    4. TESTER gesucht / Backup auf Fritz.nas - node 18.18.0
      Thomas Braun Most Active @fastfoot last edited by
      @fastfoot sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
      und dann mit backit up(ich glaube dass das env dort vielleicht zu spät gesetzt wird) um sicher zu gehen
      Leider nix:
      echad@chet:/opt/iobroker $ ls -lAh /opt/iobroker/backups/ | grep 2023_10_12-21
      -rwxrwxrwx 1 root root  16K Oct 12 21:01 historyDB_2023_10_12-21_01_11_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root 5.8M Oct 12 21:01 iobroker_2023_10_12-21_00_57_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  14K Oct 12 21:01 javascripts_2023_10_12-21_01_54_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  958 Oct 12 21:01 zigbee.0_2023_10_12-21_01_53_chet_backupiobroker.tar.gz
        Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
        @simatec
        2023-10-12 21:05:45.190  - info: backitup.0 (74816) starting. Version 2.8.4 (non-npm: simatec/ioBroker.backitup) in /opt/iobroker/node_modules/iobroker.backitup, node: v20.8.0, js-controller: 5.0.13
        2023-10-12 21:05:45.257  - debug: backitup.0 (74816) Backitup has recognized a linux system
        2023-10-12 21:05:45.269  - debug: backitup.0 (74816) UV_USE_IO_URING: undefined
        2023-10-12 21:05:45.270  - debug: backitup.0 (74816) UV_USE_IO_URING: 0
        2023-10-12 21:05:45.312  - info: backitup.0 (74816) [iobroker] backup will be activated at 03:42 every 1 day(s)
        2023-10-12 21:05:45.412  - debug: backitup.0 (74816) noserverino option: true
        2023-10-12 21:05:45.413  - debug: backitup.0 (74816) cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //fritz.nasfritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups"
        2023-10-12 21:05:46.130  - debug: backitup.0 (74816) mount successfully completed
        2023-10-12 21:05:48.172  - debug: backitup.0 (74816) detect backup file 1 from NAS: iobroker_2023_10_12-03_42_20_chet_backupiobroker.tar.gz
        2023-10-12 21:05:48.173  - debug: backitup.0 (74816) detect backup file 2 from NAS: iobroker_2023_10_12-12_19_06_chet_backupiobroker.tar.gz
        2023-10-12 21:05:48.174  - debug: backitup.0 (74816) detect backup file 3 from NAS: iobroker_2023_10_12-19_16_19_chet_backupiobroker.tar.gz
        2023-10-12 21:05:48.174  - debug: backitup.0 (74816) detect backup file 4 from NAS: iobroker_2023_10_12-19_40_27_chet_backupiobroker.tar.gz
        2023-10-12 21:05:48.174  - debug: backitup.0 (74816) detect backup file 5 from NAS: iobroker_2023_10_12-19_51_57_chet_backupiobroker.tar.gz
        2023-10-12 21:05:48.175  - debug: backitup.0 (74816) detect backup file 6 from NAS: iobroker_2023_10_12-19_55_08_chet_backupiobroker.tar.gz
        2023-10-12 21:05:48.175  - debug: backitup.0 (74816) detect backup file 7 from NAS: iobroker_2023_10_12-20_42_42_chet_backupiobroker.tar.gz
        2023-10-12 21:05:48.175  - debug: backitup.0 (74816) detect backup file 8 from NAS: iobroker_2023_10_12-21_00_57_chet_backupiobroker.tar.gz
        2023-10-12 21:05:48.177  - debug: backitup.0 (74816) detect last backup file: iobroker_2023_10_12-21_00_57_chet_backupiobroker.tar.gz
        2023-10-12 21:05:55.301  - debug: backitup.0 (74816) mount activ... umount in 2 Seconds!!
        2023-10-12 21:05:57.364  - debug: backitup.0 (74816) umount successfully completed
        AB HIER EIN MANUELL GESTARTETES BACKUP
        2023-10-12 21:08:31.726  - debug: backitup.0 (74816) The local storage check was completed successfully. On the host "chet" are currently 100237 MB free space available!
        2023-10-12 21:08:38.058  - debug: backitup.0 (74816) The local storage check was completed successfully. On the host "chet" are currently 100237 MB free space available!
        2023-10-12 21:08:38.111  - debug: backitup.0 (74816) Backup has started ...
