    3. Off Topic
    4. (erledigt) Zigbee Adapter startet nicht
      hm_krause @Thomas Braun last edited by
      2023-10-12 19:04:11.759  - info: host.raspberrypi2 "system.adapter.zigbee.0" enabled
      2023-10-12 19:04:12.349  - info: host.raspberrypi2 instance system.adapter.zigbee.0 started with pid 968
      2023-10-12 19:04:29.686  - error: zigbee.0 (968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-10-12 19:04:29.693  - error: zigbee.0 (968) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
      2023-10-12 19:04:29.710  - error: zigbee.0 (968) TypeError: Cannot read properties of undefined (reading 'getDevice')
          at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49)
          at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26)
          at Zigbee.emit (node:events:529:35)
          at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34)
          at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37)
          at process.processImmediate (node:internal/timers:476:21)
      2023-10-12 19:04:29.714  - error: zigbee.0 (968) Cannot read properties of undefined (reading 'getDevice')
      2023-10-12 19:04:33.394  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-10-12 19:04:33.397  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
      ^C
      ...hoffe das reicht.🙄
        Thomas Braun Most Active @hm_krause last edited by
        @hm_krause
        Ein richtiger Start schaut so aus:
        2023-10-12 19:22:32.152  - info: zigbee.0 (68120) Got terminate signal TERMINATE_YOURSELF
        2023-10-12 19:22:32.154  - info: zigbee.0 (68120) cleaned everything up...
        2023-10-12 19:22:32.157  - info: zigbee.0 (68120) Zigbee: disabling joining new devices.
        2023-10-12 19:22:32.655  - info: zigbee.0 (68120) terminating
        2023-10-12 19:22:32.664  - info: zigbee.0 (68120) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-10-12 19:23:07.364  - info: zigbee.0 (68952) starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.8.0, js-controller: 5.0.13
        2023-10-12 19:23:07.532  - info: zigbee.0 (68952) delete old Backup files. keep only last 10
        2023-10-12 19:23:07.535  - info: zigbee.0 (68952) Starting Zigbee  npm ...
        2023-10-12 19:23:07.969  - info: zigbee.0 (68952) Installed Version: iobroker.zigbee@1.8.24
        2023-10-12 19:23:19.816  - info: zigbee.0 (68952) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
        2023-10-12 19:23:19.828  - info: zigbee.0 (68952) Unable to disable LED, unsupported function.
        2023-10-12 19:23:19.847  - info: zigbee.0 (68952)   --> transmitPower : normal
        Die Instanz ausschalten und nach einiger Zeit frisch starten.
          @thomas-braun sagte in Zigbee Adapter startet nicht:
          Das hilft aber nicht...
          host.raspberrypi2
          	2023-10-12 19:32:24.742	info	"system.adapter.zigbee.0" disabled
          host.raspberrypi2
          	2023-10-12 19:32:03.015	info	Restart adapter system.adapter.zigbee.0 because enabled
          host.raspberrypi2
          	2023-10-12 19:32:03.012	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          zigbee.0
          	2023-10-12 19:32:01.525	error	Cannot read properties of undefined (reading 'getDevice')
          zigbee.0
          	2023-10-12 19:32:01.523	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
          zigbee.0
          	2023-10-12 19:32:01.520	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
          zigbee.0
          	2023-10-12 19:32:01.518	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0
          	2023-10-12 19:32:00.965	error	Cannot read properties of undefined (reading 'getDevice')
          zigbee.0
          	2023-10-12 19:32:00.960	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
          zigbee.0
          	2023-10-12 19:32:00.943	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
          zigbee.0
          	2023-10-12 19:32:00.936	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          host.raspberrypi2
          	2023-10-12 19:31:43.336	info	instance system.adapter.zigbee.0 started with pid 1109
          host.raspberrypi2
          	2023-10-12 19:31:42.910	info	"system.adapter.zigbee.0" enabled
            arteck Developer Most Active @hm_krause last edited by
            @hm_krause installier mal von GIT
            https://github.com/ioBroker/ioBroker.zigbee
            der sollte jetzt an der stelle ne Fehlermeldung liefern
              hm_krause @arteck last edited by
              @arteck
              Bringt folgendes:
              zigbee.0
              	2023-10-13 13:27:58.858	error	adapter disabled
              host.raspberrypi2
              	2023-10-13 13:27:20.259	info	"system.adapter.zigbee.0" disabled
              host.raspberrypi2
              	2023-10-13 13:27:14.281	info	Restart adapter system.adapter.zigbee.0 because enabled
              host.raspberrypi2
              	2023-10-13 13:27:14.278	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              zigbee.0
              	2023-10-13 13:27:12.854	error	Cannot read properties of undefined (reading 'getDevice')
              zigbee.0
              	2023-10-13 13:27:12.851	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
              zigbee.0
              	2023-10-13 13:27:12.849	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
              zigbee.0
              	2023-10-13 13:27:12.846	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0
              	2023-10-13 13:27:12.836	error	Cannot read properties of undefined (reading 'getDevice')
              zigbee.0
              	2023-10-13 13:27:12.833	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
              zigbee.0
              	2023-10-13 13:27:12.816	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
