    3. Entwicklung
    4. [Neuer Adapter] Proxmox VM
      Alero @umichel last edited by Alero
      hi,
      habe mir den proxmox adapter installiert leider bekomme ich keine Verbindung:
      proxmox.0
      2023-10-13 15:31:07.983	error	401: wrong User data, could not log in, please try again with correct user and pw
      proxmox.0
      2023-10-13 15:31:07.983	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      proxmox.0
      2023-10-13 15:31:07.982	error	Unable to authenticate with Proxmox host. Please check your credentials
      proxmox.0
      2023-10-13 15:31:04.888	debug	Use Proxmox API: https://192.168.42.90:8006/api2/json
      IP, Port, User und PW sind richtig. Damit kann ich mich auf dem Proxmox Server anmelden. Muss ich noch was im Proxmox freigeben?
      DJMarc75 ? 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @Alero last edited by
        @alero Welche Version ?
          Alero @DJMarc75 last edited by
          @djmarc75
            Alero @Alero last edited by Alero
            hi,
            laut log ruft er https auf. mein Proxmox läuft noch über http.
            ist das vielleicht der Grund?
            Auszug Protokoll:
            proxmox.0
            2023-10-13 15:38:44.163	error	401: wrong User data, could not log in, please try again with correct user and pw
            proxmox.0
            2023-10-13 15:38:44.163	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            proxmox.0
            2023-10-13 15:38:44.162	error	Unable to authenticate with Proxmox host. Please check your credentials
            proxmox.0
            2023-10-13 15:38:41.079	debug	Use Proxmox API: https://192.168.42.90:8006/api2/json
            proxmox.0
            2023-10-13 15:38:41.049	info	starting. Version 1.3.5 in /opt/iobroker/node_modules/iobroker.proxmox, node: v18.18.0, js-controller: 5.0.12
            proxmox.0
            2023-10-13 15:38:40.799	debug	States connected to redis: 127.0.0.1:9000
            proxmox.0
            2023-10-13 15:38:40.716	debug	States create User PubSub Client
            proxmox.0
            2023-10-13 15:38:40.715	debug	States create System PubSub Client
            proxmox.0
            2023-10-13 15:38:40.650	debug	Redis States: Use Redis connection: 127.0.0.1:9000
            proxmox.0
            2023-10-13 15:38:40.618	debug	Objects connected to redis: 127.0.0.1:9001
            proxmox.0
            2023-10-13 15:38:40.613	debug	Objects client initialize lua scripts
            proxmox.0
            2023-10-13 15:38:40.550	debug	Objects create User PubSub Client
            proxmox.0
            2023-10-13 15:38:40.550	debug	Objects create System PubSub Client
            proxmox.0
            2023-10-13 15:38:40.549	debug	Objects client ready ... initialize now
            proxmox.0
            2023-10-13 15:38:40.522	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
            • Meister Mopper
              Meister Mopper @Alero last edited by
              @alero sagte in [Neuer Adapter] Proxmox VM:
              Wie rufst du denn Proxmox im Browser auf?
                Alero @Meister Mopper last edited by
                @meister-mopper
                http://192.168.42.90:8006/api2/json
                • Meister Mopper
                  @alero
                  Dann ist es aus meiner Sicht eine vergeigte Installation. Standard ist immer https und http wird von Proxmox nicht wirklich unterstützt.
                    @meister-mopper
                    heisst für mich das er versucht über https aufzurufen . es aber nicht geht und dann http nutzt.
                    Meister Mopper B 2 Replies Last reply Reply Quote 0
                    • Meister Mopper
                      @alero
                      Es ist keine sichere Verbindung, weil selfsigned Zertifikate genutzt werden. Das muss man im Browser einmal erlauben, dann ist es "trusted".
                        bommel_030 @Alero last edited by
                        @alero
                        Hast du mal mit PAM statt PVE versucht?
                          @meister-mopper
                          wo muss ich das erlauben?
                            Alero @bommel_030 last edited by Alero
                            @bommel_030
                            ja. gleicher Fehler
                            • Meister Mopper
                              Das ist bei jedem Browser unterschiedlich. Hier eine im Netz gefundene Anleitung für den Chrome:
                              Wir können nun mit der in der oben blau umrahmten Eingabe über einen beliebigen Web Browser auf den Proxmox Server zugreifen. Beim Aufruf der Adresse erscheint die nachfolgende Meldung, weil unser Netzwerk das von Proxmox erstellte Zertifikat nicht kennt. Da Proxmox VE standardmäßig selbstsignierte SSL-Zertifikate verwendet, wird eine Warnmeldung angezeigt, wenn wir versuchen, die Benutzeroberfläche über den Webbrowser aufzurufen. Akzeptiert einfach das SSL-Zertifikat. Klickt in Google Chrome auf Weiter mit 192.168.x.y (unsicher).
                                @meister-mopper
                                hi,
                                das habe ich bereits gemacht. hat nix gebracht
                                • Meister Mopper
                                  @alero
                                  Hast du den root-user mit 2FA abgesichert?
                                  Wenn ja, funktioniert der Adapter nur mit einem user, der kein 2FA benötigt.
                                    @meister-mopper
                                    hi, bei zwei factor steht bei mir nix
                                    DJMarc75 Meister Mopper 3 Replies Last reply Reply Quote 0
                                    • DJMarc75
                                      nix steht da definitiv nicht - zeigen bitte !
                                      • Meister Mopper
                                        Na ja, das hättest du ja auch explizit einrichten müssen.
                                        Im Firefox sieht es nach Bestätigung des untrusted Zertifikats wie folgt aus:
                                        Im Chrome nicht bestätigt:
                                        Es hat aber mit deinem Problem nichts zu tun. Proxmox kommuniziert mit https-Protokoll und das auch mit dem Adapter.
                                        • Meister Mopper
                                          @alero
                                          v1.3.5
                                          Bei mir funktioniert es auch ohne Servereintrag
                                            Alero @Meister Mopper last edited by Alero
                                            @meister-mopper
                                            ok
                                            hier der weg den ich gehe wenn ich die Seite das erste mal aufrufen ( gelöschter Browser Cache) Chrome
                                            dann erweitert drücken
                                            dann Weiter zu 192.168.42.90 (unsicher)
                                            hier sehe ich das ich pam ausgewählt habe. mit pve komme ich mit meinem User nicht rein. dann melde ich mich an.
                                            A Meister Mopper 2 Replies Last reply Reply Quote 0
                                            proxmox
                                            75
                                            486
                                            109450
