    4. (gelöst) Telegramm Adapter rot
    • DJMarc75
      DJMarc75 @Glasfaser last edited by
      @ostseereiter
      @glasfaser sagte in Telegramm Adapter rot:
      Bitte die Full Ausgabe von
      ostseereiter 1 Reply Last reply Reply Quote 0
      • ostseereiter
        ostseereiter @DJMarc75 last edited by
        @djmarc75 ```
        Skript v.2023-06-20
        *** BASE SYSTEM ***
         Static hostname: debianIOB
               Icon name: computer-desktop
                 Chassis: desktop 🖥️
              Machine ID: 82a534abc6cf415a8cc39087cc5d7983
                 Boot ID: 4f84fb8dabb74a72afd309ddc5f5dc93
                  Kernel: Linux 6.1.0-12-amd64
            Architecture: x86-64
         Hardware Vendor: Hewlett-Packard
          Hardware Model: HP t610 WW Thin Client
        Firmware Version: K30 v01.16
        model name      : AMD G-T56N Processor
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         15:48:47 up 5 days,  3:12,  2 users,  load average: 2.16, 2.19, 2.13
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Fri 2023-10-06 15:48:47 CEST
                   Universal time: Fri 2023-10-06 13:48:47 UTC
                         RTC time: Fri 2023-10-06 13:48:47
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        andy
        /home/andy
        andy cdrom floppy sudo audio dip video plugdev users netdev iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        6.3G        913M        614K        880M        1.5G
        Swap:           1.0G        1.0G         24K
        Total:          8.8G        7.3G        913M
                 7407 M total memory
                 5996 M used memory
                 1587 M active memory
                 4512 M inactive memory
                  871 M free memory
                  272 M buffer memory
                  567 M swap cache
                  975 M total swap
                  975 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        udev           devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     741M  652K  741M   1% /run
        /dev/sda1      ext4      116G  5.9G  105G   6% /
        tmpfs          tmpfs     3.7G     0  3.7G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     741M     0  741M   0% /run/user/1000
        [Sun Oct  1 12:36:13 2023] EXT4-fs (sda1): mounted filesystem with ordered data        mode. Quota mode: none.
        [Sun Oct  1 12:36:14 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        488M    /var/
        279M    /var/cache
        271M    /var/cache/apt
        195M    /var/cache/apt/archives
        170M    /var/lib
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        103M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        651M    /opt/iobroker/iobroker-data/
        473M    /opt/iobroker/iobroker-data/files
        125M    /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        39M     /opt/iobroker/iobroker-data/objects.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.        js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.m        ap
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.m        ap
        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a        4d8d.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.0
        /usr/bin/node           v18.18.0
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Installed: 18.18.0-1nodesource1
          Candidate: 18.18.0-1nodesource1
          Version table:
         *** 18.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
                500 http://debian.netcologne.de/debian bookworm/main amd64 Packages
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        npm ERR! code ELSPROBLEMS
        npm ERR! invalid: @abandonware/noble@1.9.2-23 /opt/iobroker/node_modules/@abandonware/noble
        npm ERR! A complete log of this run can be found in: /home/andy/.npm/_logs/2023-10-06T13_48_59_541Z-debug-0.log
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    jsonl on 127.0.0.1
        States:                     jsonl on 127.0.0.1
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.10.1
        javascript:     7.1.4
        Adapters from github:   5
        Adapter State
        + system.adapter.admin.2                  : admin                 : debianIOB                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          system.adapter.alarm.0                  : alarm                 : debianIOB                                - disabled
        + system.adapter.alexa2.0                 : alexa2                : debianIOB                                -  enabled
          system.adapter.alias-manager.0          : alias-manager         : debianIOB                                - disabled
        + system.adapter.backitup.0               : backitup              : debianIOB                                -  enabled
          system.adapter.birthdays.0              : birthdays             : debianIOB                                -  enabled
          system.adapter.ble.0                    : ble                   : debianIOB                                - disabled
        + system.adapter.bring.0                  : bring                 : debianIOB                                -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : debianIOB                                -  enabled
        + system.adapter.cloud.0                  : cloud                 : debianIOB                                -  enabled
          system.adapter.daswetter.0              : daswetter             : debianIOB                                -  enabled
        + system.adapter.denon.0                  : denon                 : debianIOB                                -  enabled
        + system.adapter.device-reminder.1        : device-reminder       : debianIOB                                -  enabled
          system.adapter.devices.0                : devices               : debianIOB                                - disabled
        + system.adapter.discovery.0              : discovery             : debianIOB                                -  enabled
          system.adapter.dwd.0                    : dwd                   : debianIOB                                -  enabled
          system.adapter.emby.0                   : emby                  : debianIOB                                - disabled
          system.adapter.feiertage.0              : feiertage             : debianIOB                                -  enabled
