Speicherauslastung, Menüs werden nicht geladen
@dp20eic said in Speicherauslastung, Menüs werden nicht geladen:
was sagt# top
pi@raspberrypi:~ $ top top - 21:23:18 up 5:43, 1 user, load average: 1.33, 1.96, 1.97 Tasks: 196 total, 7 running, 189 sleeping, 0 stopped, 0 zombie %Cpu(s): 19.7 us, 7.4 sy, 0.0 ni, 71.9 id, 0.1 wa, 0.0 hi, 0.9 si, 0.0 st MiB Mem : 3743.4 total, 295.8 free, 3048.2 used, 523.3 buff/cache MiB Swap: 100.0 total, 17.2 free, 82.8 used. 695.3 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 45970 iobroker 20 0 798696 229892 36836 R 30.1 6.0 70:45.99 io.shelly.0 123725 homebri+ 20 0 171.6g 113532 85620 S 22.8 3.0 0:00.69 chromium 45549 iobroker 20 0 5314828 303608 44652 S 16.9 7.9 67:48.42 iobroker.js-con 34702 homebri+ 20 0 32.5g 159308 134952 R 8.3 4.2 14:52.53 chromium 473 pi 20 0 494084 26492 21612 R 5.0 0.7 18:47.38 deCONZ 34818 homebri+ 20 0 32.4g 140900 125644 S 4.0 3.7 12:02.94 chromium 45782 iobroker 20 0 1033224 183216 42932 S 3.6 4.8 11:46.49 io.javascript.0 34232 homebri+ 20 0 697240 99476 42240 S 2.3 2.6 7:47.36 homebridge: hom 746 root 20 0 1247884 23440 11640 S 1.7 0.6 6:28.87 tailscaled 34844 homebri+ 20 0 32.5g 150472 93596 S 1.3 3.9 6:59.86 chromium 46099 iobroker 20 0 698180 91268 36892 S 1.3 2.4 2:53.47 io.modbus.0 123581 pi 20 0 12068 5008 2856 R 1.0 0.1 0:00.20 top 33974 homebri+ 20 0 9142780 158460 43096 S 0.7 4.1 3:03.21 homebridge 34220 homebri+ 20 0 9345224 97056 44624 S 0.7 2.5 2:38.11 homebridge: hom 34239 homebri+ 20 0 685012 100900 42164 S 0.7 2.6 2:19.34 homebridge: hom 34241 homebri+ 20 0 985692 132720 43928 S 0.7 3.5 2:25.45 homebridge: hom 45886 iobroker 20 0 966172 105048 42752 S 0.7 2.7 0:45.17 io.telegram.0 45999 iobroker 20 0 988264 137324 42996 S 0.7 3.6 2:13.16 io.tuya.0 46401 iobroker 20 0 752420 78696 37448 S 0.7 2.1 0:22.81 io.cloud.0 46481 iobroker 20 0 682820 72736 36712 S 0.7 1.9 0:19.22 io.discovery.0 46488 iobroker 20 0 977020 125992 44076 S 0.7 3.3 0:58.20 io.eusec.0 46619 iobroker 20 0 689136 85264 42080 S 0.7 2.2 0:53.45 io.logparser.0 15 root 20 0 0 0 0 I 0.3 0.0 1:05.08 rcu_preempt 20 root 20 0 0 0 0 S 0.3 0.0 0:03.00 ksoftirqd/1 95 root -51 0 0 0 0 S 0.3 0.0 0:45.65 irq/37-mmc0 102 root 20 0 0 0 0 S 0.3 0.0 0:05.79 jbd2/sda2-8 468 avahi 20 0 9480 4996 2640 S 0.3 0.1 5:14.35 avahi-daemon 472 root 20 0 7276 2636 2356 S 0.3 0.1 0:32.50 deCONZ-update2. 33911 homebri+ 20 0 5184424 107660 44244 S 0.3 2.8 1:46.40 hb-service 34219 homebri+ 20 0 5147276 92344 44288 S 0.3 2.4 1:33.00 homebridge: @mi 46298 iobroker 20 0 694084 85592 36776 S 0.3 2.2 0:24.41 io.mqtt.0 46339 iobroker 20 0 4886244 90428 43516 S 0.3 2.4 0:22.05 io.backitup.0 46470 iobroker 20 0 696224 92648 37216 S 0.3 2.4 1:08.57 io.deconz.0 46793 iobroker 20 0 995628 141300 37280 R 0.3 3.7 11:04.56 io.web.0 47867 homebri+ 20 0 171.6g 152204 100852 S 0.3 4.0 0:18.71 chromium 120681 homebri+ 20 0 171.6g 146192 101208 S 0.3 3.8 0:06.30 chromium 121239 root 20 0 0 0 0 D 0.3 0.0 0:00.90 kworker/1:1+events_freezable 1 root 20 0 169532 6672 5772 S 0.0 0.2 0:05.12 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.04 kthreadd 3 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_gp 4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_par_gp
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : aarch64 Userland : arm64 Systemuptime and Load: 21:24:45 up 5:44, 2 users, load average: 2.29, 2.03, 1.99 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Wed 2023-10-11 21:24:46 CEST Universal time: Wed 2023-10-11 19:24:46 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.9G 3.2G 242M 49K 576M 688M Swap: 104M 85M 19M Total: 4.0G 3.3G 262M 3743 M total memory 3086 M used memory 1699 M active memory 1614 M inactive memory 231 M free memory 7 M buffer memory 542 M swap cache 99 M total swap 81 M used swap 18 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 235G 8.6G 217G 4% / devtmpfs devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 749M 1.2M 748M 1% /run tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/sda1 vfat 255M 32M 224M 13% /boot tmpfs tmpfs 375M 4.0K 375M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Wed Oct 11 15:40:09 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:3E:50:C8 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=c4fcad63-02 rootfstype=ext4 fsck.repair=yes rootwait [Wed Oct 11 15:40:11 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Wed Oct 11 15:40:11 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Wed Oct 11 15:40:14 2023] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 3.6G /var/ 2.2G /var/cache/apt 2.2G /var/cache 2.1G /var/cache/apt/archives 881M /var/log Archived and active journals take up 840.7M in the file system. /opt/iobroker/backups: 17M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 329M /opt/iobroker/iobroker-data/ 199M /opt/iobroker/iobroker-data/files 103M /opt/iobroker/iobroker-data/backup-objects 52M /opt/iobroker/iobroker-data/files/javascript.admin 48M /opt/iobroker/iobroker-data/files/telegram.admin The five largest files in iobroker-data are: 25M /opt/iobroker/iobroker-data/objects.jsonl 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map 15M /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map 8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js 7.2M /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00 *** NodeJS-Installation *** /usr/bin/nodejs v18.18.1 /usr/bin/node v18.18.1 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 nodejs: Installed: 18.18.1-1nodesource1 Candidate: 18.18.1-1nodesource1 Version table: *** 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.12 admin: 6.10.1 javascript: 7.1.4 Adapters from github: 1 Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : raspberrypi - enabled + system.adapter.cloud.0 : cloud : raspberrypi - enabled + system.adapter.deconz.0 : deconz : raspberrypi - enabled, port: 80 + system.adapter.discovery.0 : discovery : raspberrypi - enabled + system.adapter.eusec.0 : eusec : raspberrypi - enabled system.adapter.feiertage.0 : feiertage : raspberrypi - enabled system.adapter.flot.0 : flot : raspberrypi - enabled + system.adapter.followthesun.0 : followthesun : raspberrypi - enabled + system.adapter.info.0 : info : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled + system.adapter.logparser.0 : logparser : raspberrypi - enabled + system.adapter.modbus.0 : modbus : raspberrypi - enabled + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1886, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.shuttercontrol.0 : shuttercontrol : raspberrypi - enabled + system.adapter.shuttercontrol.1 : shuttercontrol : raspberrypi - enabled + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.tuya.0 : tuya : raspberrypi - enabled system.adapter.vis-map.0 : vis-map : raspberrypi - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : raspberrypi - enabled system.adapter.vis.0 : vis : raspberrypi - enabled + system.adapter.vw-connect.0 : vw-connect : raspberrypi - enabled system.adapter.weatherunderground.0 : weatherunderground : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.wiffi-wz.0 : wiffi-wz : raspberrypi - enabled + system.adapter.yahka.0 : yahka : raspberrypi - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.deconz.0 : deconz : raspberrypi - enabled, port: 80 + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1886, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : https://download.iobroker.net/sources-dist.json beta : https://download.iobroker.net/sources-dist-latest.json live-stable : http://iobroker.live/repo/sources-dist.json live-beta : http://iobroker.live/repo/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.10.1 , installed 6.10.1 Adapter "backitup" : 2.8.1 , installed 2.8.1 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "deconz" : 1.3.21 , installed 1.3.21 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "eusec" : 1.1.2 , installed 1.1.2 Adapter "feiertage" : 1.1.4 , installed 1.1.4 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "followthesun" : 0.4.2 , installed 0.4.2 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "logparser" : 2.2.0 , installed 2.2.0 Adapter "modbus" : 5.0.11 , installed 5.0.11 Adapter "mqtt" : 4.1.1 , installed 4.1.1 Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "shuttercontrol": 1.6.2 , installed 1.6.2 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.5.5 , installed 6.5.5 Adapter "telegram" : 1.16.0 , installed 1.16.0 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-map" : 1.0.4 , installed 1.0.4 Adapter "vw-connect" : 0.0.67 , installed 0.1.3 Adapter "weatherunderground": 3.6.0, installed 3.6.0 Adapter "web" : 6.1.2 , installed 6.1.2 Adapter "wiffi-wz" : 2.2.1 , installed 2.2.1 Adapter "ws" : 2.5.5 , installed 2.5.5 Adapter "yahka" : 1.0.3 , installed 1.0.3 Objects and States Please stand by - This may take a while Objects: 10695 States: 8867 *** OS-Repositories and Updates *** W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details. Hit:1 http://phoscon.de/apt/deconz bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 http://security.debian.org/debian-security bookworm-security InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 http://deb.debian.org/debian bookworm-updates InRelease Hit:6 http://deb.debian.org/debian bullseye-proposed-updates InRelease Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease Hit:8 https://repo.homebridge.io stable InRelease Get:9 https://pkgs.tailscale.com/stable/debian bullseye InRelease Fetched 6560 B in 5s (1377 B/s) Reading package lists... W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details. Pending Updates: 4 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:8555 0.0.0.0:* LISTEN 1001 447221 46852/go2rtc tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 16448 473/deCONZ tcp 0 0 127.0.0.1:34017 0.0.0.0:* LISTEN 110 361529 34220/homebridge: h tcp 0 0 127.0.0.1:46357 0.0.0.0:* LISTEN 110 361911 34702/chromium tcp 0 0 127.0.0.1:36117 0.0.0.0:* LISTEN 110 358831 34241/homebridge: h tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1000 14985 473/deCONZ tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15571 736/sshd: /usr/sbin tcp 0 0 127.0.0.1:38275 0.0.0.0:* LISTEN 110 360458 33974/homebridge tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 442254 46163/io.shelly.1 tcp 0 0 0.0.0.0:1887 0.0.0.0:* LISTEN 1001 442320 46298/io.mqtt.0 tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1001 442319 46298/io.mqtt.0 tcp 0 0 0.0.0.0:8182 0.0.0.0:* LISTEN 1001 453785 46800/io.wiffi-wz.0 tcp 0 0 127.0.0.1:35547 0.0.0.0:* LISTEN 110 361600 34232/homebridge: h tcp 0 0 100.89.105.61:53458 0.0.0.0:* LISTEN 0 15283 746/tailscaled tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 443621 45549/iobroker.js-c tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 443614 45549/iobroker.js-c tcp 0 0 127.0.0.1:33631 0.0.0.0:* LISTEN 1001 449143 46913/io.yahka.0 tcp 0 0 127.0.0.1:43911 0.0.0.0:* LISTEN 110 360508 34239/homebridge: h tcp 0 0 127.0.0.1:35785 0.0.0.0:* LISTEN 110 361595 34232/homebridge: h tcp 0 0 127.0.0.1:37843 0.0.0.0:* LISTEN 110 360560 34226/homebridge: h tcp 0 0 127.0.0.1:45413 0.0.0.0:* LISTEN 110 1433880 34232/homebridge: h tcp 0 0 127.0.0.1:35197 0.0.0.0:* LISTEN 110 361509 34219/homebridge: @ tcp6 0 0 :::31670 :::* LISTEN 110 359428 34219/homebridge: @ tcp6 0 0 :::39846 :::* LISTEN 110 360483 34232/homebridge: h tcp6 0 0 :::8554 :::* LISTEN 1001 447214 46852/go2rtc tcp6 0 0 :::8581 :::* LISTEN 110 358104 33911/hb-service tcp6 0 0 :::22 :::* LISTEN 0 15573 736/sshd: /usr/sbin tcp6 0 0 :::51391 :::* LISTEN 110 358490 33974/homebridge tcp6 0 0 :::42768 :::* LISTEN 110 359504 34241/homebridge: h tcp6 0 0 :::8181 :::* LISTEN 110 358489 33974/homebridge tcp6 0 0 :::30690 :::* LISTEN 110 359463 34226/homebridge: h tcp6 0 0 :::1984 :::* LISTEN 1001 447210 46852/go2rtc tcp6 0 0 fd7a:115c:a1e0:ab:53458 :::* LISTEN 0 15284 746/tailscaled tcp6 0 0 :::8081 :::* LISTEN 1001 444699 45658/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 455932 46793/io.web.0 tcp6 0 0 :::8087 :::* LISTEN 1001 452315 46706/io.simple-api tcp6 0 0 :::52764 :::* LISTEN 110 356273 34220/homebridge: h tcp6 0 0 :::36303 :::* LISTEN 1001 451387 46913/io.yahka.0 tcp6 0 0 :::34246 :::* LISTEN 110 360466 34239/homebridge: h tcp6 0 0 :::34185 :::* LISTEN 110 360495 34232/homebridge: h udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 358805 34220/homebridge: h udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 361623 34241/homebridge: h udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 359464 34226/homebridge: h udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 360496 34232/homebridge: h udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 360492 34232/homebridge: h udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 356274 34220/homebridge: h udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 359429 34219/homebridge: @ udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 360474 34239/homebridge: h udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 360467 34239/homebridge: h udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 358492 33974/homebridge udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 358101 33911/hb-service udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 15404 468/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 446264 45970/io.shelly.0 udp 0 0 0.0.0.0:5683 0.0.0.0:* 110 358495 33974/homebridge udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 447027 46470/io.deconz.0 udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 447023 46470/io.deconz.0 udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 447019 46470/io.deconz.0 udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 15074 473/deCONZ udp 0 0 0.0.0.0:55338 0.0.0.0:* 110 358866 34241/homebridge: h udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15673 1179/dhcpcd udp 0 0 0.0.0.0:57656 0.0.0.0:* 1001 450098 46488/io.eusec.0 udp 0 0 0.0.0.0:37201 0.0.0.0:* 1001 450093 46488/io.eusec.0 udp 0 0 0.0.0.0:8555 0.0.0.0:* 1001 447215 46852/go2rtc udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 445979 45999/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 445980 45999/io.tuya.0 udp 0 0 0.0.0.0:37477 0.0.0.0:* 108 15406 468/avahi-daemon: r udp 0 0 0.0.0.0:41641 0.0.0.0:* 0 1338030 746/tailscaled udp6 0 0 :::5353 :::* 108 15405 468/avahi-daemon: r udp6 0 0 :::1900 :::* 1001 447029 46470/io.deconz.0 udp6 0 0 :::1900 :::* 1001 447028 46470/io.deconz.0 udp6 0 0 :::1900 :::* 1001 447026 46470/io.deconz.0 udp6 0 0 :::1900 :::* 1001 447025 46470/io.deconz.0 udp6 0 0 :::1900 :::* 1001 447024 46470/io.deconz.0 udp6 0 0 :::1900 :::* 1001 447022 46470/io.deconz.0 udp6 0 0 :::1900 :::* 1001 447021 46470/io.deconz.0 udp6 0 0 :::1900 :::* 1001 447020 46470/io.deconz.0 udp6 0 0 :::43047 :::* 108 15407 468/avahi-daemon: r udp6 0 0 :::8443 :::* 1001 447222 46852/go2rtc udp6 0 0 :::546 :::* 0 15696 1179/dhcpcd udp6 0 0 :::41641 :::* 0 1338029 746/tailscaled *** Log File - Last 25 Lines *** 2023-10-11 17:27:32.705 - info: cloud.0 (46401) Connection changed: disconnect 2023-10-11 17:27:34.425 - error: shelly.1 (46163) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-ccdba7d035a4" 2023-10-11 17:27:34.606 - error: shelly.1 (46163) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-3ce90e2f75cc" 2023-10-11 17:27:34.715 - error: shelly.1 (46163) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-c049ef89564c" 2023-10-11 17:27:39.711 - warn: weatherunderground.0 (46287) force terminate 2023-10-11 17:27:40.287 - warn: weatherunderground.0 (46287) get state error: Connection is closed. 2023-10-11 17:27:40.291 - error: weatherunderground.0 (46287) Could not parse hourly Forecast-Data: Error: DB closed 2023-10-11 17:27:40.476 - warn: weatherunderground.0 (46287) get state error: Connection is closed. 