    2. English
    3. Development
    4. New Adapter - Soliscloud
      Schneider_Helmut @mcm1957 last edited by Schneider_Helmut
      @Trixx
      If I want to install the adapter over this link
      https://github.com/Trixx34/ioBroker.SolisCloud
      I get this error message:
      ERROR: Process exited with code 25
      Siobroker url https://github. com/Trixx34/ioBroker SolisCloud --host raspberrypi debug install Trixx34/ioBroker.SolisCloud#b39242521a5f9f1b7eee929cc658b9b1c4af0f70
      NPM version: 8.19.4
      Installing Trixx34/ioBroker. SolisCloud#b39242521a5f9f1b7eee929cc6589b1c4af0170... (System call) npm WARN skipping integrity check for git dependency ssh://git@github.com/Trixx34/ioBroker.SolisCloud.git
      added 76 packages in 1m126 packages are looking for funding run npm fund for details
      pm WARN skipping integrity check for git dependency ssh://git@github.com/Trixx34/ioBroker SolisCloud git host.raspberrypi
      Cannot install Trixx34/ioBroker. SolisCloud#b39242521a5f9f1b7eee929cc658b9b1c4af0f70: 0
      MOD-EDIT: added code tags!
      mcm1957 Trixx 4 Replies Last reply Reply Quote 0
      • mcm1957
        mcm1957 @Schneider_Helmut last edited by mcm1957
        @schneider_helmut
        Sorry to say - this adapter is not written or maintained by me. I only created the links from the german forum part.
        For support please mention @Trixx
        mcm1957
        P.S. NOT releated to you feedback but a general remark to this adapter. Please respect that this is Trix's first adapter, a short code review looked very good. So please be patient if required - we all had to learn. I'll take a look later if I can see whats the problem.
        • Trixx
          Trixx @Schneider_Helmut last edited by
          @schneider_helmut
          Could you try again and activate the debug option active ? Maybe we'll find out more then.
          Which versions of iobroker / npm / node are you running on your system ?
          In the logging I see the npm version is 8.19.4.
          My versions on my test setup are:
          • iobroker: 5.0.12
          • npm: 9.8.1
          • node: 20.6.1
          Thanks for testing.
            Homoran Global Moderator Administrators @Trixx last edited by
            @trixx sagte in New Adapter - Soliscloud:
            iobroker: 5.0.12
            npm: 9.8.1
            node: 20.6.1
            node v20 isn't yet recommended for iobroker!
            the recommended version is 18
            Trixx 1 Reply Last reply Reply Quote 0
            • Trixx
              Trixx @Homoran last edited by
              @homoran said in New Adapter - Soliscloud:
              iobroker: 5.0.12
              npm: 9.8.1
              node: 20.6.1
              Oh, I'll have to fix that on my system and retest!
              • Trixx
                @schneider_helmut said in New Adapter - Soliscloud:
                @Trixx
                Could you try using: https://github.com/Trixx34/ioBroker.soliscloud (without caps).
                Homoran S 2 Replies Last reply Reply Quote 0
                  without caps
                  I fixed this in both threads.
                  please tell me if there are more typos
                  • mcm1957
                    @schneider_helmut
                    @Trixx
                    I tried now and the installation worked as expected (I did not test the functionality).
                    BUT a look at the console output look a little supect:
                    For me, there seems to be a SPACE between the dot and the S of SolisCloud. Please retry and check your input.
                    I do not think that capital letters cause a problem here, as urls are case insensitive.
                      Homoran Global Moderator Administrators @mcm1957 last edited by
                      @mcm57 sagte in New Adapter - Soliscloud:
                      @schneider_helmut sagte in New Adapter - Soliscloud:
                      here it is, too!
                        Schneider_Helmut @Trixx last edited by Schneider_Helmut
                        @trixx
                        Thank you. Everything works great now. Grate job! I waited over a year for a Solis adapter for IO Broker because I wasn't able to use the Solis API myself.
