    4. Test Adapter TP-Link Tapo
      WA @tombox last edited by
      @tombox
      scheint mir fast identisch, die L610 hat nur einen GU10 Sockel .
      L610
      L510
        mylan @WA last edited by
        @wa
        Könnte dasselbe Problem wie mit meinen P100 sein (siehe oben).
        Für die P110 lieber Firmware Upgrade erstmal deaktivieren.
        Aber eine Lösung dürfte wohl möglich sein, wenn das hier auch dasselbe Problem war:
        https://community.tp-link.com/en/smart-home/forum/topic/620270?replyId=1245450
          Michaelnorge last edited by Michaelnorge
          Hallo ihr lieben.
          Kann mir Jemand erklären, was es mit diesen Fehlermeldungen auf sich hat, die alle 5 Minuten auftreten?
          tapo.0 | 2023-10-07 18:14:43.918 | info | Found 5 devices
          tapo.0 | 2023-10-07 18:14:43.605 | info | Login succesfull
          tapo.0 | 2023-10-07 18:14:42.925 | info | Login tp TAPO App
          tapo.0 | 2023-10-07 18:14:42.891 | info | starting. Version 0.0.8 (non-npm: TA2k/ioBroker.tapo#bec54f4bf5d6dbcaf04e8d9e691a75ff1c06e346) in /opt/iobroker/node_modules/iobroker.tapo, node: v18.17.1, js-controller: 5.0.12
          host.iobroker-pm | 2023-10-07 18:14:41.899 | info | instance system.adapter.tapo.0 started with pid 2320
          host.iobroker-pm | 2023-10-07 18:14:11.787 | info | Restart adapter system.adapter.tapo.0 because enabled
          host.iobroker-pm | 2023-10-07 18:14:11.786 | error | instance system.adapter.tapo.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker-pm | 2023-10-07 18:14:11.786 | error | Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:82:21)
          host.iobroker-pm | 2023-10-07 18:14:11.786 | error | Caught by controller[0]: at emitErrorCloseNT (node:internal/streams/destroy:116:3)
          host.iobroker-pm | 2023-10-07 18:14:11.786 | error | Caught by controller[0]: at emitErrorNT (node:internal/streams/destroy:151:8)
          host.iobroker-pm | 2023-10-07 18:14:11.786 | error | Caught by controller[0]: at Socket.emit (node:domain:489:12)
          host.iobroker-pm | 2023-10-07 18:14:11.786 | error | Caught by controller[0]: at Socket.emit (node:events:514:28)
          host.iobroker-pm | 2023-10-07 18:14:11.786 | error | Caught by controller[0]: at Socket.socketErrorListener (node:_http_client:501:9)
          host.iobroker-pm | 2023-10-07 18:14:11.786 | error | Caught by controller[0]: at ClientRequest.emit (node:domain:489:12)
          host.iobroker-pm | 2023-10-07 18:14:11.786 | error | Caught by controller[0]: at ClientRequest.emit (node:events:526:35)
          host.iobroker-pm | 2023-10-07 18:14:11.786 | error | Caught by controller[0]: at ClientRequest.<anonymous> (/opt/iobroker/node_modules/onvif/lib/cam.js:328:4)
          host.iobroker-pm | 2023-10-07 18:14:11.786 | error | Caught by controller[0]: at Cam.<anonymous> (/opt/iobroker/node_modules/onvif/lib/events.js:309:14)
          host.iobroker-pm | 2023-10-07 18:14:11.785 | error | Caught by controller[0]: TypeError: callback.call is not a function
          tapo.0 | 2023-10-07 18:14:11.698 | warn | Terminated (UNCAUGHT_EXCEPTION): Without reason
          tapo.0 | 2023-10-07 18:14:11.698 | info | terminating
          tapo.0 | 2023-10-07 18:14:11.686 | error | callback.call is not a function
          tapo.0 | 2023-10-07 18:14:11.685 | error | TypeError: callback.call is not a function at Cam.<anonymous> (/opt/iobroker/node_modules/onvif/lib/events.js:309:14) at ClientRequest.<anonymous> (/opt/iobroker/node_modules/onvif/lib/cam.js:328:4) at ClientRequest.emit (node:events:526:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:501:9) at Socket.emit (node:events:514:28) at Socket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:151:8) at emitErrorCloseNT (node:internal/streams/destroy:116:3) at processTicksAndRejections (node:internal/process/task_queues:82:21)
          tapo.0 | 2023-10-07 18:14:11.685 | error | uncaught exception: callback.call is not a function
          Der Adapter schmiert dann immer ab und startet neu, dementsprechend voll ist nach einem Tag der Log.
