Vis-2(.0) - Neuer Adapter als Beta
ich bekomme den Adapter einfach nicht installiert.
könnt ihr mir ein Tip geben?Node.js: v18.15.0
time: 1697101459530
timeOffset: --
NPM: 9.5.0
Adapter-Anzahl: 504
Datenträgergröße: 14.7 GB
Freier Festplattenspeicher: 4.9 GB
Aktive Instanzen: 8
Pfad: /opt/iobroker/
Betriebszeit: 00:01:05
aktiv:$ iobroker url iobroker.vis-2 --host vmiobrocker --debug
install iobroker.vis-2
NPM version: 9.5.0
Installing iobroker.vis-2... (System call)
up to date in 6s110 packages are looking for funding run
npm fundfor detailsupload [12] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/de/translations.json i18n/de/translations.json application/json
upload [11] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/en/translations.json i18n/en/translations.json application/json
upload [10] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/es/translations.json i18n/es/translations.json application/json
upload [9] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
upload [7] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
upload [5] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
upload [3] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
upload [0] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/vis-2.png vis-2.png image/png
upload [685] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/asset-manifest.json asset-manifest.json application/json
upload [650] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/img/favicon.png img/favicon.png image/png
upload [600] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_flat_15_cd0a0a_40x100.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_flat_15_cd0a0a_40x100.png image/png
upload [550] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_80_eeeeee_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_80_eeeeee_1x100.png image/png
upload [500] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ffffff_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ffffff_256x240.png image/png
upload [450] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffffff_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffffff_256x240.png image/png
upload [400] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png image/png
upload [350] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_inset-soft_30_ffffff_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_inset-soft_30_ffffff_1x100.png image/png
upload [300] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-soft_35_adadad_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-soft_35_adadad_1x100.png image/png
upload [250] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/signals/motionColor.png signals/motionColor.png image/png
ERROR: Process exited with code null```
@ralf125 Hi, poste bitte mal deine log Ausgabe in Codetags (das Symbol </> hier im Editor), dann lässt sich die log Ausgabe leichter lesen.
Der upload sieht unvollständig aus.
Versuch mal manuell den upload vom vis-2 adapter neu zu starten:
Du kannst auch mal die Langfassung vom folgenden Befehl hier posten, dann sieht man einmal dein gesamtes System von der Konfiguration her:
iob diag -
wollte mich auch mal mit dem Thema vis-2 befassen, da mir meine alte IoBroker installation zerstört wurde und ich sowieso neu anfangen muss.
Habe mir dazu meine vis Lizenz zu vis-2 konvertiert. Hat auch ganz gut funktioniert. Da ich aber mal wieder recht viel rumfummeln musste
hatte ich mir meinen Container zerschossen. Läuft bei mir alles im Docker auf meinem NAS. Also schnell neuen Container erstellt, geht ja fix.
Im vis-2 Adapter war danach mein alter Lizenzschlüssel nicht mehr gültig, da sich die UUID geändert hat und ich die ja nicht anpassen kann.
Mach ich da irgendwas falsch oder ist die Lizenz nun Schrott. Weis mir da im Moment keinen RatP.S.: Gibt es irgendwo Infos zu den Widgets vom Jaeger-Design? Mir ist da einiges unklar (Speichertasten z.B.) und finde nichts dazu
@marcus-0 sagte in Vis-2(.0) - Neuer Adapter als Beta:
Mach ich da irgendwas falsch oder ist die Lizenz nun Schrott. Weis mir da im Moment keinen RatHier hilft nach meinem Wissensstand sich an info@iobroker.net zu wenden.
Eine Doku zum Jaeger-Design kenn ich nicht.
Ich hab selbst erst vor kurzem angefangen, etwas mit dem Jäger-Design rumzuspielen. Was meinst du mit den "Speichertasten"?
So sieht es bei mir gerade testweise aus, um etwas mit den Funktionen zu spielen
@Feuersturm
Danke für deine Antwort. Ist aber schon irgendwie umständlich sich immer per Mail melden zu müssen nach einer Neuinstallation. Naja, ich schreib da mal hin und schau mal weiter. Danke auf jeden Fall für die Info!Zu den Speichertasten:
Im Thermostat Widget hast du unter Allgemein den Punkt Speichertastenanzahl
Weiter unten kann man zu jeder Taste noch Einstellungen machen
Bei mir wird da automatisch eine Boost Funktion erstellt, die auch funktioniert. Ich hab nur keine Ahnung wie...sprich wie wird geschaltet usw.Auch die optische Anpassung ist bis jetzt ein Problem. Ich bekomm noch nicht mal die Schrift vergrößert (Bild 1)
@Feuersturm
Hi wegen dem energy widget hätte da ne frage. Der intervallwähler hat ja die zwei oid datenpunkte. Wenn ich allerdings die 2 auf ein objekt in 0.userdata lege dann hört bekomme ich zwar die events (meistens) aber er hört auf sich selbst zu aktualisieren.
Bedeutet ich kann zwar tag woche usw bzw die zeit hin und her schalten aber das widget selber aktualisisert sich nicht mehr.
Muss dazusagen das ich das widget gerene auch für die zeitumschaltung bei den grafana einbindungen verwenden würde.
Ist da was bekannt oder gibts irgendwo eine beschreibung zu den widegets ?
Danke im vorausUpdate. Keine Ahnung warum aber nach einem iobroker serverneustart geht es jetzt tadelos.
sorry -
Erstell mal hierzu ein issue auf github https://github.com/ioBroker/ioBroker.vis-2/issues
Vielleicht kann man ja einfach den Schieberegler für die Symbolgröße auch dafür verwenden, die Schrift zu vergrößern.Bei mir wird da automatisch eine Boost Funktion erstellt, die auch funktioniert. Ich hab nur keine Ahnung wie...sprich wie wird geschaltet usw.
