    3. Einsteigerfragen
    4. Umstellung auf iobroker nicht als root
    • sissiwup
      sissiwup @Homoran last edited by
      habe iobroker fix laufen lassen und iobroker upgrade
      Jetzt kommt folgendes:
      wh@zotac /opt/iobroker % iobroker start --debug
      node:internal/modules/cjs/loader:1080
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
          at Module._load (node:internal/modules/cjs/loader:922:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
          at node:internal/main/run_main_module:23:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.18.2
      sissiwup DJMarc75 2 Replies Last reply Reply Quote 0
      • sissiwup
        sissiwup @sissiwup last edited by Homoran
        @sissiwup
        sudo -H -u iobroker npm install iobroker.js-controller        :(
        npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated topo@1.1.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
        npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
        npm WARN deprecated joi@6.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
        npm WARN deprecated homematic-manager@1.0.14: version 2.x available as electron build on https://github.com/hobbyquaker/homematic-manager
        npm WARN cleanup Failed to remove some directories [
        npm WARN cleanup   [
        npm WARN cleanup     '/opt/iobroker/node_modules/unix-dgram',
        npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/unix-dgram'] {
        npm WARN cleanup       errno: -39,
        npm WARN cleanup       code: 'ENOTEMPTY',
        npm WARN cleanup       syscall: 'rmdir',
        npm WARN cleanup       path: '/opt/iobroker/node_modules/unix-dgram'
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     '/opt/iobroker/node_modules/winston-syslog',
        npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/winston-syslog/node_modules/unix-dgram'] {
        npm WARN cleanup       path: '/opt/iobroker/node_modules/winston-syslog/node_modules/unix-dgram'
        npm WARN cleanup     }
        npm WARN cleanup   ]
        npm WARN cleanup ]
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/iobroker.vis-beta
        npm ERR! command failed
        npm ERR! command sh -c node main.js --install --beta
        npm ERR! node:internal/modules/cjs/loader:1080
        npm ERR!   throw err;
        npm ERR!   ^
        npm ERR!
        npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
        npm ERR! Require stack:
        npm ERR! - /opt/iobroker/node_modules/iobroker.vis-beta/lib/utils.js
        npm ERR! - /opt/iobroker/node_modules/iobroker.vis-beta/main.js
        npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        npm ERR!     at Module._load (node:internal/modules/cjs/loader:922:27)
        npm ERR!     at Module.require (node:internal/modules/cjs/loader:1143:19)
        npm ERR!     at require (node:internal/modules/cjs/helpers:119:18)
        npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.vis-beta/lib/utils.js:60:25)
        npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1256:14)
        npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        npm ERR!     at Module.load (node:internal/modules/cjs/loader:1119:32)
        npm ERR!     at Module._load (node:internal/modules/cjs/loader:960:12)
        npm ERR!     at Module.require (node:internal/modules/cjs/loader:1143:19) {
        npm ERR!   code: 'MODULE_NOT_FOUND',
        npm ERR!   requireStack: [
        npm ERR!     '/opt/iobroker/node_modules/iobroker.vis-beta/lib/utils.js',
        npm ERR!     '/opt/iobroker/node_modules/iobroker.vis-beta/main.js'
        npm ERR!   ]
        npm ERR! }
        npm ERR!
        npm ERR! Node.js v18.18.2
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-14T18_35_25_939Z-debug-0.log
        sudo -H -u iobroker npm install iobroker.js-controller  40,76s user 10,69s system 53% cpu 1:35,91 total
        1 wh@zotac /opt/iobroker %
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
        Qix- created this issue in visionmedia/debug
        closed ReDos Vulnerability Regression Visibility Notice #797
        timemachine3030 created this issue in axios/axios
        closed Hotfix: Prevent SSRF #3410
        • DJMarc75
          DJMarc75 @sissiwup last edited by
          @sissiwup in Codetags packen bitte
          • DJMarc75
            @sissiwup sagte in Umstellung auf iobroker nicht als root:
            welche Befehle genau ?
            bitte alle Befehle zeigen 😉
            sissiwup 1 Reply Last reply Reply Quote 0
            • sissiwup
              sissiwup @DJMarc75 last edited by
              @djmarc75
              iobroker fix
              iobroker upgrade
              DJMarc75 ? 2 Replies Last reply Reply Quote 0
              • DJMarc75
                @sissiwup
                iob stop
                iob fix
                iob start
                dann nochmal schauen bitte 🙂
                  A Former User @sissiwup last edited by
                  iobroker fix
                  iobroker upgrade
                  Moin,
                  ein Tipp am Rande, wenn Du uns zeigen möchtest, was Du gemacht hast, dann nicht nur den Befehl zeigen, die kennen wir, besser ist es die ganze Kommandozeile zu zeigen, z. B.
                  user@rechner:/opt/iobroker$ iob fix
                  Dann kann man sehen ob Du im korrekten Verzeichnis stehst oder Du den korrekten User nutzt, wie sieht denn Dein User aus
                  # id `DeinUser`
                  VG
                  Bernd
                  sissiwup 1 Reply Last reply Reply Quote 1
                  • sissiwup
                    sissiwup @Guest last edited by
                    @dp20eic
                    wh@zotac /opt/iobroker % iob stop
                    wh@zotac /opt/iobroker % iob fix
                    library: loaded
                    Library version=2023-10-13
                        Welcome to the ioBroker installation fixer!