        2023-10-12 21:08:48.112  - debug: backitup.0 (74816) [iobroker/mount] noserverino option: true        =0777,dir_mode=0777,vers=3.1.1 //fritz.nas/fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups"name=iobroker,password=****,noserverino,rw,uid=iobroker,gid=iobroker,file_mode=2023-10-12 21:08:48.237  - debug: backitup.0 (74816) [iobroker/mount] mount successfully completed
        2023-10-12 21:08:48.240  - debug: backitup.0 (74816) [iobroker/mount] done
        2023-10-12 21:08:52.950  - debug: backitup.0 (74816) [iobroker/iobroker] host.chet 8118 states saved
        2023-10-12 21:08:53.112  - debug: backitup.0 (74816) [iobroker/iobroker] host.chet 9930 objects saved
        2023-10-12 21:08:58.029  - debug: backitup.0 (74816) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_10_12-21_08_48_chet_backupiobroker.tar.gz
        2023-10-12 21:08:58.033  - debug: backitup.0 (74816) [iobroker/iobroker] This backup can only be restored with js-controller version up from 4.1
        2023-10-12 21:08:59.127  - debug: backitup.0 (74816) [iobroker/iobroker] done
        2023-10-12 21:09:00.041  - debug: backitup.0 (74816) [iobroker/historyDB] compress from historyDB started ...
        2023-10-12 21:09:10.055  - debug: backitup.0 (74816) [iobroker/historyDB] Packed 0MB so far...
        2023-10-12 21:09:20.048  - debug: backitup.0 (74816) [iobroker/historyDB] Packed 0MB so far...
        2023-10-12 21:09:30.049  - debug: backitup.0 (74816) [iobroker/historyDB] Packed 0MB so far...
        2023-10-12 21:09:33.247  - debug: backitup.0 (74816) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_10_12-21_09_00_chet_backupiobroker.tar.gz
        2023-10-12 21:09:33.249  - debug: backitup.0 (74816) [iobroker/historyDB] done
        2023-10-12 21:09:33.404  - debug: backitup.0 (74816) [iobroker/zigbee] found zigbee database: zigbee.0
        2023-10-12 21:09:33.415  - debug: backitup.0 (74816) [iobroker/zigbee] done
        2023-10-12 21:09:34.195  - debug: backitup.0 (74816) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
        2023-10-12 21:09:34.387  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: dwd_uwz_nina_warnungen
        2023-10-12 21:09:34.387  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: lautstaerke_bad
        2023-10-12 21:09:34.388  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: lautstaerke_kueche
        2023-10-12 21:09:34.389  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: paketlieferungen
        2023-10-12 21:09:34.389  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: pakettruhe_offen
        2023-10-12 21:09:34.390  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: ps4_waker
        2023-10-12 21:09:34.391  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: sonnenaufgang
        2023-10-12 21:09:34.392  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: sonnenuntergang
        2023-10-12 21:09:34.393  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: speedtest
        2023-10-12 21:09:34.393  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: telefon_klingelt
        2023-10-12 21:09:34.394  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: treppenhaus_licht_ble
        2023-10-12 21:09:34.394  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: treppenhaus_licht_hub
        2023-10-12 21:09:34.394  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: tuerklingel_laeutet
        2023-10-12 21:09:34.395  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: wohnung_verlassen
        2023-10-12 21:09:34.395  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: zuhause_verlassen
        2023-10-12 21:09:34.395  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: nuki_ext_wohnungstuer_entriegelt
        2023-10-12 21:09:34.395  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: stromzaehler
        2023-10-12 21:09:34.396  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: stromzaehler2
        2023-10-12 21:09:34.396  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: frostwarner
        2023-10-12 21:09:34.396  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: awtrix
        2023-10-12 21:09:34.552  - debug: backitup.0 (74816) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
        2023-10-12 21:09:34.606  - debug: backitup.0 (74816) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
        2023-10-12 21:09:34.607  - debug: backitup.0 (74816) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_10_12-21_09_34_chet_backupiobroker.tar.gz
        2023-10-12 21:09:34.607  - debug: backitup.0 (74816) [iobroker/javascripts] done
        2023-10-12 21:09:35.361  - debug: backitup.0 (74816) [iobroker/cifs] used copy path: /fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet
        2023-10-12 21:09:35.362  - debug: backitup.0 (74816) [iobroker/cifs] done
        2023-10-12 21:09:35.964  - debug: backitup.0 (74816) [iobroker/clean] No older backup files are deleted, because this backup was started manually
        2023-10-12 21:09:35.965  - debug: backitup.0 (74816) [iobroker/clean] done
        2023-10-12 21:09:42.038  - debug: backitup.0 (74816) [iobroker/whatsapp] done
        2023-10-12 21:09:42.201  - debug: backitup.0 (74816) [iobroker/historyHTML] new history html values created
        2023-10-12 21:09:42.299  - debug: backitup.0 (74816) [iobroker/historyHTML] done
        2023-10-12 21:09:42.472  - debug: backitup.0 (74816) [iobroker/historyJSON] new history json values created
        2023-10-12 21:09:42.472  - debug: backitup.0 (74816) [iobroker/historyJSON] done
        2023-10-12 21:09:42.644  - debug: backitup.0 (74816) [iobroker/umount] mount activ, umount is started ...
