    3. Off Topic
    4. Raspberry Pi OS Lite 'Bookworm' ist da.
    • mickym
      mickym Most Active @Homoran last edited by
      @homoran OK habs gesehen - ich lasse es aber jetzt - jedenfalls funktioniert es ohne den Netzwerk manager.
        reutli @MartyBr last edited by reutli
        @martybr
        @Thomas-Braun
        So jetzt hänge ich bei der Slave Geschichte.
        Was habe ich gemacht:
        • neue SD Karte mit bookworm Image erstellt
        • gleicher Hostname und IP
        • iobroker auf Slave installiert
        pi@iobroker2:~ $ curl -sLf https://iobroker.net/install.sh | bash -
        library: loaded
        Library version=2023-10-13
            Welcome to the ioBroker installer!
            Installer version: 2023-10-13
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
        Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
        Get:3 http://archive.raspberrypi.com/debian bookworm InRelease [23.6 kB]
        Get:4 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
        Get:5 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [77.0 kB]
        Get:6 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [74.5 kB]
        Get:7 http://deb.debian.org/debian-security bookworm-security/main Translation-en [46.0 kB]
        Get:8 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [337 kB]
        Get:9 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [345 kB]
        Fetched 1,003 kB in 3s (386 kB/s)
        Reading package lists... Done
        N: Repository 'http://archive.raspberrypi.com/debian bookworm InRelease' changed its 'Suite' value from 'testing' to 'stable'
            Node.js not found. Installing...
        Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Building dependency tree... Done
        ca-certificates is already the newest version (20230311).
        gnupg is already the newest version (2.2.40-1.1).
        gnupg set to manually installed.
        The following packages will be upgraded:
          curl libcurl3-gnutls libcurl4
        3 upgraded, 0 newly installed, 0 to remove and 11 not upgraded.
        Need to get 1,035 kB of archives.
        After this operation, 0 B of additional disk space will be used.
        Get:1 http://deb.debian.org/debian-security bookworm-security/main arm64 curl arm64 7.88.1-10+deb12u4 [308 kB]
        Get:2 http://deb.debian.org/debian-security bookworm-security/main arm64 libcurl4 arm64 7.88.1-10+deb12u4 [366 kB]
        Get:3 http://deb.debian.org/debian-security bookworm-security/main arm64 libcurl3-gnutls arm64 7.88.1-10+deb12u4 [361 kB]
        Fetched 1,035 kB in 0s (3,235 kB/s)
        apt-listchanges: Reading changelogs...
        (Reading database ... 55058 files and directories currently installed.)
        Preparing to unpack .../curl_7.88.1-10+deb12u4_arm64.deb ...
        Unpacking curl (7.88.1-10+deb12u4) over (7.88.1-10+deb12u3) ...
        Preparing to unpack .../libcurl4_7.88.1-10+deb12u4_arm64.deb ...
        Unpacking libcurl4:arm64 (7.88.1-10+deb12u4) over (7.88.1-10+deb12u3) ...
        Preparing to unpack .../libcurl3-gnutls_7.88.1-10+deb12u4_arm64.deb ...
        Unpacking libcurl3-gnutls:arm64 (7.88.1-10+deb12u4) over (7.88.1-10+deb12u3) ...
        Setting up libcurl3-gnutls:arm64 (7.88.1-10+deb12u4) ...
        Setting up libcurl4:arm64 (7.88.1-10+deb12u4) ...
        Setting up curl (7.88.1-10+deb12u4) ...
        Processing triggers for man-db (2.11.2-2) ...
        Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
         Processing triggers for man-db (2.11.2-2) ...ource1_arm64.deb ...led.)
        Installed nodejs
        Node.js Installed successfully!
        Changing npm registry to https://registry.npmjs.org
         Processing triggers for man-db (2.11.2-2) ...arm64.deb ... installed.)
        Installed acl
         Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-10) ...-10_arm64.deb ...
        Installed libavahi-compat-libdnssd-dev
         Processing triggers for man-db (2.11.2-2) ...1) ...1_arm64.deb ...ed.)
        Installed libudev-dev
         Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) .....m64.deb ...pt2) ...
        Installed libpam0g-dev
         Processing triggers for man-db (2.11.2-2) ...m64.deb ......installed.)
        Installed git
        Extracting templates from packages: 100%
         Setting up libcairo2-dev:arm64 (1.16.0-7+rpt1) ....u3) ...t1) .........rm64.deb ...
        Installed libcairo2-dev
         Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...m64.deb ... ....
