    3. Off Topic
    4. (erledigt) Zigbee Adapter startet nicht
      arteck Developer Most Active @hm_krause last edited by
      @hm_krause installier mal von GIT
      https://github.com/ioBroker/ioBroker.zigbee
      der sollte jetzt an der stelle ne Fehlermeldung liefern
        hm_krause @arteck last edited by
        @arteck
        Bringt folgendes:
        zigbee.0
        	2023-10-13 13:27:58.858	error	adapter disabled
        host.raspberrypi2
        	2023-10-13 13:27:20.259	info	"system.adapter.zigbee.0" disabled
        host.raspberrypi2
        	2023-10-13 13:27:14.281	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.raspberrypi2
        	2023-10-13 13:27:14.278	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        zigbee.0
        	2023-10-13 13:27:12.854	error	Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-13 13:27:12.851	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
        zigbee.0
        	2023-10-13 13:27:12.849	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-13 13:27:12.846	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0
        	2023-10-13 13:27:12.836	error	Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-13 13:27:12.833	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
        zigbee.0
        	2023-10-13 13:27:12.816	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-13 13:27:12.809	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        host.raspberrypi2
        	2023-10-13 13:26:54.200	info	instance system.adapter.zigbee.0 started with pid 3125
        host.raspberrypi2
        	2023-10-13 13:26:23.752	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.raspberrypi2
        	2023-10-13 13:26:23.749	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        zigbee.0
        	2023-10-13 13:26:22.299	error	this.zbController.getGroup is not a function
        zigbee.0
        	2023-10-13 13:26:22.297	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
        zigbee.0
        	2023-10-13 13:26:22.279	error	unhandled promise rejection: this.zbController.getGroup is not a function
        zigbee.0
        	2023-10-13 13:26:22.273	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        host.raspberrypi2
        	2023-10-13 13:26:02.219	info	instance system.adapter.zigbee.0 started with pid 3106
        host.raspberrypi2
        	2023-10-13 13:26:01.709	info	"system.adapter.zigbee.0" enabled
          A Former User @hm_krause last edited by
          @hm_krause sagte in Zigbee Adapter startet nicht:
          ch will auf einem Raspi 2 (als Slave)
          Moin,
          zeig doch mal den langen Output von
          # iob diag
          Vielleicht ist ja was an der Grundinstallation krum!
          VG
          Bernd
            hm_krause @Guest last edited by
            @dp20eic
            Bitte schön
            Skript v.2023-10-10
            *** BASE SYSTEM ***
               Static hostname: raspberrypi2
                     Icon name: computer
              Operating System: Raspbian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v7+
                  Architecture: arm
            Model           : Raspberry Pi 2 Model B Rev 1.1
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : armhf
            Systemuptime and Load:
             17:45:09 up 23:50,  1 user,  load average: 0.23, 0.07, 0.02
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Fri 2023-10-13 17:45:09 CEST
                       Universal time: Fri 2023-10-13 15:45:09 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            921M        236M        409M        0.0K        276M        628M
            Swap:            99M          0B         99M
            Total:          1.0G        236M        509M
                      921 M total memory
                      236 M used memory
                      174 M active memory
                      276 M inactive memory
                      409 M free memory
                       54 M buffer memory
                      221 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4       15G  3.4G   11G  25% /
            devtmpfs       devtmpfs  333M     0  333M   0% /dev
            tmpfs          tmpfs     461M     0  461M   0% /dev/shm
            tmpfs          tmpfs     185M  948K  184M   1% /run
            /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
            tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
            [Thu Oct 12 17:54:32 2023] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=984cb146-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
            [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
            [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): recovery complete
            [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Thu Oct 12 17:54:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Thu Oct 12 17:54:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            894M    /var/
            574M    /var/log
            417M    /var/log/journal/d396ac506ad544c8953772923028cd1b
            120M    /var/cache
            Archived and active journals take up 416.0M in the file system.
            /opt/iobroker/backups:
            2.4M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            103M    /opt/iobroker/iobroker-data/
            74M     /opt/iobroker/iobroker-data/files
            52M     /opt/iobroker/iobroker-data/files/javascript.admin
            34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            7.8M    /opt/iobroker/iobroker-data/objects.jsonl
            7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
            4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
            USB-Devices by-id:
            /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.18.1
            /usr/bin/node           v18.18.1
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            /usr/bin/corepack       0.19.0
            nodejs:
              Installed: 18.18.1-1nodesource1
              Candidate: 18.18.1-1nodesource1
              Version table:
             *** 18.18.1-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                    100 /var/lib/dpkg/status
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            At least one iobroker host is running.
