    4. ioBroker hängt sich regelmäßig auf
      kukli31 @DJMarc75 last edited by Homoran
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi4-master
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       15:35:57 up 7 min,  1 user,  load average: 3.17, 2.86, 1.46
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Tue 2023-10-17 15:35:57 CEST
                 Universal time: Tue 2023-10-17 13:35:57 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        2.5G        499M        1.0M        822M        1.2G
      Swap:            99M          0B         99M
      Total:          3.9G        2.5G        599M
               3793 M total memory
               2472 M used memory
               2945 M active memory
                197 M inactive memory
                499 M free memory
                 45 M buffer memory
                776 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      235G  5.8G  220G   3% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.2M  758M   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Tue Oct 17 15:28:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:71:9F:4D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=58e76898-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): write access will be enabled during recovery
      [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): 2 orphan inodes deleted
      [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): recovery complete
      [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Oct 17 15:28:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Tue Oct 17 15:28:30 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.4G    /var/
      846M    /var/log
      793M    /var/log/journal/49f5cfb508e342378183307452dc5b73
      278M    /var/cache
      Archived and active journals take up 792.1M in the file system.
      /opt/iobroker/backups:
      125M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      489M    /opt/iobroker/iobroker-data/
      286M    /opt/iobroker/iobroker-data/files
      150M    /opt/iobroker/iobroker-data/backup-objects
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      43M     /opt/iobroker/iobroker-data/files/iot.admin
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      23M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      12M     /opt/iobroker/iobroker-data/states.jsonl
      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /home/iobroker/.diag.sh: line 277: nodejs: command not found
      /usr/local/bin/node             v18.18.0
      /usr/local/bin/npm              9.8.1
      /usr/local/bin/npx              9.8.1
      /usr/local/bin/corepack         0.19.0
      /home/iobroker/.diag.sh: line 288: nodejs: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi4-master                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-master                      -  enabled
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi4-master                      - disabled
      + system.adapter.backitup.0               : backitup              : raspberrypi4-master                      -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi4-master                      -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi4-master                      -  enabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi4-master                      -  enabled
      + system.adapter.device-reminder.1        : device-reminder       : raspberrypi4-master                      -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi4-master                      -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi4-master                      -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi4-master                      -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : raspberrypi4-master                      -  enabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi4-master                      -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi4-master                      - disabled
      + system.adapter.history.0                : history               : raspberrypi4-master                      -  enabled
      + system.adapter.homepilot20.0            : homepilot20           : raspberrypi4-master                      -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi4-master                      -  enabled
        system.adapter.ical.1                   : ical                  : raspberrypi4-master                      -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi4-master                      - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi4-master                      - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4-master                      - disabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi4-master                      -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi4-master                      -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi4-master                      -  enabled
        system.adapter.jarvis.0                 : jarvis                : raspberrypi4-master                      - disabled
        system.adapter.jarvis.1                 : jarvis                : raspberrypi4-master                      - disabled
      + system.adapter.javascript.0             : javascript            : raspberrypi4-master                      -  enabled
      + system.adapter.life360.0                : life360               : raspberrypi4-master                      -  enabled
      + system.adapter.mercedesme.0             : mercedesme            : raspberrypi4-master                      -  enabled
        system.adapter.meross.0                 : meross                : raspberrypi4-master                      - disabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4neu                          -  enabled, port: 1884, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : raspberrypi4-master                      - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.netatmo.0                : netatmo               : raspberrypi4-master                      -  enabled
        system.adapter.powerfox2.0              : powerfox2             : raspberrypi4-master                      -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypi4-master                      -  enabled
      + system.adapter.pushover.1               : pushover              : raspberrypi4-master                      -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-master                      -  enabled
      + system.adapter.rssfeed.0                : rssfeed               : raspberrypi4-master                      -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi4-master                      -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : raspberrypi4-master                      -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi4-master                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi4-master                      -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi4neu                          -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : raspberrypi4-master                      -  enabled
