    • Michael Roling
      Michael Roling Developer @liv-in-sky last edited by
      @liv-in-sky ich muss aber sehen was unter common steht
        liv-in-sky @Michael Roling last edited by
        @michael-roling
        {id: 'system.adapter.telegram.3', value: {…}}
        id
        "system.adapter.telegram.3"
        value
        acl
        {object: 1636, owner: 'system.user.admin', ownerGroup: 'system.group.administrator'}
        common
        adminUI
        {custom: 'json', config: 'json'}
        authors
        (3) ['bluefox <dogafox@gmail.com>', 'apollon77 <iobroker@fischer-ka.de>', 'Matthias Kleine <info@haus-automatisierung.com>']
        blockly
        true
        compact
        true
        connectionType
        "cloud"
        dataSource
        "poll"
        dependencies
        desc
        {en: 'This adapter allows to send and receive telegram messages from ioBroker and to be a bot', de: 'Adapter ermöglicht eine Kommunikation mit dem telegram app und ist selbst ein bot', ru: 'Драйвер запускает Telegram бот, с которым можно общаться по App или через браузер', pt: 'Este adaptador permite enviar e receber mensagens de telegramas de ioBroker e ser um bot', nl: 'Met deze adapter kunt u telegramberichten van ioBroker verzenden en ontvangen en een bot zijn', …}
        docs
        {en: Array(1), de: Array(1)}
        enabled
        true
        extIcon
        "https://raw.githubusercontent.com/iobroker-community-adapters/ioBroker.telegram/master/admin/telegram.png"
        globalDependencies
        host
        "iobroker59"
        icon
        "telegram.png"
        installedFrom
        "iobroker.telegram@1.16.0"
        installedVersion
        "1.16.0"
        javascriptRules
        {i18n: true, url: 'rules/customRuleBlocks.js', name: 'ActionTelegram'}
        keywords
        (3) ['notification', 'telegram', 'message']
        license
        "MIT"
        loglevel
        "warn"
        messagebox
        true
        mode
        "daemon"
        name
        "telegram"
        platform
        "Javascript/Node.js"
        plugins
        {sentry: {…}}
        readme
        "https://github.com/iobroker-community-adapters/ioBroker.telegram/blob/master/README.md"
        restartSchedule
        "4 5 * * *"
        stopBeforeUpdate
        true
        supportCustoms
        true
        supportedMessages
        {custom: true, notifications: true}
        tier
        title
        "Telegram"
        titleLang
        "iobsteuerung"
        type
        "messaging"
        version
        "1.16.0"
        [[Prototype]]
        Object
          @michael-roling
          • Michael Roling
            @liv-in-sky 7b3073fa-0686-422f-aac1-4696c6f5932c-grafik.png so sieht es bei dir aus, aber sollte so aussehen b236301a-d36f-4ec7-8a2f-3f7b83ea83b0-grafik.png
            nachdem du einen neue instance hinzugefügt hast passt diese kurzeitig, und wird dann warum auch immer überschrieben
              @michael-roling
              das ist so von mir eingestellt, damit ich den überblick habe, welcher bot ist welche instanz 🙂 :
              • Michael Roling
                @liv-in-sky okay läuft ja jetzt
                liv-in-sky 1 Reply Last reply Reply Quote 1
                  @michael-roling
                  ja - danke nochmal - da wir ja schon ein update des adapters gemacht haben, sollte auch beim nächsten mal alles gut gehen 🙂
                  • Michael Roling
                    @liv-in-sky gerne gerne, ja der Fehler ist jetzt raus. Es es kommt ja immer wieder was neues dazu
                      Willi-Wunder @Michael Roling last edited by
                      @michael-roling
                      Erstmal vielen Dank für den tollen Adapter, gestern zufällig entdeckt und gleich ausprobiert. Hab mich kurz eingelesen und schon die ersten Menüs in Telegram erstellt. Hatte diese früher in Blockly mühsam erstellt. In deinem Adapter ist das viel schneller und vor allem übersichtlicher darstellbar. Änderungen können viel besser und schneller gemacht werden.
                      Auch den gemeldeten Bug innerhalb weniger Stunden behoben, mega. 👍 👍 👍
                      Werde meine Menüs aus dem Blockly jetzt Stück für Stück in deinem Adpater nachbauen. Bei den Rollos bin ich mir noch nicht sicher, ob ich hier den Begriff "Öffnen" in jedem Raum verwenden darf, da dieser Begriff ja sonst doppelt ist. Im Blockly hatte ich daher "1 Öffnen" "2 Öffnen"-........ verwenden müssen, da sonst alle Rollos angesprochen wurden.
                      Gruß Willi
                      • Michael Roling
                        Michael Roling Developer @Willi-Wunder last edited by
                        @willi-wunder danke, am besten benutze dafür die submenus
                        W liv-in-sky 2 Replies Last reply Reply Quote 0
                          Willi-Wunder @Michael Roling last edited by Willi-Wunder
                          @michael-roling
                          Habe Somfy Motoren und bisher die Befehle im Blockly mit "Öffnen","Schließen","My-Position","Stopp" gehabt.
                          Mit den Submenus machst du das jetzt über Eingabe der Prozentwerte wenn ich das jetzt richtig verstanden haben, oder?
                          Muss mich damit noch etwas länger beschäftigen, hab gestern erstmal rein geschnuppert. 🙂
                          Vielen Dank.