          Ich hab das Problem seit ich von RP4 auf einen Proxmox umgestiegen bin. Die Objekte habe ich bereits gelöscht, auch den Adapter neu installiert, aber es hilft nichts.
          Bin für jede Hilfe dankbar!
          Chat-GPT schlägt mir folgendes vor:
          Überprüfen Sie den Code im "tapo.0" Adapter, insbesondere an der Stelle, an der die "callback.call"-Funktion aufgerufen wird. Stellen Sie sicher, dass diese Funktion korrekt definiert und verfügbar ist.
          Überprüfen Sie die Version des "onvif"-Moduls und stellen Sie sicher, dass es auf dem neuesten Stand ist. Möglicherweise gibt es ein Update, das diesen Fehler behebt.
          Wenn der Fehler weiterhin besteht, sollten Sie die Community oder Entwickler des "tapo.0"-Adapters kontaktieren, um weitere Unterstützung bei der Fehlerbehebung zu erhalten
          Naja, von den ersten zwei Optionen verstehe ich null, da blieb nur die Dritte 😁
            tombox @Michaelnorge last edited by
            @michaelnorge irgend ein problem mit den events unsubscriben . welche Kamera ist das genau und sind irgendwelche besonderen events aktiv
              Michaelnorge @tombox last edited by Michaelnorge
              @tombox Hab alle 5 Kameras unsubscript in der App und neu subscriped, dachte das würde helfen, aber hat leider nix geholfen. Fehler kommt weiterhin alle 5 Minuten: "uncaught exception: callback.call is not a function".
              Ich habe die Kameras eigentlich ganz normal am laufen. Bei einer Kamera hab ich den "privatsphärenmodus" aktiviert, aber sonst laufen die wie "ab Werk". Ich benutze nicht mal die App, MotionEye holt die Bilder von der Kamera und stellt sie ioBroker zur Vefügung.
              Aber das macht ioBroker ja nicht auf den Punkt alle 5 Minuten sondern nur bei Bewegung....
                @michaelnorge Könntest du zum test alles wie zb motion eye deaktivieren
                  @tombox MotionEye war runtergefahren, die Fehler kommen aber immer noch ins log 😕
                    @tombox Ich hatte nun auch alle Scripts, die irgendwas mit der TAPO zu tun hatten, deaktiviert - trotzdem immer noch die Fehlermeldung.
                      Ich bin testweise mal von der Version 0.8 auf die 0.7 Version runter.
                      Jetzt bekomme ich direkt vor dem Crash des Adapters folgende Meldung ins Log:
                      tapo.0
                      2023-10-10 18:37:09.001	error	uncaught exception: callback.call is not a function
                      tapo.0
                      2023-10-10 18:37:00.685	error	TypeError: Cannot read properties of undefined (reading 'switch')
                      tapo.0
                      2023-10-10 18:36:00.675	error	TypeError: Cannot read properties of undefined (reading 'switch')
                      Können diese "Switch" was damit zu tun haben?
                      Ich habe zwei bei der App "Kasa" angemeldete Tapo-Steckdosen, die neuerdings ebenfalls in der Tapo-App auftauchen (Die haben die beiden Apps zusammengeführt) ! Ich kann mir vorstellen daß die Fehler im log daher rühren.
                      Kann das jemand bestätigen?
                        Eine kleine Frage, weil ich mich hier immer noch mit dem Problem rumschlage und keine Lösung finde.
                        Soll der letzte Eintrag im log beim Starten des Adapters
                        tapo.0 2023-10-15 06:38:31.418	info	Wait for connections
                        sein? Fehlt da nicht noch ein "Connected" am Ende?