        system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi4-master                      - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-master                      -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi4-master                      -  enabled
      + system.adapter.tr-064.1                 : tr-064                : raspberrypi4-master                      -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4-master                      -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi4-master                      - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi4-master                      - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4-master                      - disabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi4-master                      - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4-master                      - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4-master                      - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi4-master                      -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4-master                      - disabled
        system.adapter.vis-map.0                : vis-map               : raspberrypi4-master                      - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi4-master                      - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi4-master                      - disabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi4-master                      - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4-master                      - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi4-master                      - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi4-master                      -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi4-master                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi4-master                      -  enabled
      + system.adapter.wolf-smartset.0          : wolf-smartset         : raspberrypi4-master                      -  enabled
      + system.adapter.yahka.0                  : yahka                 : raspberrypi4-master                      -  enabled
      + system.adapter.yahka.1                  : yahka                 : raspberrypi4-master                      -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi4neu                          -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_76e54d3c6f12ec118f7721c7bd930c07-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "discovery"    : 3.1.0    , installed 3.2.0
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 1.14.5   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "mercedesme"   : 0.1.1    , installed 0.1.3
      Adapter    "meross"       : 1.15.1   , installed 1.15.1
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
      Adapter    "pushover"     : 3.0.3    , installed 3.0.4
      Adapter    "rssfeed"      : 2.6.1    , installed 2.8.1
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
      Adapter    "sonos"        : 2.3.1    , installed 2.3.1
      Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Objects and States
      Objects:        19704
      States:         16161
      W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 https://apt.grafana.com stable InRelease
      Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:6 https://repos.influxdata.com/debian stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:8 https://packages.grafana.com/oss/deb stable InRelease
      Reading package lists...
      Pending Updates: 12
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15303      822/iobroker.js-con
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15298      822/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13632      521/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:41421           0.0.0.0:*               LISTEN      1001       22634      2042/io.yahka.0
      tcp        0      0 127.0.0.1:40265         0.0.0.0:*               LISTEN      1001       20073      2170/io.yahka.1
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15898      1483/io.shelly.1
      tcp        0      0 127.0.0.1:36815         0.0.0.0:*               LISTEN      1001       21674      2042/io.yahka.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      110        13014      821/grafana
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13634      521/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22719      2151/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13942      979/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        1897       707/influxd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20001      2084/io.simple-api.
      tcp6       0      0 :::34217                :::*                    LISTEN      1001       20065      2170/io.yahka.1
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       17845      1494/io.sonos.0
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       17715      1357/io.broadlink2.
      udp        0      0 0.0.0.0:45956           0.0.0.0:*                           1001       17785      1357/io.broadlink2.
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12772      394/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17074      1380/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15069      703/dhcpcd
      udp        0      0 0.0.0.0:47476           0.0.0.0:*                           108        12774      394/avahi-daemon: r
      udp        0      0 0.0.0.0:55764           0.0.0.0:*                           1001       21523      1380/io.shelly.0
      udp        0      0 0.0.0.0:51720           0.0.0.0:*                           1001       17742      1357/io.broadlink2.
      udp6       0      0 :::5353                 :::*                                108        12773      394/avahi-daemon: r
      udp6       0      0 :::40833                :::*                                108        12775      394/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          15080      703/dhcpcd
      2023-10-17 15:36:36.793  - warn: powerfox2.0 (3645) get state error: Connection is closed.
      2023-10-17 15:36:37.522  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2023-10-17 15:36:45.053  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 3783
      2023-10-17 15:36:49.275  - info: powerfox2.0 (3783) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
      2023-10-17 15:36:50.185  - info: powerfox2.0 (3783) Terminated (NO_ERROR): Without reason
      2023-10-17 15:36:50.760  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2023-10-17 15:36:56.629  - info: alexa2.0 (1299) No smart home devices to query
      2023-10-17 15:37:00.240  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 3828
      2023-10-17 15:37:08.688  - info: alexa2.0 (1299) Subscribing to states...
