    4. Strom Verbrauch und separat Überschuss berechnen
    • Duffy
      Duffy @wde last edited by
      @wde
      Das skript:
        <variables>
          <variable id="8QfIKsruysJpkfI_Laz=">Einspeiseenergie</variable>
          <variable id="SDbPbz:OQ}DXoHFlfr6;">PV_Ertrag</variable>
        </variables>
        <block type="variables_set" id="mbhzmxw}Olt:RED`$HM?" x="188" y="88">
          <field name="VAR" id="8QfIKsruysJpkfI_Laz=">Einspeiseenergie</field>
            <block type="get_value" id="fv.Pyn+=XNj3mBR^O*y#">
              <field name="OID">0_userdata.0.PV_Einspeisung.PV_Einspeisung_Wh</field>
            <block type="comment" id="zB]aZ2A+Q7t}Zj)v/Mp0">
              <field name="COMMENT">Leistung (W)</field>
                <block type="on_ext" id="_s6W/4RK2_,Ax/VDHl=g">
                  <value name="OID0">
                    <shadow type="field_oid" id=".vLIJp|1X|EY%Ed2HG54">
                      <field name="oid">sonoff.0.Stromzähler.MT681_Power_cur</field>
                    <block type="controls_if" id="Ah1T+%Zg,Jwu12qd{clW">
                        <block type="logic_compare" id="!}L8R}/%Elp$%K5Sl(9|">
                          <field name="OP">LT</field>
                            <block type="on_source" id="@I~zpvc}htlNbY?ce!NV">
                              <field name="ATTR">oldState.val</field>
                            <block type="math_number" id="[T?_,mrEXTI=ga^+u3N`">
                              <field name="NUM">0</field>
                        <block type="comment" id="Oo~f?,+KUpsHqmTcN[WZ">
                          <field name="COMMENT">Energie Wh</field>
                            <block type="math_change" id="pTtl{hR/]%qAvX;A2Fz=">
                              <value name="DELTA">
                                <shadow type="math_number" id="Uk@[+;hZ(9z{7j!R!*)~">
                                  <field name="NUM">1</field>
                                <block type="math_arithmetic" id="WX:QVL4gOAnA.cJH9H`x" inline="false">
                                  <field name="OP">DIVIDE</field>
                                    <shadow type="math_number" id="q*0#7)IKIdS}sN%W7tfw">
                                    <block type="math_arithmetic" id="BNX`[d!HLVfIwcXs86Ep">
                                        <shadow type="math_number" id="J)-A5vC7c^f~YA_D,D,?">
                                        <block type="on_source" id="gl7iH#}}_gADCuUu0y@8">
                                        <shadow type="math_number" id="l{SbNq,AT{hE]hFEqSB2">
                                        <block type="math_arithmetic" id="alN.)HWWpj`ZQ~Rfl5@{">
                                            <shadow type="math_number" id="%(VU0;/9G!^AX,q%]9cr">
                                            <block type="on_source" id="y(?#xOCCF%vh.)x/JL~!">
                                              <field name="ATTR">state.lc</field>
                                            <shadow type="math_number" id="j=obz_-g%yDMlIBeJ^aH">
                                            <block type="on_source" id="TOgG)hcm*3c;`(IzwF`o">
                                              <field name="ATTR">oldState.lc</field>
                                    <shadow type="math_number" id="@J,i[0seFL!841-ytv/]">
                                      <field name="NUM">-3600000</field>
                                <block type="update" id="p+(#|mvOG}YZ0iHd9]PX">
                                    <block type="math_round" id="`p6;Gl}=kxuj.7[Ft;Qh">
                                      <field name="OP">ROUND</field>
                                      <value name="NUM">
                                        <shadow type="math_number" id="sETaomKPsuK^N:/J5Xpp">
                                          <field name="NUM">3.1</field>
                                        <block type="variables_get" id="v6mCa0tEa)Q%VFC$ULdS">
                                    <block type="comment" id="~Y5$,;#Tj$t)NCjk.%s9">
                                      <field name="COMMENT">kWh</field>
                                        <block type="update" id="SWrTagNZQwe(2KATCQS9">
                                          <field name="OID">0_userdata.0.PV_Einspeisung.PV_Einspeisung_kWh</field>
                                            <block type="math_rndfixed" id="rJP5R]kttn]Ed$IWmVAl">