                        Script version: 2023-10-13
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/5)
                    OK:1 http://deb.debian.org/debian bookworm InRelease
                    OK:2 http://download.zerotier.com/debian/bullseye bullseye InRelease
                    OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
                    Holen:4 https://download.docker.com/linux/debian bullseye InRelease [43,3 kB]
                    OK:5 https://repos.influxdata.com/debian stable InRelease
                    OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                    OK:7 http://deb.debian.org/debian bookworm-updates InRelease
                    OK:8 https://repos.influxdata.com/debian bullseye InRelease
                    OK:9 https://packages.microsoft.com/debian/11/prod bullseye InRelease
                    OK:10 http://deb.debian.org/debian bookworm-backports InRelease
                    OK:11 https://packages.sury.org/php bullseye InRelease
                    OK:12 https://packages.microsoft.com/repos/microsoft-debian-bullseye-prod bullseye InRelease
                    Holen:13 https://dl.cloudsmith.io/public/rabbitmq/rabbitmq-erlang/deb/ubuntu bionic InRelease [5.187 B]
                    Holen:14 https://dl.cloudsmith.io/public/rabbitmq/rabbitmq-server/deb/ubuntu bionic InRelease [5.169 B]
                    Holen:15 https://pkgs.tailscale.com/stable/debian bullseye InRelease
                    OK:16 https://dl.ui.com/unifi/debian stable InRelease
                    OK:17 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                    Es wurden 60,3 kB in 2 s geholt (34,1 kB/s).
                    Paketlisten werden gelesen… Fertig
                    W: http://download.zerotier.com/debian/bullseye/dists/bullseye/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                    W: https://pkgs.tailscale.com/stable/debian/dists/bullseye/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                    W: https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                    N: Für das Depot »Debian bookworm« wurde der »non-free component«-Wert von »non-free« in »non-free non-free-firmware« geändert.
                    N: Weitere Informationen hierzu finden Sie online in den Veröffentlichungshinweisen unter https://www.debian.org/releases/bookworm/amd64/release-notes/ch-information.html#non-free-split.
                        Checking ioBroker user and directory permissions (2/5)
                    Created /etc/sudoers.d/iobroker
                    Fixing directory permissions...
                        Check and cleanup npm temporary directories (3/5)
                    Done.
                        Database maintenance (4/5)
                    Checking for uncompressed JSONL databases... This might take a while!
                    Compressing /opt/iobroker/iobroker-data/states.jsonl
                    Compressing /opt/iobroker/iobroker-data/objects.jsonl
                    Compressed 2 JSONL files. Done
                        Checking autostart (5/5)
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    iob fix  8,99s user 4,68s system 70% cpu 19,472 total
                    • sissiwup
                      wh@zotac /opt/iobroker % id `wh`
                      zsh: command not found: wh
                      uid=1000(wh) gid=1000(wh) Gruppen=1000(wh),24(cdrom),25(floppy),27(sudo),29(audio),30(dip),33(www-data),44(video),46(plugdev),100(users),108(netdev),110(lpadmin),113(scanner),1009(iobroker)
                      • sissiwup
                        @sissiwup
                        aud iob diag
                        Errors in npm tree:
                        npm ERR! code ELSPROBLEMS
                        npm ERR! extraneous: @aws-sdk/abort-controller@3.357.0 /opt/iobroker/node_modules/@aws-sdk/abort-controller
                        npm ERR! extraneous: @aws-sdk/client-sso-oidc@3.370.0 /opt/iobroker/node_modules/@aws-sdk/client-sso-oidc
                        npm ERR! extraneous: @aws-sdk/config-resolver@3.357.0 /opt/iobroker/node_modules/@aws-sdk/config-resolver
                        npm ERR! extraneous: @aws-sdk/credential-provider-imds@3.357.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-imds
                        npm ERR! extraneous: @aws-sdk/eventstream-codec@3.357.0 /opt/iobroker/node_modules/@aws-sdk/eventstream-codec
                        npm ERR! extraneous: @aws-sdk/fetch-http-handler@3.357.0 /opt/iobroker/node_modules/@aws-sdk/fetch-http-handler
                        npm ERR! extraneous: @aws-sdk/hash-node@3.357.0 /opt/iobroker/node_modules/@aws-sdk/hash-node
                        npm ERR! extraneous: @aws-sdk/invalid-dependency@3.357.0 /opt/iobroker/node_modules/@aws-sdk/invalid-dependency
                        npm ERR! extraneous: @aws-sdk/is-array-buffer@3.310.0 /opt/iobroker/node_modules/@aws-sdk/is-array-buffer
                        npm ERR! extraneous: @aws-sdk/middleware-content-length@3.357.0 /opt/iobroker/node_modules/@aws-sdk/middleware-content-length
                        npm ERR! extraneous: @aws-sdk/middleware-endpoint@3.357.0 /opt/iobroker/node_modules/@aws-sdk/middleware-endpoint
                        npm ERR! extraneous: @aws-sdk/middleware-retry@3.357.0 /opt/iobroker/node_modules/@aws-sdk/middleware-retry