2023-10-11 17:27:40.481 - error: weatherunderground.0 (46287) Could not parse hourly Forecast-Data: Error: DB closed 2023-10-11 17:27:40.525 - error: weatherunderground.0 (46287) Could not parse hourly Forecast-Data: Error: DB closed 2023-10-11 17:27:40.528 - error: weatherunderground.0 (46287) Could not parse hourly Forecast-Data: Error: DB closed 2023-10-11 17:27:40.531 - error: weatherunderground.0 (46287) Could not parse hourly Forecast-Data: Error: DB closed 2023-10-11 17:27:40.538 - error: weatherunderground.0 (46287) Could not parse hourly Forecast-Data: Error: DB closed 2023-10-11 17:27:40.543 - error: weatherunderground.0 (46287) Could not parse hourly Forecast-Data: Error: DB closed 2023-10-11 17:27:40.571 - error: weatherunderground.0 (46287) Could not parse hourly Forecast-Data: Error: DB closed 2023-10-11 17:27:40.583 - error: weatherunderground.0 (46287) Could not parse hourly Forecast-Data: Error: DB closed 2023-10-11 17:27:40.594 - error: weatherunderground.0 (46287) Could not parse hourly Forecast-Data: Error: DB closed 2023-10-11 17:28:32.724 - info: cloud.0 (46401) Trying to connect as system.user.admin to cloud 2023-10-11 17:28:32.872 - info: cloud.0 (46401) Connection changed: connect 2023-10-11 17:39:57.770 - info: javascript.0 (45782) script.js.common.Kameras.Status_Eufy_Homebase_anwesend_abwesend: Homebase Nordost und Homebase Südwest wurden auf Guard Mode Abwesend (0) gesetzt. 2023-10-11 18:05:37.088 - error: vw-connect.0 (46774) Error: read ECONNRESET 2023-10-11 18:29:26.705 - info: javascript.0 (45782) script.js.common.Kameras.Status_Eufy_Homebase_anwesend_abwesend: Homebase Nordost und Homebase Südwest wurden auf Guard Mode Abwesend (0) gesetzt. 2023-10-11 20:23:06.423 - info: modbus.0 (46099) Disconnected from slave 192.168.188.90 2023-10-11 20:24:06.450 - info: modbus.0 (46099) Connected to slave 192.168.188.90 2023-10-11 21:09:59.207 - info: javascript.0 (45782) script.js.common.Kameras.Status_Eufy_Homebase_anwesend_abwesend: Homebase Nordost und Homebase Südwest wurden auf Guard Mode Anwesend Nachts (3) gesetzt.
======================= SUMMARY ======================= v.2023-10-10 Static hostname: raspberrypi Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Installation: native Kernel: aarch64 Userland: arm64 Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 X-Server: false Boot Target: multi-user.target Pending OS-Updates: 4 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.18.1 /usr/bin/node v18.18.1 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 Recommended versions are nodejs 18.18.1 and npm 9.8.1 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.9G 3.2G 252M 49K 574M 747M Swap: 104M 104M 266K Total: 4.0G 3.3G 252M Active iob-Instances: 24 Active repo(s): stable ioBroker Core: js-controller 5.0.12 admin 6.10.1 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 10695 States: 8867 Size of iob-Database: 32M /opt/iobroker/iobroker-data/objects.jsonl 6.0M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ====================
Die 4 pending os updates habe ich gerade gesehen (müssen heute nachmittag reingekommen sein, da war ich nicht da), die führe ich dann gleich noch aus.
Kann jemand was damit anfangen?
@guitardoc Eigentlich soweit unauffällig.
Schlüssel frisch/anders anlegen:
Die Quellen musst du auf bookworm anpassen.
Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Get:9 https://pkgs.tailscale.com/stable/debian bullseye InRelease
Rauswerfen:
@thomas-braun sagte in Speicherauslastung, Menüs werden nicht geladen:
bis auf den Speicherverbrauch der ganzen Chromium Prozesse von Homebridge.
@guitardoc
top bitte mal nach %mem sortieren.bei iob verbraucht shelly den meisten Speicher. Da gibts auch was im log
@thomas-braun said in Speicherauslastung, Menüs werden nicht geladen:
Rauswerfen:
Das mit den Schlüsseln wird wohl von den Entwicklern geändert - ich weiß auch nicht wie ich die Schlüssel ändern müsste.
Wie passt man die Quellen auf bookworm an bzw. wirft da was raus?
@homoran said in Speicherauslastung, Menüs werden nicht geladen:
Wie macht man das?
@guitardoc sagte in Speicherauslastung, Menüs werden nicht geladen:
Wie passt man die Quellen auf bookworm an bzw. wirft da was raus?Das ist was für einen separaten Thread.
Wie macht man das?
Moin,
also, bei allen UNIX Befehlen bekommt man eine Hilfe, wenn man das folgender auf der Kommandozeile eintippt
# man top
Dann sieht man, dass die Sortierung so auf gerufen wird,
# top -o %MEM
Dann gib mal dem kleinen mehr Swap, denn bei irgendeiner Aktion, geht Dir der Speicher aus und der kleine versucht nicht gebrauchte Prozesse auszulagern, bei ~100 MB ist das nicht gerade viel, ich würde min. die Hälfte des Memory für Swap einrichten, also ~2 GB.
Wie das geht, keine Ahnung.VG
Bernd -
Wie macht man das?
shift-M
@dp20eic sagte in Speicherauslastung, Menüs werden nicht geladen:
der SWAP ist für Notfälle.
Wenn der regelmäßig und auch noch in dem von dir empfohlenen Maße benötigt wird, läuft zu viel oder etwas falsch. -
@homoran sagte in Speicherauslastung, Menüs werden nicht geladen:
Wenn der regelmäßig und auch noch in dem von dir empfohlenen Maße benötigt wird, läuft zu viel oder etwas falsch.Moin,
ja, ist klar, aber 100 MB ist zu wenig, da passt nichts rein, wenn der Notfall eintritt.
Dass der kleine für mein Verständnis unterdimensioniert ist, steht außer Frage, und deswegen handhabe ich das auf all meinen LX Containern, die auch nur 4 GB Hauptspeicher haben, so, dass die mindestens 2 GB Swap bekommen.
Ich sehe, außer bei meinemPaperless-NGX
Dokumentenmanagement, kein/nur sehr wenig an Swap, besagtesPaperless-NGX
braucht schon mal ein Schluck mehr, wenn große PDFs verarbeitet werden.