          system.adapter.flot.0                   : flot                  : debianIOB                                - disabled
        + system.adapter.fritzbox.0               : fritzbox              : debianIOB                                -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : debianIOB                                -  enabled
        + system.adapter.harmony.0                : harmony               : debianIOB                                -  enabled
          system.adapter.heatingcontrol.0         : heatingcontrol        : debianIOB                                - disabled
        + system.adapter.heos.0                   : heos                  : debianIOB                                -  enabled
        + system.adapter.history.0                : history               : debianIOB                                -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : debianIOB                                -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : debianIOB                                -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : debianIOB                                -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : debianIOB                                -  enabled
          system.adapter.iceroad.0                : iceroad               : debianIOB                                - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : debianIOB                                - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : debianIOB                                - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debianIOB                                - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: debianIOB                                - disabled
          system.adapter.influxdb.1               : influxdb              : debianIOB                                - disabled, port: 8086
        + system.adapter.info.0                   : info                  : debianIOB                                -  enabled
        + system.adapter.iot.0                    : iot                   : debianIOB                                -  enabled
        + system.adapter.iqontrol.0               : iqontrol              : debianIOB                                -  enabled
        + system.adapter.javascript.0             : javascript            : debianIOB                                -  enabled
          system.adapter.kodi.0                   : kodi                  : debianIOB                                - disabled, port: 9090
        + system.adapter.meldungsliste.0          : meldungsliste         : debianIOB                                -  enabled
        + system.adapter.mihome.0                 : mihome                : debianIOB                                -  enabled, port: 9898, bind: 0.0.0.0
          system.adapter.mobile.0                 : mobile                : debianIOB                                - disabled
        + system.adapter.mqtt.0                   : mqtt                  : debianIOB                                -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.musiccast.0              : musiccast             : debianIOB                                -  enabled
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : debianIOB                                -  enabled
        + system.adapter.nina.0                   : nina                  : debianIOB                                -  enabled
        + system.adapter.node-red.0               : node-red              : debianIOB                                -  enabled, port: 1880, bind: 192.168.178.109
        + system.adapter.nuki-extended.0          : nuki-extended         : debianIOB                                -  enabled
          system.adapter.nut.0                    : nut                   : debianIOB                                - disabled
          system.adapter.octoprint.0              : octoprint             : debianIOB                                - disabled
          system.adapter.odl.0                    : odl                   : debianIOB                                - disabled
          system.adapter.onkyo.0                  : onkyo                 : debianIOB                                - disabled
        + system.adapter.parcel.0                 : parcel                : debianIOB                                -  enabled
          system.adapter.pi-hole.0                : pi-hole               : debianIOB                                - disabled
        + system.adapter.ping.0                   : ping                  : debianIOB                                -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : debianIOB                                -  enabled
        + system.adapter.radar2.0                 : radar2                : debianIOB                                -  enabled
          system.adapter.rickshaw.0               : rickshaw              : debianIOB                                - disabled
        + system.adapter.scenes.0                 : scenes                : debianIOB                                -  enabled
          system.adapter.schoolfree.0             : schoolfree            : debianIOB                                -  enabled
          system.adapter.shelly.0                 : shelly                : debianIOB                                - disabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : debianIOB                                -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : debianIOB                                -  enabled
        + system.adapter.statistics.0             : statistics            : debianIOB                                -  enabled
          system.adapter.switchbot-ble.0          : switchbot-ble         : debianIOB                                - disabled
        + system.adapter.switchbot-hub.0          : switchbot-hub         : debianIOB                                -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : debianIOB                                -  enabled
        + system.adapter.telegram.0               : telegram              : debianIOB                                -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : debianIOB                                -  enabled
        + system.adapter.tr-064.0                 : tr-064                : debianIOB                                -  enabled
          system.adapter.tvspielfilm.0            : tvspielfilm           : debianIOB                                - disabled
        + system.adapter.virtualpowermeter.0      : virtualpowermeter     : debianIOB                                -  enabled