        Installed libpango1.0-dev
         Setting up libjpeg-dev:arm64 (1:2.1.5-2) ...5-2) ...4.deb ....deb ...)
        Installed libjpeg-dev
         Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ... installed.)
        Installed libgif-dev
         Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.10+dfsg-1+b1) ..........
        Installed librsvg2-dev
         Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) .....nstalled.)
        Installed cmake
            Creating ioBroker user and directory (2/4)
        User iobroker created
        Created /etc/sudoers.d/iobroker
        Directory /opt/iobroker created
            Installing ioBroker (3/4)
            Finalizing installation (4/4)
        Enabling autostart...
        Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
        Autostart enabled!
        Fixing directory permissions...
            ioBroker was installed successfully
            Open http://192.168.200.42:8081 in a browser and start configuring!
        You need to re-login before doing anything else on the console!
        • Update gemacht
        pi@iobroker2:~ $ sudo apt update
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        6 packages can be upgraded. Run 'apt list --upgradable' to see them.
        pi@iobroker2:~ $ sudo apt full-upgrade
        Calculating upgrade... Done
          libssl3 libwbclient0 openssl raspberrypi-net-mods raspi-config raspi-utils
        6 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Need to get 3,342 kB of archives.
        After this operation, 57.3 kB of additional disk space will be used.
        Do you want to continue? [Y/n] Y
        Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 libssl3 arm64 3.0.11-1~deb12u1+rpt1 [1,808 kB]
        Get:2 http://deb.debian.org/debian-security bookworm-security/main arm64 libwbclient0 arm64 2:4.17.12+dfsg-0+deb12u1 [52.8 kB]
        Get:3 http://archive.raspberrypi.com/debian bookworm/main arm64 openssl arm64 3.0.11-1~deb12u1+rpt1 [1,384 kB]
        Get:4 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-config all 20231013 [29.4 kB]
        Get:5 http://archive.raspberrypi.com/debian bookworm/main arm64 raspberrypi-net-mods all 1.4.0 [2,160 B]
        Get:6 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils arm64 20231013-1 [65.8 kB]
        Fetched 3,342 kB in 1s (4,305 kB/s)
        Reading changelogs... Done
        (Reading database ... 68262 files and directories currently installed.)
        Preparing to unpack .../0-libssl3_3.0.11-1~deb12u1+rpt1_arm64.deb ...
        Unpacking libssl3:arm64 (3.0.11-1~deb12u1+rpt1) over (3.0.11-1~deb12u1) ...
        Preparing to unpack .../1-libwbclient0_2%3a4.17.12+dfsg-0+deb12u1_arm64.deb ...
        Unpacking libwbclient0:arm64 (2:4.17.12+dfsg-0+deb12u1) over (2:4.17.11+dfsg-0+deb12u1) ...
        Preparing to unpack .../2-openssl_3.0.11-1~deb12u1+rpt1_arm64.deb ...
        Unpacking openssl (3.0.11-1~deb12u1+rpt1) over (3.0.11-1~deb12u1) ...
        Preparing to unpack .../3-raspi-config_20231013_all.deb ...
        Unpacking raspi-config (20231013) over (20231009) ...
        Preparing to unpack .../4-raspberrypi-net-mods_1.4.0_all.deb ...
        Unpacking raspberrypi-net-mods (1.4.0) over (1.3.4) ...
        Preparing to unpack .../5-raspi-utils_20231013-1_arm64.deb ...
        Unpacking raspi-utils (20231013-1) over (20230922+1-1~rc1) ...
        Setting up libssl3:arm64 (3.0.11-1~deb12u1+rpt1) ...
        Setting up raspi-utils (20231013-1) ...
        Setting up libwbclient0:arm64 (2:4.17.12+dfsg-0+deb12u1) ...
        Setting up openssl (3.0.11-1~deb12u1+rpt1) ...
        Setting up raspi-config (20231013) ...
        Setting up raspberrypi-net-mods (1.4.0) ...
        pi@iobroker2:~ $ sudo reboot
        Broadcast message from root@iobroker2 on pts/1 (Sun 2023-10-15 17:47:04 CEST):
        The system will reboot now!