Dass durch das Vergrößern des Swapbereiches, die Performance nicht besser wird, steht auch außer FrageBei mir kommt halt auf ein System nicht alles, sondern ich trenne Dienste voneinander.
VG
Bernd -
Hier die sortierte Speicherliste:
total used free shared buff/cache available Mem: 3743 2731 345 0 741 1011 Swap: 99 63 36 pi@raspberrypi:~ $ top -o %MEM top - 12:27:51 up 13:33, 1 user, load average: 1.72, 1.62, 1.77 Tasks: 185 total, 1 running, 184 sleeping, 0 stopped, 0 zombie %Cpu(s): 14.3 us, 4.9 sy, 0.0 ni, 80.1 id, 0.0 wa, 0.0 hi, 0.8 si, 0.0 st MiB Mem : 3743.4 total, 339.6 free, 2735.0 used, 744.4 buff/cache MiB Swap: 100.0 total, 37.0 free, 63.0 used. 1008.5 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 6272 iobroker 20 0 5320084 280032 16016 S 25.2 7.3 216:23.88 iobroker.js-con 6389 iobroker 20 0 800324 208824 14756 S 25.5 5.4 227:29.69 io.shelly.0 6350 iobroker 20 0 1059352 168828 15708 S 3.6 4.4 36:05.05 io.javascript.0 230098 homebri+ 20 0 32.5g 147596 131140 S 0.0 3.9 2:27.20 chromium 230162 homebri+ 20 0 32.4g 135496 121644 S 0.0 3.5 1:58.33 chromium 229650 homebri+ 20 0 9110984 124276 41976 S 0.3 3.2 0:35.56 homebridge 230137 homebri+ 20 0 32.3g 123064 110828 S 0.0 3.2 0:00.16 chromium 230136 homebri+ 20 0 32.3g 122860 110748 S 0.0 3.2 0:00.17 chromium 6441 iobroker 20 0 992516 122300 15716 S 0.7 3.2 5:59.78 io.tuya.0 6290 iobroker 20 0 1040752 121492 15856 S 0.3 3.2 1:52.86 io.admin.0 229806 homebri+ 20 0 977824 121020 43332 S 0.0 3.2 0:30.65 homebridge: hom 1159 homebri+ 20 0 5189836 112540 18188 S 0.3 2.9 3:37.53 hb-service 6982 iobroker 20 0 986984 102520 14772 S 0.0 2.7 11:00.57 io.web.0 6958 iobroker 20 0 5152940 100148 15656 S 0.0 2.6 30:43.45 io.vw-connect.0 6697 iobroker 20 0 977912 98116 15928 S 0.0 2.6 2:34.05 io.eusec.0 229790 homebri+ 20 0 5147464 95888 43132 S 0.3 2.5 0:18.71 homebridge: hom 230193 homebri+ 20 0 32.5g 95324 70112 S 0.0 2.5 1:01.50 chromium 229797 homebri+ 20 0 695204 93988 41760 S 1.0 2.5 1:19.26 homebridge: hom 6471 iobroker 20 0 716668 90912 14772 S 2.6 2.4 9:06.12 io.shelly.1 229784 homebri+ 20 0 9338932 89944 44116 S 0.7 2.3 0:25.50 homebridge: hom 229783 homebri+ 20 0 5009056 88040 43748 S 0.0 2.3 0:15.36 homebridge: @mi 229804 homebri+ 20 0 667420 82980 41712 S 0.7 2.2 0:21.32 homebridge: hom 230166 homebri+ 20 0 171.6g 81212 66040 S 0.0 2.1 0:00.15 chromium 111862 iobroker 20 0 988972 79744 15512 S 0.0 2.1 0:51.86 io.telegram.0 7049 iobroker 20 0 771244 79164 14796 S 0.3 2.1 1:26.37 io.yahka.0 7023 iobroker 20 0 703960 76648 14704 S 0.0 2.0 2:26.51 io.wiffi-wz.0 6618 iobroker 20 0 702712 74388 14788 S 0.0 1.9 2:44.06 io.deconz.0 6456 iobroker 20 0 702288 74200 14684 S 0.7 1.9 9:00.38 io.modbus.0 6874 iobroker 20 0 701500 71668 14820 S 2.0 1.9 2:45.57 io.shuttercontr 6579 iobroker 20 0 5090876 71424 15640 S 0.3 1.9 0:56.27 io.backitup.0 7204 iobroker 20 0 694044 70456 14820 S 1.0 1.8 2:14.62 io.shuttercontr 6572 iobroker 20 0 697848 67632 14748 S 0.0 1.8 1:03.91 io.mqtt.0 7088 iobroker 20 0 758540 65968 14832 S 0.7 1.7 1:03.58 io.followthesun 6764 iobroker 20 0 954888 65384 15676 S 0.3 1.7 1:04.85 io.info.0 6806 iobroker 20 0 692996 63080 15004 S 0.3 1.6 2:40.80 io.logparser.0 6891 iobroker 20 0 711888 63060 14736 S 0.0 1.6 1:04.54 io.simple-api.0 6611 iobroker 20 0 822624 60692 15452 S 0.0 1.6 0:59.40 io.cloud.0 6678 iobroker 20 0 687852 54948 14672 S 0.0 1.4 0:49.82 io.discovery.0 660 root 20 0 1247884 24984 11972 S 2.6 0.7 15:44.10 tailscaled 441 pi 20 0 493048 22960 16356 S 4.6 0.6 41:54.84 deCONZ 230139 homebri+ 20 0 32.3g 16188 3952 S 0.0 0.4 0:00.72 chromium 6873 iobroker 20 0 724436 15140 4 S 0.0 0.4 0:00.32 go2rtc 230196 homebri+ 20 0 32.3g 15064 2896 S 0.0 0.4 0:00.00 chromium 145 root 20 0 66756 11956 10696 S 0.0 0.3 0:07.65 systemd-journal
Gestern Abend 23:00 Uhr hatte ich noch ca. 1,2 GB freien Speicher und keine Auslagerung. Über Nacht ist der Speicher vollgelaufen... Wie kann man herausbekommen, wo das Speicherleck ist?
