Log-Warnungen
Die Langfassung bitte.
du meinst vom iob diag? -
@thomas-braun said in Log-Warnungen:
ls -la /var/run/reboot-required
======================= SUMMARY ======================= v.2023-10-10 Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Installation: native Kernel: aarch64 Userland: armhf Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 Recommended versions are nodejs 18.18.2 and npm 9.8.1 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.8G 1.2G 1.8G 0.0K 728M 2.5G Swap: 99M 0B 99M Total: 3.9G 1.2G 1.9G Active iob-Instances: 21 Active repo(s): stable ioBroker Core: js-controller 5.0.12 admin 6.10.1 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 28879 States: 21973 Size of iob-Database: 37M /opt/iobroker/iobroker-data/objects.jsonl 23M /opt/iobroker/iobroker-data/objects.json.migrated 23M /opt/iobroker/iobroker-data/objects.json.bak.migrated 0 /opt/iobroker/iobroker-data/objects.json.broken 67M /opt/iobroker/iobroker-data/states.jsonl 6.6M /opt/iobroker/iobroker-data/states.json.migrated 6.6M /opt/iobroker/iobroker-data/states.json.bak.migrated 0 /opt/iobroker/iobroker-data/states.json.broken =================== END OF SUMMARY ====================
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : aarch64 Userland : armhf Systemuptime and Load: 14:47:25 up 9 min, 1 user, load average: 1.34, 1.61, 1.01 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Tue 2023-10-17 14:47:25 CEST Universal time: Tue 2023-10-17 12:47:25 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 1.3G 1.8G 0.0K 731M 2.4G Swap: 99M 0B 99M Total: 3.9G 1.3G 1.9G 3793 M total memory 1288 M used memory 1327 M active memory 499 M inactive memory 1773 M free memory 106 M buffer memory 624 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 110G 21G 85G 20% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 759M 836K 758M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sda1 vfat 253M 53M 200M 21% /boot tmpfs tmpfs 380M 8.0K 380M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Oct 17 14:38:03 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:48:61:3D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=52c6d86a-02 rootfstype=ext4 fsck.repair=yes rootwait [Tue Oct 17 14:38:05 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Tue Oct 17 14:38:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Tue Oct 17 14:38:06 2023] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro Files in neuralgic directories: /var: 4.9G /var/ 3.6G /var/log 3.0G /var/log/journal/45677fd33dca4b97838c0214e7692911 3.0G /var/log/journal 1.2G /var/cache/apt Archived and active journals take up 2.9G in the file system. /opt/iobroker/backups: 9.6G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.3G /opt/iobroker/iobroker-data/ 513M /opt/iobroker/iobroker-data/files 311M /opt/iobroker/iobroker-data/backup-objects 306M /opt/iobroker/iobroker-data/sonosCache 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png The five largest files in iobroker-data are: 69M /opt/iobroker/iobroker-data/states.jsonl 37M /opt/iobroker/iobroker-data/objects.jsonl 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 23M /opt/iobroker/iobroker-data/objects.json.migrated 23M /opt/iobroker/iobroker-data/objects.json.bak.migrated USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 nodejs: Installed: 18.18.2-1nodesource1 Candidate: 18.18.2-1nodesource1 Version table: *** 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.12 admin: 6.10.1 javascript: 7.1.4 Adapters from github: 1 Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled system.adapter.ble.0 : ble : raspberrypi - disabled system.adapter.daswetter.0 : daswetter : raspberrypi - disabled + system.adapter.deconz.0 : deconz : raspberrypi - enabled, port: 8090 system.adapter.devices.0 : devices : raspberrypi - disabled + system.adapter.discovery.0 : discovery : raspberrypi - enabled system.adapter.dwd.0 : dwd : raspberrypi - disabled system.adapter.fb-checkpresence.0 : fb-checkpresence : raspberrypi - disabled system.adapter.flot.0 : flot : raspberrypi - disabled system.adapter.harmony.0 : harmony : raspberrypi - disabled system.adapter.homekit-controller.0 : homekit-controller : raspberrypi - disabled system.adapter.hue-extended.0 : hue-extended : raspberrypi - disabled + system.adapter.hue.0 : hue : raspberrypi - enabled, port: 80 + system.adapter.hue.1 : hue : raspberrypi - enabled, port: 80 + system.adapter.hue.2 : hue : raspberrypi - enabled, port: 443 system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting : raspberrypi - disabled system.adapter.icons-icons8.0 : icons-icons8 : raspberrypi - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : raspberrypi - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : raspberrypi - disabled system.adapter.influxdb.0 : influxdb : raspberrypi - disabled, port: 8086 + system.adapter.iot.0 : iot : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled system.adapter.lg-thinq.0 : lg-thinq : raspberrypi - disabled system.adapter.lgtv.0 : lgtv : raspberrypi - disabled system.adapter.linkeddevices.0 : linkeddevices : raspberrypi - disabled system.adapter.meteoalarm.0 : meteoalarm : raspberrypi - enabled system.adapter.mihome-vacuum.0 : mihome-vacuum : raspberrypi - disabled, port: 54321 system.adapter.mihome.0 : mihome : raspberrypi - disabled, port: 9898, bind: 0.0.0.0 + system.adapter.ping.0 : ping : raspberrypi - enabled system.adapter.pollenflug.0 : pollenflug : raspberrypi - disabled + system.adapter.sayit.0 : sayit : raspberrypi - enabled + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.socketio.0 : socketio : raspberrypi - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonos.0 : sonos : raspberrypi - enabled + system.adapter.spotify-premium.0 : spotify-premium : raspberrypi - enabled + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.terminal.0 : terminal : raspberrypi - enabled, port: 8088, bind: 0.0.0.0, run as: admin system.adapter.tr-064.0 : tr-064 : raspberrypi - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : raspberrypi - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : raspberrypi - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : raspberrypi - disabled system.adapter.vis-google-fonts.0 : vis-google-fonts : raspberrypi - enabled system.adapter.vis-history.0 : vis-history : raspberrypi - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - disabled system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : raspberrypi - disabled system.adapter.vis-justgage.0 : vis-justgage : raspberrypi - disabled system.adapter.vis-material.0 : vis-material : raspberrypi - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : raspberrypi - disabled system.adapter.vis-metro.0 : vis-metro : raspberrypi - disabled system.adapter.vis-players.0 : vis-players : raspberrypi - disabled system.adapter.vis-plumb.0 : vis-plumb : raspberrypi - disabled system.adapter.vis-rgraph.0 : vis-rgraph : raspberrypi - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - disabled system.adapter.vis-weather.0 : vis-weather : raspberrypi - disabled system.adapter.vis.0 : vis : raspberrypi - enabled system.adapter.weatherunderground.0 : weatherunderground : raspberrypi - disabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.yahka.0 : yahka : raspberrypi - disabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.deconz.0 : deconz : raspberrypi - enabled, port: 8090 + system.adapter.hue.0 : hue : raspberrypi - enabled, port: 80 + system.adapter.hue.1 : hue : raspberrypi - enabled, port: 80 + system.adapter.hue.2 : hue : raspberrypi - enabled, port: 443 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.socketio.0 : socketio : raspberrypi - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.terminal.0 : terminal : raspberrypi - enabled, port: 8088, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.10.1 , installed 6.10.1 Adapter "alexa2" : 3.25.2 , installed 3.25.2 Adapter "backitup" : 2.8.1 , installed 2.8.1 Adapter "ble" : 0.13.4 , installed 0.13.4 Adapter "daswetter" : 3.1.10 , installed 3.1.10 Adapter "deconz" : 1.3.21 , installed 1.3.21 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "homekit-controller": 0.5.8, installed 0.5.8 Adapter "hue" : 3.10.0 , installed 3.10.0 Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "iot" : 1.14.5 , installed 1.14.5 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "lg-thinq" : 0.1.4 , installed 0.1.4 Adapter "lgtv" : 2.1.1 , installed 2.1.1 Adapter "linkeddevices": 1.5.5 , installed 1.5.5 Adapter "meteoalarm" : 2.3.7 , installed 2.3.7 Adapter "mihome" : 1.4.0 , installed 1.4.0 Adapter "mihome-vacuum": 4.0.0 , installed 4.0.0 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "sayit" : 3.0.5 , installed 3.0.5 Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.5.5 , installed 6.5.5 Adapter "sonos" : 2.3.1 , installed 2.3.1 Adapter "spotify-premium": 1.2.2 , installed 1.2.2 Adapter "telegram" : 1.16.0 , installed 1.16.0 Adapter "terminal" : 1.0.0 , installed 1.0.0 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 0.96.0 , installed 0.96.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.6 , installed 2.5.6 Adapter "weatherunderground": 3.6.0, installed 3.6.0 Adapter "web" : 6.1.2 , installed 6.1.2 Adapter "ws" : 2.5.5 , installed 2.5.5 Adapter "yahka" : 1.0.3 , installed 1.0.3 Objects and States Please stand by - This may take a while Objects: 28879 States: 21973 *** OS-Repositories and Updates *** Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:5005 0.0.0.0:* LISTEN 0 13129 373/node tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14759 530/sshd: /usr/sbin tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 1829 504/iobroker.js-con tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 12175 504/iobroker.js-con tcp6 0 0 :::22 :::* LISTEN 0 14761 530/sshd: /usr/sbin tcp6 0 0 :::8088 :::* LISTEN 1001 16244 1099/io.terminal.0 tcp6 0 0 :::8081 :::* LISTEN 1001 17440 802/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 17894 1214/io.web.0 tcp6 0 0 :::8084 :::* LISTEN 1001 17367 1231/io.socketio.0 tcp6 0 0 :::3500 :::* LISTEN 0 13265 373/node tcp6 0 0 :::3501 :::* LISTEN 1001 21047 1364/io.sonos.0 udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 17667 1017/io.shelly.0 udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 17320 1207/io.deconz.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 14781 724/dhcpcd udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 1737 356/avahi-daemon: r udp 0 0 0.0.0.0:34062 0.0.0.0:* 108 1739 356/avahi-daemon: r udp6 0 0 :::1900 :::* 1001 17322 1207/io.deconz.0 udp6 0 0 :::1900 :::* 1001 17321 1207/io.deconz.0 udp6 0 0 :::546 :::* 0 14793 724/dhcpcd udp6 0 0 :::37766 :::* 108 1740 356/avahi-daemon: r udp6 0 0 :::5353 :::* 108 1738 356/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-10-17 14:48:00.027 - warn: javascript.0 (859) at listOnTimeout (node:internal/timers:569:17) 2023-10-17 14:48:00.027 - warn: javascript.0 (859) at processTimers (node:internal/timers:512:7) 2023-10-17 14:48:00.051 - warn: javascript.0 (859) Read-only state "deconz.0.Groups.24.all_on" has been written without ack-flag with value "true" 2023-10-17 14:48:01.029 - warn: javascript.0 (859) State "hue.1.Philips_hue_2.REPEATER.on" not found 2023-10-17 14:48:01.030 - warn: javascript.0 (859) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20) 2023-10-17 14:48:01.031 - warn: javascript.0 (859) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1798:29) 2023-10-17 