        • alle Adapter gelöscht - Ergebnis:
        pi@iobroker2:~ $ iob list adapters
        • Multihost Connect versucht - keine Reaktion auch nach langer Zeit:
        pi@iobroker2:~ $ iobroker multihost connect
        • dann config versucht - keine Reaktion
        iob setup custom
        Current configuration:
        - Objects database:
          - Type: jsonl
          - Host/Unix Socket: 127.0.0.1
          - Port: 9001
        - States database:
          - Type: jsonl
          - Port: 9000
        - Data Directory: ../../iobroker-data/
        Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
        Host / Unix Socket of objects DB(jsonl), default[127.0.0.1]: 192.168.200.5
        Port of objects DB(jsonl), default[9001]:
        Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [jsonl]:
        Host / Unix Socket of states DB (jsonl), default[192.168.200.5]:
        Port of states DB (jsonl), default[9000]:
        Host name of this machine [iobroker2]:
        updating conf/iobroker.json
        • reboot und nochmals versucht (hier steht die Maschine nun ohne weitere Reaktion):
        Broadcast message from root@iobroker2 on pts/1 (Sun 2023-10-15 18:12:16 CEST):
        pi@iobroker2:~ $ Connection to 192.168.200.42 closed by remote host.
        Connection to 192.168.200.42 closed.
        micha@iMac-Micha ~ % ssh pi@192.168.200.42
        pi@192.168.200.42's password:
        Linux iobroker2 6.1.0-rpi4-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.54-1+rpt2 (2023-10-05) aarch64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Sun Oct 15 17:50:25 2023 from 192.168.200.167
        Zusätzlich auf dem Master:
        admin@macmini-iobroker:~$ iob multihost enable
        Multihost discovery server activated on this host. If iobroker is currently not running please start befeore trying to discover this host.
        Important: Multihost discovery works with UDP packets. Make sure they are routed correctly in your network. If you use Docker you also need to configure this correctly.
        Multihost discovery will be automatically deactivated after 15 minutes. If you want to activate it permanently use the --persist flag
        Discovery authentication activated.
        Enter secret phrase for connection:
        Repeat secret phrase for connection:
        Please check the binding of the configured jsonl server to allow remote connections.
        Please restart ioBroker for the changes to take effect: "iobroker restart"
        Multihost discovery server: enabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    jsonl on 0.0.0.0
        States:                     jsonl on 0.0.0.0
        sudo reboot
        ^C
        admin@macmini-iobroker:~$ sudo reboot
        [sudo] Passwort für admin:
        Connection to 192.168.200.5 closed by remote host.
        Connection to 192.168.200.5 closed.
        micha@iMac-Micha ~ % ssh admin@192.168.200.5
        admin@192.168.200.5's password:
        Linux macmini-iobroker 5.10.0-26-amd64 #1 SMP Debian 5.10.197-1 (2023-09-29) x86_64
        Last login: Sun Oct 15 18:09:41 2023 from 192.168.200.167
        admin@macmini-iobroker:~$ iob status
        Objects type: jsonl
        States  type: jsonl
        admin@macmini-iobroker:~$ iob multihost status
        No configuration change needed.
        Jetzt habe ich keine Idee mehr, wie ich den Slave reinbekomme...
        • mickym
          mickym Most Active @Marc Berg last edited by mickym
          @marc-berg Na ja ich weiß jedenfalls wo ich suchen muss - aber da werden wohl wieder einige drüber stolpern. Ich bekomm da echt die Krise.
          Hier ist die Lösung: https://forum.iobroker.net/topic/69165/raspberry-networkmanager-keine-ipv6-verbindung-von-extern
            Homoran Global Moderator Administrators @reutli last edited by
            @reutli sagte in Raspberry Pi OS Lite 'Bookworm' ist da.:
            welche Node-Version? mit 18.18.0 gabs Probleme
              reutli @Homoran last edited by
              auf demSlave:
              pi@iobroker2:~ $ node -v
              v18.18.2
                auf demSlave:
                v18.18.2
                und auf dem Master?
                  MartyBr @MartyBr last edited by
                  @reutli
                  Hast du auch die js-controller downgegraded? Das hat bei mir geholfen.
                  @martybr sagte in Raspberry Pi OS Lite 'Bookworm' ist da.:
                  @reutli
                  Ich habe es nun für mich gelöst. Das Problem war der io.js-controller. Ich habe ihn auf dem Master auf 5.0.11 und den Slave auf 4.0.24 downgegraded und dann konnte ich den Slave mit dem Master verbinden. Danach war es Easy.
                  Auf dem Slave habe ich nur 3 Adapter laufen: BLE, SmartMeter und W-MBUS.
                  Die Einstellungen und die USB-Verbindungen wurden auf dem Slave sauber erkannt. Bluetooth läuft unter Bookworm out of the Box. Keinerlei Verrenkungen mehr mit hciconfig etc.