Moin,
muss kein Speicherleck sein.
Nach einem Neustart, wurden noch nicht alle Funktionen aufgerufen, erst nach einer gewissen Zeit, haben die Programme alle Verzweigungen einmal durchlaufen, nur ein Beispiel, Du hast vielleicht Skripte (JS, Blockly) die zyklisch laufen und eins aber erst um kurz nach Mitternacht und das würde eine große Menge an Daten sammeln, Schreiben, Manipulieren, dann läuft das System, den ganzen Tag über normal und erst kurz nach Mitternacht, frisst das Skript den Speicher.Ob das jetzt an unglücklicher Programmierung, oder aus sich ändernden Rahmenbedingungen kommt, muss man analysieren.
Zu Deinem Problem,
top
ist leider eine Momentaufnahme und sagt nichts über das System im 7x24 Std. Betrieb aus.Ich an Deiner Stelle würde Systeme (ioBroker, homebridge, oder das andere) ausschalten und schauen, ob das System stabil läuft, dann eins nach dem anderen einschalten und wieder schauen.
Ein gern gesehener Gast, der Speicher braucht, ist derBackitUp - Adapter
, setzt Du den ein und wenn ja, um welcher Zeit?VG
Bernd -
da leckt nix!
addiere alleine mal alles was homebridge amn RAM verbrät.
ohne die hast du reichlich RAM@guitardoc sagte in Speicherauslastung, Menüs werden nicht geladen:
backitup?
Ja, ich habe tatsächlich Backitup im Einsatz. Um 02:00 Uhr schreibt der das Backup. Gibt es eine Alternative?
mehr verfügbaren RAM.
Es muss ja die gesamten Konfigurationen und Dateien gepackt werden. Das braucht RAMWenn du zusätzlich noch Dateien in falschen Verzeichnissen speicherst (z.b. Backups) wird das Backup imner größer und damit der RAM Bedarf
Wie bekommt man das raus?
Moin,
in dem Du Dich per ssh (putty) auf die Kiste begibst, dann
# ls -la /opt/iobroker/backups
Das ist das Verzeichnis, in dem standardmäßig die Backups abgelegt werden, es sei denn Du hast irgendwo ein NAS, Googel, OneDrive und sicherst außerhalb des
ioBrokers
VG
Bernd -
Ja, dort liegen die Backups.
Jeweils 10 Stück von
- ioBroker
- Javascripts
- Yahka
zeigen!
Manchmal wurden keine Daten gesichert, da der Raspi zur gleichen Zeit automatisch neu gestartet wurde - das hatte ich gar nicht mehr auf dem Schirm. Hab den Neustart vor ein paar Tagen rausgenommen als ich es gemerkt hab.
MySQL wird nicht mehr gesichert, hab den Adapter nicht mehr drin weil ich keine Daten mehr sammle.pi@raspberrypi:~ $ ls -la /opt/iobroker/backups total 17364 drwxrwxr-x+ 2 iobroker iobroker 36864 Oct 12 02:00 . drwxrwxr-x+ 6 iobroker iobroker 4096 Oct 11 22:59 .. -rw-rwxr--+ 1 iobroker iobroker 8319380 Sep 15 14:18 2023_09_15-14_18_26_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 4695282 Oct 1 02:00 iobroker_2023_10_01-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 4637737 Oct 2 02:11 iobroker_2023_10_02-02_11_19_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 4 02:00 iobroker_2023_10_04-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 5 02:00 iobroker_2023_10_05-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 6 02:00 iobroker_2023_10_06-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 7 04:56 iobroker_2023_10_07-02_40_34_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 8 02:00 iobroker_2023_10_08-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 9 02:00 iobroker_2023_10_09-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 11 02:00 iobroker_2023_10_11-02_00_10_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 0 Oct 12 02:00 iobroker_2023_10_12-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 May 30 02:00 javascripts_2023_05_30-02_00_41_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 May 31 02:00 javascripts_2023_05_31-02_00_43_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 4 02:00 javascripts_2023_10_04-02_00_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 65536 Oct 5 02:00 javascripts_2023_10_05-02_00_26_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 6 02:00 javascripts_2023_10_06-02_00_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 7 04:56 javascripts_2023_10_07-04_56_17_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 8 02:00 javascripts_2023_10_08-02_00_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 9 02:00 javascripts_2023_10_09-02_00_23_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 11 02:00 javascripts_2023_10_11-02_00_34_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 0 Oct 12 02:00 javascripts_2023_10_12-02_00_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 May 30 02:00 mysql_2023_05_30-02_00_26_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 May 31 02:00 mysql_2023_05_31-02_00_28_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 1 03:17 mysql_2023_06_01-03_17_31_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 2 02:00 mysql_2023_06_02-02_00_28_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 3 02:00 mysql_2023_06_03-02_00_26_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 4 02:00 mysql_2023_06_04-02_00_29_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 5 02:00 mysql_2023_06_05-02_00_31_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 6 02:54 mysql_2023_06_06-02_53_42_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 7 02:00 mysql_2023_06_07-02_00_35_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 9 02:00 mysql_2023_06_09-02_00_25_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 1 02:00 mysql_2023_10_01-02_00_22_backupiobroker.sql -rw-rwxr--+ 1 iobroker iobroker 0 Oct 2 02:11 mysql_2023_10_02-02_11_33_backupiobroker.sql -rw-rwxr--+ 1 iobroker iobroker 0 May 30 02:00 yahka.0_2023_05_30-02_00_41_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 May 31 02:00 yahka.0_2023_05_31-02_00_44_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 2257 Oct 4 02:00 yahka.0_2023_10_04-02_00_25_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 5 02:00 yahka.0_2023_10_05-02_00_27_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 6 02:00 yahka.0_2023_10_06-02_00_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 7 04:56 yahka.0_2023_10_07-04_56_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 8 02:00 yahka.0_2023_10_08-02_00_25_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 2258 Oct 9 02:00 yahka.0_2023_10_09-02_00_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 11 02:00 yahka.0_2023_10_11-02_00_36_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 0 Oct 12 02:00 yahka.0_2023_10_12-02_00_25_backupiobroker.tar.gz
soll heissen leere Dateien?
