    4. ioBroker extrem langsam
      Spidermike @Homoran last edited by
      @homoran sagte in ioBroker extrem langsam:
      iob node-update
      login as: pi
      pi@192.168.178.78's password:
      Linux raspberrypi4-iobroker 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022        armv7l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sun Oct 15 19:47:53 2023 from 192.168.178.20
      pi@raspberrypi4-iobroker:~ $ iob node-update
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
        iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
        iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
      Options:
        --help  Show help  [boolean]
      dann bekomme ich das als antwort
        Homoran Global Moderator Administrators @Spidermike last edited by
        @spidermike sagte in ioBroker extrem langsam:
        dann
        iob stop
        iob fix
        iob start
        w a r t e n
        iob node-update
          iob start
          Warum bekomme ich da eine Fehlermeldung
          OK:1 http://phoscon.de/apt/deconz bullseye InRelease
          OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Holen:3 https://repos.influxdata.com/debian bullseye InRelease [7.040 B]
          Holen:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
          OK:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Fehl:3 https://repos.influxdata.com/debian bullseye InRelease
            Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
          Es wurden 22,0 kB in 2 s geholt (14,6 kB/s).
          Paketlisten werden gelesen… Fertig
          W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/bullseye/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
            Thomas Braun Most Active @Spidermike last edited by
            @spidermike
            Weil du das influxdb-Repository nicht aktuell gehalten hast.
              dann
              iob stop
              iob fix
              iob start
              w a r t e n
              iob node-update
              erledigt bekomme aber das gleiche wie ich schon gepostet hab
              iobroker [command]
              Commands:
              Options:
                @spidermike
                iob nodejs-update
                  Spidermike @Thomas Braun last edited by
                  @thomas-braun sagte in ioBroker extrem langsam:
                  iob nodejs-update
                  es tut sich jetzt etwas 👍
                  wie kann ich dann influxdb-Repository aktualisieren?
                    @spidermike
                    iob nodejs-update
                    danke Dir bzw. ihr seid der Wahnsinn, es hat funktioniert.
                    Der 1. Eindruck beim starten. "jetzt hab ich ein Ferrari"
                    was muss ich jetzt machen das es auch so bleibt?
                      https://forum.iobroker.net/topic/67822/grafana-repo-braucht-neuen-schlüssel
                      • haselchen
                        haselchen Most Active @Spidermike last edited by
                        @spidermike
                        Damit er noch schneller wird , solltest Du die 150 Updates noch machen
                          Spidermike @haselchen last edited by
                          @haselchen sagte in ioBroker extrem langsam:
                          @spidermike
                          und wie geht das ?
                            Spidermike @Thomas Braun last edited by Spidermike
                            hab ich jetzt gemacht und wie kann ich schauen ob es geklappt hat?
                              @spidermike
                              sudo apt update
                              sudo apt full-upgrade
                                jetzt hab ich mal
                                "sudo reboot" gemacht
                                und bekomme jetzt diese Fehlermeldungen im Protokoll
                                admin.0
                                	2023-10-15 21:29:59.173	info	<== Disconnect system.user.admin from ::ffff:192.168.178.20 javascript
                                host.raspberrypi4-iobroker
                                	2023-10-15 21:29:59.118	info	instance system.adapter.rpi2.0 started with pid 1191
                                admin.0
                                admin.0
                                admin.0
                                admin.0
                                smartthings.0
                                	2023-10-15 21:28:52.523	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.powerConsumptionReport.powerConsumption.value {"energy":1385000,"deltaEnergy":0,"power":18,"powerEnergy":796.4271791658799,"persistedEnergy":0,"energySaved":0,"start":"2023-10-01T16:44:55Z","end":"2023-10-02T16:52:57Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.522	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.523	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.522	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.audioVolume.volume {"value":1,"unit":"%","timestamp":"2022-08-28T16:55:08.492Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.521	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.waterFilter.waterFilterUsage {"value":0,"timestamp":"2023-08-23T13:22:35.380Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.521	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.520	error	Error: DB closed
                                smartthings.0
                                smartthings.0
                                	2023-10-15 21:28:52.519	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.freezer.temperatureMeasurement.temperature {"value":18,"unit":"C","timestamp":"2023-10-02T16:52:58.244Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.519	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.mnml {"value":"http://www.samsung.com","timestamp":"2020-04-08T03:47:32.225Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.520	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.icemaker-02.switch.switch {"value":""}
                                smartthings.0
