    4. Objekte werden verzögert aktualisiert
    • Pepsi1183
      Pepsi1183 @Thomas Braun last edited by Pepsi1183
      Danke für den Tip mit Nodejs, hat aber auch nichts gebracht.
      wie komme ich an die "Langfassung" Putty springt direkt ins summery....
      ======= Start marking the full check here =========
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: ioBrokerVM
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-21-amd64
            Architecture: x86-64
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       00:54:56 up  1:28,  1 user,  load average: 0.45, 0.58, 0.45
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Sun 2023-10-15 00:54:56 CEST
                 Universal time: Sat 2023-10-14 22:54:56 UTC
                       RTC time: Sat 2023-10-14 22:54:57
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      christoph
      /home/christoph
      christoph cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            5.9G        3.7G        1.1G        0.0K        1.2G        2.1G
      Swap:           974M          0B        974M
      Total:          6.9G        3.7G        2.0G
               5940 M total memory
               3692 M used memory
                361 M active memory
               4172 M inactive memory
               1070 M free memory
                153 M buffer memory
               1024 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  2.9G     0  2.9G   0% /dev
      tmpfs          tmpfs     595M  496K  594M   1% /run
      /dev/sda1      ext4       48G   13G   34G  27% /
      tmpfs          tmpfs     3.0G     0  3.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     595M     0  595M   0% /run/user/1000
      [Sat Oct 14 23:26:57 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Oct 14 23:26:57 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      5.7G    /var/
      4.7G    /var/log
      4.1G    /var/log/journal/f27f865acaa7446abfab405c3542c7b6
      643M    /var/lib
      Archived and active journals take up 32.0M in the file system.
      /opt/iobroker/backups:
      22M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.3G    /opt/iobroker/iobroker-data/
      493M    /opt/iobroker/iobroker-data/files
      461M    /opt/iobroker/iobroker-data/iobroker-data
      197M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      78M     /opt/iobroker/iobroker-data/states.jsonl
      42M     /opt/iobroker/iobroker-data/objects.jsonl
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   2
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : ioBrokerVM                               -  enabled
      + system.adapter.admin.0                  : admin                 : ioBrokerVM                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBrokerVM                               -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : ioBrokerVM                               -  enabled
      + system.adapter.awtrix-light.1           : awtrix-light          : ioBrokerVM                               -  enabled
      + system.adapter.backitup.0               : backitup              : ioBrokerVM                               -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : ioBrokerVM                               -  enabled
      + system.adapter.chromecast.1             : chromecast            : ioBrokerVM                               -  enabled
      + system.adapter.deconz.0                 : deconz                : ioBrokerVM                               -  enabled, port: 80
      + system.adapter.deconz.1                 : deconz                : ioBrokerVM                               -  enabled, port: 80
        system.adapter.devices.0                : devices               : ioBrokerVM                               - disabled
      + system.adapter.discovery.0              : discovery             : ioBrokerVM                               -  enabled
        system.adapter.eusec.0                  : eusec                 : ioBrokerVM                               - disabled
      + system.adapter.fullcalendar.0           : fullcalendar          : ioBrokerVM                               -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : ioBrokerVM                               - disabled
      + system.adapter.harmony.0                : harmony               : ioBrokerVM                               -  enabled
      + system.adapter.history.0                : history               : ioBrokerVM                               -  enabled
      + system.adapter.homekit-controller.0     : homekit-controller    : ioBrokerVM                               -  enabled
      + system.adapter.hue.0                    : hue                   : ioBrokerVM                               -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : ioBrokerVM                               - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : ioBrokerVM                               - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : ioBrokerVM                               - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : ioBrokerVM                               - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerVM                               - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBrokerVM                               - disabled
      + system.adapter.influxdb.0               : influxdb              : ioBrokerVM                               -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : ioBrokerVM                               -  enabled
      + system.adapter.iot.0                    : iot                   : ioBrokerVM                               -  enabled
      + system.adapter.javascript.0             : javascript            : ioBrokerVM                               -  enabled
        system.adapter.material.0               : material              : ioBrokerVM                               - disabled
      + system.adapter.modbus.0                 : modbus                : ioBrokerVM                               -  enabled
        system.adapter.mqtt-client.0            : mqtt-client           : ioBrokerVM                               - disabled, port: 1883
      + system.adapter.mqtt.0                   : mqtt                  : ioBrokerVM                               -  enabled, port: 1883, bind: 192.168.73.54
      + system.adapter.myenergi.0               : myenergi              : ioBrokerVM                               -  enabled
        system.adapter.net-tools.0              : net-tools             : ioBrokerVM                               - disabled
        system.adapter.nina.0                   : nina                  : ioBrokerVM                               - disabled