            Objects type: file
            States  type: file
            Core adapters versions
            js-controller:  5.0.12
            admin:          6.10.1
            javascript:     7.1.4
            Adapters from github:   0
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.4, run as: admin
              system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
            + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
            + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
            + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
            + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
            + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
            + system.adapter.history.0                : history               : iobroker                                 -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 8701
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.javascript.1             : javascript            : raspberrypi2                             -  enabled
            + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
            + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
            + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
              system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
            + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
            + system.adapter.resol.0                  : resol                 : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
            + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
              system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
            + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
              system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
              system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.zigbee.0                 : zigbee                : raspberrypi2                             - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
            + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.10.1   , installed 6.10.1
            Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
            Adapter    "deconz"       : 1.3.21   , installed 1.3.21
            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
            Adapter    "javascript"   : 7.1.4    , installed 7.1.4
            Controller "js-controller": 5.0.12   , installed 5.0.12
            Adapter    "tuya"         : 3.14.2   , installed 3.14.2
            Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
            Objects and States
            Objects:        22288
            States:         19027
            Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 5
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13985      437/sshd: /usr/sbin
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13987      437/sshd: /usr/sbin
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1712       536/dhcpcd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13885      328/avahi-daemon: r
            udp        0      0 0.0.0.0:46530           0.0.0.0:*                           108        13887      328/avahi-daemon: r
            udp6       0      0 :::53325                :::*                                108        13888      328/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        13886      328/avahi-daemon: r
            2023-10-13 13:48:53.686  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
            2023-10-13 13:48:53.698  - error: zigbee.0 (3202) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-10-13 13:48:53.700  - error: zigbee.0 (3202) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
            2023-10-13 13:48:53.703  - error: zigbee.0 (3202) TypeError: Cannot read properties of undefined (reading 'getDevice')
            2023-10-13 13:48:53.705  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
            2023-10-13 13:48:55.306  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2023-10-13 13:48:55.308  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
            2023-10-13 13:49:01.630  - info: host.raspberrypi2 "system.adapter.zigbee.0" disabled
            2023-10-13 13:49:42.820  - error: zigbee.0 (3218) adapter disabled
            2023-10-13 13:49:43.820  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
            2023-10-13 13:49:43.823  - info: host.raspberrypi2 Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
            2023-10-13 16:03:53.346  - error: host.raspberrypi2 Objects database error: read ECONNRESET
            2023-10-13 16:03:53.345  - error: javascript.1 (550) Objects database error: read ECONNRESET
            2023-10-13 16:03:58.380  - error: host.raspberrypi2 Objects database error: connect ECONNREFUSED 192.168.178.4:9001
            2023-10-13 16:03:58.424  - error: javascript.1 (550) Objects database error: connect ECONNREFUSED 192.168.178.4:9001
            2023-10-13 16:04:00.227  - error: host.raspberrypi2 States database error: read ECONNRESET
            2023-10-13 16:04:01.512  - error: javascript.1 (550) States database error: read ECONNRESET
            2023-10-13 16:04:03.397  - info: host.raspberrypi2 Objects database successfully reconnected
            2023-10-13 16:04:05.240  - info: host.raspberrypi2 Objects database successfully reconnected
            iob diag has finished.
              Bitte schön
              Moin,
              ist das eine Master/Slave Installation?
              Auch das wäre dann schon am Anfang von Interesse gewesen!
              Du hast auf dem RasPI-2 noch Deconz installiert, kann das sein, dass sich das mit dem Zigbee - Adapter beißt?
              VG
              Bernd
                @dp20eic sagte in Zigbee Adapter startet nicht:
                Bitte schön
                Moin,
                ...Stand im 1. Beitrag und Deconz ist deinstalliert
                  Moin,
                  ok, das kleine geklammerte Slave habe ich überlesen.
                  Aber dekonz wird mir doch in der Liste des RasPI-2 aufgelistet
                  Adapter    "deconz"       : 1.3.21   , installed 1.3.21                      <------
                  VG
                  Bernd
                    @dp20eic
                    Deconz ist aber weder in der Instanz noch im Adapter zu sehen.
                    pi@raspberrypi2:~ $ sudo systemctl status deconz
                    Unit deconz.service could not be found.
                    pi@raspberrypi2:~ $
                      A Former User @hm_krause last edited by A Former User
                      Moin,
                      kenne mich mit Master/Slave nicht wirklich aus, gerade wenn auch mal umgeschaltet wurde und dann Adapter installiert, oder deinstalliert werden.