          system.adapter.vis-bars.0               : vis-bars              : debianIOB                                - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debianIOB                                - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : debianIOB                                - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debianIOB                                - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debianIOB                                - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : debianIOB                                - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debianIOB                                - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : debianIOB                                - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : debianIOB                                - disabled
          system.adapter.vis-metro.0              : vis-metro             : debianIOB                                - disabled
          system.adapter.vis-players.0            : vis-players           : debianIOB                                - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : debianIOB                                - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : debianIOB                                - disabled
          system.adapter.vis.0                    : vis                   : debianIOB                                -  enabled
          system.adapter.vodafone-speedtest.0     : vodafone-speedtest    : debianIOB                                - disabled
        + system.adapter.web.0                    : web                   : debianIOB                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.wled.0                   : wled                  : debianIOB                                - disabled
        + system.adapter.yeelight-2.0             : yeelight-2            : debianIOB                                -  enabled
        + system.adapter.zigbee.0                 : zigbee                : debianIOB                                -  enabled, port: /dev/ttyACM0
        + system.adapter.zigbee.1                 : zigbee                : debianIOB                                -  enabled, port: tcp://192.168.178.110:6638
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        latest1       : http://iobroker.live/repo/sources-dist-latest.json
        stable        : http://iobroker.live/repo/sources-dist.json
        Active repo(s): Stable (default)
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "admin"        : 6.10.1   , installed 6.10.1
        Adapter    "alarm"        : 3.3.13   , installed 3.3.13
        Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
        Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
        Adapter    "ble"          : 0.13.4   , installed 0.13.4
        Adapter    "bring"        : 1.8.1    , installed 1.8.1
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "denon"        : 1.15.4   , installed 1.15.4
        Adapter    "device-reminder": 1.2.9  , installed 1.2.9
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "emby"         : 1.0.2    , installed 1.0.2
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
        Adapter    "heos"         : 2.1.0    , installed 2.1.0
        Adapter    "history"      : 2.2.6    , installed 2.2.6
        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "kodi"         : 3.0.0    , installed 3.0.0
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "musiccast"    : 1.1.0    , installed 1.1.0
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
        Adapter    "odl"          : 2.0.5    , installed 2.0.5
        Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
        Adapter    "parcel"       : 0.0.27   , installed 0.0.27
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "radar2"       : 2.0.7    , installed 2.0.7
        Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
        Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "statistics"   : 2.3.0    , installed 2.3.0
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
        Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "web"          : 6.1.2    , installed 6.1.2
        Adapter    "wled"         : 0.6.7    , installed 0.6.7
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        Objects and States
        Objects:        25501
        States:         23880
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://debian.netcologne.de/debian bookworm InRelease
        Hit:3 http://debian.netcologne.de/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 9
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13694      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17260      423/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17718      400/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17713      400/iobroker.js-con
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       81579      37606/io.sonoff.0
        tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       125285     62675/io.mqtt.0
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       125284     62675/io.mqtt.0
        tcp        0      0 192.168.178.109:2001    0.0.0.0:*               LISTEN      1001       150070     77398/io.hm-rpc.0
        tcp        0      0 192.168.178.109:1880    0.0.0.0:*               LISTEN      1001       119917     59208/node-red
        tcp        0      0 192.168.178.109:8701    0.0.0.0:*               LISTEN      1001       150683     77407/io.hm-rpc.1
        tcp6       0      0 :::111                  :::*                    LISTEN      0          13696      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17271      423/sshd: /usr/sbin
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       22554048   3645510/io.harmony.
        tcp6       0      0 :::51989                :::*                    LISTEN      1001       115723     56799/io.nuki-exten
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       336169     187185/io.admin.2
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       497453     273106/io.web.0
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       355979     199192/io.radar2.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17205      401/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13695      1/init
        udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       47554      17021/io.musiccast.