      2023-10-17 15:37:08.696  - info: alexa2.0 (1299) Deleting the following states: ["Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece","Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f.#delete","Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f.#enabled","Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f.active","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d.#delete","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d.#enabled","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d.active","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8.#delete","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8.#enabled","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8.powerState","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#delete","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#enabled","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#includeInAllQuery","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#query","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.Blind-Lift-rangeValue","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f.#delete","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f.#enabled","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f.powerState","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#delete","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#enabled","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#includeInAllQuery","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#query","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.percentage","Smart-Home-Devices.41a4fc68-0e9c-4b7e-b977-2fe6931bd520.Blind-Lift-rangeValue","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#delete","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#enabled","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#includeInAllQuery","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#query","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.Blind-Lift-rangeValue","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#delete","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#enabled","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#includeInAllQuery","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#query","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.Blind-Lift-rangeValue","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8.#delete","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8.#enabled","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8.powerState","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e.#delete","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e.#enabled","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e.powerState","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#delete","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#enabled","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#includeInAllQuery","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#query","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.connectivity","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.connectivity-reason","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.powerState","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#delete","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#enabled","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#includeInAllQuery","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#query","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.powerState","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa.#delete","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa.#enabled","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa.powerState","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d.#delete","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d.#enabled","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d.active","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044.#delete","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044.#enabled","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044.powerState","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#delete","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#enabled","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#includeInAllQuery","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#query","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.Blind-Lift-rangeValue","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#delete","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#enabled","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#includeInAllQuery","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#query","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.Blind-Lift-rangeValue","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#delete","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#enabled","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#includeInAllQuery","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#query","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.connectivity","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.connectivity-reason","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.powerState","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#delete","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#enabled","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#includeInAllQuery","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#query","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.Blind-Lift-rangeValue","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#delete","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#enabled","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#includeInAllQuery","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#query","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.connectivity","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.connectivity-reason","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.powerState","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#delete","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#enabled","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#includeInAllQuery","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#query","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.connectivity","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.connectivity-reason","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.powerState","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.#delete","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.#enabled","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.#query","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.connectivity","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.connectivity-reason","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.powerState","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57.#delete","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57.#enabled","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57.active","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#delete","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#enabled","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#includeInAllQuery","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#query","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.connectivity","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.connectivity-reason","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.powerState","Smart-Home-Devices.d3b1e404-cfa4-4b7f-9cf1-9ee838498889.Blind-Lift-rangeValue","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39.#delete","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39.#enabled","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39.powerState","Smart-Home-Devices.e9180145-e4c6-43f3-acf7-2bf7a54acc31.Blind-Lift-rangeValue","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#delete","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#enabled","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#includeInAllQuery","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#query","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.connectivity","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.connectivity-reason","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.powerState","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#delete","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#enabled","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#includeInAllQuery","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#query","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.Blind-Lift-rangeValue","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#delete","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#enabled","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#includeInAllQuery","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#query","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.Blind-Lift-rangeValue"]
      2023-10-17 15:37:08.722  - info: powerfox2.0 (3828) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
      2023-10-17 15:37:10.825  - info: alexa2.0 (1299) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2023-10-17 15:37:13.296  - info: powerfox2.0 (3828) Terminated (NO_ERROR): Without reason
      2023-10-17 15:37:13.993  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2023-10-17 15:37:16.699  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 3877
      2023-10-17 15:37:21.493  - info: smartcontrol.0 (2097) Trigger 'Bewegung.Flur' was already activated 0.05 seconds ago and is ignored. Must be at least 2 seconds.
      2023-10-17 15:37:23.059  - info: powerfox2.0 (3877) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
      2023-10-17 15:37:27.148  - info: powerfox2.0 (3877) Terminated (NO_ERROR): Without reason
      2023-10-17 15:37:28.559  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2023-10-17 15:37:30.520  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 4498
      2023-10-17 15:37:32.558  - info: alexa2.0 (1299) Initialization Done ...
      2023-10-17 15:37:36.004  - info: powerfox2.0 (4498) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
      2023-10-17 15:37:38.061  - info: powerfox2.0 (4498) Terminated (NO_ERROR): Without reason
      2023-10-17 15:37:38.613  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2023-10-17 15:37:45.058  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 5180
      DJMarc75 Samson71 K 3 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @kukli31 last edited by
        @kukli31 bitte in Codetags packen ... </>
        • Samson71
          Samson71 Global Moderator @kukli31 last edited by
          @kukli31
          Zusätzlich zu den Codetags das korrigieren
            kukli31 @kukli31 last edited by
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     3793 M total memory
                     2472 M used memory
                      499 M free memory
                       45 M buffer memory
                      776 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            1.4G    /var/
            846M    /var/log
            278M    /var/cache
            USB-Devices by-id:
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.10.1
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        19704
            States:         16161
            Pending Updates: 12
              kukli31 @Samson71 last edited by kukli31
              @samson71 Hallo Markus, wie kann ich das reparieren?