                                              <field name="n">2</field>
                                              <value name="x">
                                                <shadow type="math_number">
                                                  <field name="NUM">3.1234</field>
                                                <block type="math_arithmetic" id="s0df=%jV0^edxx?OPKbk">
                                                    <block type="variables_get" id="iF[Ynm5;JlzOvt3[R`I}">
                                                    <shadow type="math_number" id="j@Rsu6yq3w4Ti+ZJ7$V7">
                                                      <field name="NUM">1000</field>
                    <block type="variables_set" id="Hq?}d)?smw_)GbI[X%_O">
                      <field name="VAR" id="SDbPbz:OQ}DXoHFlfr6;">PV_Ertrag</field>
                        <block type="get_value" id="8eFA4h.5dy5i4BTB5mgW">
                          <field name="OID">0_userdata.0.PV_Ertrag.PV_Ertrag</field>
                        <block type="on_ext" id="39Zyh3,]?dT$Snl?%Iju">
                          <value name="OID0">
                            <shadow type="field_oid" id="0BA(E[a8n0|p]kHrF(JB">
                              <field name="oid">opendtu.0.total.yieldtotal</field>
                            <block type="math_change" id="h%%#,jKHpq1uu*I+0M)H">
                                <shadow type="math_number" id=":2|w+1{Z4wgjt.jm8/NV">
                                <block type="math_arithmetic" id="z{iBC$3[A!q~q,p-qCWo">
                                    <shadow type="math_number" id="#cf[4jtT2a$7wH6ai.7/">
                                    <block type="on_source" id="`%4:X]97$%4iza!OkG5}">
                                    <shadow type="math_number" id="u:0W0|1=v%?MyadaBn1H">
                                    <block type="on_source" id="LUhI|.bpz85EPa8ENhHx">
                                <block type="update" id="ag%ciS8dt92qUrV8Gu8%">
                                    <block type="variables_get" id="ts63{FF??1N7X]~oPL{W">
                                    <block type="update" id="(csCPu{!sQBEgT[`,XJ2">
                                      <field name="OID">0_userdata.0.PV_Ersparnis.Ersparnis_kWh</field>
                                        <block type="math_rndfixed" id="%ZF=}T8DCk7,f%7twN~p">
                                          <value name="x">
                                            <shadow type="math_number" id="(RpiGL[FCghz3wNH28|!">
                                            <block type="math_arithmetic" id="?g*)8}Sn2{Nv7c^mv)(%">
                                                <shadow type="math_number" id="D3}dw(Z6W2`5HEyk[@Kb">
                                                <block type="variables_get" id="cRRG5Xp/`uyu_%xjS;iN">
                                                <shadow type="math_number" id="EDrD2WO$F#1Cw%|{U)7_">
                                                <block type="math_arithmetic" id="j+UCQApe[olx#Vbe8$Z:">
                                                    <shadow type="math_number" id="p=^0~m8DpJCAliSe)5X3">
                                                    <block type="variables_get" id="qcbR.0#nEY0r0]PvzXsi">
                                                    <shadow type="math_number" id="gsLF;/(,M)2)utesU;o+">
                                        <block type="debug" id="#T[Pl*fwLqYq*8EK}Nl)" disabled="true">
                                          <value name="TEXT">
                                            <shadow type="text">
                                            <block type="text_join" id="`%((7Q{A2XMLeRy4xE29">
                                              <value name="ADD0">
                                                <block type="variables_get" id=";UjjaW^%:SbBU]wPA^7G">
      Gruss Duffy
        wde @Duffy last edited by
        @duffy
        ja, das wäre was ich bräuchte: Habe nur einen 1-Richtungszähler und würde gerne die Einspeisung ins Netz
        dokumentieren, habe vonJave und Blockly leider keine Ahnung. Wäre toll wenn Du mir das Script zur Verfügung
        stellen würdest.
        👍 Willi
        • Duffy
          Duffy @wde last edited by Duffy
          @wde
          Hallo Willi,
          Das was ich in den post gestellt habe ist das blockly skript.