                                	2023-10-15 21:28:52.518	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.519	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.518	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModes.value.Natürlich "Natürlich"
                                smartthings.0
                                	2023-10-15 21:28:52.517	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModes.value.Film "Film"
                                smartthings.0
                                	2023-10-15 21:28:52.517	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.sec.wifiConfiguration.supportedAuthType.value.WPA2-PSK "WPA2-PSK"
                                smartthings.0
                                	2023-10-15 21:28:52.516	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.517	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:53.621	error	Caught by controller[0]: at Shelly._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                                smartthings.0
                                	2023-10-15 21:28:52.516	error	Cannot extract array d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModesMap
                                smartthings.0
                                	2023-10-15 21:28:52.515	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.fridgeMode.fridgeModeValue {"value":""}
                                	2023-10-15 21:28:53.621	error	Caught by controller[0]: at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                smartthings.0
                                	2023-10-15 21:28:52.514	error	Error: DB closed
                                smartthings.0
                                smartthings.0
                                	2023-10-15 21:28:52.515	error	Error: DB closed
                                	2023-10-15 21:28:53.620	error	Caught by controller[0]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                smartthings.0
                                	2023-10-15 21:28:52.513	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.sec.diagnosticsInformation.signinPermission {"value":""}
                                smartthings.0
                                	2023-10-15 21:28:52.514	error	Cannot extract array d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModesMap
                                	2023-10-15 21:28:53.620	error	Caught by controller[0]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                smartthings.0
                                	2023-10-15 21:28:52.513	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.512	error	Error: DB closed
                                	2023-10-15 21:28:53.620	error	Caught by controller[0]: Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.511	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.freezer.temperatureMeasurement.temperature {"value":18,"unit":"C","timestamp":"2023-10-02T16:52:58.244Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.511	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.mnpv {"value":"Tizen 4.0","timestamp":"2020-04-08T03:47:32.225Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.512	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.mnpv {"value":"Tizen 4.0","timestamp":"2020-04-08T03:47:32.225Z"}
                                	2023-10-15 21:28:53.620	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                smartthings.0
                                	2023-10-15 21:28:52.510	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.511	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.510	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.cooler.custom.thermostatSetpointControl.minimumSetpoint {"value":1,"unit":"C","timestamp":"2023-02-12T10:51:16.092Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.509	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.508	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.507	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.freezer.temperatureMeasurement.temperature {"value":18,"unit":"C","timestamp":"2023-10-02T16:52:58.244Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.508	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.dmv {"value":"res.1.1.0,sh.1.1.0","timestamp":"2020-04-08T03:47:32.225Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.507	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.506	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.505	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.execute.data.value.payload {"rt":["x.com.samsung.tv.deviceinfo"],"if":["oic.if.baseline","oic.if.r"],"x.com.samsung.country":"GERMANY","x.com.samsung.infolinkversion":"T-INFOLINK2018-1013","x.com.samsung.modelid":"18_KANTM2_QTV","x.com.samsung.tv.ambientsupport":true,"x.com.samsung.tv.blemac":"FC:03:9F:58:C9:B6","x.com.samsung.tv.btmac":"FC:03:9F:58:C9:B6","x.com.samsung.tv.category":"tv","x.com.samsung.tv.countrycode":"DE","x.com.samsung.tv.ethmac":"fc:03:9f:a3:82:1c","x.com.samsung.tv.onsupport":true,"x.com.samsung.tv.p2pmac":"fe:03:9f:58:c9:b5","x.com.samsung.tv.paneltime":57281,"x.com.samsung.tv.sn":"0E6B3HEKB00847R","x.com.samsung.tv.swmodel":"QNQ9F","x.com.samsung.tv.thingversion":"2.4.0","x.com.samsung.tv.ttxsupport":false,"x.com.samsung.tv.udn":"abb0b0b1-4f1b-4336-8882-a927118b269b","x.com.samsung.tv.wifimac":"fc:03:9f:58:c9:b5"}
                                smartthings.0
                                	2023-10-15 21:28:52.506	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.samsungce.deviceIdentification.binaryId {"value":"23K_REF_LCD_FHUB8.0","timestamp":"2023-10-02T16:52:58.063Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.505	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.504	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.503	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.ocf.n {"value":"[refrigerator] Samsung (LCD)","timestamp":"2023-09-05T09:48:57.735Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.504	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.energyType.supportedEnergySavingLevels {"value":""}