so was wollte ich sehen, oder noch viel schlimmer
8MB?
und die Tage davor nur 4?das ist was ich mit der Backupschleife meinte. Da scheinst du dir das vorherige Backup im Backup zu sichern
@homoran Wie kann sowas passieren? Und was muss man dagegen tun? Im Backitup hab ich die Standardeinstellungen drin:
Aber irgendwas scheint nicht zu stimmen. Ich habe gerade manuell ein Backup angestoßen und das sieht so aus:
pi@raspberrypi:~ $ ls -la /opt/iobroker/backups total 17364 drwxrwxr-x+ 2 iobroker iobroker 36864 Oct 12 15:14 . drwxrwxr-x+ 6 iobroker iobroker 4096 Oct 11 22:59 .. -rw-rwxr--+ 1 iobroker iobroker 8319380 Sep 15 14:18 2023_09_15-14_18_26_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 4695282 Oct 1 02:00 iobroker_2023_10_01-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 4637737 Oct 2 02:11 iobroker_2023_10_02-02_11_19_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 4 02:00 iobroker_2023_10_04-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 5 02:00 iobroker_2023_10_05-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 6 02:00 iobroker_2023_10_06-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 7 04:56 iobroker_2023_10_07-02_40_34_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 8 02:00 iobroker_2023_10_08-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 9 02:00 iobroker_2023_10_09-02_00_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 11 02:00 iobroker_2023_10_11-02_00_10_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 0 Oct 12 02:00 iobroker_2023_10_12-02_00_10_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 0 Oct 12 15:14 iobroker_2023_10_12-15_14_00_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 May 30 02:00 javascripts_2023_05_30-02_00_41_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 May 31 02:00 javascripts_2023_05_31-02_00_43_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 4 02:00 javascripts_2023_10_04-02_00_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 65536 Oct 5 02:00 javascripts_2023_10_05-02_00_26_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 6 02:00 javascripts_2023_10_06-02_00_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 7 04:56 javascripts_2023_10_07-04_56_17_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 8 02:00 javascripts_2023_10_08-02_00_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 9 02:00 javascripts_2023_10_09-02_00_23_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 11 02:00 javascripts_2023_10_11-02_00_34_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 0 Oct 12 02:00 javascripts_2023_10_12-02_00_24_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 0 Oct 12 15:14 javascripts_2023_10_12-15_14_14_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 May 30 02:00 mysql_2023_05_30-02_00_26_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 May 31 02:00 mysql_2023_05_31-02_00_28_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 1 03:17 mysql_2023_06_01-03_17_31_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 2 02:00 mysql_2023_06_02-02_00_28_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 3 02:00 mysql_2023_06_03-02_00_26_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 4 02:00 mysql_2023_06_04-02_00_29_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 5 02:00 mysql_2023_06_05-02_00_31_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 6 02:54 mysql_2023_06_06-02_53_42_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 7 02:00 mysql_2023_06_07-02_00_35_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Jun 9 02:00 mysql_2023_06_09-02_00_25_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 1 02:00 mysql_2023_10_01-02_00_22_backupiobroker.sql -rw-rwxr--+ 1 iobroker iobroker 0 Oct 2 02:11 mysql_2023_10_02-02_11_33_backupiobroker.sql -rw-rwxr--+ 1 iobroker iobroker 0 May 30 02:00 yahka.0_2023_05_30-02_00_41_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 May 31 02:00 yahka.0_2023_05_31-02_00_44_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 2257 Oct 4 02:00 yahka.0_2023_10_04-02_00_25_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 5 02:00 yahka.0_2023_10_05-02_00_27_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 6 02:00 yahka.0_2023_10_06-02_00_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 7 04:56 yahka.0_2023_10_07-04_56_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 8 02:00 yahka.0_2023_10_08-02_00_25_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 2258 Oct 9 02:00 yahka.0_2023_10_09-02_00_24_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 0 Oct 11 02:00 yahka.0_2023_10_11-02_00_36_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 0 Oct 12 02:00 yahka.0_2023_10_12-02_00_25_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 0 Oct 12 15:14 yahka.0_2023_10_12-15_14_14_backupiobroker.tar.gz
Er muss aber was gemacht haben, das Log sagt es zumindest:
backitup.0 2023-10-12 15:19:35.750 debug The local storage check was completed successfully. On the host "raspberrypi" are currently 231497 MB free space available! backitup.0 2023-10-12 15:14:17.944 debug [iobroker] exec: done backitup.0 2023-10-12 15:14:17.642 debug [iobroker/historyJSON] done backitup.0 2023-10-12 15:14:17.641 debug [iobroker/historyJSON] new history json values created backitup.0 2023-10-12 15:14:17.468 debug [iobroker/historyHTML] done backitup.0 2023-10-12 15:14:17.350 debug [iobroker/historyHTML] new history html values created backitup.0 2023-10-12 15:14:16.405 debug [iobroker/email] done backitup.0 2023-10-12 15:14:16.096 debug [iobroker/clean] done backitup.0 2023-10-12 15:14:16.094 debug [iobroker/clean] No older backup files are deleted, because this backup was started manually backitup.0 2023-10-12 15:14:15.489 debug [iobroker/cifs] done backitup.0 