              zigbee.0
              	2023-10-13 13:27:12.809	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              host.raspberrypi2
              	2023-10-13 13:26:54.200	info	instance system.adapter.zigbee.0 started with pid 3125
              host.raspberrypi2
              	2023-10-13 13:26:23.752	info	Restart adapter system.adapter.zigbee.0 because enabled
              host.raspberrypi2
              	2023-10-13 13:26:23.749	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              zigbee.0
              	2023-10-13 13:26:22.299	error	this.zbController.getGroup is not a function
              zigbee.0
              	2023-10-13 13:26:22.297	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
              zigbee.0
              	2023-10-13 13:26:22.279	error	unhandled promise rejection: this.zbController.getGroup is not a function
              zigbee.0
              	2023-10-13 13:26:22.273	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              host.raspberrypi2
              	2023-10-13 13:26:02.219	info	instance system.adapter.zigbee.0 started with pid 3106
              host.raspberrypi2
              	2023-10-13 13:26:01.709	info	"system.adapter.zigbee.0" enabled
                A Former User @hm_krause last edited by
                @hm_krause sagte in Zigbee Adapter startet nicht:
                ch will auf einem Raspi 2 (als Slave)
                Moin,
                zeig doch mal den langen Output von
                # iob diag
                Vielleicht ist ja was an der Grundinstallation krum!
                VG
                Bernd
                  hm_krause @Guest last edited by
                  @dp20eic
                  Bitte schön
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                     Static hostname: raspberrypi2
                           Icon name: computer
                    Operating System: Raspbian GNU/Linux 11 (bullseye)
                              Kernel: Linux 6.1.21-v7+
                        Architecture: arm
                  Model           : Raspberry Pi 2 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : armv7l
                  Userland        : armhf
                  Systemuptime and Load:
                   17:45:09 up 23:50,  1 user,  load average: 0.23, 0.07, 0.02
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Fri 2023-10-13 17:45:09 CEST
                             Universal time: Fri 2023-10-13 15:45:09 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            921M        236M        409M        0.0K        276M        628M
                  Swap:            99M          0B         99M
                  Total:          1.0G        236M        509M
                            921 M total memory
                            236 M used memory
                            174 M active memory
                            276 M inactive memory
                            409 M free memory
                             54 M buffer memory
                            221 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/root      ext4       15G  3.4G   11G  25% /
                  devtmpfs       devtmpfs  333M     0  333M   0% /dev
                  tmpfs          tmpfs     461M     0  461M   0% /dev/shm
                  tmpfs          tmpfs     185M  948K  184M   1% /run
                  /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                  tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                  [Thu Oct 12 17:54:32 2023] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=984cb146-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                  [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                  [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): recovery complete
                  [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Thu Oct 12 17:54:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Thu Oct 12 17:54:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  TARGET  SOURCE         FSTYPE OPTIONS
                  /       /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  894M    /var/
                  574M    /var/log
                  417M    /var/log/journal/d396ac506ad544c8953772923028cd1b
                  120M    /var/cache
                  Archived and active journals take up 416.0M in the file system.
                  /opt/iobroker/backups:
                  2.4M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  103M    /opt/iobroker/iobroker-data/
                  74M     /opt/iobroker/iobroker-data/files
                  52M     /opt/iobroker/iobroker-data/files/javascript.admin
                  34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                  33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  7.8M    /opt/iobroker/iobroker-data/objects.jsonl
                  7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                  5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
                  4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.18.1
                  /usr/bin/node           v18.18.1
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  /usr/bin/corepack       0.19.0
                  nodejs:
                    Installed: 18.18.1-1nodesource1
                    Candidate: 18.18.1-1nodesource1
                    Version table:
                   *** 18.18.1-1nodesource1 1001
                          500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                          100 /var/lib/dpkg/status
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                       12.22.12~dfsg-1~deb11u4 500
                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  At least one iobroker host is running.
