Umstellung auf iobroker nicht als root
@sissiwup sagte in Umstellung auf iobroker nicht als root:
Website nicht erreichbar (Versuche es von meinen Windows-PC).
Der admin läuft ja auch nicht
habe iobroker fix laufen lassen und iobroker upgrade
Jetzt kommt folgendes:
wh@zotac /opt/iobroker % iobroker start --debug node:internal/modules/cjs/loader:1080 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) at Module._load (node:internal/modules/cjs/loader:922:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) at node:internal/main/run_main_module:23:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.18.2
sudo -H -u iobroker npm install iobroker.js-controller :( npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142 npm WARN deprecated topo@1.1.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial). npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3 npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained. npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial). npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.) npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410 npm WARN deprecated joi@6.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial). npm WARN deprecated homematic-manager@1.0.14: version 2.x available as electron build on https://github.com/hobbyquaker/homematic-manager npm WARN cleanup Failed to remove some directories [ npm WARN cleanup [ npm WARN cleanup '/opt/iobroker/node_modules/unix-dgram', npm WARN cleanup [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/unix-dgram'] { npm WARN cleanup errno: -39, npm WARN cleanup code: 'ENOTEMPTY', npm WARN cleanup syscall: 'rmdir', npm WARN cleanup path: '/opt/iobroker/node_modules/unix-dgram' npm WARN cleanup } npm WARN cleanup ], npm WARN cleanup [ npm WARN cleanup '/opt/iobroker/node_modules/unix-dgram', npm WARN cleanup [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/unix-dgram'] { npm WARN cleanup errno: -39, npm WARN cleanup code: 'ENOTEMPTY', npm WARN cleanup syscall: 'rmdir', npm WARN cleanup path: '/opt/iobroker/node_modules/unix-dgram' npm WARN cleanup } npm WARN cleanup ], npm WARN cleanup [ npm WARN cleanup '/opt/iobroker/node_modules/winston-syslog', npm WARN cleanup [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/winston-syslog/node_modules/unix-dgram'] { npm WARN cleanup errno: -39, npm WARN cleanup code: 'ENOTEMPTY', npm WARN cleanup syscall: 'rmdir', npm WARN cleanup path: '/opt/iobroker/node_modules/winston-syslog/node_modules/unix-dgram' npm WARN cleanup } npm WARN cleanup ] npm WARN cleanup ] npm ERR! code 1 npm ERR! path /opt/iobroker/node_modules/iobroker.vis-beta npm ERR! command failed npm ERR! command sh -c node main.js --install --beta npm ERR! node:internal/modules/cjs/loader:1080 npm ERR! throw err; npm ERR! ^ npm ERR! npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js' npm ERR! Require stack: npm ERR! - /opt/iobroker/node_modules/iobroker.vis-beta/lib/utils.js npm ERR! - /opt/iobroker/node_modules/iobroker.vis-beta/main.js npm ERR! at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) npm ERR! at Module._load (node:internal/modules/cjs/loader:922:27) npm ERR! at Module.require (node:internal/modules/cjs/loader:1143:19) npm ERR! at require (node:internal/modules/cjs/helpers:119:18) npm ERR! at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.vis-beta/lib/utils.js:60:25) npm ERR! at Module._compile (node:internal/modules/cjs/loader:1256:14) npm ERR! at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) npm ERR! at Module.load (node:internal/modules/cjs/loader:1119:32) npm ERR! at Module._load (node:internal/modules/cjs/loader:960:12) npm ERR! at Module.require (node:internal/modules/cjs/loader:1143:19) { npm ERR! code: 'MODULE_NOT_FOUND', npm ERR! requireStack: [ npm ERR! '/opt/iobroker/node_modules/iobroker.vis-beta/lib/utils.js', npm ERR! '/opt/iobroker/node_modules/iobroker.vis-beta/main.js' npm ERR! ] npm ERR! } npm ERR! npm ERR! Node.js v18.18.2 npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-14T18_35_25_939Z-debug-0.log sudo -H -u iobroker npm install iobroker.js-controller 40,76s user 10,69s system 53% cpu 1:35,91 total 1 wh@zotac /opt/iobroker %
@sissiwup in Codetags packen bitte
welche Befehle genau ?