                @djmarc75 said in ioBroker hängt sich regelmäßig auf:
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         3793 M total memory
                         2472 M used memory
                          499 M free memory
                           45 M buffer memory
                          776 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.4G    /var/
                846M    /var/log
                278M    /var/cache
                USB-Devices by-id:
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.10.1
                javascript:     7.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        19704
                States:         16161
                Pending Updates: 12
                • Samson71
                  @kukli31
                  Es gibt einer Fixer dafür von @Thomas-Braun
                    Thomas Braun Most Active @kukli31 last edited by Thomas Braun
                    @kukli31 sagte in ioBroker hängt sich regelmäßig auf:
                    Die Doublette in der Datei auch rauswerfen.
                    Zusätzlich halt das nodejs-Trümmerfeld aufräumen:
                    https://forum.iobroker.net/topic/69068/neuer-befehl-iob-nodejs-update
                      @samson71 said in ioBroker hängt sich regelmäßig auf:
                      @kukli31
                      Ich habe den Fixer laufen lassen. Danke schon mal für den Tipp.
                      Sieht es jetzt besser aus?
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                       16:10:31 up 42 min,  1 user,  load average: 4.03, 2.47, 2.04
                      CPU threads: 4
                      Current issues:
                                     Local time: Tue 2023-10-17 16:10:31 CEST
                                 Universal time: Tue 2023-10-17 14:10:31 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        2.6G        248M        0.0K        949M        1.1G
                      Swap:            99M        1.0M         98M
                      Total:          3.9G        2.6G        346M
                               3793 M total memory
                               2591 M used memory
                               3042 M active memory
                                164 M inactive memory
                                251 M free memory
                                 11 M buffer memory
                                938 M swap cache
                                 99 M total swap
                                  1 M used swap
                                 98 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4      235G  5.9G  220G   3% /
                      /var:
                      1.6G    /var/
                      846M    /var/log
                      444M    /var/cache
                      493M    /opt/iobroker/iobroker-data/
                      16M     /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      /usr/bin/nodejs         v18.18.2
                      /usr/bin/node           v18.18.2
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      /usr/bin/corepack       0.19.0
                      nodejs:
                        Installed: 18.18.2-1nodesource1
                        Candidate: 18.18.2-1nodesource1
                        Version table:
                       *** 18.18.2-1nodesource1 1001
                           18.18.1-1nodesource1 1001
                           18.18.0-1nodesource1 1001
                           18.17.1-1nodesource1 1001
                           18.17.0-1nodesource1 1001
                           18.16.1-1nodesource1 1001
                           18.16.0-1nodesource1 1001
                           18.15.0-1nodesource1 1001
                           18.14.2-1nodesource1 1001
                           18.14.1-1nodesource1 1001
                           18.14.0-1nodesource1 1001
                           18.13.0-1nodesource1 1001
                           18.12.0-1nodesource1 1001
                           18.11.0-1nodesource1 1001
                           18.10.0-1nodesource1 1001
                           18.9.1-1nodesource1 1001
                           18.9.0-1nodesource1 1001
                           18.8.0-1nodesource1 1001
                           18.7.0-1nodesource1 1001
                           18.6.0-1nodesource1 1001
                           18.5.0-1nodesource1 1001
                           18.4.0-1nodesource1 1001
                           18.3.0-1nodesource1 1001
                           18.2.0-1nodesource1 1001
                           18.1.0-1nodesource1 1001
                           18.0.0-1nodesource1 1001
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.10.1
                      javascript:     7.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        19704
                      States:         16161
                      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                      Hit:6 https://apt.grafana.com stable InRelease
                      Hit:7 https://repos.influxdata.com/debian stable InRelease
                      Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       132141     14958/iobroker.js-c
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       132134     14958/iobroker.js-c
                      tcp        0      0 127.0.0.1:45531         0.0.0.0:*               LISTEN      1001       135040     15730/io.yahka.0
                      tcp        0      0 0.0.0.0:36917           0.0.0.0:*               LISTEN      1001       135024     15730/io.yahka.0
                      tcp        0      0 127.0.0.1:33495         0.0.0.0:*               LISTEN      1001       135741     15779/io.yahka.1