                                smartthings.0
                                	2023-10-15 21:28:52.503	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.502	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.fridgeMode.fridgeMode {"value":""}
                                smartthings.0
                                	2023-10-15 21:28:52.501	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.cooler.thermostatCoolingSetpoint.coolingSetpoint {"value":3,"unit":"C","timestamp":"2023-08-23T20:04:06.005Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.500	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.501	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.500	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.vid {"value":"VD-STV_2018_K","timestamp":"2020-04-08T03:47:32.225Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.499	error	Cannot extract array d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModesMap
                                smartthings.0
                                	2023-10-15 21:28:52.498	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.499	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.498	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.samsungce.viewInside.lastUpdatedTime {"value":"2023-10-02T16:52:54Z","timestamp":"2023-10-02T16:52:58.187Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.497	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.execute.data.value.payload {"rt":["x.com.samsung.tv.deviceinfo"],"if":["oic.if.baseline","oic.if.r"],"x.com.samsung.country":"GERMANY","x.com.samsung.infolinkversion":"T-INFOLINK2018-1013","x.com.samsung.modelid":"18_KANTM2_QTV","x.com.samsung.tv.ambientsupport":true,"x.com.samsung.tv.blemac":"FC:03:9F:58:C9:B6","x.com.samsung.tv.btmac":"FC:03:9F:58:C9:B6","x.com.samsung.tv.category":"tv","x.com.samsung.tv.countrycode":"DE","x.com.samsung.tv.ethmac":"fc:03:9f:a3:82:1c","x.com.samsung.tv.onsupport":true,"x.com.samsung.tv.p2pmac":"fe:03:9f:58:c9:b5","x.com.samsung.tv.paneltime":57281,"x.com.samsung.tv.sn":"0E6B3HEKB00847R","x.com.samsung.tv.swmodel":"QNQ9F","x.com.samsung.tv.thingversion":"2.4.0","x.com.samsung.tv.ttxsupport":false,"x.com.samsung.tv.udn":"abb0b0b1-4f1b-4336-8882-a927118b269b","x.com.samsung.tv.wifimac":"fc:03:9f:58:c9:b5"}
                                smartthings.0
                                	2023-10-15 21:28:52.496	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.497	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.496	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.fridgeMode.fridgeModeValue {"value":""}
                                smartthings.0
                                	2023-10-15 21:28:52.495	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.icv {"value":"core.1.1.0","timestamp":"2020-04-08T03:47:32.225Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.494	error	Error: DB closed
                                smartthings.0
                                smartthings.0
                                	2023-10-15 21:28:52.495	error	Error: DB closed
                                	2023-10-15 21:28:52.981	error	Caught by controller[0]: at TCP.<anonymous> (node:net:350:12)
                                smartthings.0
                                	2023-10-15 21:28:52.493	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.energyType.energySavingSupport {"value":false,"timestamp":"2023-02-12T10:51:16.400Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.493	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.cvroom.custom.fridgeMode.fridgeModeValue {"value":""}
                                smartthings.0
                                	2023-10-15 21:28:52.494	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.freezer.custom.thermostatSetpointControl.maximumSetpoint {"value":-15,"unit":"C","timestamp":"2023-02-12T10:51:16.092Z"}
                                	2023-10-15 21:28:52.981	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
                                smartthings.0
                                	2023-10-15 21:28:52.492	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.493	error	Error: DB closed
                                	2023-10-15 21:28:52.980	error	Caught by controller[0]: at Socket.emit (node:events:517:28)
                                smartthings.0
                                	2023-10-15 21:28:52.491	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.error.error {"value":"","timestamp":"2020-10-16T19:24:39.390Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.491	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.samsungce.viewInside.contents.e67bbc40-f9aa-949b-1e0a-6184228169f4 {"fileId":"e67bbc40-f9aa-949b-1e0a-6184228169f4","mimeType":"image/jpeg","expiredTime":"2023-08-28T15:02:06Z"}
                                	2023-10-15 21:28:52.980	error	Caught by controller[0]: at Object.onceWrapper (node:events:632:26)
                                smartthings.0
                                	2023-10-15 21:28:52.490	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.491	error	Error: DB closed
                                	2023-10-15 21:28:52.980	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                smartthings.0
                                	2023-10-15 21:28:52.490	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.execute.data.value.payload.rt.x.com.samsung.tv.deviceinfo "x.com.samsung.tv.deviceinfo"
                                smartthings.0
                                	2023-10-15 21:28:52.489	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.samsungce.viewInside.contents.e67bbc40-f9aa-949b-1e0a-6184228169f4 {"fileId":"e67bbc40-f9aa-949b-1e0a-6184228169f4","mimeType":"image/jpeg","expiredTime":"2023-08-28T15:02:06Z"}
                                	2023-10-15 21:28:52.980	error	Caught by controller[0]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                smartthings.0