          Du musst den Text nur bei dir in ein Blockly importieren und dann die Datenpunkte auf deine Eigenen anpassen.
          Alternativ kannst du dir das Blockly auch anhand der Screenshots zusammen puzzeln. (Ist halt umständlicher)
          Eine andere Alternative ist mir noch nicht bekannt aber hier im Forum gibt es echte Profis die da vielleicht noch andere Wege kennen.
          Gruss Duffy
          Edit:
          Bei Skripte auf das + klicken
          dann Blockly klicken
          Namen eingeben für das Blockly
          OK Klicken
          Im rechten Fenster auf Blöcke importieren klicken
          dort den von mir im Post eingefügten Text rein kopieren
          Importieren klicken
          Dann deine Datenpunkte anpassen*.
          *)Beachte, du musst auch noch eigene Datenpunkte anlegen in 0_userdata damit das Blockly da reinschreiben kann.
          z.B.
            DocEmmetBrown @Duffy last edited by
            @duffy Hallo Duffy, ich habe das Script jetzt nachgebaut und es mit meinen Datenpunkten verbunden. Es müsste funktionieren. Eine Fehlermeldung habe ich noch nicht erhalten. Allerdings habe ich noch keine Einträge in meinen Datenpunkten.
            PV_Ertrag.PV_Ertrag
            Das kann aber schon durchaus so sein, ich hatte es gestern abend eingeschaltet und bis heute keine siknifkante Sonneneinstahlung von der Solar Anlage. Und eben auch keinen Überschuss produziert.
            Ich habe gesehen das du da was mit im Thema drin hast was du gepostet hast.
            CurrentDay, PreviousDay, CurrentWeek; PreviousWeek, ec.
            Ich möchte mir eine Historie bauen in der ich jeden einzelnen Tag, jede Woche, jeden Monat und das jeweilige Jahr abspeichern kann.
            Geht das mit einem Zeitplan?
            Frank
            paul53 D 2 Replies Last reply Reply Quote 0
              paul53 @DocEmmetBrown last edited by paul53
              @docemmetbrown sagte: jeden einzelnen Tag, jede Woche, jeden Monat und das jeweilige Jahr
              Für Periodenwerte gibt es den Sourceanalytix-Adapter.
              Man kann es auch mit Blockly machen.
                Hallo Paul, hast du Erfahrungen mit dem Adapter. Ist der stabil? Den gibt es nicht unter der Stable Iobroker Oberfläche. Ich müsste dafür auf beta umstellen um den Adapter zu laden.
                Frank
                paul53 Duffy 2 Replies Last reply Reply Quote 0
                  @docemmetbrown sagte: hast du Erfahrungen mit dem Adapter. Ist der stabil?
                  Ich habe keine Erfahrung mit dem Adapter, aber viele andere Nutzer.
                  • Duffy
                    Duffy @DocEmmetBrown last edited by Duffy
                    @docemmetbrown
                    Bin damit sehr zufrieden. Macht was er soll.
                    Kommen jetzt Daten?
                      @duffy nein, leider keine Daten in den Datenpunkten vorhanden. Ich muss das noch einmal überprüfen
                      Frank
                        @duffy So, jetzt muss ich mich nochmal melden. Ich denke ich habe das Skript richtig nachgebaut. Kann man vielleicht am Screenshot sehen. Der zweite Screenshot zeigt die Werte die ich in den Objekten habe. Da stimmt was nicht. Man müsste die eingespeiste Enregie sehen können, da ich heute morgen wieder ins Netz eingespeist habe. Was ich nicht genau weis, ob die Datenpunkte die dafür nötig waren richtig gesetzt sind.
                        Ich hatte Lokalisiert: Von oben nach unten
                        Einspeiseenergie=PV_Einspeisung_Wh müsste stimmen
                        Falls Objekt, Objekt ID=Lesekopf Easymeter SML power_use_sum (Stomzähler Momentverbrauch) Müsste stimmen
                        PV_Einspeiseenergie_Wh
                        PV_Einspeiseenergie_kWh
                        PV_Ertrag
                        Das nächste Falls Objekt, ich weis nicht ob das richtig ist, kommt bei mir aus einem anderen Skript
                        Strom_Bezug_Tagesverbrauch=das wäre der Tagesverbrauch den ich von meinem Stromanbieter beziehe
                        Ist das richtig so? Oder wo ist der Fehler?