Dies ist ein Datenpunkt von deinem Homematik Thermostat. Dort gibt es den Boost Datenpunkt welcher auf true stellt wird. Beim Setzen der Datenpunkte für die Temperatur hat der Editor automtisch erkannt, das es auch einen Boost Modus gibt und diesen auf eine Taste gemappt.
So sieht es bei mir unter den Objekten aus:
@feuersturm said in Vis-2(.0) - Neuer Adapter als Beta:
Das ist mir schon klar. Bei mir werden sogar 2 angelegt.
Nur warum steht unter Wert nichts, sprich, woher weiß ich was gemacht wird bei Tastendruck?
Bei Taste 2 kann ich mir gar nicht erklären warum die erstellt wurde. Der State wird bei mir nirgends angezeigt oder so dezent, dass ich es übersehe.
Wie gesagt, der Boost funktioniert auch. Würde halt gerne eine weitere Taste für Manu/Auto Mode machen. Naja, ich werd wohl einfach mal rum probieren
Ne Kurze Zwischenfrage:
Ich habe jetzt vis-2 ausprobiert und meine SEHR css Lastigen Visus sind dazu nicht kompatibel.
Ich werde mich hinsetzen und mir neue machen aber bis dahin brauche ich meine alten Visus.Geht denn VIS mit meiner nun umgewandelten Lizenz weiterhin oder sitze ich demnächst ohne eine vis da?
LG
Nils -
@jmeister79 sagte in Vis-2(.0) - Neuer Adapter als Beta:
Vorerst wird Sie weiter gehen, wie lange ist noch nicht entschieden.
@apollon77 Wäre eine migration zurück oder eine andere Lösung technisch möglich?
@jmeister79 Jetzt mal doch mal weiter erstmal. Ich denke bevor vis2 in stable geht (und auch dann noch eine zeit) wird es weiter gehen ...
Hmm, hänge seit gestern daran meine Visualisierung irgendwie in der Runtime scrollbar zu bekommen. Nun habe ich eben gelesen, dass das gar nicht gehen soll! Ist das korrekt??Ok, habs endlich gefunden. Da muss man aber auch erstmal drauf kommen...
Scrollen geht jetzt, aber die Runtime springt, ca. 2 Sek. nach Scrollstart, immer auf den ersten View in der Navigation.
Navigation über interne Seitennavigation erstellt.Hat einer eine Idee was das sein könnte und wie man es wegbekommt?
@apollon77 das werde ich natürlich tun.
Haben wir n Discord server für meine Zahlreichen dummen Frage n?Hier klären oder n Einzelthread? Ich stehe nämlich auf dem Schlauch.
@apollon77 Hi kurze Zwischenfrage gibt es eigentlich ein update bezüglich des Menues das man die Einträge Verschieben kann weil im moment kann man ja die Reihenfolge nicht ändern oder gibt es da eine möglichkeit ?
Danke für ein kurze info
Mfg Smilie108 -
@smilie108 Hierzu gibt es bereits ein issue https://github.com/ioBroker/ioBroker.vis-2/issues/15
Mit einem
im issue zeigst du dem Entwickler, dass du auch betroffen bist
Einen Workaround kenn ich nicht -
Hier klären oder n Einzelthread? Ich stehe nämlich auf dem Schlauch.Es gibt auf dem ioBroker Diskord Server einen vis-2 Kanal: https://discord.com/channels/743167951875604501/1154887769554952353
ich habe mal eine Frage zu einer Funktion, die in VIS1 funktionierte und jetzt nicht mehr (zumindest nicht so wie vorher).
In VIS1 konnte man zum Beispiel bei width und height eines widgets mit "calc()" arbeiten. Wenn ich zum Beispiel in height "calc(100%-80px)" eingetragen habe, bekam das Widget die Höhe 100% des Übergeordneten Elements minus 80 Pixel.Im github readme gibt es ja bei den Bindings den Unterpunkt "calculations". Damit habe ich versucht, das umzusetzen, aber habe es nicht hinbekommen. Das Resultat war immer, dass das widget dann komplett verschwunden ist auf der Runtime (so also ob height = 0).
Gibt es diese Funktion noch? Wenn ja, wäre ich sehr dankbar für ein Beispiel für meinen Anwendungsfall.Sollte dies schonmal thematisiert worden sein, dann konnte ich es leider bisher nicht finden.
EDIT: Ich konnte mir die Frage nun selbst beantworten. Bei der Funktion "calc()" ist es wichtig, Leerzeichen zwischen den Parametern zu lassen. Also statt "calc(100%-80px)" muss es "calc(100% - 80px)".
Manchmal kommt man auf die einfachsten Sachen nicht. -
nachdem ich ein paar Probleme mit Vis habe, wollte ich mal Vis-2 ausprobieren. Mein altes Projekt konnte leider nicht geladen werden so dass ich es neu gebaut habe. Als ich fast fertig war, habe ich das Vis-2 Projekt exportiert. Ich habe dann ein Rollback auf ein früheres Snapshot gemacht (ein widget ging nicht und die alte Vis ließ sich auch nicht mehr anzeigen) jetzt wollte ich das Vis-2 Projekt in Vis-2 importieren. Das gestaltet sich aber schwierig. Es wird nach dem Import in einem kleinen Auswahlfenster angezeigt, aber es lässt sich einfach nicht öffen. Was is da los?VG Schmidti
@schmidti das klingt nach einem bekannten Problem. Wenn du dieses kleine Fenster mit den Projekten siehst, dann importiere von dort noch einmal dein Projekt, dann sollte es gehen.