                  Zu Zigbee kann ich dir keinen Bericht geben, das läuft bei mir auf dem Master (auch Debian 12 Bookworm). Hier ohne Probleme. Der Master wurde aber nur upgedated und nicht neu erstellt.
                  R Homoran 2 Replies Last reply Reply Quote 0
                    Master:
                    admin@macmini-iobroker:~$ node -v
                    v18.18.0
                    dann ist's der Master? Also mit dem fixer-script von @Thomas-Braun ?
                      @reutli
                      wenn notwendig... wie?
                      Will ich auf'm master ungern machen (da rennt 'ne Menge)...
                      @Homoran reicht der Node-Update?
                        @reutli ich hab das nicht mehr zu Ende verfolgt.
                        Ich kann es daher nicht versprechen
                          Habe auf'm Master nun 18.18.2 leider bleibt das Problem:
                          ioBroker nodejs fixer 2023-10-09
                          Recommended nodejs-version is: 18.18.2
                          Checking your installation now. Please be patient!
                          Your current setup is:
                          /usr/bin/nodejs 	v18.18.2
                          /usr/bin/node 		v18.18.2
                          /usr/bin/npm 		9.8.1
                          /usr/bin/npx 		9.8.1
                          /usr/bin/corepack 	0.19.0
                          We found these nodejs versions available for installation:
                          nodejs:
                            Installed: 18.18.2-1nodesource1
                            Candidate: 18.18.2-1nodesource1
                            Version table:
                           *** 18.18.2-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                  100 /var/lib/dpkg/status
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                               12.22.12~dfsg-1~deb11u4 500
                                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                          Nothing to do - Your installation is using the correct paths.
                          Nothing to do - Your version is the recommended one.
                          ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
                          *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
                           *** DO NOT use 'nodejs-update' as part of a regular update process! ***
                          Multihost discovery server: disabled
                          ^C
                          admin@macmini-iobroker:~$ iobroker restart
                          Auf dem Slave bleibt es beim alten:
                          --> Kiste hängt
                            Homoran Global Moderator Administrators @MartyBr last edited by
                            @reutli
                            mist!
                            dann bleibt wohl nur es so zu versuchen
                            @reutli
                              ähhh, und wie sieht es mit einem 'how to' aus und 'root cause analysis'?
                              Bevor ich da ran gehe, wüsste ich schon, warum js-contoller und vor allem Konsequenzen... habe einen Master (mit viel drauf) und zwei Salzes am rennen als Prod-System- da möchte ich nur berechenbares Risiko eingehen.
                                root cause analysis
                                ich denke das wird gerade gemacht. ich hab das wohlt durcheinander gebracht mit der node version.
                                sieh dir den Thread dazu mal an
                                müsste der von @MartyBr gewesen sein
                                  Ja, habe ich gelesen, weiss aber nicht, warum der downgrade benötigt wird.
                                  Dazu müsste es ja schon was geben.
                                  Wenn ich auf meinem Prod-Master (mit für mich unbekannten Konsequenzen!) ein dorngrade machen soll, dann müsst ich da gerne ein bisschen mehr.
                                  Offen ist auch das 'how to' für das downgrade und wo notwendig...
                                  Da hängt ein ganzes Haus dran....
                                    was?
                                      reutli @Homoran last edited by reutli
                                      @homoran sagte in Raspberry Pi OS Lite 'Bookworm' ist da.:
                                      was?
                                      technische Begründung, Anleitung, welche Version, wo wann in welcher Konstellation (master zu Slave)
                                      Homoran M 2 Replies Last reply Reply Quote 0
                                        Homoran Global Moderator Administrators @reutli last edited by Homoran
                                        was?
                                        Da verlangst du aber ein bischen viel!
                                        der "Fehler" ist doch gerade das erste mal beobachtet worden und versucht einzugrenzen.
                                        Wie soll es da sofirt ein Rundumsorglos Paket geben, wenn es erst einen Fall gibt und das Ganze nicht einmal verifiziert wurde.
                                          MartyBr @reutli last edited by MartyBr
                                          @reutli
                                          Das lief bei mir ohne Probleme ab:
                                          cd /opt/iobroker
                                          npm install iobroker.js-controller@5.0.11
                                            @martybr
                                            Das ist ja genau die Frage(n):
                                            1. warum ist der downgrade in Sachen Multi-Host notwendig?
                                            2. Downgrade auf welchen notwendig? Master und/oder Slave?
                                            3. Danach Update wieder möglich?
                                            4. Über NPM habe ich gelernt nicht "korrekt"?!
                                            68
                                            10197
