(erledigt) Zigbee Adapter startet nicht
@dp20eic
Bitte schön
======== Start marking the full check here ========= Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi2 Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v7+ Architecture: arm Model : Raspberry Pi 2 Model B Rev 1.1 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 17:45:09 up 23:50, 1 user, load average: 0.23, 0.07, 0.02 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Fri 2023-10-13 17:45:09 CEST Universal time: Fri 2023-10-13 15:45:09 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 921M 236M 409M 0.0K 276M 628M Swap: 99M 0B 99M Total: 1.0G 236M 509M 921 M total memory 236 M used memory 174 M active memory 276 M inactive memory 409 M free memory 54 M buffer memory 221 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 15G 3.4G 11G 25% / devtmpfs devtmpfs 333M 0 333M 0% /dev tmpfs tmpfs 461M 0 461M 0% /dev/shm tmpfs tmpfs 185M 948K 184M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 255M 51M 205M 20% /boot tmpfs tmpfs 93M 0 93M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Thu Oct 12 17:54:32 2023] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyAMA0,115200 console=tty1 root=PARTUUID=984cb146-02 rootfstype=ext4 fsck.repair=yes rootwait [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): recovery complete [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Thu Oct 12 17:54:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Thu Oct 12 17:54:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 894M /var/ 574M /var/log 417M /var/log/journal/d396ac506ad544c8953772923028cd1b 417M /var/log/journal 120M /var/cache Archived and active journals take up 416.0M in the file system. /opt/iobroker/backups: 2.4M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 103M /opt/iobroker/iobroker-data/ 74M /opt/iobroker/iobroker-data/files 52M /opt/iobroker/iobroker-data/files/javascript.admin 34M /opt/iobroker/iobroker-data/files/javascript.admin/static 33M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 7.8M /opt/iobroker/iobroker-data/objects.jsonl 7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map 5.8M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map 4.6M /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00 *** NodeJS-Installation *** /usr/bin/nodejs v18.18.1 /usr/bin/node v18.18.1 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 nodejs: Installed: 18.18.1-1nodesource1 Candidate: 18.18.1-1nodesource1 Version table: *** 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. At least one iobroker host is running. Objects type: file States type: file Core adapters versions js-controller: 5.0.12 admin: 6.10.1 javascript: 7.1.4 Adapters from github: 0 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.4, run as: admin system.adapter.alexa2.0 : alexa2 : iobroker - disabled system.adapter.alias-manager.0 : alias-manager : iobroker - enabled + system.adapter.backitup.0 : backitup : iobroker - enabled system.adapter.daswetter.0 : daswetter : iobroker - enabled + system.adapter.device-watcher.0 : device-watcher : iobroker - enabled + system.adapter.discovery.0 : discovery : iobroker - enabled + system.adapter.echarts.0 : echarts : iobroker - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker - enabled + system.adapter.energiefluss.0 : energiefluss : iobroker - enabled + system.adapter.energiefluss.1 : energiefluss : iobroker - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : iobroker - enabled system.adapter.flot.0 : flot : iobroker - enabled + system.adapter.fronius.0 : fronius : iobroker - enabled + system.adapter.heatingcontrol.0 : heatingcontrol : iobroker - enabled + system.adapter.heizoel.0 : heizoel : iobroker - enabled + system.adapter.history.0 : history : iobroker - enabled + system.adapter.hm-rega.0 : hm-rega : iobroker - enabled + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 8701 system.adapter.ical.0 : ical : iobroker - enabled system.adapter.icons-icons8.0 : icons-icons8 : iobroker - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - enabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker - enabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086 + system.adapter.info.0 : info : iobroker - enabled + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.javascript.1 : javascript : raspberrypi2 - enabled + system.adapter.linux-control.0 : linux-control : iobroker - enabled + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.4 + system.adapter.mqtt.1 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.nut.0 : nut : iobroker - enabled + system.adapter.openligadb.0 : openligadb : iobroker - enabled system.adapter.openweathermap.0 : openweathermap : iobroker - enabled + system.adapter.operating-hours.0 : operating-hours : iobroker - enabled + system.adapter.ping.0 : ping : iobroker - enabled + system.adapter.proxmox.0 : proxmox : iobroker - enabled, port: 8006 + system.adapter.resol.0 : resol : iobroker - enabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1883, bind: 192.168.178.4 + system.adapter.shuttercontrol.0 : shuttercontrol : iobroker - enabled + system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1885, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled system.adapter.telegram.0 : telegram : iobroker - disabled, port: 8443, bind: 0.0.0.0 + system.adapter.tr-064.0 : tr-064 : iobroker - enabled + system.adapter.trashschedule.0 : trashschedule : iobroker - enabled + system.adapter.tuya.0 : tuya : iobroker - enabled + system.adapter.upnp.0 : upnp : iobroker - enabled system.adapter.vis-bars.0 : vis-bars : iobroker - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - enabled system.adapter.vis-history.0 : vis-history : iobroker - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - enabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled system.adapter.vis-justgage.0 : vis-justgage : iobroker - enabled system.adapter.vis-plumb.0 : vis-plumb : iobroker - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - enabled system.adapter.vis-weather.0 : vis-weather : iobroker - enabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : raspberrypi2 - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00 + system.adapter.zigbee2mqtt.0 : zigbee2mqtt : iobroker - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.4, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 8701 + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.4 + system.adapter.mqtt.1 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.proxmox.0 : proxmox : iobroker - enabled, port: 8006 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1883, bind: 192.168.178.4 + system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1885, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.10.1 , installed 6.10.1 Adapter "backitup" : 2.8.1 , installed 2.6.23 [Updatable] Adapter "deconz" : 1.3.21 , installed 1.3.21 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "zigbee" : 1.8.23 , installed 1.8.23 Objects and States Please stand by - This may take a while Objects: 22288 States: 19027 *** OS-Repositories and Updates *** Hit:1 http://phoscon.de/apt/deconz bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 5 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13985 437/sshd: /usr/sbin tcp6 0 0 :::22 :::* LISTEN 0 13987 437/sshd: /usr/sbin udp 0 0 0.0.0.0:68 0.0.0.0:* 0 1712 536/dhcpcd udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 13885 328/avahi-daemon: r udp 0 0 0.0.0.0:46530 0.0.0.0:* 108 13887 328/avahi-daemon: r udp6 0 0 :::53325 :::* 108 13888 328/avahi-daemon: r udp6 0 0 :::5353 :::* 108 13886 328/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-10-13 13:48:53.686 - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice') 2023-10-13 13:48:53.698 - error: zigbee.0 (3202) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-10-13 13:48:53.700 - error: zigbee.0 (3202) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice') 2023-10-13 13:48:53.703 - error: zigbee.0 (3202) TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21) 2023-10-13 13:48:53.705 - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice') 2023-10-13 13:48:55.306 - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-10-13 13:48:55.308 - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled 2023-10-13 13:49:01.630 - info: host.raspberrypi2 "system.adapter.zigbee.0" disabled 2023-10-13 13:49:42.820 - error: zigbee.0 (3218) adapter disabled 2023-10-13 13:49:43.820 - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND) 2023-10-13 13:49:43.823 - info: host.raspberrypi2 Do not restart adapter system.adapter.zigbee.0 because disabled or deleted 2023-10-13 16:03:53.346 - error: host.raspberrypi2 Objects database error: read ECONNRESET 2023-10-13 16:03:53.345 - error: javascript.1 (550) Objects database error: read ECONNRESET 2023-10-13 16:03:58.380 - error: host.raspberrypi2 Objects database error: connect ECONNREFUSED 192.168.178.4:9001 2023-10-13 16:03:58.424 - error: javascript.1 (550) Objects database error: connect ECONNREFUSED 192.168.178.4:9001 2023-10-13 16:04:00.227 - error: host.raspberrypi2 States database error: read ECONNRESET 2023-10-13 16:04:01.512 - error: javascript.1 (550) States database error: read ECONNRESET 2023-10-13 16:04:03.397 - info: host.raspberrypi2 Objects database successfully reconnected 2023-10-13 16:04:05.240 - info: host.raspberrypi2 Objects database successfully reconnected============ Mark until here for C&P =============
iob diag has finished.
@hm_krause sagte in Zigbee Adapter startet nicht:
Bitte schön
Moin,
ist das eine Master/Slave Installation?
Auch das wäre dann schon am Anfang von Interesse gewesen!Du hast auf dem
RasPI-2nochDeconzinstalliert, kann das sein, dass sich das mit demZigbee - Adapterbeißt?VG
Bernd -
@dp20eic sagte in Zigbee Adapter startet nicht:
Bitte schön
Moin,
...Stand im 1. Beitrag und Deconz ist deinstalliert
Moin,
ok, das kleine geklammerte
Slavehabe ich überlesen.