                        Perhaps it would be important to mention that for "Station/Plant ID" you do not have to enter the ID "1668XX" from the Soli portal as expected, but rather the id from the browser address while you are logged in to your solis account "https://www.soliscloud.com/#/station/stationdetail_1?id=12984919194490002YY". "Station/Plant ID" must be entered here "12984919194490002YY".
                        Trixx M T 2 Replies Last reply Reply Quote 0
                        • Trixx
                          @Schneider_Helmut
                          Good to hear everything is working now for you!
                          You're correct on the information regarding the plant ID, I'll update the documentation to make that more clear.
                          If there's any value you are missing and would like to have available in in ioBroker, let me know and I'll see what I can do!
                          Regards,
                          Trixx
                            @trixx
                            I really appreciate your support. Your adapter will be very useful to Solis as people increasingly want to network systems. I can't understand why manufacturers don't make an effort to open up to common automation solutions and offer adapters themselves. For example, I have been looking for a wallbox for months where the manufacturer offers an IoBroker adapter with which I can start charging via IO-Broker and specify the charging current for the car myself.
                            And I still did not find one.
                            • Trixx
                              Trixx @Schneider_Helmut last edited by Trixx
                              The latest version on github is broken, I broke it while trying to fix something else...
                              I'll try fixing this tonight.
                              Edit; small fix. Already ok again
                                Luapsi @Trixx last edited by
                                @trixx
                                I am also interested in the “Soliscloud” adapter.
                                The installation was successful, unfortunately I can't get any further with the settings so that access to the SolisCloud is possible.
                                No SolisCloud is displayed in the instances, but that's okay in the objects?
                                I have already activated the Solis API.
                                I have only recently started using ioBroker.
                                Thk Sven
                                Trixx Homoran 2 Replies Last reply Reply Quote 0
                                • Trixx
                                  Trixx @Luapsi last edited by
                                  @luapsi
                                  Thanks for trying my adapter. Once the install from github is completed, you should now be able to find the solis adapter in the "adapters" screen.
                                  From there you should be able to add an instance of the adapter to your ioBroker installation. Once the instance is installed, it will take you directly to the configuration screen.
                                    Homoran Global Moderator Administrators @Luapsi last edited by
                                    @luapsi sagte in New Adapter - Soliscloud:
                                    that is the regular behavior by installing via github.
                                    The instance has to be added manually
                                      Luapsi @Homoran last edited by
                                      Hello, I just found it in the documentation.
                                      Thank you very much:)
                                        battery_current_usage
                                        hi @trixx,
                                        The SolisCloud adapter also works for me. Thank you for your implementation.
                                        As you requested, it would be great if these values ​​could be added:
                                        from the Power Station List:
                                        1. batteryTodayDischargeEnergy
                                        2. batteryTodayChargeEnergy
                                        3. homeLoadTodayEnergy
                                        4. state
                                        5. oneSelf
                                        from the Inverter List:
                                        1. eToday
                                        2. etodayStr
                                        3. state
                                        Gerne teste ich für Dich!
                                        • Trixx
                                          @luapsi said in New Adapter - Soliscloud:
                                          hi @trixx,
                                          4. state
                                          5. oneSelf
                                          1. eToday
                                          2. etodayStr
                                          3. state
                                          Thanks for the suggestions, I'll see what I can do. The first 5 shouldn't be to much work, I should be able to do that right away. The other ones require an additional API call, but still shouldn't be a problem.
                                          I'll let you know once I have an update on this.
                                          L 2 Replies Last reply Reply Quote 1
                                            @trixx
                                            hi @Trixx
                                            thank you for taking the suggestions!
                                            Here's a little addition!
                                            In ioBroker, instances are assigned a category!
                                            Would you be so kind as to put your instance in the “Energy” category?
                                            Here is an excerpt from instances in this category
                                            Thx Sven
                                            57
                                            8520