                                	2023-10-15 21:28:52.488	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.489	error	Error: DB closed
                                	2023-10-15 21:28:52.980	error	Caught by controller[0]: Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.488	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.cvroom.custom.fridgeMode.fridgeMode {"value":""}
                                smartthings.0
                                	2023-10-15 21:28:52.487	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.ocf.pi {"value":"fd9e8b42-11df-2073-6607-17d0ab099f3a","timestamp":"2023-02-12T10:51:16.548Z"}
                                	2023-10-15 21:28:52.979	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                smartthings.0
                                	2023-10-15 21:28:52.487	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.486	error	Error: DB closed
                                smartthings.0
                                smartthings.0
                                	2023-10-15 21:28:52.485	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModes {"value":["Dynamisch","Standard","Natürlich","Film"],"timestamp":"2020-11-21T21:13:41.247Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.486	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModesMap {"value":[{"id":"modeDynamic","name":"Dynamisch"},{"id":"modeStandard","name":"Standard"},{"id":"modeNatural","name":"Natürlich"},{"id":"modeMovie","name":"Film"}],"timestamp":"2020-12-22T23:29:19.098Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.484	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.484	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.sec.wifiConfiguration.supportedAuthType {"value":["OPEN","WEP","WPA-PSK","WPA2-PSK"],"timestamp":"2023-09-05T09:48:57.670Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.483	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.ocf.st {"value":"2021-01-01T09:00:40Z","timestamp":"2023-06-18T10:46:31.282Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.483	error	Error: DB closed
                                smartthings.0
                                smartthings.0
                                	2023-10-15 21:28:52.482	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.ocf.st {"value":"2021-01-01T09:00:40Z","timestamp":"2023-06-18T10:46:31.282Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.481	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.samsungvd.ambientContent.supportedAmbientApps {"value":[],"timestamp":"2021-01-17T04:57:10.341Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.480	error	Error: DB closed
                                smartthings.0
                                smartthings.0
                                	2023-10-15 21:28:52.481	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.479	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.soundmode.soundMode {"value":"Standard","timestamp":"2020-11-21T21:13:41.457Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.480	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.deviceReportStateConfiguration.reportStatePeriod {"value":"enabled","timestamp":"2023-02-12T10:51:16.341Z"}
                                smartthings.0
                                	2023-10-15 21:28:52.479	error	Error: DB closed
                                smartthings.0
                                	2023-10-15 21:28:52.478	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.ocf.mnhw {"value":"","timestamp":"2023-09-05T09:48:50.375Z"}
                                und
                                • haselchen
                                  @spidermike
                                  Was sagt denn jetzt
                                  iob diag
                                    Spidermike @haselchen last edited by Spidermike
                                    iob diag
                                    *** BASE SYSTEM ***
                                       Static hostname: raspberrypi4-iobroker
                                             Icon name: computer
                                      Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                Kernel: Linux 6.1.21-v8+
                                          Architecture: arm64
                                    Model           : Raspberry Pi 4 Model B Rev 1.4
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : aarch64
                                    Userland        : armhf
                                    Systemuptime and Load:
                                     17:52:10 up 20:23,  1 user,  load average: 2.58, 3.55, 3.71
                                    CPU threads: 4
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                    *** Time and Time Zones ***
                                                   Local time: Mon 2023-10-16 17:52:10 CEST
                                               Universal time: Mon 2023-10-16 15:52:10 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** User and Groups ***
                                    pi
                                    /home/pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
                                    *** X-Server-Setup ***
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            7.8G        1.5G        4.6G        0.0K        1.7G        6.2G
                                    Swap:            99M          0B         99M
                                    Total:          7.9G        1.5G        4.7G
                                             7811 M total memory
                                             1516 M used memory
                                             2222 M active memory
                                              849 M inactive memory
                                             4578 M free memory
                                               86 M buffer memory
                                             1629 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FAILED SERVICES ***
                                    0 loaded units listed.
