    4. TESTER gesucht / Backup auf Fritz.nas - node 18.18.0
      Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
      @simatec
      2023-10-12 21:05:45.190  - info: backitup.0 (74816) starting. Version 2.8.4 (non-npm: simatec/ioBroker.backitup) in /opt/iobroker/node_modules/iobroker.backitup, node: v20.8.0, js-controller: 5.0.13
      2023-10-12 21:05:45.257  - debug: backitup.0 (74816) Backitup has recognized a linux system
      2023-10-12 21:05:45.269  - debug: backitup.0 (74816) UV_USE_IO_URING: undefined
      2023-10-12 21:05:45.270  - debug: backitup.0 (74816) UV_USE_IO_URING: 0
      2023-10-12 21:05:45.312  - info: backitup.0 (74816) [iobroker] backup will be activated at 03:42 every 1 day(s)
      2023-10-12 21:05:45.412  - debug: backitup.0 (74816) noserverino option: true
      2023-10-12 21:05:45.413  - debug: backitup.0 (74816) cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //fritz.nasfritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups"
      2023-10-12 21:05:46.130  - debug: backitup.0 (74816) mount successfully completed
      2023-10-12 21:05:48.172  - debug: backitup.0 (74816) detect backup file 1 from NAS: iobroker_2023_10_12-03_42_20_chet_backupiobroker.tar.gz
      2023-10-12 21:05:48.173  - debug: backitup.0 (74816) detect backup file 2 from NAS: iobroker_2023_10_12-12_19_06_chet_backupiobroker.tar.gz
      2023-10-12 21:05:48.174  - debug: backitup.0 (74816) detect backup file 3 from NAS: iobroker_2023_10_12-19_16_19_chet_backupiobroker.tar.gz
      2023-10-12 21:05:48.174  - debug: backitup.0 (74816) detect backup file 4 from NAS: iobroker_2023_10_12-19_40_27_chet_backupiobroker.tar.gz
      2023-10-12 21:05:48.174  - debug: backitup.0 (74816) detect backup file 5 from NAS: iobroker_2023_10_12-19_51_57_chet_backupiobroker.tar.gz
      2023-10-12 21:05:48.175  - debug: backitup.0 (74816) detect backup file 6 from NAS: iobroker_2023_10_12-19_55_08_chet_backupiobroker.tar.gz
      2023-10-12 21:05:48.175  - debug: backitup.0 (74816) detect backup file 7 from NAS: iobroker_2023_10_12-20_42_42_chet_backupiobroker.tar.gz
      2023-10-12 21:05:48.175  - debug: backitup.0 (74816) detect backup file 8 from NAS: iobroker_2023_10_12-21_00_57_chet_backupiobroker.tar.gz
      2023-10-12 21:05:48.177  - debug: backitup.0 (74816) detect last backup file: iobroker_2023_10_12-21_00_57_chet_backupiobroker.tar.gz
      2023-10-12 21:05:55.301  - debug: backitup.0 (74816) mount activ... umount in 2 Seconds!!
      2023-10-12 21:05:57.364  - debug: backitup.0 (74816) umount successfully completed
      AB HIER EIN MANUELL GESTARTETES BACKUP
      2023-10-12 21:08:31.726  - debug: backitup.0 (74816) The local storage check was completed successfully. On the host "chet" are currently 100237 MB free space available!
      2023-10-12 21:08:38.058  - debug: backitup.0 (74816) The local storage check was completed successfully. On the host "chet" are currently 100237 MB free space available!
      2023-10-12 21:08:38.111  - debug: backitup.0 (74816) Backup has started ...
      2023-10-12 21:08:48.112  - debug: backitup.0 (74816) [iobroker/mount] noserverino option: true        =0777,dir_mode=0777,vers=3.1.1 //fritz.nas/fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups"name=iobroker,password=****,noserverino,rw,uid=iobroker,gid=iobroker,file_mode=2023-10-12 21:08:48.237  - debug: backitup.0 (74816) [iobroker/mount] mount successfully completed
      2023-10-12 21:08:48.240  - debug: backitup.0 (74816) [iobroker/mount] done
      2023-10-12 21:08:52.950  - debug: backitup.0 (74816) [iobroker/iobroker] host.chet 8118 states saved
      2023-10-12 21:08:53.112  - debug: backitup.0 (74816) [iobroker/iobroker] host.chet 9930 objects saved
      2023-10-12 21:08:58.029  - debug: backitup.0 (74816) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_10_12-21_08_48_chet_backupiobroker.tar.gz
      2023-10-12 21:08:58.033  - debug: backitup.0 (74816) [iobroker/iobroker] This backup can only be restored with js-controller version up from 4.1
      2023-10-12 21:08:59.127  - debug: backitup.0 (74816) [iobroker/iobroker] done
      2023-10-12 21:09:00.041  - debug: backitup.0 (74816) [iobroker/historyDB] compress from historyDB started ...