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       132686     15264/io.shelly.1
                      tcp6       0      0 :::3000                 :::*                    LISTEN      110        129431     13931/grafana
                      tcp6       0      0 :::46621                :::*                    LISTEN      1001       135737     15779/io.yahka.1
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       136772     15710/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       131147     14979/io.admin.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       135544     15627/io.simple-api
                      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       132700     15279/io.sonos.0
                      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       130891     15357/io.broadlink2
                      udp        0      0 0.0.0.0:42105           0.0.0.0:*                           1001       129820     15204/io.shelly.0
                      udp        0      0 0.0.0.0:52763           0.0.0.0:*                           1001       132881     15357/io.broadlink2
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       129746     15204/io.shelly.0
                      udp        0      0 0.0.0.0:45468           0.0.0.0:*                           1001       131813     15357/io.broadlink2
                      udp6       0      0 :::546                  :::*                                0          127441     703/dhcpcd
                      2023-10-17 16:11:15.390  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16682
                      2023-10-17 16:11:19.473  - warn: shelly.0 (15204) State value to set for "shelly.0.SHDM-1#D3F1BE#1.temperatureF" has value "104.37" greater than max "100"
                      2023-10-17 16:11:21.407  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                      2023-10-17 16:11:21.458  - info: cloud.0 (15797) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                      2023-10-17 16:11:21.461  - info: cloud.0 (15797) Connection changed: disconnect
                      2023-10-17 16:11:26.630  - info: powerfox2.0 (16682) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                      2023-10-17 16:11:30.042  - warn: host.raspberrypi4-master instance system.adapter.powerfox2.0 already running with pid 16682
                      2023-10-17 16:11:31.113  - info: powerfox2.0 (16682) Terminated (NO_ERROR): Without reason
                      2023-10-17 16:11:31.695  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                      2023-10-17 16:11:45.070  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16749
                      2023-10-17 16:11:49.638  - warn: shelly.0 (15204) State value to set for "shelly.0.SHDM-1#D3F1BE#1.temperatureF" has value "104.49" greater than max "100"
                      2023-10-17 16:11:49.966  - info: powerfox2.0 (16749) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                      2023-10-17 16:11:52.217  - info: powerfox2.0 (16749) Terminated (NO_ERROR): Without reason
                      2023-10-17 16:11:52.760  - warn: powerfox2.0 (16749) get state error: Connection is closed.
                      2023-10-17 16:11:52.904  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                      2023-10-17 16:12:00.068  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16835
                      2023-10-17 16:12:03.990  - info: smartcontrol.0 (15638) Trigger 'Bewegung.Flur' was already activated 0.27 seconds ago and is ignored. Must be at least 2 seconds.
                      2023-10-17 16:12:06.244  - info: powerfox2.0 (16835) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                      2023-10-17 16:12:11.486  - info: powerfox2.0 (16835) Terminated (NO_ERROR): Without reason
                      2023-10-17 16:12:12.048  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                      2023-10-17 16:12:15.215  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 17434
                      2023-10-17 16:12:20.635  - info: powerfox2.0 (17434) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                      2023-10-17 16:12:21.623  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                      2023-10-17 16:12:24.250  - info: powerfox2.0 (17434) Terminated (NO_ERROR): Without reason
                      2023-10-17 16:12:25.251  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                        kukli31 @Thomas Braun last edited by
                        @thomas-braun said in ioBroker hängt sich regelmäßig auf:
                        So, ich habe beides bereinigt und sieht jetzt so aus:
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         16:19:40 up 51 min,  1 user,  load average: 1.87, 2.28, 2.20
                        CPU threads: 4
                        Current issues:
                                       Local time: Tue 2023-10-17 16:19:40 CEST
                                   Universal time: Tue 2023-10-17 14:19:40 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            3.8G        2.4G        716M        0.0K        637M        1.2G
                        Swap:            99M         95M        4.0M
                        Total:          3.9G        2.5G        721M
                                 3793 M total memory
                                 2439 M used memory
                                  601 M active memory
                                 2196 M inactive memory
                                  716 M free memory
                                    5 M buffer memory