                                    *** FILESYSTEM ***
                                    /dev/root      ext4      118G   23G   90G  21% /
                                    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                    tmpfs          tmpfs     3.9G   16K  3.9G   1% /dev/shm
                                    tmpfs          tmpfs     1.6G  904K  1.6G   1% /run
                                    /dev/sdb1      exfat      29G  2.7G   27G  10% /mnt/usb0
                                    /dev/sda1      vfat      253M   51M  202M  20% /boot
                                    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                                    [Sun Oct 15 21:29:08 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:FD:BB:CC vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 console=ttyS0,11520        0 root=PARTUUID=1045efe5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes ro        otwait
                                    [Sun Oct 15 21:29:11 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
                                    [Sun Oct 15 21:29:11 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
                                    [Sun Oct 15 21:29:14 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                    TARGET      SOURCE    FSTYPE OPTIONS
                                    /           /dev/sda2 ext4   rw,noatime
                                    |-/mnt/usb0 /dev/sdb1 exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=00        00,allow_utime=0022,iocharset=utf8,errors=remount-ro
                                    `-/boot     /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioch        arset=ascii,shortname=mixed,flush,errors=remount-ro
                                    /var:
                                    4.9G    /var/
                                    3.9G    /var/log
                                    3.7G    /var/log/journal/ceda8666c83a44189d7d8b22875c3095
                                    502M    /var/lib
                                    Archived and active journals take up 3.6G in the file system.
                                    /opt/iobroker/backups:
                                    6.2G    /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    899M    /opt/iobroker/iobroker-data/
                                    430M    /opt/iobroker/iobroker-data/history
                                    324M    /opt/iobroker/iobroker-data/files
                                    85M     /opt/iobroker/iobroker-data/backup-objects
                                    52M     /opt/iobroker/iobroker-data/files/javascript.admin
                                    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.        js.map
                                    25M     /opt/iobroker/iobroker-data/states.jsonl
                                    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.m        ap
                                    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.m        ap
                                    11M     /opt/iobroker/iobroker-data/objects.json.broken
                                    USB-Devices by-id:
                                    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs         v18.18.2
                                    /usr/bin/node           v18.18.2
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    /usr/bin/corepack       0.19.0
                                    nodejs:
                                      Installed: 18.18.2-1nodesource1
                                      Candidate: 18.18.2-1nodesource1
                                      Version table:
                                     *** 18.18.2-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                            100 /var/lib/dpkg/status
                                         18.18.1-1nodesource1 1001
                                         18.18.0-1nodesource1 1001
                                         18.17.1-1nodesource1 1001
                                         18.17.0-1nodesource1 1001
                                         18.16.1-1nodesource1 1001
                                         18.16.0-1nodesource1 1001
                                         18.15.0-1nodesource1 1001
                                         18.14.2-1nodesource1 1001
                                         18.14.1-1nodesource1 1001
                                         18.14.0-1nodesource1 1001
                                         18.13.0-1nodesource1 1001
                                         18.12.0-1nodesource1 1001
                                         18.11.0-1nodesource1 1001
                                         18.10.0-1nodesource1 1001
                                         18.9.1-1nodesource1 1001
                                         18.9.0-1nodesource1 1001
                                         18.8.0-1nodesource1 1001
                                         18.7.0-1nodesource1 1001
                                         18.6.0-1nodesource1 1001
                                         18.5.0-1nodesource1 1001
                                         18.4.0-1nodesource1 1001
                                         18.3.0-1nodesource1 1001
                                         18.2.0-1nodesource1 1001
                                         18.1.0-1nodesource1 1001
                                         18.0.0-1nodesource1 1001
                                         12.22.12~dfsg-1~deb11u4 500
                                            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
                                    No problems detected
                                    Errors in npm tree:
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Core adapters versions