        system.adapter.node-red.0               : node-red              : ioBrokerVM                               - disabled, port: 1880, bind: 0.0.0.0
        system.adapter.paw.0                    : paw                   : ioBrokerVM                               - disabled, port: 8898
      + system.adapter.pi-hole.0                : pi-hole               : ioBrokerVM                               -  enabled
        system.adapter.ping.0                   : ping                  : ioBrokerVM                               - disabled
      + system.adapter.proxmox.0                : proxmox               : ioBrokerVM                               -  enabled, port: 8006
      + system.adapter.pushbullet.0             : pushbullet            : ioBrokerVM                               -  enabled
      + system.adapter.pushbullet.1             : pushbullet            : ioBrokerVM                               -  enabled
        system.adapter.scenes.0                 : scenes                : ioBrokerVM                               - disabled
      + system.adapter.semp.0                   : semp                  : ioBrokerVM                               -  enabled
      + system.adapter.shelly.0                 : shelly                : ioBrokerVM                               -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : ioBrokerVM                               - disabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.sma-em.0                 : sma-em                : ioBrokerVM                               - disabled
        system.adapter.sonos.0                  : sonos                 : ioBrokerVM                               - disabled
      + system.adapter.synology.0               : synology              : ioBrokerVM                               -  enabled, port: 5000
      + system.adapter.synology.1               : synology              : ioBrokerVM                               -  enabled, port: 5000
      + system.adapter.tr-064.0                 : tr-064                : ioBrokerVM                               -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBrokerVM                               -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBrokerVM                               -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBrokerVM                               -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBrokerVM                               -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBrokerVM                               -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBrokerVM                               -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBrokerVM                               -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerVM                               -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBrokerVM                               -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBrokerVM                               -  enabled
        system.adapter.vis-metro.0              : vis-metro             : ioBrokerVM                               -  enabled
        system.adapter.vis-players.0            : vis-players           : ioBrokerVM                               -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerVM                               -  enabled
        system.adapter.vis.0                    : vis                   : ioBrokerVM                               -  enabled
      + system.adapter.web.0                    : web                   : ioBrokerVM                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.ws.0                     : ws                    : ioBrokerVM                               - disabled, port: 8084, bind: 192.168.73.54, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "awtrix-light" : 0.8.0    , installed 0.8.0
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "eusec"        : 1.1.2    , installed 1.1.2
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "fullcalendar" : 1.2.0    , installed 2.2.2
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "homekit-controller": 0.5.8, installed 0.5.8
      Adapter    "hue"          : 3.10.0   , installed 3.10.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
      Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "paw"          : 0.3.2    , installed 0.3.2
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
      Adapter    "pushbullet"   : 1.0.1    , installed 1.0.1
      Adapter    "sbfspot"      : 4.1.6    , installed 4.1.6
      Adapter    "semp"         : 1.3.4    , installed 1.3.4
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sonos"        : 2.3.1    , installed 2.3.1
      Adapter    "synology"     : 3.0.0    , installed 3.0.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Objects and States
      ** OS-Repositories and Updates ***
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Get:3 https://apt.grafana.com stable InRelease [5984 B]
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Err:3 https://apt.grafana.com stable InRelease
      Reading package lists...
      • OliverIO
        OliverIO @Pepsi1183 last edited by OliverIO
        @pepsi1183
        also bei der auslastung wundert es mich nicht, das da iobroker nicht immer sofort zum zug kommt.
        evtl kannst du tricksen in dem du die prozess priorität des prozesse für den iobroker.js-controller etwas hochsetzt. allerdings leidet dann die performance der anderen prozesse darunter, da linux anhand des nice-wertes entscheidet, wieviel zeitscheiben ein prozess auf einem kern erhält, bevor er dem nächsten prozess den kern übergibt.
        https://www.atlantic.net/vps-hosting/how-to-set-linux-process-priority-using-nice-and-renice-commands/
        mit top kann man sich das dann anschauen
        Pepsi1183 1 Reply Last reply Reply Quote 0
        • Pepsi1183
          Pepsi1183 @OliverIO last edited by
          @oliverio
          Danke fürs Feedback, Welche Auslastung meinst du?
          Welche stelle übersehe ich die ganze Zeit?
          Ja, die vm hat was zu tun, aber hat noch luft nach oben, so wie ich das sehen....
          • OliverIO
            @pepsi1183
            ok, sorry,
            ich glaube in einem anderen thread war dann auch ein top auszug mit deutlich höheren auslastungen (chromium, shelly, etc)
            dann hab ich das verwechselt.
            hab den vorhin nur unterwegs mal angeschaut und nun etwas später dazugeschrieben
            • Pepsi1183
              @oliverio
              Ok, "schade" hatte die Hoffnung du siehst etwas das ich übersehe...
              habe nochmal geschaut, wenn ich top per ssh offen habe und in einem Blockly den Object-Browser aufrufe macht js-con jede menge.....
              PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
              422 iobroker  20   0   12,0g   1,2g  40360 R 110,3  21,5  27:55.63 iobroker.js-con
              • OliverIO
                @pepsi1183
                hm ja das wäre erklärbar.
                im javascript-adapter werden sämtliche datenpunkte beim öffnen abonniert. das ist wohl so, damit die auswahl der datenpunkte und anzeige der werte einfacher ist. das kann beim öffnen schon ganz schön last erzeugen. ist aber nur bei der Bearbeitung so.
                Nach kurzer Zeit sollte sich das beruhigen.
                evtl noch etwas zu deiner auslastungsanzeige oben.
                da sieht man jetzt die einzelne VM
                wie sieht den die Gesamtbelastung der Hardware aus?
                wenn da noch andere VMs oder Container laufen, benötigen die ja auch ein wenig Leistung.
                Allerdings weiß ich nicht, ob sich das in der Auslastung der einzelnen VM wiederspiegelt. So von der Grafik her würde ich auch sagen, das passt.
                evtl könnte man mal noch nach der Lese/Schreibauslastung schauen.
                Was hängt da dran? SD-Karte/SSD?
                was verwendest du für den objektspeicher bei iobroker? redis/jsonl?
                prüfe mal die qualität deines datenspeichers, nicht das sich da schon sektoren/speicherblockausfälle ankündigen?
                https://wiki.ubuntuusers.de/Festplattenstatus/
                schau auch mal das syslog nach warning/error durch.
                idealerweise in der iobroker vm, als auch auf dem host-system unter proxmox, falls das geht (ich hab kein proxmox)
                ggfs. auch mal parallel eine 2 vm mit einer neuen iobroker installation aufmachen, backup einspielen und schauen ob es sich da genauso verhält
                sorry für die relativ wahllose vorschlagsliste. das sind die sachen die mir noch eingefallen sind.
                  ticaki Developer last edited by ticaki
                  Eine Uptime von 130 Tagen heißt schon mal das der Kernel von vor 130 Tagen ist. Mal iobroker neu gestartet? Weiß nicht ob ne neue nodejs Version verwendet wird, wenn er nicht neu gestartet wird.
                  • Pepsi1183
                    @oliverio
                    Das Sorry kannste streichen, versuchst ja zumindest zu helfen, da ich auch keine Idee habe, freue ich mich über jeden Vorschlag wo man was prüfen/optimieren könnte.
                    "was verwendest du für den objektspeicher bei iobroker? redis/jsonl?"
                    • Gute Frage, müsste ich gleich mal schauen, was ist denn performace technisch zu empfehlen?
                    Also der Host hat ebenfalls wenig zu tun.... und zur SSD kann ich noch keine Fehlermeldungen/Hinweise finden.
                    @ticaki :
                    iob habe ich gerade mal neu gestartet und auch mal ein sudo reboot gemacht, trotzdem keine Verbesserung
                    Pepsi1183 T OliverIO 3 Replies Last reply Reply Quote 0
                    • Pepsi1183
                      Pepsi1183 @Pepsi1183 last edited by
                      Nochmal allgemein:
                      sehe ich irgendwo wie viele Objekte ein Adapter / eine Instanz hat?
                      Überlege gerade ob ggf. ein Adapter mal unkontrolliert Objekte generiert hat oder ähnliches und das Problem einfach leere ungenutzte Objekte sind.....
                        ticaki Developer @Pepsi1183 last edited by ticaki
                        @pepsi1183
                        redis
                        wichtig: https://forum.iobroker.net/topic/52976/wichtiger-hinweis-für-redis-installationen
                        Experte -> object baum -> mülleimer klicken, da steht die Zahl wieviele States gelöscht werden, nur nicht bestätigen. 🙂
                        • OliverIO
                          @pepsi1183
                          Ich verwende auch redis
                          In der expertensicht der Instanzen siehst du welcher Instanz aktuell wieviele states liest und schreibt.
                          • Pepsi1183
                            @oliverio & @ticaki
                            Danke für die Ideen.
                            Habe jetzt auch auf redis umgestellt und die Performance im Admin Bereich scheint auch besser zu sein.
                            Habe dabei auch gesehen, dass mein MQTT Server von einem ESPresence "versuch" mit Datenpunkten überflutet wurde.
                            Habe ich jetzt erstmal gelöscht und das Thema ESPresence verschoben, bis das System wieder richtig läuft.
                            Ich habe noch 18640 Objekte und grob überschlagen passt je Instanz die Anzahl Objekte.
                            Aber irgendwas scheint noch nicht sauber zu sein. Mein Vis Projekt zeigt mir beim starten immer noch initial keine Daten an, sondern lädt die Werte anscheinend immer erst nach und nach bei Änderungen bzw. Wert Update Meldungen.
                            Kann man definieren, wie lange Werte in Objekten "Gültig" sind? Oder irgendwas in der Richtung?
                            749