                        npm ERR! extraneous: @aws-sdk/middleware-serde@3.357.0 /opt/iobroker/node_modules/@aws-sdk/middleware-serde
                        npm ERR! extraneous: @aws-sdk/middleware-stack@3.357.0 /opt/iobroker/node_modules/@aws-sdk/middleware-stack
                        npm ERR! extraneous: @aws-sdk/node-config-provider@3.357.0 /opt/iobroker/node_modules/@aws-sdk/node-config-provider
                        npm ERR! extraneous: @aws-sdk/node-http-handler@3.357.0 /opt/iobroker/node_modules/@aws-sdk/node-http-handler
                        npm ERR! extraneous: @aws-sdk/property-provider@3.357.0 /opt/iobroker/node_modules/@aws-sdk/property-provider
                        npm ERR! extraneous: @aws-sdk/protocol-http@3.357.0 /opt/iobroker/node_modules/@aws-sdk/protocol-http
                        npm ERR! extraneous: @aws-sdk/querystring-builder@3.357.0 /opt/iobroker/node_modules/@aws-sdk/querystring-builder
                        npm ERR! extraneous: @aws-sdk/querystring-parser@3.357.0 /opt/iobroker/node_modules/@aws-sdk/querystring-parser
                        npm ERR! extraneous: @aws-sdk/service-error-classification@3.357.0 /opt/iobroker/node_modules/@aws-sdk/service-error-classification
                        npm ERR! extraneous: @aws-sdk/shared-ini-file-loader@3.357.0 /opt/iobroker/node_modules/@aws-sdk/shared-ini-file-loader
                        npm ERR! extraneous: @aws-sdk/signature-v4@3.357.0 /opt/iobroker/node_modules/@aws-sdk/signature-v4
                        npm ERR! extraneous: @aws-sdk/smithy-client@3.358.0 /opt/iobroker/node_modules/@aws-sdk/smithy-client
                        npm ERR! extraneous: @aws-sdk/url-parser@3.357.0 /opt/iobroker/node_modules/@aws-sdk/url-parser
                        npm ERR! extraneous: @aws-sdk/util-base64@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-base64
                        npm ERR! extraneous: @aws-sdk/util-body-length-browser@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-body-length-browser
                        npm ERR! extraneous: @aws-sdk/util-body-length-node@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-body-length-node
                        npm ERR! extraneous: @aws-sdk/util-buffer-from@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-buffer-from
                        npm ERR! extraneous: @aws-sdk/util-config-provider@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-config-provider
                        npm ERR! extraneous: @aws-sdk/util-defaults-mode-browser@3.358.0 /opt/iobroker/node_modules/@aws-sdk/util-defaults-mode-browser
                        npm ERR! extraneous: @aws-sdk/util-defaults-mode-node@3.358.0 /opt/iobroker/node_modules/@aws-sdk/util-defaults-mode-node
                        npm ERR! extraneous: @aws-sdk/util-hex-encoding@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-hex-encoding
                        npm ERR! extraneous: @aws-sdk/util-middleware@3.357.0 /opt/iobroker/node_modules/@aws-sdk/util-middleware
                        npm ERR! extraneous: @aws-sdk/util-retry@3.357.0 /opt/iobroker/node_modules/@aws-sdk/util-retry
                        npm ERR! extraneous: @aws-sdk/util-stream@3.358.0 /opt/iobroker/node_modules/@aws-sdk/util-stream
                        npm ERR! extraneous: @aws-sdk/util-uri-escape@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-uri-escape
                        npm ERR! extraneous: @aws-sdk/util-utf8-node@3.208.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-node
                        npm ERR! extraneous: @aws-sdk/util-utf8@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8
                        npm ERR! extraneous: @azure/core-http@2.2.5 /opt/iobroker/node_modules/@azure/core-http
                        npm ERR! extraneous: @azure/ms-rest-azure-env@2.0.0 /opt/iobroker/node_modules/@azure/ms-rest-azure-env
                        npm ERR! extraneous: @azure/ms-rest-js@2.6.1 /opt/iobroker/node_modules/@azure/ms-rest-js
                        npm ERR! extraneous: @azure/ms-rest-nodeauth@3.1.1 /opt/iobroker/node_modules/@azure/ms-rest-nodeauth
                        npm ERR! extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                        npm ERR! extraneous: @homebridge/ciao@1.1.5 /opt/iobroker/node_modules/@homebridge/ciao
                        npm ERR! extraneous: @leichtgewicht/ip-codec@2.0.4 /opt/iobroker/node_modules/@leichtgewicht/ip-codec
                        npm ERR! extraneous: @material/animation@7.0.0 /opt/iobroker/node_modules/@material/animation
                        npm ERR! extraneous: @material/base@7.0.0 /opt/iobroker/node_modules/@material/base
                        npm ERR! extraneous: @material/button@7.0.0 /opt/iobroker/node_modules/@material/button
                        npm ERR! extraneous: @material/card@7.0.0 /opt/iobroker/node_modules/@material/card
                        npm ERR! extraneous: @material/density@7.0.0 /opt/iobroker/node_modules/@material/density
                        npm ERR! extraneous: @material/dom@7.0.0 /opt/iobroker/node_modules/@material/dom
                        npm ERR! extraneous: @material/elevation@7.0.0 /opt/iobroker/node_modules/@material/elevation