bitte alle Befehle zeigen -
iobroker fix iobroker upgrade
iobroker fix
iobroker upgradeMoin,
ein Tipp am Rande, wenn Du uns zeigen möchtest, was Du gemacht hast, dann nicht nur den Befehl zeigen, die kennen wir, besser ist es die ganze Kommandozeile zu zeigen, z. B.
user@rechner:/opt/iobroker$ iob fix
Dann kann man sehen ob Du im korrekten Verzeichnis stehst oder Du den korrekten User nutzt, wie sieht denn Dein User aus
# id `DeinUser`
VG
Bernd -
@dp20eic
wh@zotac /opt/iobroker % iob stop wh@zotac /opt/iobroker % iob fix library: loaded Library version=2023-10-13 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2023-10-13 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/5) ========================================================================== OK:1 http://deb.debian.org/debian bookworm InRelease OK:2 http://download.zerotier.com/debian/bullseye bullseye InRelease OK:3 http://deb.debian.org/debian-security bookworm-security InRelease Holen:4 https://download.docker.com/linux/debian bullseye InRelease [43,3 kB] OK:5 https://repos.influxdata.com/debian stable InRelease OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease OK:7 http://deb.debian.org/debian bookworm-updates InRelease OK:8 https://repos.influxdata.com/debian bullseye InRelease OK:9 https://packages.microsoft.com/debian/11/prod bullseye InRelease OK:10 http://deb.debian.org/debian bookworm-backports InRelease OK:11 https://packages.sury.org/php bullseye InRelease OK:12 https://packages.microsoft.com/repos/microsoft-debian-bullseye-prod bullseye InRelease Holen:13 https://dl.cloudsmith.io/public/rabbitmq/rabbitmq-erlang/deb/ubuntu bionic InRelease [5.187 B] Holen:14 https://dl.cloudsmith.io/public/rabbitmq/rabbitmq-server/deb/ubuntu bionic InRelease [5.169 B] Holen:15 https://pkgs.tailscale.com/stable/debian bullseye InRelease OK:16 https://dl.ui.com/unifi/debian stable InRelease OK:17 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease Es wurden 60,3 kB in 2 s geholt (34,1 kB/s). Paketlisten werden gelesen… Fertig W: http://download.zerotier.com/debian/bullseye/dists/bullseye/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details. W: https://pkgs.tailscale.com/stable/debian/dists/bullseye/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details. W: https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details. N: Für das Depot »Debian bookworm« wurde der »non-free component«-Wert von »non-free« in »non-free non-free-firmware« geändert. N: Weitere Informationen hierzu finden Sie online in den Veröffentlichungshinweisen unter https://www.debian.org/releases/bookworm/amd64/release-notes/ch-information.html#non-free-split. ========================================================================== Checking ioBroker user and directory permissions (2/5) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Check and cleanup npm temporary directories (3/5) ========================================================================== Done. ========================================================================== Database maintenance (4/5) ========================================================================== Checking for uncompressed JSONL databases... This might take a while! Compressing /opt/iobroker/iobroker-data/states.jsonl Compressing /opt/iobroker/iobroker-data/objects.jsonl Compressed 2 JSONL files. Done ========================================================================== Checking autostart (5/5) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== iob fix 8,99s user 4,68s system 70% cpu 19,472 total wh@zotac /opt/iobroker %
wh@zotac /opt/iobroker % id `wh` zsh: command not found: wh uid=1000(wh) gid=1000(wh) Gruppen=1000(wh),24(cdrom),25(floppy),27(sudo),29(audio),30(dip),33(www-data),44(video),46(plugdev),100(users),108(netdev),110(lpadmin),113(scanner),1009(iobroker)
aud iob diag
Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! extraneous: @aws-sdk/abort-controller@3.357.0 /opt/iobroker/node_modules/@aws-sdk/abort-controller npm ERR! extraneous: @aws-sdk/client-sso-oidc@3.370.0 /opt/iobroker/node_modules/@aws-sdk/client-sso-oidc npm ERR! extraneous: @aws-sdk/config-resolver@3.357.0 /opt/iobroker/node_modules/@aws-sdk/config-resolver npm ERR! extraneous: @aws-sdk/credential-provider-imds@3.357.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-imds npm ERR! extraneous: @aws-sdk/eventstream-codec@3.357.0 /opt/iobroker/node_modules/@aws-sdk/eventstream-codec npm ERR! extraneous: @aws-sdk/fetch-http-handler@3.357.0 /opt/iobroker/node_modules/@aws-sdk/fetch-http-handler npm ERR! extraneous: @aws-sdk/hash-node@3.357.0 /opt/iobroker/node_modules/@aws-sdk/hash-node npm ERR! extraneous: @aws-sdk/invalid-dependency@3.357.0 /opt/iobroker/node_modules/@aws-sdk/invalid-dependency npm ERR! extraneous: @aws-sdk/is-array-buffer@3.310.0 /opt/iobroker/node_modules/@aws-sdk/is-array-buffer npm ERR! extraneous: @aws-sdk/middleware-content-length@3.357.0 /opt/iobroker/node_modules/@aws-sdk/middleware-content-length npm ERR! extraneous: @aws-sdk/middleware-endpoint@3.357.0 /opt/iobroker/node_modules/@aws-sdk/middleware-endpoint npm ERR! extraneous: @aws-sdk/middleware-retry@3.357.0 /opt/iobroker/node_modules/@aws-sdk/middleware-retry npm ERR! extraneous: @aws-sdk/middleware-serde@3.357.0 /opt/iobroker/node_modules/@aws-sdk/middleware-serde npm ERR! extraneous: @aws-sdk/middleware-stack@3.357.0 /opt/iobroker/node_modules/@aws-sdk/middleware-stack npm ERR! extraneous: @aws-sdk/node-config-provider@3.357.0 /opt/iobroker/node_modules/@aws-sdk/node-config-provider npm ERR! extraneous: @aws-sdk/node-http-handler@3.357.0 /opt/iobroker/node_modules/@aws-sdk/node-http-handler npm ERR! extraneous: @aws-sdk/property-provider@3.357.0 /opt/iobroker/node_modules/@aws-sdk/property-provider npm ERR! extraneous: @aws-sdk/protocol-http@3.357.0 /opt/iobroker/node_modules/@aws-sdk/protocol-http npm ERR! extraneous: @aws-sdk/querystring-builder@3.357.0 /opt/iobroker/node_modules/@aws-sdk/querystring-builder npm ERR! extraneous: @aws-sdk/querystring-parser@3.357.0 /opt/iobroker/node_modules/@aws-sdk/querystring-parser npm ERR! extraneous: @aws-sdk/service-error-classification@3.357.0 /opt/iobroker/node_modules/@aws-sdk/service-error-classification npm ERR! extraneous: @aws-sdk/shared-ini-file-loader@3.357.0 /opt/iobroker/node_modules/@aws-sdk/shared-ini-file-loader npm ERR! extraneous: @aws-sdk/signature-v4@3.357.0 /opt/iobroker/node_modules/@aws-sdk/signature-v4 npm ERR! extraneous: @aws-sdk/smithy-client@3.358.0 /opt/iobroker/node_modules/@aws-sdk/smithy-client npm ERR! extraneous: @aws-sdk/url-parser@3.357.0 /opt/iobroker/node_modules/@aws-sdk/url-parser npm ERR! extraneous: @aws-sdk/util-base64@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-base64 npm ERR! extraneous: @aws-sdk/util-body-length-browser@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-body-length-browser npm ERR! extraneous: @aws-sdk/util-body-length-node@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-body-length-node npm ERR! extraneous: @aws-sdk/util-buffer-from@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-buffer-from npm ERR! extraneous: @aws-sdk/util-config-provider@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-config-provider npm ERR! extraneous: @aws-sdk/util-defaults-mode-browser@3.358.0 /opt/iobroker/node_modules/@aws-sdk/util-defaults-mode-browser npm ERR! extraneous: @aws-sdk/util-defaults-mode-node@3.358.0 /opt/iobroker/node_modules/@aws-sdk/util-defaults-mode-node npm ERR! extraneous: @aws-sdk/util-hex-encoding@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-hex-encoding npm ERR! extraneous: @aws-sdk/util-middleware@3.357.0 /opt/iobroker/node_modules/@aws-sdk/util-middleware npm ERR! extraneous: @aws-sdk/util-retry@3.357.0 /opt/iobroker/node_modules/@aws-sdk/util-retry npm ERR! extraneous: @aws-sdk/util-stream@3.358.0 /opt/iobroker/node_modules/@aws-sdk/util-stream npm ERR! extraneous: @aws-sdk/util-uri-escape@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-uri-escape npm ERR! extraneous: @aws-sdk/util-utf8-node@3.208.