      2023-10-12 21:09:10.055  - debug: backitup.0 (74816) [iobroker/historyDB] Packed 0MB so far...
      2023-10-12 21:09:20.048  - debug: backitup.0 (74816) [iobroker/historyDB] Packed 0MB so far...
      2023-10-12 21:09:30.049  - debug: backitup.0 (74816) [iobroker/historyDB] Packed 0MB so far...
      2023-10-12 21:09:33.247  - debug: backitup.0 (74816) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_10_12-21_09_00_chet_backupiobroker.tar.gz
      2023-10-12 21:09:33.249  - debug: backitup.0 (74816) [iobroker/historyDB] done
      2023-10-12 21:09:33.404  - debug: backitup.0 (74816) [iobroker/zigbee] found zigbee database: zigbee.0
      2023-10-12 21:09:33.415  - debug: backitup.0 (74816) [iobroker/zigbee] done
      2023-10-12 21:09:34.195  - debug: backitup.0 (74816) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      2023-10-12 21:09:34.387  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: dwd_uwz_nina_warnungen
      2023-10-12 21:09:34.387  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: lautstaerke_bad
      2023-10-12 21:09:34.388  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: lautstaerke_kueche
      2023-10-12 21:09:34.389  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: paketlieferungen
      2023-10-12 21:09:34.389  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: pakettruhe_offen
      2023-10-12 21:09:34.390  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: ps4_waker
      2023-10-12 21:09:34.391  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: sonnenaufgang
      2023-10-12 21:09:34.392  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: sonnenuntergang
      2023-10-12 21:09:34.393  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: speedtest
      2023-10-12 21:09:34.393  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: telefon_klingelt
      2023-10-12 21:09:34.394  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: treppenhaus_licht_ble
      2023-10-12 21:09:34.394  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: treppenhaus_licht_hub
      2023-10-12 21:09:34.394  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: tuerklingel_laeutet
      2023-10-12 21:09:34.395  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: wohnung_verlassen
      2023-10-12 21:09:34.395  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: zuhause_verlassen
      2023-10-12 21:09:34.395  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: nuki_ext_wohnungstuer_entriegelt
      2023-10-12 21:09:34.395  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: stromzaehler
      2023-10-12 21:09:34.396  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: stromzaehler2
      2023-10-12 21:09:34.396  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: frostwarner
      2023-10-12 21:09:34.396  - debug: backitup.0 (74816) [iobroker/javascripts] found Script: awtrix
      2023-10-12 21:09:34.552  - debug: backitup.0 (74816) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      2023-10-12 21:09:34.606  - debug: backitup.0 (74816) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      2023-10-12 21:09:34.607  - debug: backitup.0 (74816) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_10_12-21_09_34_chet_backupiobroker.tar.gz
      2023-10-12 21:09:34.607  - debug: backitup.0 (74816) [iobroker/javascripts] done
      2023-10-12 21:09:35.361  - debug: backitup.0 (74816) [iobroker/cifs] used copy path: /fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet
      2023-10-12 21:09:35.362  - debug: backitup.0 (74816) [iobroker/cifs] done
      2023-10-12 21:09:35.964  - debug: backitup.0 (74816) [iobroker/clean] No older backup files are deleted, because this backup was started manually
      2023-10-12 21:09:35.965  - debug: backitup.0 (74816) [iobroker/clean] done
      2023-10-12 21:09:42.038  - debug: backitup.0 (74816) [iobroker/whatsapp] done
      2023-10-12 21:09:42.201  - debug: backitup.0 (74816) [iobroker/historyHTML] new history html values created
      2023-10-12 21:09:42.299  - debug: backitup.0 (74816) [iobroker/historyHTML] done
      2023-10-12 21:09:42.472  - debug: backitup.0 (74816) [iobroker/historyJSON] new history json values created
      2023-10-12 21:09:42.472  - debug: backitup.0 (74816) [iobroker/historyJSON] done
      2023-10-12 21:09:42.644  - debug: backitup.0 (74816) [iobroker/umount] mount activ, umount is started ...
