    5. Text in Base64 codieren und Datei von Netzlaufwerk suchen
    • Armilar
      Armilar Most Active Forum Testing @Chris76e last edited by Armilar
      @chris76e
      Jetzt mit toLowerCase (Hatte die vorher noch nicht)
        <variables>
          <variable id="8;HpY]B2OxIN[kdORi-N">text</variable>
          <variable id="u+mE0j_ZSEIC7C5U$t5h">cover</variable>
          <variable id="xLn/#U__],S7chRg;8|f">b64</variable>
          <variable id="}::%ssNR6x.*%p5dXe;X">pfad</variable>
        </variables>
        <block type="procedures_defcustomreturn" id="rY;j^;~*L]2/F7RXQ:vP" x="63" y="12">
          <mutation statements="false">
            <arg name="text" varid="8;HpY]B2OxIN[kdORi-N"></arg>
          </mutation>
          <field name="NAME">lowCase</field>
          <field name="SCRIPT">cmV0dXJuIHRleHQudG9Mb3dlckNhc2UoKTs=</field>
        <block type="procedures_defcustomreturn" id="?=Ght)|4a^y+NM^zYle." x="62" y="38">
          </mutation>
          <field name="NAME">encode</field>
          <field name="SCRIPT">cmV0dXJuIEJ1ZmZlci5mcm9tKHRleHQpLnRvU3RyaW5nKCdiYXNlNjQnKTs=</field>
        <block type="procedures_defcustomreturn" id="Iodb:IxRxNP!s`/!v3)?" x="63" y="63">
          </mutation>
          <field name="NAME">decode</field>
          <field name="SCRIPT">cmV0dXJuIEJ1ZmZlci5mcm9tKHRleHQsJ2Jhc2U2NCcpLnRvU3RyaW5nKCd1dGY4Jyk7</field>
        <block type="variables_set" id="g^5.h*(*]0_nqmg[wRxH" x="63" y="88">
          <field name="VAR" id="u+mE0j_ZSEIC7C5U$t5h">cover</field>
            <block type="procedures_callcustomreturn" id="w?SQy@+y*Ql0~VC/6/v.">
              <mutation name="lowCase">
                <arg name="text"></arg>
              </mutation>
              <value name="ARG0">
                <block type="text" id="ke8i-7n!ZN[JTeQ6:j[M">
                  <field name="TEXT">Guardians of the Galaxy Vol. 2</field>
            <block type="variables_set" id="QszkP[4Nizg/fDtBww`Q">
              <field name="VAR" id="xLn/#U__],S7chRg;8|f">b64</field>
                <block type="procedures_callcustomreturn" id="p7|Y?YW|q;N!s%E=k`lq" inline="true">
                  <mutation name="encode">
                  </mutation>
                  <value name="ARG0">
                    <block type="variables_get" id="b@80qrRs|+hN72O=jHln">
                <block type="variables_set" id="!gB}Q]POG(3$CjWbLpt5">
                  <field name="VAR" id="8;HpY]B2OxIN[kdORi-N">text</field>
                    <block type="procedures_callcustomreturn" id="+f,Ibj@iy(ON!Eeyu#pE" inline="true">
                      <mutation name="decode">
                      </mutation>
                      <value name="ARG0">
                        <block type="variables_get" id="^Y66h3Kir=,,ax^nE%#f">
                    <block type="variables_set" id="]eSeI7=%3a),QIMc|3$J">
                      <field name="VAR" id="}::%ssNR6x.*%p5dXe;X">pfad</field>
                        <block type="text_join" id="eI)24{)OJmyLTw5_HhmQ">
                          <value name="ADD0">
                            <block type="text" id="FKr2Mj?/yu8tc-LJhe9%">
                              <field name="TEXT">/media/hdd/AdvancedEventLibrary/cover/</field>
                          <value name="ADD1">
                            <block type="variables_get" id="XpM,P786cfc.bD0P-69g">
                        <block type="debug" id="mWdUp_h/%vZCKta7i37/" inline="true">
                          <value name="TEXT">
                            <shadow type="text" id="i?gGvfN}OAZqzJr=Z!L%">
                            <block type="variables_get" id=".G.W].MtuFq|y5T%+^rF">
                            <block type="debug" id="~KlN^Lx4XN2rUzXYJToc" inline="true">
                              <value name="TEXT">
                                <block type="variables_get" id="cHCV_bj|j`iqlpH=mww`">
                                <block type="debug" id="cC:Z=[Nu#d+kf0RXZz=3" inline="true">
                                  <value name="TEXT">
                                    <block type="variables_get" id="cZ.r6CGJHp^,[+=h_7R_">
                                    <block type="debug" id="v;TV6+Xg$T:|X/*-j|2N" inline="true">
                                      <value name="TEXT">
                                        <block type="variables_get" id="i;CEywOS#6*f`_N389|_">
      Okay die letzte hatte es - sorry 😊
        fastfoot @Chris76e last edited by fastfoot
        @chris76e sagte in Text in Base64 codieren und Datei von Netzlaufwerk suchen:
        Wie kann ich das jetzt in ioBroker machen
        ich würde die Box ja mit nfs einbinden(wird empfohlen), aber da du deine Settings auf cifs/smb eingestellt hast sollte das auf der Konsole der VM so gehen, erstmal nur händisch
        sudo -u iobroker mkdir -p /home/iobroker/vubox
        sudo mount -t cifs -o username=user,password=password,rw,file_mode=0777,dir_mode=0777 //192.168.0.90/VUUNO4KSE/Harddisk /home/iobroker/vubox
        Chris76e 1 Reply Last reply Reply Quote 1
        • Chris76e
          Chris76e @fastfoot last edited by Chris76e
          @fastfoot
          kommt dieser Fehler
          mount: bad usage
          @fastfoot sagte in Text in Base64 codieren und Datei von Netzlaufwerk suchen:
          Bin offen für alles
            @chris76e mach mal das Leerzeichen vor password weg
            Chris76e 1 Reply Last reply Reply Quote 0
            • Chris76e
              @fastfoot
              mount error(22): Invalid argument
              Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
              habe schon mit smbpasswd das passwort geändert, box neugestartet......
