    4. Update ioBroker klappt nicht - gelöst durch neuinstallation
    • DJMarc75
      DJMarc75 @Thomas Braun last edited by
      https://forum.iobroker.net/topic/69038/iobroker-fix/5
      dort scheint u.U. das selbe Problem zu sein - kann mich aber auch täuschen
        DLaurenz last edited by
        @djmarc75
        die meldung hatte ich auch gesehen - gibt aber kein gcc-c++ paket unter debian
          Homoran Global Moderator Administrators @DLaurenz last edited by
          @dlaurenz enotempty und code 25 erinnert mich an https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update
            DLaurenz @Homoran last edited by
            auch schon x-mal gemacht...
            pi@io-fhem:~ $ find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec echo {} \;
            pi@io-fhem:~ $ sudo -H -u iobroker npm install iobroker.js-controller
            npm notice
            npm notice New major version of npm available! 9.8.1 -> 10.2.0
            npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.0
            npm notice Run npm install -g npm@10.2.0 to update!
            npm notice
            npm ERR! code EACCES
            npm ERR! syscall mkdir
            npm ERR! path /home/pi/node_modules
            npm ERR! errno -13
            npm ERR! Error: EACCES: permission denied, mkdir '/home/pi/node_modules'
            npm ERR!  [Error: EACCES: permission denied, mkdir '/home/pi/node_modules'] {
            npm ERR!   errno: -13,
            npm ERR!   code: 'EACCES',
            npm ERR!   syscall: 'mkdir',
            npm ERR!   path: '/home/pi/node_modules'
            npm ERR! }
            npm ERR!
            npm ERR! The operation was rejected by your operating system.
            npm ERR! It is likely you do not have the permissions to access this file as the current user
            npm ERR!
            npm ERR! If you believe this might be a permissions issue, please double-check the
            npm ERR! permissions of the file and its containing directories, or try running
            npm ERR! the command again as root/Administrator.
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T10_31_49_005Z-debug-0.log
            pi@io-fhem:~ $ cd /opt/iobroker/
            pi@io-fhem:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            npm WARN cleanup Failed to remove some directories [
            npm WARN cleanup   [
            npm WARN cleanup     '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket',
            npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib'] {
            npm WARN cleanup       errno: -39,
            npm WARN cleanup       code: 'ENOTEMPTY',
            npm WARN cleanup       syscall: 'rmdir',
            npm WARN cleanup       path: '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib'
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ]
            npm WARN cleanup ]
            npm ERR! code 1
            npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
            npm ERR! command failed
            npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
            npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
            npm ERR!   CXX(target) Release/obj.target/bindings/src/serialport.o
            npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
            npm ERR! gyp info it worked if it ends with ok
            npm ERR! gyp info using node-gyp@9.4.0
            npm ERR! gyp info using node@18.18.1 | linux | arm
            npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
            npm ERR! gyp info spawn /usr/bin/python3
            npm ERR! gyp info spawn args [
            npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
            npm ERR! gyp info spawn args   'binding.gyp',
            npm ERR! gyp info spawn args   '-f',
            npm ERR! gyp info spawn args   'make',
            npm ERR! gyp info spawn args   '-I',
            npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',
            npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
            npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.1/include/node/common.gypi',
            npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
            npm ERR! gyp info spawn args   '-Dvisibility=default',
            npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.1',
            npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
            npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.1/<(target_arch)/node.lib',
            npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',
            npm ERR! gyp info spawn args   '-Dnode_engine=v8',
            npm ERR! gyp info spawn args   '--depth=.',
            npm ERR! gyp info spawn args   '--no-parallel',
            npm ERR! gyp info spawn args   '--generator-output',
            npm ERR! gyp info spawn args   'build',
            npm ERR! gyp info spawn args   '-Goutput_dir=.'
            npm ERR! gyp info spawn args ]
            npm ERR! gyp info spawn make
            npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!    78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
            npm ERR!       |                                                   ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
            npm ERR!       |                                                     ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:270:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   270 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:314:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   314 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
            npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
            npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
            npm ERR!   329 |     results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
            npm ERR!       |        ^
            npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-array-buffer.h:13,
            npm ERR!                  from /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8.h:24,
            npm ERR!                  from /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:73,
            npm ERR!                  from ../../../nan/nan.h:62,
            npm ERR!                  from ../src/./serialport.h:6,
            npm ERR!                  from ../src/serialport.cpp:1:
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
            npm ERR!   244 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
            npm ERR!       |                                     ^~~
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:244:37: note:   candidate expects 3 arguments, 2 provided
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
            npm ERR!   247 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
            npm ERR!       |                                     ^~~
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:247:37: note:   candidate expects 3 arguments, 2 provided
            npm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
            npm ERR!   330 |     results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
            npm ERR!       |        ^
            npm ERR!       |                                     ^~~
            npm ERR!       |                                     ^~~
            npm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
            npm ERR!   331 |     results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
            npm ERR!       |        ^
            npm ERR!       |                                     ^~~
            npm ERR!       |                                     ^~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:363:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   363 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
            npm ERR!       |                                                          ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
            npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
            npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
            npm ERR!   378 |     results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
            npm ERR!       |        ^
            npm ERR!       |                                     ^~~
            npm ERR!       |                                     ^~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:409:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   409 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
            npm ERR! ../src/serialport.cpp: At global scope:
            npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
            npm ERR!   430 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
            npm ERR!       |                            ^
            npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
            npm ERR!   449 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
            npm ERR!       |                              ^
            npm ERR! In file included from ../../../nan/nan.h:62,
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:1014:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
            npm ERR!  1014 |       (node::addon_register_func) (regfunc),                          \
            npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
            npm ERR!  1048 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
            npm ERR!   483 | NODE_MODULE(serialport, init);
            npm ERR! make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/serialport.o] Fehler 1
            npm ERR! gyp ERR! build error
            npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
            npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
            npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
            npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
            npm ERR! gyp ERR! System Linux 5.10.103-v7+
            npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
            npm ERR! gyp ERR! node -v v18.18.1
            npm ERR! gyp ERR! node-gyp -v v9.4.0
            npm ERR! gyp ERR! not ok
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T10_33_16_805Z-debug-0.log
            Qix- created this issue in visionmedia/debug
            closed ReDos Vulnerability Regression Visibility Notice #797
            mikeal created this issue in request/request
            open Request’s Past, Present and Future #3142
            ? Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
              A Former User @DLaurenz last edited by
              @dlaurenz sagte in Update ioBroker klappt nicht:
              Moin,
              welche rechte haben den die angetackerten Dateien und Verzeichnisse?
              VG
              Bernd
                Thomas Braun Most Active @DLaurenz last edited by
                @dlaurenz
                Du stehst im falschen Verzeichnis...
                npm notice
                  doch noch verbogene Rechte durch root?
                    @homoran sagte in Update ioBroker klappt nicht:
                    Nee, der user 'iobroker' darf dem user 'pi' aber keine Eier in's Nest legen.
                    Hier greifen die User-Rechte von Unix/Linux richtig ein.
                    Als root wäre das aber durchgescheppert. Weswegen man auch nicht als root herumhampelt. Aber das Thema hatten wir ja schon.
                      @thomas-braun sagte in Update ioBroker klappt nicht:
                      recht du hast! Hab falschrum gedacht, da pi in der Gruppe iobroker ist
                      • Marc Berg
                        Marc Berg Most Active @Thomas Braun last edited by Marc Berg
                        ja, er stand erst im falschen Verzeichnis, ab Zeile 28 dann aber im richtigen Verzeichnis.
                        3095