                        npm ERR! extraneous: @material/feature-targeting@7.0.0 /opt/iobroker/node_modules/@material/feature-targeting
                        npm ERR! extraneous: @material/ripple@7.0.0 /opt/iobroker/node_modules/@material/ripple
                        npm ERR! extraneous: @material/rtl@7.0.0 /opt/iobroker/node_modules/@material/rtl
                        npm ERR! extraneous: @material/shape@7.0.0 /opt/iobroker/node_modules/@material/shape
                        npm ERR! extraneous: @material/switch@7.0.0 /opt/iobroker/node_modules/@material/switch
                        npm ERR! extraneous: @material/theme@7.0.0 /opt/iobroker/node_modules/@material/theme
                        npm ERR! extraneous: @material/touch-target@7.0.0 /opt/iobroker/node_modules/@material/touch-target
                        npm ERR! extraneous: @material/typography@7.0.0 /opt/iobroker/node_modules/@material/typography
                        npm ERR! extraneous: @sentry/hub@6.19.7 /opt/iobroker/node_modules/@sentry/hub
                        npm ERR! extraneous: @sentry/minimal@6.19.7 /opt/iobroker/node_modules/@sentry/minimal
                        npm ERR! extraneous: @sentry/tracing@6.18.0 /opt/iobroker/node_modules/@sentry/tracing
                        npm ERR! extraneous: @tootallnate/once@1.1.2 /opt/iobroker/node_modules/@tootallnate/once
                        npm ERR! extraneous: @types/caseless@0.12.3 /opt/iobroker/node_modules/@types/caseless
                        npm ERR! extraneous: @types/color-name@1.1.1 /opt/iobroker/node_modules/@types/color-name
                        npm ERR! extraneous: @types/component-emitter@1.2.11 /opt/iobroker/node_modules/@types/component-emitter
                        npm ERR! extraneous: @types/es-aggregate-error@1.0.2 /opt/iobroker/node_modules/@types/es-aggregate-error
                        npm ERR! extraneous: @types/json-buffer@3.0.0 /opt/iobroker/node_modules/@types/json-buffer
                        npm ERR! extraneous: @types/node-fetch@2.6.2 /opt/iobroker/node_modules/@types/node-fetch
                        npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                        npm ERR! extraneous: @types/tough-cookie@4.0.3 /opt/iobroker/node_modules/@types/tough-cookie
                        npm ERR! extraneous: @types/tunnel@0.0.3 /opt/iobroker/node_modules/@types/tunnel
                        npm ERR! extraneous: @xmldom/xmldom@0.7.5 /opt/iobroker/node_modules/@xmldom/xmldom
                        npm ERR! extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                        npm ERR! extraneous: acorn-globals@6.0.0 /opt/iobroker/node_modules/acorn-globals
                        npm ERR! extraneous: adal-node@0.2.3 /opt/iobroker/node_modules/adal-node
                        npm ERR! extraneous: any-observable@0.3.0 /opt/iobroker/node_modules/any-observable
                        npm ERR! extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
                        npm ERR! extraneous: array-filter@1.0.0 /opt/iobroker/node_modules/array-filter
                        npm ERR! extraneous: at-least-node@1.0.0 /opt/iobroker/node_modules/at-least-node
                        npm ERR! extraneous: aws-iot-device-sdk@2.2.12 /opt/iobroker/node_modules/aws-iot-device-sdk
                        npm ERR! extraneous: binrpc@3.3.1 /opt/iobroker/node_modules/binrpc
                        npm ERR! extraneous: bl@5.1.0 /opt/iobroker/node_modules/bl
                        npm ERR! extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
                        npm ERR! extraneous: bonjour-hap@3.6.4 /opt/iobroker/node_modules/bonjour-hap
                        npm ERR! extraneous: browser-process-hrtime@1.0.0 /opt/iobroker/node_modules/browser-process-hrtime
                        npm ERR! extraneous: callback-stream@1.1.0 /opt/iobroker/node_modules/callback-stream
                        npm ERR! extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
                        npm ERR! extraneous: camelcase@7.0.1 /opt/iobroker/node_modules/camelcase
                        npm ERR! extraneous: canvas@2.10.2 /opt/iobroker/node_modules/canvas
                        npm ERR! extraneous: ci-info@3.8.0 /opt/iobroker/node_modules/ci-info
                        npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler
                        npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script
                        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                        npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                        npm ERR! extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                        npm ERR! extraneous: compress-brotli@1.3.8 /opt/iobroker/node_modules/compress-brotli
                        npm ERR! extraneous: cosmiconfig@8.3.6 /opt/iobroker/node_modules/cosmiconfig
                        npm ERR! extraneous: country-list-js@3.1.7 /opt/iobroker/node_modules/country-list-js
                        npm ERR! extraneous: cssom@0.5.0 /opt/iobroker/node_modules/cssom
                        npm ERR! extraneous: cssstyle@2.3.0 /opt/iobroker/node_modules/cssstyle
                        npm ERR! extraneous: d@1.0.1 /opt/iobroker/node_modules/d