        2023-10-12 21:09:47.688  - debug: backitup.0 (74816) [iobroker/umount] umount successfully completed
        2023-10-12 21:09:47.691  - debug: backitup.0 (74816) [iobroker/umount] done
        2023-10-12 21:09:47.843  - debug: backitup.0 (74816) [iobroker] exec: done
        Backup aber 'putt:
        echad@chet:/opt/iobroker $ ls -lAh /opt/iobroker/backups/ | grep 2023_10_12-21_09
        -rwxrwxrwx 1 root root  16K Oct 12 21:09 historyDB_2023_10_12-21_09_00_chet_backupiobroker.tar.gz
        -rwxrwxrwx 1 root root  14K Oct 12 21:09 javascripts_2023_10_12-21_09_34_chet_backupiobroker.tar.gz
        -rwxrwxrwx 1 root root  958 Oct 12 21:09 zigbee.0_2023_10_12-21_09_33_chet_backupiobroker.tar.gz
        simatec F 2 Replies Last reply Reply Quote 0
        • simatec
          simatec Developer Most Active @Thomas Braun last edited by
          @thomas-braun hmmm sehr sehr komisch. Bei mir ist es nicht beschädigt
            Thomas Braun Most Active @simatec last edited by
            @simatec
            Muss ich jetzt für alle Ewigkeit auf nodejs@18 bleiben? 😨
            • simatec
              @thomas-braun oder ein gescheites NAS kaufen 😋
                @simatec sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                Hab ich keine Verwendung für. Dann schieb ich es lieber immer direkt bei google hoch.
                  fastfoot @Thomas Braun last edited by
                  @thomas-braun sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                  das Log zeigt aber dass bei Eintritt in den Backitup-Adapter das env UV_USE....... nicht gesetzt war!!! Hattest du das so gestartet wie gezeigt? Ich bin der Meinung dass es da zu spät gesetzt wird.
                    Thomas Braun Most Active @fastfoot last edited by Thomas Braun
                    Klar.
                    echad@chet:/opt/iobroker $ iob stop
                    export UV_USE_IO_URING=0
                    iob start
                    echad@chet:/opt/iobroker $ echo $UV_USE_IO_URING
                    0
                      Ich kapier es nicht...
                      iob start
                      0
                      echad@chet:/opt/iobroker $ ls -lAh backups/
                      total 90M
                      -rwxrwxrwx 1 root root  16K Oct 12 21:57 2023_10_12-21_56_59_backupiobroker.tar.gz
                      • simatec
                        @thomas-braun @fastfoot
                        Könnt ihr mal eure Kernel-Versionen checken...
                        Bei dir @fastfoot lief ja das Backup oder?
                        Ich habe aktuell 6.2.16-5-pve
                        Thomas Braun F 2 Replies Last reply Reply Quote 0
                          @simatec
                          6.1.21-v8+
                          • simatec
                            @thomas-braun schau mal https://github.com/nodejs/node/issues/49937#issuecomment-1740490144
                            brubbel created this issue in nodejs/node
                            closed raspberry pi 300% cpu setTimeout() #49937
                              @simatec
                              Ich hab aber ein reines 64bit-System.
                              • simatec
                                @simatec
                                Hier steht ....
                                "however: in 64bit mode (6.1.54-v8+) -> OK!"
                                  Thomas Braun Most Active @simatec last edited by Thomas Braun
                                  @simatec
                                   *** Updating kernel modules
                                   *** depmod 6.1.57-v8+
                                  Mal schauen ob es was bringt...
                                  Edit: Nein, auch mit Kernel 6.1.57-v8+ keine Änderung, das Backup von History ist weiterhin kaputt.
                                  • simatec
                                    @thomas-braun Mach mal ohne der Env
                                      @simatec
                                      iobroker.backitup@2.8.4
                                      ist ohne ENV. Ich kann aber mal mit der github-Version probieren.
                                      Edit:
                                      Mit
                                      iobroker.backitup@2.8.6 (git+ssh://git@github.com/simatec/ioBroker.backitup.git#d68f6fe1fc54cbf85c4b89fce5c746894d26ca93)
                                      auch korrupt.
                                      • simatec
                                        @thomas-braun War ein Versuch wert 😧
                                          fastfoot @simatec last edited by
                                          ja, was immer ich versuche, es läuft einfach. heute auch noch smb zum container host probiert, es läuft. kernel scheint etwas älter 5.10.60-qnap.
                                          WSL2 bietet 5.15.90.1-microsoft-standard-WSL2 muss ich aber erst noch testen
                                          @Thomas-Braun hast du die 20.8.0 mal mit bullseye getestet?
                                            Nein, aber die 20.8.1 mit Trixie...
                                            204
                                            28291