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-node npm ERR! extraneous: @aws-sdk/util-utf8@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8 npm ERR! extraneous: @azure/core-http@2.2.5 /opt/iobroker/node_modules/@azure/core-http npm ERR! extraneous: @azure/ms-rest-azure-env@2.0.0 /opt/iobroker/node_modules/@azure/ms-rest-azure-env npm ERR! extraneous: @azure/ms-rest-js@2.6.1 /opt/iobroker/node_modules/@azure/ms-rest-js npm ERR! extraneous: @azure/ms-rest-nodeauth@3.1.1 /opt/iobroker/node_modules/@azure/ms-rest-nodeauth npm ERR! extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq npm ERR! extraneous: @homebridge/ciao@1.1.5 /opt/iobroker/node_modules/@homebridge/ciao npm ERR! extraneous: @leichtgewicht/ip-codec@2.0.4 /opt/iobroker/node_modules/@leichtgewicht/ip-codec npm ERR! extraneous: @material/animation@7.0.0 /opt/iobroker/node_modules/@material/animation npm ERR! extraneous: @material/base@7.0.0 /opt/iobroker/node_modules/@material/base npm ERR! extraneous: @material/button@7.0.0 /opt/iobroker/node_modules/@material/button npm ERR! extraneous: @material/card@7.0.0 /opt/iobroker/node_modules/@material/card npm ERR! extraneous: @material/density@7.0.0 /opt/iobroker/node_modules/@material/density npm ERR! extraneous: @material/dom@7.0.0 /opt/iobroker/node_modules/@material/dom npm ERR! extraneous: @material/elevation@7.0.0 /opt/iobroker/node_modules/@material/elevation npm ERR! extraneous: @material/feature-targeting@7.0.0 /opt/iobroker/node_modules/@material/feature-targeting npm ERR! extraneous: @material/ripple@7.0.0 /opt/iobroker/node_modules/@material/ripple npm ERR! extraneous: @material/rtl@7.0.0 /opt/iobroker/node_modules/@material/rtl npm ERR! extraneous: @material/shape@7.0.0 /opt/iobroker/node_modules/@material/shape npm ERR! extraneous: @material/switch@7.0.0 /opt/iobroker/node_modules/@material/switch npm ERR! extraneous: @material/theme@7.0.0 /opt/iobroker/node_modules/@material/theme npm ERR! extraneous: @material/touch-target@7.0.0 /opt/iobroker/node_modules/@material/touch-target npm ERR! extraneous: @material/typography@7.0.0 /opt/iobroker/node_modules/@material/typography npm ERR! extraneous: @sentry/hub@6.19.7 /opt/iobroker/node_modules/@sentry/hub npm ERR! extraneous: @sentry/minimal@6.19.7 /opt/iobroker/node_modules/@sentry/minimal npm ERR! extraneous: @sentry/tracing@6.18.0 /opt/iobroker/node_modules/@sentry/tracing npm ERR! extraneous: @tootallnate/once@1.1.2 /opt/iobroker/node_modules/@tootallnate/once npm ERR! extraneous: @types/caseless@0.12.3 /opt/iobroker/node_modules/@types/caseless npm ERR! extraneous: @types/color-name@1.1.1 /opt/iobroker/node_modules/@types/color-name npm ERR! extraneous: @types/component-emitter@1.2.11 /opt/iobroker/node_modules/@types/component-emitter npm ERR! extraneous: @types/es-aggregate-error@1.0.2 /opt/iobroker/node_modules/@types/es-aggregate-error npm ERR! extraneous: @types/json-buffer@3.0.0 /opt/iobroker/node_modules/@types/json-buffer npm ERR! extraneous: @types/node-fetch@2.6.2 /opt/iobroker/node_modules/@types/node-fetch npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request npm ERR! extraneous: @types/tough-cookie@4.0.3 /opt/iobroker/node_modules/@types/tough-cookie npm ERR! extraneous: @types/tunnel@0.0.3 /opt/iobroker/node_modules/@types/tunnel npm ERR! extraneous: @xmldom/xmldom@0.7.5 /opt/iobroker/node_modules/@xmldom/xmldom npm ERR! extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab npm ERR! extraneous: acorn-globals@6.0.0 /opt/iobroker/node_modules/acorn-globals npm ERR! extraneous: adal-node@0.2.3 /opt/iobroker/node_modules/adal-node npm ERR! extraneous: any-observable@0.3.0 /opt/iobroker/node_modules/any-observable npm ERR! extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg npm ERR! extraneous: array-filter@1.0.0 /opt/iobroker/node_modules/array-filter npm ERR! extraneous: at-least-node@1.0.0 /opt/iobroker/node_modules/at-least-node npm ERR! extraneous: aws-iot-device-sdk@2.2.12 /opt/iobroker/node_modules/aws-iot-device-sdk npm ERR! extraneous: binrpc@3.3.1 /opt/iobroker/node_modules/binrpc npm ERR! extraneous: bl@5.1.0 /opt/iobroker/node_modules/bl npm ERR! extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser npm ERR! extraneous: bonjour-hap@3.6.4 /opt/iobroker/node_modules/bonjour-hap npm ERR! extraneous: browser-process-hrtime@1.0.0 /opt/iobroker/node_modules/browser-process-hrtime npm ERR! extraneous: callback-stream@1.1.0 /opt/iobroker/node_modules/callback-stream npm ERR! extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys npm ERR! extraneous: camelcase@7.0.1 /opt/iobroker/node_modules/camelcase npm ERR! extraneous: canvas@2.10.2 /opt/iobroker/node_modules/canvas npm ERR! extraneous: ci-info@3.8.0 /opt/iobroker/node_modules/ci-info npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert npm ERR! extraneous: color@3.2.1 /opt/iobroker/node_modules/color npm ERR! extraneous: compress-brotli@1.3.8 /opt/iobroker/node_modules/compress-brotli npm ERR! extraneous: cosmiconfig@8.3.6 /opt/iobroker/node_modules/cosmiconfig npm ERR! extraneous: country-list-js@3.1.7 /opt/iobroker/node_modules/country-list-js npm ERR! extraneous: cssom@0.5.0 /opt/iobroker/node_modules/cssom npm ERR! extraneous: cssstyle@2.3.0 /opt/iobroker/node_modules/cssstyle npm ERR! extraneous: d@1.0.1 /opt/iobroker/node_modules/d npm ERR! extraneous: data-urls@3.0.2 /opt/iobroker/node_modules/data-urls npm ERR! extraneous: date-utils@1.2.21 /opt/iobroker/node_modules/date-utils npm ERR! extraneous: dateformat@4.5.1 /opt/iobroker/node_modules/dateformat npm ERR! extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/decamelize npm ERR! extraneous: decimal.js@10.4.2 /opt/iobroker/node_modules/decimal.js npm ERR! extraneous: deep-equal@2.1.0 /opt/iobroker/node_modules/deep-equal npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is npm ERR! extraneous: dev-null@0.1.1 /opt/iobroker/node_modules/dev-null npm ERR! extraneous: dicer@0.3.0 /opt/iobroker/node_modules/dicer npm ERR! extraneous: dns-packet@5.4.0 /opt/iobroker/node_modules/dns-packet npm ERR! extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception npm ERR! extraneous: echarts@4.9.0 /opt/iobroker/node_modules/echarts npm ERR! extraneous: engine.io-client@1.8.6 /opt/iobroker/node_modules/engine.io-client npm ERR! extraneous: es-get-iterator@1.1.2 /opt/iobroker/node_modules/es-get-iterator npm ERR! extraneous: es5-ext@0.10.53 /opt/iobroker/node_modules/es5-ext npm ERR! extraneous: es6-iterator@2.0.3 /opt/iobroker/node_modules/es6-iterator npm ERR! extraneous: es6-map@0.1.5 /opt/iobroker/node_modules/es6-map npm ERR! extraneous: es6-set@0.1.5 /opt/iobroker/node_modules/es6-set npm ERR! extraneous: es6-symbol@3.1.3 /opt/iobroker/node_modules/es6-symbol npm ERR! extraneous: escodegen@2.0.0 /opt/iobroker/node_modules/escodegen npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/esprima npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/estraverse npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils npm ERR! extraneous: event-emitter@0.3.5 /opt/iobroker/node_modules/event-emitter npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template npm ERR! extraneous: ext@1.6.0 /opt/iobroker/node_modules/ext npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein npm ERR! extraneous: fast-safe-stringify@2.1.1 /opt/iobroker/node_modules/fast-safe-stringify npm ERR! extraneous: fast-srp-hap@2.0.4 /opt/iobroker/node_modules/fast-srp-hap npm ERR! extraneous: foreach@2.0.5 /opt/iobroker/node_modules/foreach npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf npm ERR! extraneous: gaxios@6.1.1 /opt/iobroker/node_modules/gaxios npm ERR! extraneous: gcp-metadata@6.0.0 /opt/iobroker/node_modules/gcp-metadata npm ERR! extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package npm ERR! extraneous: glob-stream@6.1.0 /opt/iobroker/node_modules/glob-stream npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem npm ERR! extraneous: hap-nodejs@0.9.8 /opt/iobroker/node_modules/hap-nodejs npm ERR! extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer npm ERR! extraneous: http-proxy-agent@4.0.1 /opt/iobroker/node_modules/http-proxy-agent npm ERR! extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string npm ERR! extraneous: ini@2.0.0 /opt/iobroker/node_modules/ini npm ERR! extraneous: iobroker.coronavirus-statistics@0.8.7 /opt/iobroker/node_modules/iobroker.coronavirus-statistics npm ERR! extraneous: iobroker.iot@1.11.9 /opt/iobroker/node_modules/iobroker.iot npm ERR! extraneous: iobroker.jarvis@3.0.0 /opt/iobroker/node_modules/iobroker.jarvis npm ERR! extraneous: iobroker.ping@1.5.3 /opt/iobroker/node_modules/iobroker.ping npm ERR! extraneous: iobroker.pushover@3.0.2 /opt/iobroker/node_modules/iobroker.pushover npm ERR! extraneous: iobroker.tankerkoenig@2.1.1 /opt/iobroker/node_modules/iobroker.tankerkoenig npm ERR! extraneous: iobroker.type-detector@1.1.1 /opt/iobroker/node_modules/iobroker.type-detector npm ERR! extraneous: iobroker.unifi@0.5.10 /opt/iobroker/node_modules/iobroker.unifi npm ERR! extraneous: iobroker.vodafone-speedtest@0.0.7 /opt/iobroker/node_modules/iobroker.vodafone-speedtest npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server npm ERR! extraneous: iobroker.yahka@0.13.1 /opt/iobroker/node_modules/iobroker.yahka npm ERR! extraneous: ip-regex@2.1.0 /opt/iobroker/node_modules/ip-regex npm ERR! invalid: ip@2.0.0 /opt/iobroker/node_modules/ip npm ERR! extraneous: ip@2.0.0 /opt/iobroker/node_modules/ip npm ERR! extraneous: is-absolute@1.0.0 /opt/iobroker/node_modules/is-absolute npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/is-arguments npm ERR! extraneous: is-arrayish@0.2.1 /opt/iobroker/node_modules/is-arrayish npm ERR! extraneous: is-generator-function@1.0.10 /opt/iobroker/node_modules/is-generator-function npm ERR! extraneous: is-map@2.0.2 /opt/iobroker/node_modules/is-map npm ERR! extraneous: is-nan@1.3.2 /opt/iobroker/node_modules/is-nan npm ERR! extraneous: is-negated-glob@1.0.0 /opt/iobroker/node_modules/is-negated-glob npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero npm ERR! extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name npm ERR! extraneous: is-relative@1.0.0 /opt/iobroker/node_modules/is-relative npm ERR! extraneous: is-set@2.0.2 /opt/iobroker/node_modules/is-set npm ERR! extraneous: is-unc-path@1.0.0 /opt/iobroker/node_modules/is-unc-path npm ERR! extraneous: is-weakmap@2.0.1 /opt/iobroker/node_modules/is-weakmap npm ERR! extraneous: is-weakset@2.0.2 /opt/iobroker/node_modules/is-weakset npm ERR! extraneous: is-windows@1.0.2 /opt/iobroker/node_modules/is-windows npm ERR! extraneous: jsdom@19.0.0 /opt/iobroker/node_modules/jsdom npm ERR! extraneous: json-logic-js@2.0.1 /opt/iobroker/node_modules/json-logic-js npm ERR! extraneous: json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/json-stable-stringify-without-jsonify npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata npm ERR! extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn npm ERR! extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie npm ERR! extraneous: macaddress@0.5.1 /opt/iobroker/node_modules/macaddress npm ERR! extraneous: mem@4.3.0 /opt/iobroker/node_modules/mem npm ERR! extraneous: micro@9.3.4 /opt/iobroker/node_modules/micro npm ERR! extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response npm ERR! extraneous: multicast-dns-service-types@1.1.0 /opt/iobroker/node_modules/multicast-dns-service-types npm ERR! extraneous: multicast-dns@7.2.5 /opt/iobroker/node_modules/multicast-dns npm ERR! extraneous: mysql@2.18.1 /opt/iobroker/node_modules/mysql npm ERR! extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils npm ERR! extraneous: ncp@2.0.0 /opt/iobroker/node_modules/ncp npm ERR! extraneous: needle@2.9.1 /opt/iobroker/node_modules/needle npm ERR! extraneous: next-tick@1.0.0 /opt/iobroker/node_modules/next-tick npm ERR! extraneous: nice-try@1.0.5 /opt/iobroker/node_modules/nice-try npm ERR! extraneous: node-abi@3.30.0 /opt/iobroker/node_modules/node-abi npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect npm ERR! extraneous: node-libcurl@2.3.3 /opt/iobroker/node_modules/node-libcurl npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist npm ERR! extraneous: node-pre-gyp@0.11.0 /opt/iobroker/node_modules/node-pre-gyp npm ERR! extraneous: node-unifi@1.4.3 /opt/iobroker/node_modules/node-unifi npm ERR! extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data npm ERR! extraneous: npm-bundled@1.1.2 /opt/iobroker/node_modules/npm-bundled npm ERR! extraneous: npm-normalize-package-bin@1.0.1 /opt/iobroker/node_modules/npm-normalize-package-bin npm ERR! extraneous: npm-packlist@1.4.8 /opt/iobroker/node_modules/npm-packlist npm ERR! extraneous: npm@8.5.0 /opt/iobroker/node_modules/npm npm ERR! extraneous: nwsapi@2.2.2 /opt/iobroker/node_modules/nwsapi npm ERR! extraneous: object-is@1.1.5 /opt/iobroker/node_modules/object-is npm ERR! extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator npm ERR! extraneous: ordered-read-streams@1.0.1 /opt/iobroker/node_modules/ordered-read-streams npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/os-homedir npm ERR! extraneous: osenv@0.1.5 /opt/iobroker/node_modules/osenv npm ERR! extraneous: p-is-promise@2.1.0 /opt/iobroker/node_modules/p-is-promise npm ERR! extraneous: p-limit@3.1.0 /opt/iobroker/node_modules/p-limit npm ERR! extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map npm ERR! extraneous: passport.socketio@3.7.0 /opt/iobroker/node_modules/passport.socketio npm ERR! extraneous: path-dirname@1.0.2 /opt/iobroker/node_modules/path-dirname npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors npm ERR! extraneous: ping@0.4.1 /opt/iobroker/node_modules/ping npm ERR! extraneous: platform@1.3.6 /opt/iobroker/node_modules/platform npm ERR! extraneous: prebuild-install@7.1.1 /opt/iobroker/node_modules/prebuild-install npm ERR! extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls npm ERR! extraneous: proper-lockfile@4.1.2 /opt/iobroker/node_modules/proper-lockfile npm ERR! extraneous: pumpify@1.5.1 /opt/iobroker/node_modules/pumpify npm ERR! extraneous: pushover-notifications@1.2.2 /opt/iobroker/node_modules/pushover-notifications npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q npm ERR! extraneous: querystring@0.2.1 /opt/iobroker/node_modules/querystring npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body npm ERR! extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent npm ERR! extraneous: regexp.prototype.flags@1.5.1 /opt/iobroker/node_modules/regexp.prototype.flags npm ERR! extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/require-main-filename npm ERR! extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from npm ERR! extraneous: saslprep@1.0.3 /opt/iobroker/node_modules/saslprep npm ERR! invalid: sax@0.4.3 /opt/iobroker/node_modules/sax npm ERR! extraneous: sax@0.4.3 /opt/iobroker/node_modules/sax npm ERR! extraneous: saxes@5.0.1 /opt/iobroker/node_modules/saxes npm ERR! invalid: seq-logging@0.4.6 /opt/iobroker/node_modules/seq-logging npm ERR! extraneous: seq-logging@0.4.6 /opt/iobroker/node_modules/seq-logging npm ERR! extraneous: set-immediate-shim@1.0.1 /opt/iobroker/node_modules/set-immediate-shim npm ERR! extraneous: sharp@0.30.7 /opt/iobroker/node_modules/sharp npm ERR! extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat npm ERR! extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get npm ERR! extraneous: socket.io-client@1.7.4 /opt/iobroker/node_modules/socket.io-client npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/source-map-support npm ERR! extraneous: strip-eof@1.0.0 /opt/iobroker/node_modules/strip-eof npm ERR! extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent .... npm ERR! A complete log of this run can be found in: /home/wh/.npm/_logs/2023-10-14T19_08_41_698Z-debug-0.log *** ioBroker-Installation ***