                        npm ERR! extraneous: data-urls@3.0.2 /opt/iobroker/node_modules/data-urls
                        npm ERR! extraneous: date-utils@1.2.21 /opt/iobroker/node_modules/date-utils
                        npm ERR! extraneous: dateformat@4.5.1 /opt/iobroker/node_modules/dateformat
                        npm ERR! extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
                        npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/decamelize
                        npm ERR! extraneous: decimal.js@10.4.2 /opt/iobroker/node_modules/decimal.js
                        npm ERR! extraneous: deep-equal@2.1.0 /opt/iobroker/node_modules/deep-equal
                        npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                        npm ERR! extraneous: dev-null@0.1.1 /opt/iobroker/node_modules/dev-null
                        npm ERR! extraneous: dicer@0.3.0 /opt/iobroker/node_modules/dicer
                        npm ERR! extraneous: dns-packet@5.4.0 /opt/iobroker/node_modules/dns-packet
                        npm ERR! extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                        npm ERR! extraneous: echarts@4.9.0 /opt/iobroker/node_modules/echarts
                        npm ERR! extraneous: engine.io-client@1.8.6 /opt/iobroker/node_modules/engine.io-client
                        npm ERR! extraneous: es-get-iterator@1.1.2 /opt/iobroker/node_modules/es-get-iterator
                        npm ERR! extraneous: es5-ext@0.10.53 /opt/iobroker/node_modules/es5-ext
                        npm ERR! extraneous: es6-iterator@2.0.3 /opt/iobroker/node_modules/es6-iterator
                        npm ERR! extraneous: es6-map@0.1.5 /opt/iobroker/node_modules/es6-map
                        npm ERR! extraneous: es6-set@0.1.5 /opt/iobroker/node_modules/es6-set
                        npm ERR! extraneous: es6-symbol@3.1.3 /opt/iobroker/node_modules/es6-symbol
                        npm ERR! extraneous: escodegen@2.0.0 /opt/iobroker/node_modules/escodegen
                        npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/esprima
                        npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/estraverse
                        npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                        npm ERR! extraneous: event-emitter@0.3.5 /opt/iobroker/node_modules/event-emitter
                        npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                        npm ERR! extraneous: ext@1.6.0 /opt/iobroker/node_modules/ext
                        npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                        npm ERR! extraneous: fast-safe-stringify@2.1.1 /opt/iobroker/node_modules/fast-safe-stringify
                        npm ERR! extraneous: fast-srp-hap@2.0.4 /opt/iobroker/node_modules/fast-srp-hap
                        npm ERR! extraneous: foreach@2.0.5 /opt/iobroker/node_modules/foreach
                        npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                        npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                        npm ERR! extraneous: gaxios@6.1.1 /opt/iobroker/node_modules/gaxios
                        npm ERR! extraneous: gcp-metadata@6.0.0 /opt/iobroker/node_modules/gcp-metadata
                        npm ERR! extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                        npm ERR! extraneous: glob-stream@6.1.0 /opt/iobroker/node_modules/glob-stream
                        npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                        npm ERR! extraneous: hap-nodejs@0.9.8 /opt/iobroker/node_modules/hap-nodejs
                        npm ERR! extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                        npm ERR! extraneous: http-proxy-agent@4.0.1 /opt/iobroker/node_modules/http-proxy-agent
                        npm ERR! extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
                        npm ERR! extraneous: ini@2.0.0 /opt/iobroker/node_modules/ini
                        npm ERR! extraneous: iobroker.coronavirus-statistics@0.8.7 /opt/iobroker/node_modules/iobroker.coronavirus-statistics
                        npm ERR! extraneous: iobroker.iot@1.11.9 /opt/iobroker/node_modules/iobroker.iot
                        npm ERR! extraneous: iobroker.jarvis@3.0.0 /opt/iobroker/node_modules/iobroker.jarvis
                        npm ERR! extraneous: iobroker.ping@1.5.3 /opt/iobroker/node_modules/iobroker.ping
                        npm ERR! extraneous: iobroker.pushover@3.0.2 /opt/iobroker/node_modules/iobroker.pushover
                        npm ERR! extraneous: iobroker.tankerkoenig@2.1.1 /opt/iobroker/node_modules/iobroker.tankerkoenig
                        npm ERR! extraneous: iobroker.type-detector@1.1.1 /opt/iobroker/node_modules/iobroker.type-detector
                        npm ERR! extraneous: iobroker.unifi@0.5.10 /opt/iobroker/node_modules/iobroker.unifi
                        npm ERR! extraneous: iobroker.vodafone-speedtest@0.0.7 /opt/iobroker/node_modules/iobroker.vodafone-speedtest
                        npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server
                        npm ERR! extraneous: iobroker.yahka@0.13.1 /opt/iobroker/node_modules/iobroker.yahka