                                    js-controller:  5.0.12
                                    admin:          6.10.1
                                    javascript:     7.1.4
                                    Adapters from github:   3
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : raspberrypi4-iobroker                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.backitup.0               : backitup              : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.cloud.0                  : cloud                 : raspberrypi4-iobroker                    -  enabled
                                      system.adapter.devices.0                : devices               : raspberrypi4-iobroker                    - disabled
                                    + system.adapter.discovery.0              : discovery             : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.energiefluss.1           : energiefluss          : raspberrypi4-iobroker                    -  enabled
                                      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi4-iobroker                    - disabled
                                      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi4-iobroker                    - disabled
                                    + system.adapter.growatt.0                : growatt               : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.history.0                : history               : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.hs100.0                  : hs100                 : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.info.0                   : info                  : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.iot.0                    : iot                   : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.javascript.0             : javascript            : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4-iobroker                    -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.plenticore.0             : plenticore            : raspberrypi4-iobroker                    -  enabled, port: 80
                                    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.shelly.0                 : shelly                : raspberrypi4-iobroker                    -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.smartthings.0            : smartthings           : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.telegram.0               : telegram              : raspberrypi4-iobroker                    -  enabled, port: 8443, bind: 0.0.0.0
                                      system.adapter.tuya.0                   : tuya                  : raspberrypi4-iobroker                    - disabled
                                      system.adapter.vis.0                    : vis                   : raspberrypi4-iobroker                    - disabled
                                      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4-iobroker                    -  enabled
                                    + system.adapter.web.0                    : web                   : raspberrypi4-iobroker                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + system.adapter.wled.0                   : wled                  : raspberrypi4-iobroker                    -  enabled
                                      system.adapter.zigbee.0                 : zigbee                : raspberrypi4-iobroker                    - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2414409-if00
                                    + instance is alive
                                    ioBroker-Repositories
                                    Active repo(s): stable
                                    Installed ioBroker-Instances
                                    Used repository: stable
                                    Adapter    "admin"        : 6.10.1   , installed 6.10.1
                                    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                                    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                                    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                                    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                                    Adapter    "growatt"      : 3.2.1    , installed 3.2.1
                                    Adapter    "history"      : 2.2.6    , installed 2.2.6
                                    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                                    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                                    Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                    Controller "js-controller": 5.0.12   , installed 5.0.12
                                    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                                    Adapter    "plenticore"   : 2.2.0    , installed 2.3.1
                                    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                                    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                                    Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                    Adapter    "web"          : 6.1.2    , installed 6.1.2
                                    Adapter    "wled"         : 0.7.1    , installed 0.7.1
                                    Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                                    Objects and States
                                    Objects:        8968
                                    States:         16359
                                    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                    W: Some index files failed to download. They have been ignored, or old ones used instead.