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       22554049   3645510/io.harmony.
        udp        0      0 0.0.0.0:45824           0.0.0.0:*                           1001       19107610   955/io.broadlink2.0
        udp        0      0 0.0.0.0:58349           0.0.0.0:*                           1001       166087     86942/io.heos.0
        udp        0      0 0.0.0.0:34277           0.0.0.0:*                           1001       21145      955/io.broadlink2.0
        udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       19984      706/io.mihome.0
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       21102      955/io.broadlink2.0
        udp6       0      0 :::111                  :::*                                0          13697      1/init
        2023-10-06 15:51:00.109  - warn: javascript.0 (42081)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
        2023-10-06 15:51:00.109  - warn: javascript.0 (42081)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
        2023-10-06 15:51:00.109  - warn: javascript.0 (42081)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
        2023-10-06 15:51:00.109  - warn: javascript.0 (42081)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
        2023-10-06 15:51:00.109  - warn: javascript.0 (42081)     at listOnTimeout (node:internal/timers:569:17)
        2023-10-06 15:51:00.110  - warn: javascript.0 (42081)     at processTimers (node:internal/timers:512:7)
        2023-10-06 15:51:00.147  - info: javascript.0 (42081) script.js.Haustür.Tuerauf_Klingel: Tuerzeitplan start
        2023-10-06 15:51:00.219  - info: javascript.0 (42081) script.js.Tablett_.Wetter1: []
        2023-10-06 15:51:04.481  - info: radar2.0 (199192) debug: started #58120 hciconfig hci0 down
        2023-10-06 15:51:04.693  - info: radar2.0 (199192) debug: started #58121 hciconfig hci0 up
        2023-10-06 15:51:04.875  - info: radar2.0 (199192) debug: started #58122 hcitool -i hci0 lescan --duplicates
        2023-10-06 15:51:04.942  - info: radar2.0 (199192) debug: started #58123 l2ping  -c 1 01:23:45:56:78:89
        2023-10-06 15:51:05.394  - info: radar2.0 (199192) debug: ChangeState ack:true of Ich._lastHere = 2023-10-06@15:51:04
        2023-10-06 15:51:06.183  - info: radar2.0 (199192) debug: ChangeState ack:true of Fritzbox._lastHere = 2023-10-06@15:51:05
        2023-10-06 15:51:06.763  - info: tr-064.0 (26932) forEachConfiguredDevice: in GetSpecificHostEntry 16(homematic-ccu2/00:1A:22:09:3D:13) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2023-10-06 15:51:07.290  - info: tr-064.0 (26932) forEachConfiguredDevice: in GetSpecificHostEntry 24(Handy-Jessy-poco/fe80::6cea:41ff:fe52:b9ef) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2023-10-06 15:51:08.324  - info: radar2.0 (199192) debug: ChangeState ack:true of HarmonyHub._lastHere = 2023-10-06@15:51:08
        2023-10-06 15:51:10.431  - info: radar2.0 (199192) debug: ChangeState ack:true of Ich._nHere = 14277
        2023-10-06 15:51:10.496  - info: radar2.0 (199192) debug: ChangeState ack:true of Fritzbox._nHere = 14277
        2023-10-06 15:51:10.574  - info: radar2.0 (199192) debug: ChangeState ack:true of HarmonyHub._nHere = 14277
        2023-10-06 15:51:10.602  - info: radar2.0 (199192) debug: radar2 found here (Ich, Fritzbox, HarmonyHub)
        2023-10-06 15:51:10.602  - info: radar2.0 (199192) debug: and who here (Fritzbox, HarmonyHub)
        2023-10-06 15:51:10.602  - info: radar2.0 (199192) debug: and not here (HandyAndy, Handy-Heike)
        2023-10-06 15:51:10.602  - info: radar2.0 (199192) debug: radar2 found uBT's: []
        2023-10-06 15:51:10.603  - info: radar2.0 (199192) debug: radar2 found uIP's: []
        iob diag has finished.