                      Da müssen andere helfen, da stocher ich nur im Trüben.
                      Wenn das nicht zu viel Arbeit ist, würde ich den ganz neu von vorne aufsetzen.
                      VG
                      Bernd
                      P.S.: sehe gerade, Du suchst den Service, ich schrieb vom Adapter im ioBroker
                        @dp20eic
                        Werde alles nochmal neu machen, Danke
                          hm_krause @hm_krause last edited by
                          @hm_krause
                          Läuft noch nicht.
                          Master als VM auf Proxmox
                          Slave komplett neu auf Raspi 4.
                          Wenn ich mit der Maus auf dem roten Kreis bin zeigt eine Verbindung mit Gerät oder Dienst an (grün)
                          Die beiden anderen, Verbunden mit Host und Lebensszeichen, bleiben rot
                          host.iob-oben
                          	2023-10-15 14:51:25.836	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                          host.iob-oben
                          	2023-10-15 14:51:25.836	info	Restart adapter system.adapter.zigbee.0 because enabled
                          host.iob-oben
                          	2023-10-15 14:51:25.835	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          zigbee.0
                          	2023-10-15 14:51:24.417	error	this.zbController.getGroup is not a function
                          zigbee.0
                          	2023-10-15 14:51:24.416	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                          zigbee.0
                          	2023-10-15 14:51:24.413	error	unhandled promise rejection: this.zbController.getGroup is not a function
                          zigbee.0
                          	2023-10-15 14:51:24.411	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          host.iob-oben
                          	2023-10-15 14:51:16.312	info	instance system.adapter.zigbee.0 started with pid 1125
                          host.iob-oben
                          	2023-10-15 14:50:45.849	info	Restart adapter system.adapter.zigbee.0 because enabled
                          host.iob-oben
                          	2023-10-15 14:50:45.848	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          zigbee.0
                          	2023-10-15 14:50:44.412	error	this.zbController.getGroup is not a function
                          zigbee.0
                          	2023-10-15 14:50:44.411	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                          zigbee.0
                          	2023-10-15 14:50:44.408	error	unhandled promise rejection: this.zbController.getGroup is not a function
                          zigbee.0
                          	2023-10-15 14:50:44.406	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          host.iob-oben
                          	2023-10-15 14:50:37.187	info	instance system.adapter.zigbee.0 started with pid 1109
                          host.iob-oben
                          	2023-10-15 14:50:06.660	info	Restart adapter system.adapter.zigbee.0 because enabled
                          host.iob-oben
                          	2023-10-15 14:50:06.659	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          zigbee.0
                          	2023-10-15 14:50:04.658	error	this.zbController.getGroup is not a function
                          zigbee.0
                          	2023-10-15 14:50:04.657	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                          zigbee.0
                          	2023-10-15 14:50:04.654	error	unhandled promise rejection: this.zbController.getGroup is not a function
                          zigbee.0
                          	2023-10-15 14:50:04.652	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          host.iob-oben
                          	2023-10-15 14:49:56.318	info	instance system.adapter.zigbee.0 started with pid 1092
                          host.iob-oben
                          	2023-10-15 14:49:55.849	info	"system.adapter.zigbee.0" enabled
                          Noch jemand vielleicht eine Idee..?
                            @hm_krause said in Zigbee Adapter startet nicht:
                            Moin,
                            natürlich, vom Slave die lange Ausgabe von
                            # iob diag
                            Welche Version vom Zigbe Adapter, vielleicht mal die Github Version getestet?
                            Schon mal darüber nachgedacht, mittels LAN/WLAN Zigbee Stick zu arbeiten, den kann man besser im Haus positionieren als die, die über USB angeschlossen sind, dann noch gescheite Repeater und man bekommt auch ein stabiles Zigbee Mesh hin.
                            Network -> https://www.zigbee2mqtt.io/guide/adapters/#recommended
                               - Tube's Zigbee Gateways (CC2652P2 variant)
                               - cyijun OpenZ3Gateway
                               - XGG 52PZ2MGateway
                               - SMLIGHT Zigbee LAN Adapter CC2652P Model SLZB-05
                               - cod.m ZigBee CC2652P2 TCP Coordinator
                            VG
                            Bernd
                              @dp20eic
                              Ich habe jetzt aufgegeben und einen seperaten Iobroker auf den Raspi gebracht.
                              Der Stick funktioniert tadellos.
                              1038