                        npm ERR! extraneous: ip-regex@2.1.0 /opt/iobroker/node_modules/ip-regex
                        npm ERR! invalid: ip@2.0.0 /opt/iobroker/node_modules/ip
                        npm ERR! extraneous: ip@2.0.0 /opt/iobroker/node_modules/ip
                        npm ERR! extraneous: is-absolute@1.0.0 /opt/iobroker/node_modules/is-absolute
                        npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/is-arguments
                        npm ERR! extraneous: is-arrayish@0.2.1 /opt/iobroker/node_modules/is-arrayish
                        npm ERR! extraneous: is-generator-function@1.0.10 /opt/iobroker/node_modules/is-generator-function
                        npm ERR! extraneous: is-map@2.0.2 /opt/iobroker/node_modules/is-map
                        npm ERR! extraneous: is-nan@1.3.2 /opt/iobroker/node_modules/is-nan
                        npm ERR! extraneous: is-negated-glob@1.0.0 /opt/iobroker/node_modules/is-negated-glob
                        npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero
                        npm ERR! extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                        npm ERR! extraneous: is-relative@1.0.0 /opt/iobroker/node_modules/is-relative
                        npm ERR! extraneous: is-set@2.0.2 /opt/iobroker/node_modules/is-set
                        npm ERR! extraneous: is-unc-path@1.0.0 /opt/iobroker/node_modules/is-unc-path
                        npm ERR! extraneous: is-weakmap@2.0.1 /opt/iobroker/node_modules/is-weakmap
                        npm ERR! extraneous: is-weakset@2.0.2 /opt/iobroker/node_modules/is-weakset
                        npm ERR! extraneous: is-windows@1.0.2 /opt/iobroker/node_modules/is-windows
                        npm ERR! extraneous: jsdom@19.0.0 /opt/iobroker/node_modules/jsdom
                        npm ERR! extraneous: json-logic-js@2.0.1 /opt/iobroker/node_modules/json-logic-js
                        npm ERR! extraneous: json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/json-stable-stringify-without-jsonify
                        npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
                        npm ERR! extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                        npm ERR! extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                        npm ERR! extraneous: macaddress@0.5.1 /opt/iobroker/node_modules/macaddress
                        npm ERR! extraneous: mem@4.3.0 /opt/iobroker/node_modules/mem
                        npm ERR! extraneous: micro@9.3.4 /opt/iobroker/node_modules/micro
                        npm ERR! extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                        npm ERR! extraneous: multicast-dns-service-types@1.1.0 /opt/iobroker/node_modules/multicast-dns-service-types
                        npm ERR! extraneous: multicast-dns@7.2.5 /opt/iobroker/node_modules/multicast-dns
                        npm ERR! extraneous: mysql@2.18.1 /opt/iobroker/node_modules/mysql
                        npm ERR! extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                        npm ERR! extraneous: ncp@2.0.0 /opt/iobroker/node_modules/ncp
                        npm ERR! extraneous: needle@2.9.1 /opt/iobroker/node_modules/needle
                        npm ERR! extraneous: next-tick@1.0.0 /opt/iobroker/node_modules/next-tick
                        npm ERR! extraneous: nice-try@1.0.5 /opt/iobroker/node_modules/nice-try
                        npm ERR! extraneous: node-abi@3.30.0 /opt/iobroker/node_modules/node-abi
                        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                        npm ERR! extraneous: node-libcurl@2.3.3 /opt/iobroker/node_modules/node-libcurl
                        npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                        npm ERR! extraneous: node-pre-gyp@0.11.0 /opt/iobroker/node_modules/node-pre-gyp
                        npm ERR! extraneous: node-unifi@1.4.3 /opt/iobroker/node_modules/node-unifi
                        npm ERR! extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
                        npm ERR! extraneous: npm-bundled@1.1.2 /opt/iobroker/node_modules/npm-bundled
                        npm ERR! extraneous: npm-normalize-package-bin@1.0.1 /opt/iobroker/node_modules/npm-normalize-package-bin
                        npm ERR! extraneous: npm-packlist@1.4.8 /opt/iobroker/node_modules/npm-packlist
                        npm ERR! extraneous: npm@8.5.0 /opt/iobroker/node_modules/npm
                        npm ERR! extraneous: nwsapi@2.2.2 /opt/iobroker/node_modules/nwsapi
                        npm ERR! extraneous: object-is@1.1.5 /opt/iobroker/node_modules/object-is
                        npm ERR! extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                        npm ERR! extraneous: ordered-read-streams@1.0.1 /opt/iobroker/node_modules/ordered-read-streams
                        npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/os-homedir
                        npm ERR! extraneous: osenv@0.1.5 /opt/iobroker/node_modules/osenv
                        npm ERR! extraneous: p-is-promise@2.1.0 /opt/iobroker/node_modules/p-is-promise
                        npm ERR! extraneous: p-limit@3.1.0 /opt/iobroker/node_modules/p-limit