                          Android51 last edited by Android51
                          Ich habe die gleichen Fehlermeldungen mit der Kamera Tapo C520WS
                          023-10-18 21:50:06.558 - error: tapo.0 (3192) callback.call is not a function
                          2023-10-18 21:50:06.611 - info: tapo.0 (3192) terminating
                          2023-10-18 21:50:06.614 - warn: tapo.0 (3192) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2023-10-18 21:50:06.832 - error: host.raspberrypi-iobroker Caught by controller[0]: TypeError: callback.call is not a function
                          2023-10-18 21:50:06.833 - error: host.raspberrypi-iobroker Caught by controller[0]: at Cam. (/opt/iobroker/node_modules/onvif/lib/events.js:309:14)
                          2023-10-18 21:50:06.833 - error: host.raspberrypi-iobroker Caught by controller[0]: at parseSOAPString (/opt/iobroker/node_modules/onvif/lib/utils.js:108:3)
                          2023-10-18 21:50:06.833 - error: host.raspberrypi-iobroker Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/onvif/lib/cam.js:297:4)
                          2023-10-18 21:50:06.834 - error: host.raspberrypi-iobroker Caught by controller[0]: at IncomingMessage.emit (node:events:525:35)
                          2023-10-18 21:50:06.834 - error: host.raspberrypi-iobroker Caught by controller[0]: at IncomingMessage.emit (node:domain:489:12)
                          2023-10-18 21:50:06.834 - error: host.raspberrypi-iobroker Caught by controller[0]: at endReadableNT (node:internal/streams/readable:1358:12)
                          2023-10-18 21:50:06.834 - error: host.raspberrypi-iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:83:21)
                          2023-10-18 21:50:06.834 - error: host.raspberrypi-iobroker instance system.adapter.tapo.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2023-10-18 21:50:06.834 - info: host.raspberrypi-iobroker Restart adapter system.adapter.tapo.0 because enabled
                            Michaelnorge @Android51 last edited by
                            @android51 Hast Du zufällig auch andere Geräte von TAPO (Steckdosen) die die Tapo-App bei dem letzten Update selbstständig gefunden und mit in seine Liste eingefügt hat?
                            Bin immer noch auf Fehlersuche....
                              Android51 @Michaelnorge last edited by
                              @michaelnorge
                              Nein, ich habe nur die eine Kamera. Habe auch in den Einstellungen der App erstmal soweit es geht alle Features deaktiviert. Dennoch funktioniert es nicht.
                              Bekomme immer wieder diese Fehlermeldungen.
                                tombox @mylan last edited by
                                @mylan Bitte die GitHub version testen die sollte die neue firmware unterstützen
                                M M 3 Replies Last reply Reply Quote 0
                                  @tombox Habe nun alle Objekte gelöscht, die alte Version runtergeschmissen und die aus github direkt installiert, Zugangsdaten eingegeben, den MFA-Code eingegeben und die Instanz gestartet.
                                  Im Moment schweigt das Log, ich beobachte mal weiter....
                                  Zusatz:
                                  Ich habe eine Innenkamera an eine Schaltsteckdose angeschlossen, die schaltet aus Gründen der Privatsphäre die Kamera nur dann an wenn niemand zu Hause ist.
                                  Bei dieser Version kommt alle zwei Sekunden folgende Warnung ins Log:
                                  "FetchError: request to https://192.168.178.159/ failed, reason: connect EHOSTUNREACH 192.168.178.159:443"
                                    @tombox Mir scheint das der Adapter jetzt super seinen Dienst tut!
                                    Vielen lieben Dank und ein schönes Wochenende!!!
                                      mylan @tombox last edited by
                                      @tombox
                                      Ja danke, in einem ersten Test kann ich eine P100 mit neuer Firmware wieder steuern! 🙂
                                        @tombox Mein ProxMox macht nachts ein Backup von ioBroker.
                                        Danach kommen die gleichen Fehler wieder ins Log, (sprich "tapo.0 (2311) callback.call is not a function") wahrscheinlich weil ProxMox für das Backup das System kurzzeitig stoppt und der Adapter damit nicht klar kommt.
                                          @michaelnorge
                                          Werde das heute Abend auch mal testen mit der Version. Mache auch nachts ein Backup. Werde berichten, wie es sich bei mir verhält.
                                            Ich habe jetzt die Version 0.1.0 installiert und die Probleme bestehen weiterhin. Es kommen die gleichen Fehlermeldungen wie oben beschrieben.
                                            @Michaelnorge
                                            Was hast du denn bei MFA eingegeben? Der Code ändert sich doch stetig?! Ich dachte, man müsste MFA in der Handy-App deaktivieren.
                                            753
                                            189072