                  Objects type: file
                  States  type: file
                  Core adapters versions
                  js-controller:  5.0.12
                  admin:          6.10.1
                  javascript:     7.1.4
                  Adapters from github:   0
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.4, run as: admin
                    system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                    system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                  + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                  + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                  + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                  + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                  + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
                  + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                    system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                  + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                  + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
                  + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
                  + system.adapter.history.0                : history               : iobroker                                 -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 8701
                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                  + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                  + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                  + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  + system.adapter.javascript.1             : javascript            : raspberrypi2                             -  enabled
                  + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
                  + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                  + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
                    system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                  + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                  + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                  + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                  + system.adapter.resol.0                  : resol                 : iobroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
                  + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                  + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                    system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                  + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                  + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                    system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                    system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                    system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                    system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    system.adapter.zigbee.0                 : zigbee                : raspberrypi2                             - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
                  + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 6.10.1   , installed 6.10.1
                  Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
                  Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                  Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                  Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                  Controller "js-controller": 5.0.12   , installed 5.0.12
                  Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                  Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                  Objects and States
                  Objects:        22288
                  States:         19027
                  Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 5
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13985      437/sshd: /usr/sbin
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13987      437/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1712       536/dhcpcd
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13885      328/avahi-daemon: r
                  udp        0      0 0.0.0.0:46530           0.0.0.0:*                           108        13887      328/avahi-daemon: r
                  udp6       0      0 :::53325                :::*                                108        13888      328/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                108        13886      328/avahi-daemon: r
                  2023-10-13 13:48:53.686  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
                  2023-10-13 13:48:53.698  - error: zigbee.0 (3202) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  2023-10-13 13:48:53.700  - error: zigbee.0 (3202) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
                  2023-10-13 13:48:53.703  - error: zigbee.0 (3202) TypeError: Cannot read properties of undefined (reading 'getDevice')
                  2023-10-13 13:48:53.705  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
                  2023-10-13 13:48:55.306  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  2023-10-13 13:48:55.308  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
                  2023-10-13 13:49:01.630  - info: host.raspberrypi2 "system.adapter.zigbee.0" disabled
                  2023-10-13 13:49:42.820  - error: zigbee.0 (3218) adapter disabled
                  2023-10-13 13:49:43.820  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                  2023-10-13 13:49:43.823  - info: host.raspberrypi2 Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
                  2023-10-13 16:03:53.346  - error: host.raspberrypi2 Objects database error: read ECONNRESET
                  2023-10-13 16:03:53.345  - error: javascript.1 (550) Objects database error: read ECONNRESET
                  2023-10-13 16:03:58.380  - error: host.raspberrypi2 Objects database error: connect ECONNREFUSED 192.168.178.4:9001
                  2023-10-13 16:03:58.424  - error: javascript.1 (550) Objects database error: connect ECONNREFUSED 192.168.178.4:9001
                  2023-10-13 16:04:00.227  - error: host.raspberrypi2 States database error: read ECONNRESET
                  2023-10-13 16:04:01.512  - error: javascript.1 (550) States database error: read ECONNRESET
                  2023-10-13 16:04:03.397  - info: host.raspberrypi2 Objects database successfully reconnected
                  2023-10-13 16:04:05.240  - info: host.raspberrypi2 Objects database successfully reconnected
                  iob diag has finished.
                    Bitte schön
                    Moin,
                    ist das eine Master/Slave Installation?
                    Auch das wäre dann schon am Anfang von Interesse gewesen!
                    Du hast auf dem RasPI-2 noch Deconz installiert, kann das sein, dass sich das mit dem Zigbee - Adapter beißt?
                    VG
                    Bernd
                      @dp20eic sagte in Zigbee Adapter startet nicht:
                      Bitte schön
                      Moin,
                      ...Stand im 1. Beitrag und Deconz ist deinstalliert
                        Moin,
                        ok, das kleine geklammerte Slave habe ich überlesen.
                        Aber dekonz wird mir doch in der Liste des RasPI-2 aufgelistet
                        Adapter    "deconz"       : 1.3.21   , installed 1.3.21                      <------
                        VG
                        Bernd
                          @dp20eic
                          Deconz ist aber weder in der Instanz noch im Adapter zu sehen.
                          pi@raspberrypi2:~ $ sudo systemctl status deconz
                          Unit deconz.service could not be found.
                          pi@raspberrypi2:~ $
                            A Former User @hm_krause last edited by A Former User
                            Moin,
                            kenne mich mit Master/Slave nicht wirklich aus, gerade wenn auch mal umgeschaltet wurde und dann Adapter installiert, oder deinstalliert werden.