                          Gruß Willi
                            liv-in-sky @Michael Roling last edited by liv-in-sky
                            @michael-roling
                            sorry - brauche schon wieder deine hilfe - es funktioniert alles sehr gut bis auf ein inline-keyboard. das funktionierte mal - ich habe nix geändert - absichtlich
                            der fehler zuerst:
                            telegram-menu.0
                            2023-10-14 19:54:09.233	debug	Error1 {}
                            telegram-menu.0
                            2023-10-14 19:54:09.232	debug	Group: "liv-in-sky"
                            das menu definiert
                            setState sieht so aus
                            Michael Roling Negalein 3 Replies Last reply Reply Quote 0
                            • Michael Roling
                              @liv-in-sky schaue ich mir an.
                              • Michael Roling
                                @liv-in-sky so funktioniert wieder
                                  @michael-roling
                                  leider nein - jetzt kommt das:
                                  telegram-menu.0
                                  	2023-10-14 22:21:00.579	debug	SubmenuData3[]
                                  telegram-menu.0
                                  	2023-10-14 22:21:00.579	debug	Submenu data [null,null,null,[]]
                                  telegram-menu.0
                                  	2023-10-14 22:21:00.579	error	Error Switch{}
                                  telegram-menu.0
                                  	2023-10-14 22:21:00.578	debug	{"device2Switch":"","data":{"an":{"nav":[["Lüfter5","outSide","getStandort"],["TestDP"],["IN","OUT"],["Clear","CompAus","➡ Grüner"]],"text":"Startseite aktualisiert ...."},"➡ Grüner":{"nav":[["MelPic","MelSet"],["SonderBeginn","SonderEnde","SonderPic"],["MelBild","PostGPS"],["BACK ↩"]],"text":"Wähle eine Aktion"},"BACK ↩":{"nav":[["menu:back"]],"text":"Wähle eine Aktion"},"outSide":{"nav":[["menu:number0-6-1- :Aussen:"]],"text":"Wähle eine Aktion"},"Lüfter5":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.Luefter5","value":"!","toggle":true,"confirm":"true","returnText":"Lüfter ist jetzt: &amp;&amp; ack:true"}]},"TestDP":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.Luefter5","value":true,"toggle":true,"confirm":"true","returnText":"{\"id\":\"0_userdata.0.CONTROL-OWN.AAATEST.TestString4\",\"text\":\"wert ist &amp;&amp;\"}"}]},"IN":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.AAATEST.telegramInnen","value":"!","toggle":true,"confirm":"true","returnText":"ack:true"}]},"OUT":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.AAATEST.telegramAUSSEN","value":"!","toggle":true,"confirm":"true","returnText":"ack:true"}]},"MelBild":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.sendTelegramMelikeGesamtBild","value":"-","toggle":true,"confirm":"true","returnText":"-"}]},"Clear":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TelegramDelete3Chat","value":"-","toggle":true,"confirm":"true","returnText":"lösche Verlauf"}]},"CompAus":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.fx6300","value":false,"toggle":true,"confirm":"true","returnText":"Computer wird abgeschalten! Value: &amp;&amp;"}]},"SonderBeginn":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.SonderfahrtBeginn","value":true,"toggle":false,"confirm":"true","returnText":"Name und Kilometer (mit Komma){\"id\":\"0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.BeginnKM\",\"text\":\"Kilometer Start ist &amp;&amp;\"}"}]},"SonderEnde":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.SonderfahrtEnde","value":true,"toggle":false,"confirm":"true","returnText":"{\"id\":\"0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.EndeKM\",\"text\":\"Kilometer Ende ist &amp;&amp;\"}"}]},"MelSet":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.MelikeSchreiben","value":"-","toggle":true,"confirm":"true","returnText":"Wert ist &amp;&amp;"}]},"PostGPS":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.postGPSData","value":true,"toggle":false,"confirm":"true","returnText":"{\"id\":\"0_userdata.0.CONTROL-OWN.TRACCAR.postGPSResult\",\"text\":\"GPS Post ist:\\n&amp;&amp;\"}"}]},"Aussen":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.MOTION.Standort","value":"!","toggle":false,"confirm":"true","returnText":"Standort: &amp;&amp; ack:true"}]},"getStandort":{"getData":[{"id":"0_userdata.0.CONTROL-OWN.MOTION.Standort","text":"Standort ist momentan: &&","newline":"true"}]},"MelPic":{"sendPic":[{"id":"-","delay":"5000","fileName":"/opt/iobroker/iobrokerMelike.png"}]},"SonderPic":{"sendPic":[{"id":"-","delay":"5000","fileName":"/opt/iobroker/iobrokerSonder.png"}]}},"user":"liv-in-sky","value":6}
                                    @michael-roling
                                    EDIT - FALSCHMELDUNG
                                    jetzt funktioniert auch der rückgbewert mit einer anderen id nicht mehr
                                      @michael-roling
                                      vergiss den post mit dem rückgabewert - jetzt funktioniert es wieder - keine ahnung was eben los war
                                      • Michael Roling
                                        @liv-in-sky also funktioniert alles wieder?
                                          @michael-roling
                                          guten morgen
                                          nein - das inline keyboard nicht
                                          https://forum.iobroker.net/post/1060702
                                          • Michael Roling
                                            @liv-in-sky ein neuer Test steht bereit
                                            1.0k
                                            1801
                                            791452