v.2023-10-10 Static hostname: zotac Icon name: computer-desktop Chassis: desktop 🖥️ Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-13-amd64 Architecture: x86-64 Hardware Vendor: ASRock Hardware Model: H81M-DGS Firmware Version: P2.00 Installation: native Kernel: x86_64 Userland: amd64 Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 X-Server: true Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 8 Nodejs-Installation: /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 Recommended versions are nodejs and npm Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 16G 11G 423M 137M 4.9G 4.8G Swap: 34G 3.2G 31G Total: 50G 14G 31G Active iob-Instances: 20 Active repo(s): live-stable ioBroker Core: js-controller 5.0.12 admin 6.10.2 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: system.adapter.admin.0 : admin : zotac - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : zotac - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 12656 States: 10563 Size of iob-Database: 21M /opt/iobroker/iobroker-data/objects.jsonl 18M /opt/iobroker/iobroker-data/objects.json.migrated 18M /opt/iobroker/iobroker-data/objects.json.bak.migrated 18M /opt/iobroker/iobroker-data/objects.json.bak 18M /opt/iobroker/iobroker-data/objects.json 3.4M /opt/iobroker/iobroker-data/states.jsonl 2.9M /opt/iobroker/iobroker-data/states.json.migrated 2.9M /opt/iobroker/iobroker-data/states.json.bak.migrated 2.9M /opt/iobroker/iobroker-data/states.json.bak 2.9M /opt/iobroker/iobroker-data/states.json =================== END OF SUMMARY ====================
=== Mark text until here for copying ===
iob diag 28,29s user 5,45s system 19% cpu 2:51,91 total -
Wassen das für'n komischer Prompt? Hab ich noch nie gesehen:
Entweder ist das # für root logins oder $ für einen user. Aber % kenn ich nicht.
@thomas-braun sagte in Umstellung auf iobroker nicht als root:
Habe das in zsh so eingestellt. Ist aber der User wh. Kein root.
.k zsh kenn ich nicht genau. Ein bash prompt kann man zwar auch umstellen, ist aber eher ungewöhnlich.
Noch als Hinweis: iob_diag verwendet bash, keine Ahnung ob es unter der zsh da zu Komplikationen kommt.
bash ist natürlich auch da.2023-10-14 21:16:55.685 - error: host.zotac instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2023-10-14 21:16:55.685 - info: host.zotac Restart adapter system.adapter.admin.0 because enabled 2023-10-14 21:17:25.720 - info: host.zotac instance system.adapter.admin.0 started with pid 488395 2023-10-14 21:17:25.975 - error: host.zotac Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:21 2023-10-14 21:17:25.975 - error: host.zotac Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:21:44) 2023-10-14 21:17:25.975 - error: host.zotac instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2023-10-14 21:17:25.975 - info: host.zotac Restart adapter system.adapter.admin.0 because enabled
@sissiwup
Kann ich das neu installieren und meine Einstellungen übernehmen? -
Nix, also keinen Fehler.wh@zotac:/opt/iobroker$ iob start admin wh@zotac:/opt/iobroker$
023-10-14 21:46:08.216 - info: host.zotac instance system.adapter.admin.0 started with pid 610506 2023-10-14 21:46:08.542 - error: host.zotac Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:21 2023-10-14 21:46:08.544 - error: host.zotac Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:21:44) 2023-10-14 21:46:08.546 - error: host.zotac instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2023-10-14 21:46:08.546 - info: host.zotac Restart adapter system.adapter.admin.0 because enabled 2023-10-14 21:46:38.578 - info: host.zotac instance system.adapter.admin.0 started with pid 611113 2023-10-14 21:46:38.897 - error: host.zotac Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:21 2023-10-14 21:46:38.898 - error: host.zotac Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:21:44) 2023-10-14 21:46:38.899 - error: host.zotac instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2023-10-14 21:46:38.899 - info: host.zotac Restart adapter system.adapter.admin.0 because enabled
Kann das mit den vielen Fehlern aus diag zu tun haben?