                            Da müssen andere helfen, da stocher ich nur im Trüben.
                            Wenn das nicht zu viel Arbeit ist, würde ich den ganz neu von vorne aufsetzen.
                            VG
                            Bernd
                            P.S.: sehe gerade, Du suchst den Service, ich schrieb vom Adapter im ioBroker
                              @dp20eic
                              Werde alles nochmal neu machen, Danke
                                hm_krause @hm_krause last edited by
                                @hm_krause
                                Läuft noch nicht.
                                Master als VM auf Proxmox
                                Slave komplett neu auf Raspi 4.
                                Wenn ich mit der Maus auf dem roten Kreis bin zeigt eine Verbindung mit Gerät oder Dienst an (grün)
                                Die beiden anderen, Verbunden mit Host und Lebensszeichen, bleiben rot
                                host.iob-oben
                                	2023-10-15 14:51:25.836	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                                host.iob-oben
                                	2023-10-15 14:51:25.836	info	Restart adapter system.adapter.zigbee.0 because enabled
                                host.iob-oben
                                	2023-10-15 14:51:25.835	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                zigbee.0
                                	2023-10-15 14:51:24.417	error	this.zbController.getGroup is not a function
                                zigbee.0
                                	2023-10-15 14:51:24.416	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                                zigbee.0
                                	2023-10-15 14:51:24.413	error	unhandled promise rejection: this.zbController.getGroup is not a function
                                zigbee.0
                                	2023-10-15 14:51:24.411	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                host.iob-oben
                                	2023-10-15 14:51:16.312	info	instance system.adapter.zigbee.0 started with pid 1125
                                host.iob-oben
                                	2023-10-15 14:50:45.849	info	Restart adapter system.adapter.zigbee.0 because enabled
                                host.iob-oben
                                	2023-10-15 14:50:45.848	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                zigbee.0
                                	2023-10-15 14:50:44.412	error	this.zbController.getGroup is not a function
                                zigbee.0
                                	2023-10-15 14:50:44.411	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                                zigbee.0
                                	2023-10-15 14:50:44.408	error	unhandled promise rejection: this.zbController.getGroup is not a function
                                zigbee.0
                                	2023-10-15 14:50:44.406	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                host.iob-oben
                                	2023-10-15 14:50:37.187	info	instance system.adapter.zigbee.0 started with pid 1109
                                host.iob-oben
                                	2023-10-15 14:50:06.660	info	Restart adapter system.adapter.zigbee.0 because enabled
                                host.iob-oben
                                	2023-10-15 14:50:06.659	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                zigbee.0
                                	2023-10-15 14:50:04.658	error	this.zbController.getGroup is not a function
                                zigbee.0
                                	2023-10-15 14:50:04.657	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                                zigbee.0
                                	2023-10-15 14:50:04.654	error	unhandled promise rejection: this.zbController.getGroup is not a function
                                zigbee.0
                                	2023-10-15 14:50:04.652	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                host.iob-oben
                                	2023-10-15 14:49:56.318	info	instance system.adapter.zigbee.0 started with pid 1092
                                host.iob-oben
                                	2023-10-15 14:49:55.849	info	"system.adapter.zigbee.0" enabled
                                Noch jemand vielleicht eine Idee..?
                                  @hm_krause said in Zigbee Adapter startet nicht:
                                  Moin,
                                  natürlich, vom Slave die lange Ausgabe von
                                  # iob diag
                                  Welche Version vom Zigbe Adapter, vielleicht mal die Github Version getestet?
                                  Schon mal darüber nachgedacht, mittels LAN/WLAN Zigbee Stick zu arbeiten, den kann man besser im Haus positionieren als die, die über USB angeschlossen sind, dann noch gescheite Repeater und man bekommt auch ein stabiles Zigbee Mesh hin.
                                  Network -> https://www.zigbee2mqtt.io/guide/adapters/#recommended
                                     - Tube's Zigbee Gateways (CC2652P2 variant)
                                     - cyijun OpenZ3Gateway
                                     - XGG 52PZ2MGateway
                                     - SMLIGHT Zigbee LAN Adapter CC2652P Model SLZB-05
                                     - cod.m ZigBee CC2652P2 TCP Coordinator
                                  VG
                                  Bernd
                                    @dp20eic
                                    Ich habe jetzt aufgegeben und einen seperaten Iobroker auf den Raspi gebracht.
                                    Der Stick funktioniert tadellos.
                                    1038