                        Hier sind die Screenshots.
                        Frank
                          DocEmmetBrown @DocEmmetBrown last edited by
                          @docemmetbrown Hallo Duffy, ich habe mir jetzt mal das Skript was du hochgeladen hast reingezogen. Da sind am ende noch 2 Blöcke drin die in dem fertigen Skript nicht vorkommen. Kann ich die löschen?
                          Frank
                            @docemmetbrown
                            Falsche Trigger-Datenpunkte: "Power_Use_Sum" hört sich nicht nach Leistung an. "Tagesverbrauch" enthält sicherlich nicht den kumulativen Zählwert.
                            Falsche Variable links und es muss durch 1000 dividiert werden.
                              DocEmmetBrown @paul53 last edited by
                              Hallo Paul. Bei mir ist der Datenpunkt: "Power_Use_Sum" der momentverbrauch an Strom meines Stromzählers. Gemeint ist Summer aller Phasen im Momentanverbrauch Kilowatt
                              Frank
                                @docemmetbrown sagte: Momentanverbrauch Kilowatt
                                Das Skript rechnet mit W. Der Wert wird negativ bei Einspeisung?
                                  @docemmetbrown sagte: Tagesverbrauch den ich von meinem Stromanbieter beziehe
                                  Ist das richtig so?
                                  Nein, es muss die von der PV erzeugte Energie (in kWh) in den Trigger.
                                    @paul53 said in Strom Verbrauch und separat Überschuss berechnen:
                                    O.K. Das habe ich nun geändert. Präzise Formulierung wäre Total Energie Solar in kWh, das bedeutet die bereits von der Solaranlage erzeugte Energie in kwh. Der Datenpunkt ist von mir nun darauf geändert worden. Konnte man in deinen Screenshots auch so erahnen.
                                    Nun muss ich noch den ausgelesenen Wert des Momentanverbrauchs meines Zählers in Watt umstellen, da ich den nur als kW habe. Beispiel 0,678kW in 678W
                                    Stimmt das so?
                                    Frank
                                      @docemmetbrown sagte: in Watt umstellen, da ich den nur als kW habe.
                                      Dann ändere besser das Skript auf kW und lasse den DP "PV_Einspeisung_Wh" weg.
                                      Wenn der Energiewert des WR bei dir auch Sprünge macht, dann ändere den unteren Trigger auf "wurde geändert".
                                        @paul53 Hallo Paul, ich versuche jetzt die Werte die ich in W und Wh benötige in diesen Dimensionen bereit zu stellen.
                                        Die momentanen Zählerwerte habe ich bereits in W umstellen können, da in dieser Tasmota Firmware ein Script arbeitet. Aber den Wert den ich vom Balkonkraftwerk benötige "Ertrag Gestern" den habe ich auch nur in kWh. Da ich diese Werte von einem Shelly 1PM mit Tasmota bekomme, ist das umstellen im Shelly nicht so einfach, da dort kein Skript arbeitet.
                                        Frank
                                          @docemmetbrown sagte: Wert den ich vom Balkonkraftwerk benötige "Ertrag Gestern" den habe ich auch nur in kWh.
                                          Das Skript ist auf PV-Ertrag "Energy Total" in kWh ausgelegt.
                                            jokermic last edited by jokermic
                                            ich wollte basierend auf dieses Skript, so ein Art anteilige Mieterstromberechnung durchführen. Wir sind ein Mehrfamilienhaus mit 5WE und ich wollte den anteiligen PV Stromanteil meiner Wohnung, im Verhältnis zum Gesamthausverbrauch berechnen. Aber der Code kann nicht stimmen, weil der berechnete Anteilige PV Energieanteil ist manchmal größer als der komplette PV Ertrag des Tages.
                                            Habt ihr vielleicht eine Idee wo mein Fehler liegt oder eine andere Idee wie ich das umsetzen kann?
                                            155
                                            25473