2023-10-12 15:14:15.477 debug [iobroker/cifs] Copy yahka.0_2023_10_12-15_14_14_backupiobroker.tar.gz... backitup.0 2023-10-12 15:14:15.443 debug [iobroker/cifs] Copy javascripts_2023_10_12-15_14_14_backupiobroker.tar.gz... backitup.0 2023-10-12 15:14:15.429 debug [iobroker/cifs] Copy iobroker_2023_10_12-15_14_00_backupiobroker.tar.gz... backitup.0 2023-10-12 15:14:15.427 debug [iobroker/cifs] used copy path: /opt/iobroker/backups backitup.0 2023-10-12 15:14:14.824 debug [iobroker/yahka] done backitup.0 2023-10-12 15:14:14.823 debug [iobroker/yahka] found yahka database: yahka.0 backitup.0 2023-10-12 15:14:14.663 debug [iobroker/javascripts] done backitup.0 2023-10-12 15:14:14.661 debug [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_10_12-15_14_14_backupiobroker.tar.gz backitup.0 2023-10-12 15:14:14.661 debug [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted backitup.0 2023-10-12 15:14:14.644 debug [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts" backitup.0 2023-10-12 15:14:14.400 debug [iobroker/javascripts] found Script: Steuerung_infolge_Verschattung_und_Wind_alt backitup.0 2023-10-12 15:14:14.400 debug [iobroker/javascripts] found Script: Kellerflur backitup.0 2023-10-12 15:14:14.399 debug [iobroker/javascripts] found Script: Schalte_Licht_Teich_(alt) backitup.0 2023-10-12 15:14:14.398 debug [iobroker/javascripts] found Script: Fensterputzermodus_schalten backitup.0 2023-10-12 15:14:14.398 debug [iobroker/javascripts] found Script: Steuerung_Verschattung_für_Auslösung_durch_HomeKit backitup.0 2023-10-12 15:14:14.397 debug [iobroker/javascripts] found Script: Steuerung_infolge_Verschattung_und_Wind backitup.0 2023-10-12 15:14:14.397 debug [iobroker/javascripts] found Script: Wohnzimmer_Tür_zur_Terrasse_offen_geschlossen_angekippt backitup.0 2023-10-12 15:14:14.395 debug [iobroker/javascripts] found Script: Schlafzimmer_offen_geschlossen_angekippt backitup.0 2023-10-12 15:14:14.394 debug [iobroker/javascripts] found Script: Status_Eufy_Homebase_anwesend_abwesend backitup.0 2023-10-12 15:14:14.393 debug [iobroker/javascripts] found Script: Zeit_letzte_Abfrage_Weatherman backitup.0 2023-10-12 15:14:14.388 debug [iobroker/javascripts] found Script: Ist_es_dunkel_ backitup.0 2023-10-12 15:14:14.387 debug [iobroker/javascripts] found Script: Ist_es_Nacht_ backitup.0 2023-10-12 15:14:14.385 debug [iobroker/javascripts] found Script: Ist_die_Nachtruhe_beendet_ backitup.0 2023-10-12 15:14:14.383 debug [iobroker/javascripts] found Script: Daten_von_Hydrawise_abholen backitup.0 2023-10-12 15:14:14.382 debug [iobroker/javascripts] found Script: Manuelle_Bewässerung backitup.0 2023-10-12 15:14:14.381 debug [iobroker/javascripts] found Script: Automatische_Bewässerung backitup.0 2023-10-12 15:14:14.380 debug [iobroker/javascripts] found Script: Temperaturvorhersage backitup.0 2023-10-12 15:14:14.378 debug [iobroker/javascripts] found Script: Fahre_Markise_ein_(Wind__Regen) backitup.0 2023-10-12 15:14:14.377 debug [iobroker/javascripts] found Script: Schalte_Licht_Kommode backitup.0 2023-10-12 15:14:14.373 debug [iobroker/javascripts] found Script: Initialisiere_Shuttercontrol backitup.0 2023-10-12 15:14:14.373 debug [iobroker/javascripts] found Script: Sende_Mitteilung_Anwesenheit backitup.0 2023-10-12 15:14:14.372 debug [iobroker/javascripts] found Script: Test_Ausgabe_Auslöser backitup.0 2023-10-12 15:14:14.371 debug [iobroker/javascripts] found Script: Umrechnungen backitup.0 2023-10-12 15:14:14.250 debug [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts" backitup.0 2023-10-12 15:14:12.440 debug [iobroker/iobroker] done backitup.0 2023-10-12 15:14:11.344 debug [iobroker/iobroker] This backup can only be restored with js-controller version up from 4.1 backitup.0 2023-10-12 15:14:11.342 debug [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_10_12-15_14_00_backupiobroker.tar.gz backitup.0 2023-10-12 15:14:07.626 debug [iobroker/iobroker] host.raspberrypi 10713 objects saved backitup.0 2023-10-12 15:14:07.335 debug [iobroker/iobroker] host.raspberrypi 8866 states saved backitup.0 2023-10-12 15:14:00.654 debug Backup has started ... backitup.0 2023-10-12 15:14:00.471 debug The local storage check was completed successfully. On the host "raspberrypi" are currently 231484 MB free space available! backitup.0 2023-10-12 15:13:55.462 debug The local storage check was completed successfully. On the host "raspberrypi" are currently 231484 MB free space available! backitup.0 2023-10-12 15:12:42.134 debug The local storage check was completed successfully. On the host "raspberrypi" are currently 231484 MB free space available! backitup.0 2023-10-12 15:11:48.093 debug The local storage check was completed successfully. On the host "raspberrypi" are currently 231484 MB free space available! backitup.0 2023-10-12 15:10:52.815 debug The local storage check was completed successfully. On the host "raspberrypi" are currently 231484 MB free space available! backitup.0 2023-10-12 15:10:10.608 debug The local storage check was completed successfully. On the host "raspberrypi" are currently 231484 MB free space available! backitup.0 2023-10-12 14:46:53.519 debug The local storage check was completed successfully. On the host "raspberrypi" are currently 231493 MB free space available! backitup.0 2023-10-12 14:46:20.120 debug The local storage check was completed successfully. On the host "raspberrypi" are currently 231493 MB free space available! backitup.0 2023-10-12 14:38:28.174 debug The local storage check was completed successfully. On the host "raspberrypi" are currently 221699 MB free space available! backitup.0 2023-10-12 14:37:48.307 debug The local storage check was completed successfully. On the host "raspberrypi" are currently 221699 MB free space available!
