm ERR! gyp info spawn args   'binding.gyp',
        npm ERR! gyp info spawn args   '-f',
        npm ERR! gyp info spawn args   'make',
        npm ERR! gyp info spawn args   '-I',
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',
        npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
        npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.1/include/node/common.gypi',
        npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
        npm ERR! gyp info spawn args   '-Dvisibility=default',
        npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.1',
        npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
        npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.1/<(target_arch)/node.lib',
        npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',
        npm ERR! gyp info spawn args   '-Dnode_engine=v8',
        npm ERR! gyp info spawn args   '--depth=.',
        npm ERR! gyp info spawn args   '--no-parallel',
        npm ERR! gyp info spawn args   '--generator-output',
        npm ERR! gyp info spawn args   'build',
        npm ERR! gyp info spawn args   '-Goutput_dir=.'
        npm ERR! gyp info spawn args ]
        npm ERR! gyp info spawn make
        npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
        npm ERR! ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
        npm ERR!        ^~~~~~~~~~~~~
        npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
        npm ERR! ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
        npm ERR!        ^~~~~~~~~~~~~~~
        npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
        npm ERR! ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
        npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
        npm ERR! ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
        npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
        npm ERR! ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
        npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
        npm ERR! ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
        npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
        npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
        npm ERR!      results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
        npm ERR!        ^
        npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-array-buffer.h:13,
        npm ERR!                  from /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8.h:24,
        npm ERR!                  from /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:73,
        npm ERR!                  from ../../../nan/nan.h:62,
        npm ERR!                  from ../src/./serialport.h:6,
        npm ERR!                  from ../src/serialport.cpp:1:
        npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
        npm ERR!    V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
        npm ERR!                                      ^~~
        npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:244:37: note:   candidate expects 3 arguments, 2 provided
        npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
        npm ERR!    V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
        npm ERR!                                      ^~~
        npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:247:37: note:   candidate expects 3 arguments, 2 provided
        npm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
        npm ERR!      results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
        npm ERR!        ^
        npm ERR!                                      ^~~
        npm ERR!                                      ^~~
        npm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
        npm ERR!      results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
        npm ERR!        ^
        npm ERR!                                      ^~~
        npm ERR!                                      ^~~
        npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
        npm ERR! ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
        npm ERR!        ^~~~~~~~~~~~~~~~~~~~
        npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
        npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
        npm ERR!      results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
        npm ERR!        ^
        npm ERR!                                      ^~~
        npm ERR!                                      ^~~
        npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
        npm ERR! ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
        npm ERR! ../src/serialport.cpp: At global scope:
        npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
        npm ERR!  SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
        npm ERR!                             ^
        npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
        npm ERR!  SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
        npm ERR!                               ^
        npm ERR! In file included from ../../../nan/nan.h:62,
        npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:1014:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
        npm ERR!        (node::addon_register_func) (regfunc),                          \
        npm ERR!                                            ^
        npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
        npm ERR!    NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
        npm ERR!  NODE_MODULE(serialport, init);
        npm ERR! make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/serialport.o] Fehler 1
        npm ERR! gyp ERR! build error
        npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
        npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
        npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
        npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
        npm ERR! gyp ERR! System Linux 5.10.103-v7+
        npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
        npm ERR! gyp ERR! node -v v18.18.1
        npm ERR! gyp ERR! node-gyp -v v9.4.0
        npm ERR! gyp ERR! not ok
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T04_24_27_413Z-debug-0.log
        Adapter "system.adapter.vis.0" restarted.
        upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
        upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
        upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
        upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
        upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
        Qix- created this issue in visionmedia/debug
        closed ReDos Vulnerability Regression Visibility Notice #797
          Thomas Braun Most Active @DLaurenz last edited by
          @dlaurenz
          Buster ist tot und du hampelst da als root herum und für 1GB läuft da auch viel zu viel komisches Zeug mit.
          Was ist saltprojext? Was macht webmin auf der Kiste? Was sind das für seltsame mounts?
          ? D 3 Replies Last reply Reply Quote 0
            A Former User @Thomas Braun last edited by
            @thomas-braun sagte in Update ioBroker klappt nicht:
            saltprojext
            Moin,
            das ist ein Automatisierungstool salt, mit Client/Server, Du schreibst Dir Kochbücher für die verschiedenen Nodes, die Du dann einfach von einer zentralen Stelle, verteilen kannst oder der Node holt sich die Informationen mittel Pull vom Server.
            Ansible, Terraform, Puppet, Chef und Salt
            VG
            Bernd
              DLaurenz @Thomas Braun last edited by
              Salt ist eine Konfiguration Management und der RPI macht FHEM & Zigbee... die Mounts sind für Backups
              willst du mir sagen dass ein update auf bulls-eye das problem behebt?
              deine anmerkungen gehen überhaupt nicht in richtung lösungsfindung
                Thomas Braun Most Active @DLaurenz last edited by Thomas Braun
                @dlaurenz sagte in Update ioBroker klappt nicht:
                Nö. Aber verschafft erstmal eine sinnvolle Basis für weiteres.