        Press any key for a summary
        • DJMarc75
          DJMarc75 @ostseereiter last edited by
          @ostseereiter lass mal das Skript von @Thomas-Braun ´s Signatur laufen.
          • ostseereiter
            @djmarc75
            ok
            • Glasfaser
              Glasfaser @Glasfaser last edited by
              @ostseereiter
              @ostseereiter sagte in Telegramm Adapter rot:
              mein Telegrammadapter ist einmal am Tag rot
              nach diesem hier
              https://forum.iobroker.net/topic/67149/alles-neu
              oder schon davor !?
              Was steht im Log wenn der Adapter rot ( Ampel ) wird oder funktioniert er weiterhin ohne Fehlermeldung im Log , das kann man so nicht erlesen !?
              Die Antwort fehlt dazu !?
              • ostseereiter
                ostseereiter @Glasfaser last edited by
                @glasfaser
                im Moment ist er ja nicht rot erst nach einen obligatorischen Neustart der ja automatisch abläuft.So kann ich erst morgen dazu was schreiben. wenn er dann wieder rot ist.
                • Glasfaser
                  Glasfaser @ostseereiter last edited by Glasfaser
                  Du meinst die Einstellung im Adapter den Neustart selber um die Eingestellte Zeit X , die kannst du ausschalten , das war mal früher so !
                  • ostseereiter
                    ostseereiter @Glasfaser last edited by ostseereiter
                    @glasfaser
                    Ja genau nach dem Neustart scheint es nicht mehr zu gehen oder auch zufällig denn um 4 Uhr morgens habe ich auch ein Neustart aus Sicherheit eingefügt.Da er dfamals schon sporadisch ausgefallen ist.
                    v6.10.1
                    038
                    Log-Größe: 15.2 MB
                    Zeit
                    Nachricht
                    telegram.0
                    	2023-10-07 10:46:44.908	info	starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.0, js-controller: 5.0.12
                    telegram.0
                    	2023-10-07 10:46:26.610	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    telegram.0
                    	2023-10-07 10:46:26.607	info	terminating
                    telegram.0
                    	2023-10-07 10:46:26.097	info	Got terminate signal TERMINATE_YOURSELF
                    telegram.0
                    	2023-10-07 10:46:22.216	info	starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.0, js-controller: 5.0.12
                    telegram.0
                    	2023-10-07 10:46:05.632	warn	get state error: Connection is closed.
                    telegram.0
                    	2023-10-07 10:46:05.631	warn	get state error: Connection is closed.
                    telegram.0
                    	2023-10-07 10:46:05.630	warn	get state error: Connection is closed.
                    telegram.0
                    	2023-10-07 10:46:05.628	warn	get state error: Connection is closed.
                    telegram.0
                    	2023-10-07 10:46:05.627	warn	get state error: Connection is closed.
                    telegram.0
                    	2023-10-07 10:46:05.622	warn	get state error: Connection is closed.
                    telegram.0
                    telegram.0
                    	2023-10-07 10:46:05.621	warn	get state error: Connection is closed.
                    telegram.0
                    	2023-10-07 10:46:05.619	warn	get state error: Connection is closed.
                    telegram.0
                    	2023-10-07 10:46:05.537	info	starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.0, js-controller: 5.0.12
                    telegram.0
                    	2023-10-07 10:46:05.445	info	terminating with timeout
                    telegram.0
                    	2023-10-07 10:46:04.443	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    telegram.0
                    	2023-10-07 10:46:04.425	info	terminating
                    telegram.0
                    	2023-10-07 10:46:03.890	info	Got terminate signal TERMINATE_YOURSELF
                    ich habe jetzt mal komplett ausgestellt mal sehen.
                    • ostseereiter
                      Hallo Freunde,
                      nachdem ich nun den Neustart ausgestellt habe läuft der Adapter ohne Probleme seit ein paar Tagen durch.
                      Danke für die Hilfe
                      Glasfaser 1 Reply Last reply Reply Quote 1
                      • Glasfaser
                        @ostseereiter sagte in (gelöst) Telegramm Adapter rot:
                        Danke für die Hilfe
                        Freut mich ... 🙂
                        439