                        npm ERR! extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                        npm ERR! extraneous: passport.socketio@3.7.0 /opt/iobroker/node_modules/passport.socketio
                        npm ERR! extraneous: path-dirname@1.0.2 /opt/iobroker/node_modules/path-dirname
                        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                        npm ERR! extraneous: ping@0.4.1 /opt/iobroker/node_modules/ping
                        npm ERR! extraneous: platform@1.3.6 /opt/iobroker/node_modules/platform
                        npm ERR! extraneous: prebuild-install@7.1.1 /opt/iobroker/node_modules/prebuild-install
                        npm ERR! extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                        npm ERR! extraneous: proper-lockfile@4.1.2 /opt/iobroker/node_modules/proper-lockfile
                        npm ERR! extraneous: pumpify@1.5.1 /opt/iobroker/node_modules/pumpify
                        npm ERR! extraneous: pushover-notifications@1.2.2 /opt/iobroker/node_modules/pushover-notifications
                        npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                        npm ERR! extraneous: querystring@0.2.1 /opt/iobroker/node_modules/querystring
                        npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
                        npm ERR! extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
                        npm ERR! extraneous: regexp.prototype.flags@1.5.1 /opt/iobroker/node_modules/regexp.prototype.flags
                        npm ERR! extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                        npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/require-main-filename
                        npm ERR! extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
                        npm ERR! extraneous: saslprep@1.0.3 /opt/iobroker/node_modules/saslprep
                        npm ERR! invalid: sax@0.4.3 /opt/iobroker/node_modules/sax
                        npm ERR! extraneous: sax@0.4.3 /opt/iobroker/node_modules/sax
                        npm ERR! extraneous: saxes@5.0.1 /opt/iobroker/node_modules/saxes
                        npm ERR! invalid: seq-logging@0.4.6 /opt/iobroker/node_modules/seq-logging
                        npm ERR! extraneous: seq-logging@0.4.6 /opt/iobroker/node_modules/seq-logging
                        npm ERR! extraneous: set-immediate-shim@1.0.1 /opt/iobroker/node_modules/set-immediate-shim
                        npm ERR! extraneous: sharp@0.30.7 /opt/iobroker/node_modules/sharp
                        npm ERR! extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                        npm ERR! extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                        npm ERR! extraneous: socket.io-client@1.7.4 /opt/iobroker/node_modules/socket.io-client
                        npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/source-map-support
                        npm ERR! extraneous: strip-eof@1.0.0 /opt/iobroker/node_modules/strip-eof
                        npm ERR! extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
                        npm ERR! A complete log of this run can be found in: /home/wh/.npm/_logs/2023-10-14T19_08_41_698Z-debug-0.log
                        *** ioBroker-Installation ***
                        • sissiwup
                          @sissiwup
                          			v.2023-10-10
                           Static hostname: zotac
                                 Icon name: computer-desktop
                                   Chassis: desktop 🖥️
                                    Kernel: Linux 6.1.0-13-amd64
                              Architecture: x86-64
                           Hardware Vendor: ASRock
                            Hardware Model: H81M-DGS
                          Firmware Version: P2.00
                          Installation: 		native
                          Kernel: 		x86_64
                          Userland: 		amd64
                          Timezone: 		Europe/Berlin (CEST, +0200)
                          User-ID: 		1000
                          X-Server: 		true
                          Boot Target: 		graphical.target
                          Pending OS-Updates: 	0
                          Pending iob updates: 	8
                          Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
                          			/usr/bin/node 		v18.18.2
                          			/usr/bin/npm 		9.8.1
                          			/usr/bin/npx 		9.8.1
                          			/usr/bin/corepack 	0.19.0
                          Recommended versions are nodejs  and npm
                          MEMORY:
                          Mem:             16G         11G        423M        137M        4.9G        4.8G
                          Swap:            34G        3.2G         31G
                          Total:           50G         14G         31G
                          Active iob-Instances: 	20
                          Active repo(s): live-stable
                          ioBroker Core: 		js-controller 		5.0.12
                          			admin 			6.10.2
                          ioBroker Status: 	iobroker is running on this host.