                                    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    Get:4 https://repos.influxdata.com/debian bullseye InRelease [7040 B]
                                    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                    Err:4 https://repos.influxdata.com/debian bullseye InRelease
                                    Fetched 7040 B in 2s (3908 B/s)
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        12652      427/influxd
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      110        15421      577/mosquitto
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12965      776/iobroker.js-con
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16684      776/iobroker.js-con
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13913      574/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          15457      422/python
                                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        12825      427/influxd
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21903      1679/io.web.0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14290      1089/io.admin.0
                                    tcp6       0      0 :::1883                 :::*                    LISTEN      110        15422      577/mosquitto
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13915      574/sshd: /usr/sbin
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13979      484/dhcpcd
                                    udp        0      0 0.0.0.0:49382           0.0.0.0:*                           108        13746      399/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       19160      1888/io.wled.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13744      399/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17601      1247/io.shelly.0
                                    udp6       0      0 :::546                  :::*                                0          15323      484/dhcpcd
                                    udp6       0      0 :::5353                 :::*                                108        13745      399/avahi-daemon: r
                                    udp6       0      0 :::55835                :::*                                108        13747      399/avahi-daemon: r
                                    2023-10-16 17:50:37.856  - info: admin.0 (1089) Subscribe to all states again
                                    2023-10-16 17:50:40.956  - info: admin.0 (1089) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                                    2023-10-16 17:51:39.536  - error: host.raspberrypi4-iobroker Caught by controller[0]: <--- Last few GCs --->
                                    2023-10-16 17:51:39.538  - error: host.raspberrypi4-iobroker Caught by controller[0]: [32592:0x54af008] 39717362 ms: Scavenge 908.4 (1045.2) -> 907.7 (1045.2) MB, 10.5 / 0.0 ms  (average mu = 0.912, current mu = 0.956) allocation failure;
                                    2023-10-16 17:51:39.538  - error: host.raspberrypi4-iobroker Caught by controller[0]: [32592:0x54af008] 39717425 ms: Scavenge 908.8 (1045.2) -> 908.2 (1045.2) MB, 10.3 / 0.0 ms  (average mu = 0.912, current mu = 0.956) allocation failure;
                                    2023-10-16 17:51:39.538  - error: host.raspberrypi4-iobroker Caught by controller[0]: [32592:0x54af008] 39717454 ms: Scavenge 909.5 (1045.2) -> 909.4 (1049.2) MB, 24.8 / 0.0 ms  (average mu = 0.912, current mu = 0.956) allocation failure;
                                    2023-10-16 17:51:39.538  - error: host.raspberrypi4-iobroker Caught by controller[0]: <--- JS stacktrace --->
                                    2023-10-16 17:51:39.538  - error: host.raspberrypi4-iobroker Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                    2023-10-16 17:51:39.539  - warn: host.raspberrypi4-iobroker instance system.adapter.smartthings.0 terminated due to SIGABRT
                                    2023-10-16 17:51:39.539  - info: host.raspberrypi4-iobroker instance system.adapter.smartthings.0 terminated with code null ()
                                    2023-10-16 17:51:39.539  - info: host.raspberrypi4-iobroker Restart adapter system.adapter.smartthings.0 because enabled
                                    2023-10-16 17:51:41.875  - info: admin.0 (1089) Subscribe to all states again
                                    2023-10-16 17:51:44.975  - info: admin.0 (1089) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                                    2023-10-16 17:52:06.891  - info: weatherunderground.0 (30819) Terminated (NO_ERROR): Without reason
                                    2023-10-16 17:52:07.426  - info: host.raspberrypi4-iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                                    2023-10-16 17:52:09.657  - info: host.raspberrypi4-iobroker instance system.adapter.smartthings.0 started with pid 5069
                                    2023-10-16 17:52:13.567  - info: smartthings.0 (5069) starting. Version 0.0.4 (non-npm: TA2k/ioBroker.smartthings#2f3c7e70f203e4c904dba0d692a387e1c44d7bbe) in /opt/iobroker/node_modules/iobroker.smartthings, node: v18.18.2, js-controller: 5.0.12
                                    2023-10-16 17:52:13.618  - info: smartthings.0 (5069) Set interval to minimum 1
                                    2023-10-16 17:52:14.363  - info: smartthings.0 (5069) 4 devices detected
                                    2023-10-16 17:52:45.899  - info: admin.0 (1089) Subscribe to all states again
                                    2023-10-16 17:52:49.000  - info: admin.0 (1089) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                                    2023-10-16 17:52:54.129  - info: alexa2.0 (1159) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                    2023-10-16 17:52:55.811  - info: alexa2.0 (1159) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                    2023-10-16 17:53:49.341  - info: admin.0 (1089) Subscribe to all states again
                                    2023-10-16 17:53:53.486  - info: admin.0 (1089) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                                    DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
                                    • DJMarc75
                                      DJMarc75 @Spidermike last edited by
                                      @spidermike setz das ganze bitte in Codetags - dann kann man das besser lesen 😉
                                        Spidermike @DJMarc75 last edited by
                                        @djmarc75 sagte in ioBroker extrem langsam:
                                        jetzt besser habs geändert
                                          Da musst du ran.
                                          Es muss ein neuer Schlüssel installiert werden.
                                            Da musst du ran.
                                            ich dachte das hab ich gestern gemacht
                                            kannst Du mir nochmal sagen wie genau das geht
                                            iobroker keine aktualisierung möglich langsam
                                            8510