14:48:01.031 - warn: javascript.0 (859) at listOnTimeout (node:internal/timers:571:11) 2023-10-17 14:48:01.031 - warn: javascript.0 (859) at processTimers (node:internal/timers:512:7) 2023-10-17 14:48:01.032 - warn: javascript.0 (859) State "deconz.0.Lights.10.on" not found 2023-10-17 14:48:01.033 - warn: javascript.0 (859) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20) 2023-10-17 14:48:01.033 - warn: javascript.0 (859) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1798:29) 2023-10-17 14:48:01.034 - warn: javascript.0 (859) at listOnTimeout (node:internal/timers:571:11) 2023-10-17 14:48:01.034 - warn: javascript.0 (859) at processTimers (node:internal/timers:512:7) 2023-10-17 14:48:01.035 - warn: javascript.0 (859) State "deconz.0.Lights.8.on" not found 2023-10-17 14:48:01.036 - warn: javascript.0 (859) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20) 2023-10-17 14:48:01.037 - warn: javascript.0 (859) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1798:29) 2023-10-17 14:48:01.037 - warn: javascript.0 (859) at listOnTimeout (node:internal/timers:571:11) 2023-10-17 14:48:01.038 - warn: javascript.0 (859) at processTimers (node:internal/timers:512:7) 2023-10-17 14:48:01.043 - warn: javascript.0 (859) State "deconz.0.Lights.9.on" not found 2023-10-17 14:48:01.045 - warn: javascript.0 (859) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20) 2023-10-17 14:48:01.045 - warn: javascript.0 (859) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1798:29) 2023-10-17 14:48:01.046 - warn: javascript.0 (859) at listOnTimeout (node:internal/timers:571:11) 2023-10-17 14:48:01.046 - warn: javascript.0 (859) at processTimers (node:internal/timers:512:7) 2023-10-17 14:48:52.260 - warn: sonos.0 (1364) State "sonos.0.root.192_168_1_62.current_track_number" has no existing object, this might lead to an error in future versions 2023-10-17 14:48:52.310 - warn: sonos.0 (1364) State "sonos.0.root.192_168_1_62.queue_html" has no existing object, this might lead to an error in future versions
das kommt gleich ls -la /var/run/reboot-required
pi@raspberrypi:~ $ ls -la /var/run/reboot-required ls: cannot access '/var/run/reboot-required': No such file or directory
Okay, die Meldung zum Reboot im iob diag ist ja auch verschwunden...
War also doch erforderlich. -
jep. habe vorhin vom Firefox zum Chrome Browser gewechselt. Der Firefox spinnt manchmal -
iob diag hat aber nix mit dem Browser zu tun, das läuft auf einer tieferen Ebene ab.
System soweit auf Stand, dann kannst du ja jetzt deine States in den Skripten usw. suchen. -
was ist damit denn gemeint?
javascript.0 2023-10-17 14:56:01.016 warn at processTimers (node:internal/timers:512:7) javascript.0 2023-10-17 14:56:01.016 warn at listOnTimeout (node:internal/timers:571:11) javascript.0 2023-10-17 14:56:01.015 warn at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1798:29) javascript.0 2023-10-17 14:56:01.015 warn at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
System soweit auf Stand, dann kannst du ja jetzt deine States in den Skripten usw. suchen.Dickes Danke! Also ist soweit alles in Ordnung? Sorry, aber wo finde ich das denn, das ich es ändern kann?
@rehmosch sagte: was ist damit denn gemeint?
Das sind Folgewarnungen, die i.d.R. nicht interessieren. Sie verschwinden mit der Beseitigung der Ursache für die ursprüngliche Warnung, z.B.
warn State "deconz.0.Lights.9.on" not found
@paul53 Danke Paul, aber wie kann ich dieses beseitigen bzw. wie editiere ich die
javascript.0 in der Zeile 571 ? Darf ich diese überhaupt editieren oder gibt es einen Adapter oder Programm dafür? Mir ist nicht klar wo das script sein soll ;(Danke nochmal
@rehmosch sagte: wie editiere ich die javascript.0 in der Zeile 571 ?
Gar nicht: Ignorieren. Folgefehler erzeugt der Javascript-Adapter. An dem sollte man nicht schrauben.