                          Objects type: jsonl
                          States  type: jsonl
                            system.adapter.admin.0                  : admin                 : zotac                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.web.0                    : web                   : zotac                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          Objects: 		12656
                          States: 		10563
                          Size of iob-Database:
                          21M	/opt/iobroker/iobroker-data/objects.jsonl
                          18M	/opt/iobroker/iobroker-data/objects.json.migrated
                          18M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                          3.4M	/opt/iobroker/iobroker-data/states.jsonl
                          2.9M	/opt/iobroker/iobroker-data/states.json.migrated
                          2.9M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                          === Mark text until here for copying ===
                          iob diag 28,29s user 5,45s system 19% cpu 2:51,91 total
                            Thomas Braun Most Active @sissiwup last edited by
                            @sissiwup
                            Wassen das für'n komischer Prompt? Hab ich noch nie gesehen:
                            Entweder ist das # für root logins oder $ für einen user. Aber % kenn ich nicht.
                            • sissiwup
                              sissiwup @Thomas Braun last edited by
                              @thomas-braun sagte in Umstellung auf iobroker nicht als root:
                              @sissiwup
                              Habe das in zsh so eingestellt. Ist aber der User wh. Kein root.
                                Thomas Braun Most Active @sissiwup last edited by Thomas Braun
                                @sissiwup
                                .k zsh kenn ich nicht genau. Ein bash prompt kann man zwar auch umstellen, ist aber eher ungewöhnlich.
                                Noch als Hinweis: iob_diag verwendet bash, keine Ahnung ob es unter der zsh da zu Komplikationen kommt.
                                • sissiwup
                                  bash ist natürlich auch da.
                                  2023-10-14 21:16:55.685  - error: host.zotac instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2023-10-14 21:16:55.685  - info: host.zotac Restart adapter system.adapter.admin.0 because enabled
                                  2023-10-14 21:17:25.720  - info: host.zotac instance system.adapter.admin.0 started with pid 488395
                                  2023-10-14 21:17:25.975  - error: host.zotac Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:21
                                  2023-10-14 21:17:25.975  - error: host.zotac Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:21:44)
                                  2023-10-14 21:17:25.975  - error: host.zotac instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2023-10-14 21:17:25.975  - info: host.zotac Restart adapter system.adapter.admin.0 because enabled
                                  • sissiwup
                                    @sissiwup
                                    Kann ich das neu installieren und meine Einstellungen übernehmen?
                                      @sissiwup
                                      iob start admin
                                      sagt?
                                      sissiwup 2 Replies Last reply Reply Quote 0
                                      • sissiwup
                                        Nix, also keinen Fehler.
                                        wh@zotac:/opt/iobroker$ iob start admin
                                        023-10-14 21:46:08.216  - info: host.zotac instance system.adapter.admin.0 started with pid 610506
                                        2023-10-14 21:46:08.542  - error: host.zotac Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:21
                                        2023-10-14 21:46:08.544  - error: host.zotac Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:21:44)
                                        2023-10-14 21:46:08.546  - error: host.zotac instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2023-10-14 21:46:08.546  - info: host.zotac Restart adapter system.adapter.admin.0 because enabled
                                        2023-10-14 21:46:38.578  - info: host.zotac instance system.adapter.admin.0 started with pid 611113
                                        2023-10-14 21:46:38.897  - error: host.zotac Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:21
                                        2023-10-14 21:46:38.898  - error: host.zotac Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:21:44)
                                        2023-10-14 21:46:38.899  - error: host.zotac instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2023-10-14 21:46:38.899  - info: host.zotac Restart adapter system.adapter.admin.0 because enabled
                                        • sissiwup
                                          Kann das mit den vielen Fehlern aus diag zu tun haben?
                                            Welche? Gib mal die Langfassung.
                                            Bei den Repos solltest du ran, die sind mittlerweile alle auf die neue Nomenklatur umgestellt.
                                            installlation
                                            2132