              • Chris76e
                so sieht die smb.conf auf der Box aus
                #config version:3.6.25-vti001
                [global]
                   guest account = root
                   security = user
                   map to guest = bad user
                   server string = VTi/Vu+ network shares at %h
                   workgroup = VuPlus
                   socket options = TCP_NODELAY
                   smb passwd file = /etc/samba/private/smbpasswd
                   encrypt passwords = yes
                   passdb backend = smbpasswd
                   idmap backend = smbpasswd
                   obey pam restrictions = no
                   unix extensions = no
                   wide links = yes
                   unix charset = utf-8
                   max stat cache size = 64
                   null passwords = yes
                [rootfs]
                  comment = Do not touch !
                  path = /
                  read only = no
                  public = yes
                  guest ok = yes
                  valid users = root
                  force create mode = 600
                  force directory mode = 700
                  force security mode = 600
                  force directory security mode = 700
                [Harddisk]
                  comment = The harddisk
                  path = /media/hdd
                  read only = no
                  public = yes
                  guest ok = yes
                  valid users = root
                [VMC]
                comment = VMC
                path = /media/VMC
                read only = no
                public = yes
                guest ok = yes
                  @chris76e username und passwort hast du aber geändert?
                  • OliverIO
                    OliverIO @Chris76e last edited by OliverIO
                    @chris76e
                    Leider hilft dir der Pfad auf deine nas so erst mal nicht, wenn du das Bild im Browser anzeigen lassen möchtest.
                    Deinem Browser kann so nicht auf das Laufwerk zugreifen.
                    Jetzt könnte man das über ioBroker machen, allerdings ist es da etwas aufwändig, da man die Datei erst einmal zum Web Server hochladen muss.
                    Daher schlage ich vor, dass du einen neuen Web Server einrichtest (Nginx bietet sich da an ).
                    Dieser Web Server ist so konfiguriert, dass er nur dieses eine Verzeichnis anbietet.
                    So musst du in vis einfach nur die URL so berechnen, dass sie auf die URL des jeweiligen Bildes zeigt. Wie du vom Film Namen zur Base 64 Bezeichnung kommst, haben wir die vorschreiber schon dargestellt
                    F Chris76e OliverIO 4 Replies Last reply Reply Quote 0
                      fastfoot @OliverIO last edited by
                      @oliverio sagte in Text in Base64 codieren und Datei von Netzlaufwerk suchen:
                      werk zugreifen.
                      aber auch nginx braucht die Datei ja erstmal lokal? deshalb der mount
                      • OliverIO
                        OliverIO @fastfoot last edited by
                        @fastfoot
                        Je nachdem wo man am besten nginx laufen lässt.
                        Ja wahrscheinlich erst per Mount auf die eine Maschine,
                        Dort dann nginx installieren und einrichten.
                        • Chris76e
                          Chris76e @OliverIO last edited by
                          @oliverio
                          Das ist eine VU+ Box, ein Enigma2 Sat Receiver 😎 Glaube nicht das da ein Webserver drauf läuft..... Möchte ja nur einfach die Datei davon laden können.
                            @fastfoot
                            nimm mal noch das hier weg ,file_mode=0777,dir_mode=0777
                            • Chris76e
                              @fastfoot
                              jetzt kommt das
                              mount: /home/iobroker/vubox: can't find in /etc/fstab.
                              • Chris76e
                                Hmm, dachte wenn ich den Mount von der VU+ auf meinem ioBroker habe das ich dann einfach die Datei laden kann als ob die lokal im ioBroker liegt.
                                Ist das nicht so?
                                • OliverIO
                                  @chris76e
                                  Ich lese, das es für Enigma vu+ ein webinterface / openwebif gibt
                                  Wenn man über dieses webinterface schafft die Bilder anzeigen zu lassen, dann hast du deinen Webserver.
                                  Dann musst du in vis nur noch die URLs so einbauen, das sie auf das webinterface zeigen.
                                    @chris76e seltsam, mit proxmox vm kenne ich mich nicht aus aber eigentlich sollte man eben keinen eintrag in der fstab benötigen.
                                    da bin ich jetzt erstmal überfragt, sorry
                                    • Chris76e
                                      @chris76e
                                      Wenn ich das Versuche
                                      http://192.168.0.90/media/hdd/AdvancedEventLibrary/preview/a25hc3QgaW4gZGV1dHNjaGxhbmQgLSBlMDEgLSBzdHJhZmUsIGxpZWJlLCBob2ZmbnVuZw==.jpg%22
                                      kommt ein 404 Fehler.
                                        @chris76e gib mal //192.168.0.90/VUUNO4KSE/Harddisk im Windows Dateiexplorer ein ob das überhaupt der richtige share ist. NICHT im Browser
                                        • Chris76e
                                          @fastfoot
                                          Also das Netztlaufwerk auf die Festplatte ist
                                          \\vuuno4kse\Harddisk
                                          so in Windows angebunden. Habe es auch schon mit kleinbuchstaben probiert
                                            @chris76e ja dann passt der mount point, finde nichts im Netz zu diesem fstab Fehler. Ist denn überhaupt /home/iobroker/vubox erstellt worden???
                                            2661