      2023-10-12 21:09:47.688  - debug: backitup.0 (74816) [iobroker/umount] umount successfully completed
      2023-10-12 21:09:47.691  - debug: backitup.0 (74816) [iobroker/umount] done
      2023-10-12 21:09:47.843  - debug: backitup.0 (74816) [iobroker] exec: done
      Backup aber 'putt:
      echad@chet:/opt/iobroker $ ls -lAh /opt/iobroker/backups/ | grep 2023_10_12-21_09
      -rwxrwxrwx 1 root root  16K Oct 12 21:09 historyDB_2023_10_12-21_09_00_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  14K Oct 12 21:09 javascripts_2023_10_12-21_09_34_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  958 Oct 12 21:09 zigbee.0_2023_10_12-21_09_33_chet_backupiobroker.tar.gz
      simatec F 2 Replies Last reply Reply Quote 0
      • simatec
        simatec Developer Most Active @Thomas Braun last edited by
        @thomas-braun hmmm sehr sehr komisch. Bei mir ist es nicht beschädigt
          Thomas Braun Most Active @simatec last edited by
          @simatec
          Muss ich jetzt für alle Ewigkeit auf nodejs@18 bleiben? 😨
          • simatec
            @thomas-braun oder ein gescheites NAS kaufen 😋
              @simatec sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
              Hab ich keine Verwendung für. Dann schieb ich es lieber immer direkt bei google hoch.
                fastfoot @Thomas Braun last edited by
                @thomas-braun sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                das Log zeigt aber dass bei Eintritt in den Backitup-Adapter das env UV_USE....... nicht gesetzt war!!! Hattest du das so gestartet wie gezeigt? Ich bin der Meinung dass es da zu spät gesetzt wird.
                  Thomas Braun Most Active @fastfoot last edited by Thomas Braun
                  @fastfoot sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                  Klar.
                  echad@chet:/opt/iobroker $ iob stop
                  export UV_USE_IO_URING=0
                  iob start
                  echad@chet:/opt/iobroker $ echo $UV_USE_IO_URING
                  0
                    Ich kapier es nicht...
                    iob start
                    0
                    echad@chet:/opt/iobroker $ ls -lAh backups/
                    total 90M
                    -rwxrwxrwx 1 root root  16K Oct 12 21:57 2023_10_12-21_56_59_backupiobroker.tar.gz
                    • simatec
                      @thomas-braun @fastfoot
                      Könnt ihr mal eure Kernel-Versionen checken...
                      Bei dir @fastfoot lief ja das Backup oder?
                      Ich habe aktuell 6.2.16-5-pve
                      Thomas Braun F 2 Replies Last reply Reply Quote 0
                        @simatec
                        6.1.21-v8+
                        • simatec
                          @thomas-braun schau mal https://github.com/nodejs/node/issues/49937#issuecomment-1740490144
                          brubbel created this issue in nodejs/node
                          closed raspberry pi 300% cpu setTimeout() #49937
                            @simatec
                            Ich hab aber ein reines 64bit-System.
                            • simatec
                              @simatec
                              Hier steht ....
                              "however: in 64bit mode (6.1.54-v8+) -> OK!"
                                Thomas Braun Most Active @simatec last edited by Thomas Braun
                                @simatec
                                 *** Updating kernel modules
                                 *** depmod 6.1.57-v8+
                                Mal schauen ob es was bringt...
                                Edit: Nein, auch mit Kernel 6.1.57-v8+ keine Änderung, das Backup von History ist weiterhin kaputt.
                                • simatec
                                  @thomas-braun Mach mal ohne der Env
                                    @simatec
                                    iobroker.backitup@2.8.4
                                    ist ohne ENV. Ich kann aber mal mit der github-Version probieren.
                                    Edit:
                                    Mit
                                    iobroker.backitup@2.8.6 (git+ssh://git@github.com/simatec/ioBroker.backitup.git#d68f6fe1fc54cbf85c4b89fce5c746894d26ca93)
                                    auch korrupt.
                                    • simatec
                                      @thomas-braun War ein Versuch wert 😧
                                        fastfoot @simatec last edited by
                                        ja, was immer ich versuche, es läuft einfach. heute auch noch smb zum container host probiert, es läuft. kernel scheint etwas älter 5.10.60-qnap.
                                        WSL2 bietet 5.15.90.1-microsoft-standard-WSL2 muss ich aber erst noch testen
                                        @Thomas-Braun hast du die 20.8.0 mal mit bullseye getestet?
                                          Nein, aber die 20.8.1 mit Trixie...
                                            ist ohne ENV.
                                            traue deinem setup nicht 🙂 wenn du deinen iobroker startest (mit github backitup) und dann grep UV_USE log/*curr*|tail -2 ausführst solltest du 2 gleiche Einträge sehen, beide mit Wert 0. Sollte der erste undefined sein, dann setze mal bitte das env in deinen Systemeinstellungen. Immerhin hatte doch das Skript mit der env funktioniert, das muss dann auch im Backitup funktionieren. Und vergiss mal für kurze Zeit den History Teil und die anderen, die werden ja etwas anders erzeugt. Man wird sonst ganz durcheinander. Evtl. könnte @simatec dann ja die pipeline Methode aus dem Skript zum testen einbauen für die History wenn das normale Backup geklärt ist
                                            Thomas Braun simatec 3 Replies Last reply Reply Quote 0
                                            204
                                            28291