                Warum nicht?
                  gut mache ich - melde mich
                    "hampelst"....
                    übirgens habe ich noch einen buster-pi, der lässt sich einwandfrei updaten und sieht genauso aus...
                    (salt, webmin, root)
                    ich betreibe das ganze schon seit den anfangstagen von iobroker
                      @dlaurenz
                      Und das bedeutet jetzt für den Patienten genau was?
                        2x raspbian, 2x debian buster, 2x iobroker, 2x Node 18, einer lässt sich updaten, der andere nicht.
                        Wie wahrscheinlich ist es, dass es am OS liegt?
                        • DJMarc75
                          DJMarc75 @DLaurenz last edited by
                          10.2.0
                          Die NPM passt nicht zu NODE 18.18.1
                            DLaurenz @DJMarc75 last edited by
                            @djmarc75
                            laut iob diag ok....
                            Nodejs-Installation:    /usr/bin/nodejs         v18.18.1
                                                    /usr/bin/node           v18.18.1
                                                    /usr/bin/npm            10.2.0
                                                    /usr/bin/npx            10.2.0
                                                    /usr/bin/corepack       0.21.0
                            Recommended versions are nodejs  and npm
                            wie bekomme ich die hoch? bzw. welche version muss es sein?
                              @dlaurenz
                              ich muss gerade schmunzeln während das update zu bulls-eye läuft....
                              ihr liefert selber ein Image mit buster aus?
                              Image basiert auf dem aktuellen Raspberry Pi OS (Buster) Lite
                              https://forum.iobroker.net/topic/41520/raspberry-os-lite-image-for-with-iobroker
                                Egal. Die Version ist obsolet... TOT.
                                sudo apt install --reinstall nodejs
                                • Codierknecht
                                  Codierknecht Developer Most Active @DLaurenz last edited by
                                  Nö. Der sagt Dir lediglich, dass Node korrekt installiert ist.
                                  Der zur Node-Version passende NPM hat immer die "halbe" Versionsnummer.
                                  Node 18 also mit NPM 9. Node 20 dementsprechend NPM 10.
                                  Ohne @Thomas-Braun hier zu nahe treten oder seine Arbeit an der Ecke schmälern zu wollen: iob diag ist ein Hilfsmittel ... mehr nicht.
                                  Es nimmt einem nicht die Arbeit ab.
                                  "hampelst"....
                                  Das allererste was ein Linux-Admin lernt: Man agiert im System nicht als User "root".
                                  Alles was man mit der Hand am Arm im System treibt, wird allerhöchstens mit temporären Rechten per "sudo" ausgeführt. Da mit "root" unterwegs zu sein, ist reine Bequemlichkeit und führt in aller Regel zu Fehlern.
                                  Es gibt da so einen schönen Spruch, der sinngemäß lautet: "Nur ausgewiesene Profis sollten sich als root anmelden - und die werden es nicht tun"
                                  Ansonsten wurde ja schon erwähnt:
                                  Ein Pi3 mit 1 GB RAM ist die absolute Minimalausstattung und mittlerweile fast nicht mehr sinnvoll (produktiv) einsetzbar. Da noch zusätzliche Verwaltungstools einzusetzen verbietet sich fast von selbst.
                                  Debian "buster" liegt inzwischen 2 Versionen zurück und ist definitiv tot. Inzwischen gibt's auch offiziell "bookworm" für den Pi.
                                  Thomas Braun D 2 Replies Last reply Reply Quote 1
                                    Thomas Braun Most Active @Codierknecht last edited by
                                    @codierknecht sagte in Update ioBroker klappt nicht:
                                    Mehr soll es auch nicht sein.
                                      Homoran Global Moderator Administrators @DLaurenz last edited by
                                      datum gelesen?
                                      Das war 2021
                                      D 1 Reply Last reply Reply Quote 2
                                        DLaurenz @Homoran last edited by
                                        genau, deswegen ist es auch offiziell verlinkt.... wenn etwas nicht mehr freigegeben oder supported ist, gehört es entsprechend makiert, macht man so...
                                          Homoran Global Moderator Administrators @DLaurenz last edited by Homoran
                                          Wenn du den Download nutzen würdest, würdest du ein aktuelle Image bekommen, kein Buster.
                                          der Beitrag ist historisch. Den lässt man so.
                                            DLaurenz @Codierknecht last edited by
                                            @codierknecht
                                            können wir mal über die sinn oder unsinnhaftigkeit bei mir aufhören zu sprechen und uns dem problem widmen? bisher hat sich keiner die mühe gemacht, zu fragen warum dinge so laufen sondern es wird wie üblich der oberlehrer rausgekehrt...
                                            ich kenn linux schon seit dem es noch bookware war, ich weiß also was ich tue oder nicht tue... das dürften so ca. 25 jahre sein...
                                            danke!
                                            3087