Aberdekonzwird mir doch in der Liste des RasPI-2 aufgelistetInstalled ioBroker-Instances Used repository: stable Adapter "admin" : 6.10.1 , installed 6.10.1 Adapter "backitup" : 2.8.1 , installed 2.6.23 [Updatable] Adapter "deconz" : 1.3.21 , installed 1.3.21 <------ Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "zigbee" : 1.8.23 , installed 1.8.23VG
Bernd -
@dp20eic
Deconz ist aber weder in der Instanz noch im Adapter zu sehen.
pi@raspberrypi2:~ $ sudo systemctl status deconz Unit deconz.service could not be found. pi@raspberrypi2:~ $ -
Moin,
kenne mich mit Master/Slave nicht wirklich aus, gerade wenn auch mal umgeschaltet wurde und dann Adapter installiert, oder deinstalliert werden.
Da müssen andere helfen, da stocher ich nur im Trüben.Wenn das nicht zu viel Arbeit ist, würde ich den ganz neu von vorne aufsetzen.
VG
BerndP.S.: sehe gerade, Du suchst den Service, ich schrieb vom Adapter im
ioBroker -
@dp20eic
Werde alles nochmal neu machen, Danke -
@hm_krause
Läuft noch nicht.
Master als VM auf Proxmox
Slave komplett neu auf Raspi 4.
Wenn ich mit der Maus auf dem roten Kreis bin zeigt eine Verbindung mit Gerät oder Dienst an (grün)
Die beiden anderen, Verbunden mit Host und Lebensszeichen, bleiben rothost.iob-oben 2023-10-15 14:51:25.836 warn Do not restart adapter system.adapter.zigbee.0 because restart loop detected host.iob-oben 2023-10-15 14:51:25.836 info Restart adapter system.adapter.zigbee.0 because enabled host.iob-oben 2023-10-15 14:51:25.835 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) zigbee.0 2023-10-15 14:51:24.417 error this.zbController.getGroup is not a function zigbee.0 2023-10-15 14:51:24.416 error TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21) zigbee.0 2023-10-15 14:51:24.413 error unhandled promise rejection: this.zbController.getGroup is not a function zigbee.0 2023-10-15 14:51:24.411 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). host.iob-oben 2023-10-15 14:51:16.312 info instance system.adapter.zigbee.0 started with pid 1125 host.iob-oben 2023-10-15 14:50:45.849 info Restart adapter system.adapter.zigbee.0 because enabled host.iob-oben 2023-10-15 14:50:45.848 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) zigbee.0 2023-10-15 14:50:44.412 error this.zbController.getGroup is not a function zigbee.0 2023-10-15 14:50:44.411 error TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21) zigbee.0 2023-10-15 14:50:44.408 error unhandled promise rejection: this.zbController.getGroup is not a function zigbee.0 2023-10-15 14:50:44.406 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). host.iob-oben 2023-10-15 14:50:37.187 info instance system.adapter.zigbee.0 started with pid 1109 host.iob-oben 2023-10-15 14:50:06.660 info Restart adapter system.adapter.zigbee.0 because enabled host.iob-oben 2023-10-15 14:50:06.659 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) zigbee.0 2023-10-15 14:50:04.658 error this.zbController.getGroup is not a function zigbee.0 2023-10-15 14:50:04.657 error TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21) zigbee.0 2023-10-15 14:50:04.654 error unhandled promise rejection: this.zbController.getGroup is not a function zigbee.0 2023-10-15 14:50:04.652 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). host.iob-oben 2023-10-15 14:49:56.318 info instance system.adapter.zigbee.0 started with pid 1092 host.iob-oben 2023-10-15 14:49:55.849 info "system.adapter.zigbee.0" enabledNoch jemand vielleicht eine Idee..?
@hm_krause said in Zigbee Adapter startet nicht:
Moin,
natürlich, vom
SlavedielangeAusgabe von# iob diagWelche Version vom
Zigbe Adapter, vielleicht mal dieGithubVersion getestet?Schon mal darüber nachgedacht, mittels
LAN/WLAN Zigbee Stickzu arbeiten, den kann man besser im Haus positionieren als die, die über USB angeschlossen sind, dann noch gescheite Repeater und man bekommt auch ein stabiles Zigbee Mesh hin.
Network -> https://www.zigbee2mqtt.io/guide/adapters/#recommended- Tube's Zigbee Gateways (CC2652P2 variant) - cyijun OpenZ3Gateway - XGG 52PZ2MGateway - SMLIGHT Zigbee LAN Adapter CC2652P Model SLZB-05 - cod.m ZigBee CC2652P2 TCP CoordinatorVG
Bernd -
@dp20eic
Ich habe jetzt aufgegeben und einen seperaten Iobroker auf den Raspi gebracht.
Der Stick funktioniert tadellos.