                                  632 M swap cache
                                   99 M total swap
                                   95 M used swap
                                    4 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        1.6G    /var/
                        846M    /var/log
                        444M    /var/cache
                        518M    /opt/iobroker/iobroker-data/
                        33M     /opt/iobroker/iobroker-data/objects.jsonl
                        30M     /opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.10.1
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        19704
                        States:         16161
                        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:5 https://apt.grafana.com stable InRelease
                        Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Hit:8 https://repos.influxdata.com/debian stable InRelease
                        Pending Updates: 0
                        2023-10-17 16:20:19.759  - info: powerfox2.0 (19266) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                        2023-10-17 16:20:21.899  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                        2023-10-17 16:20:23.268  - info: powerfox2.0 (19266) Terminated (NO_ERROR): Without reason
                        2023-10-17 16:20:23.805  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                        2023-10-17 16:20:30.125  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19323
                        2023-10-17 16:20:38.246  - info: powerfox2.0 (19323) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                        2023-10-17 16:20:39.263  - info: powerfox2.0 (19323) Terminated (NO_ERROR): Without reason
                        2023-10-17 16:20:40.056  - warn: powerfox2.0 (19323) get state error: Connection is closed.
                        2023-10-17 16:20:40.180  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                        2023-10-17 16:20:45.069  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19371
                        2023-10-17 16:20:50.071  - info: powerfox2.0 (19371) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                        2023-10-17 16:20:52.169  - info: wolf-smartset.0 (15320) Initialization with Login and new Session done!
                        2023-10-17 16:20:52.404  - info: powerfox2.0 (19371) Terminated (NO_ERROR): Without reason
                        2023-10-17 16:20:53.477  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                        2023-10-17 16:21:00.064  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19455
                        2023-10-17 16:21:06.027  - info: powerfox2.0 (19455) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                        2023-10-17 16:21:08.498  - info: smartcontrol.0 (15638) Trigger 'Bewegung.Flur' was already activated 0.04 seconds ago and is ignored. Must be at least 2 seconds.
                        2023-10-17 16:21:11.620  - info: powerfox2.0 (19455) Terminated (NO_ERROR): Without reason
                        2023-10-17 16:21:12.157  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                        2023-10-17 16:21:15.245  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19998
                        2023-10-17 16:21:20.020  - info: powerfox2.0 (19998) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                        2023-10-17 16:21:21.136  - info: powerfox2.0 (19998) Terminated (NO_ERROR): Without reason
                        2023-10-17 16:21:21.735  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                        2023-10-17 16:21:21.797  - warn: powerfox2.0 (19998) get state error: Connection is closed.
                        2023-10-17 16:21:21.992  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                          Dein Dateisystem ist löchrig.
                          K Homoran 2 Replies Last reply Reply Quote 0
                            Was heißt das, bzw. wie und wo muss ich was fixen?
                              @thomas-braun sagte in ioBroker hängt sich regelmäßig auf:
                              Ich muss den Raspberry aus- und einschalten
                              aka Stecker ziehen.
                              killt Dateisysteme
                                @kukli31
                                Das heißt, das zwei inodes nicht mehr zugeordnet werden konnten und gelöscht wurden.
                                Konkret kann das alles mögliche verursachen, hängt davon ab was da drin stand.
                                Bei grafana ist immer noch was krumm:
                                Da sollte nur eine Zeile erscheinen.
                                  @kukli31
                                  Und nun? Hast du einen Tipp?
                                    Schau in /etc/apt/sources.list.d ob es etweder zwei .list-Dateien zu grafana gibt oder ob die bestehende Datei zwei entsprechende Zeilen hat.
                                      kukli31 @Thomas Braun last edited by kukli31
                                      pi@raspberrypi4-master:~ $ ls /etc/apt/
                                      apt.conf.d  auth.conf.d  keyrings  listchanges.conf  listchanges.conf.d  preferences.d  sources.list  sources.list.d  trusted.gpg  trusted.gpg.d
                                      sources.list.d ist leer
                                        @kukli31 Das kann/soll nicht sein.
                                        ls -lAh /etc/apt/sources.list.d/
                                          pi@raspberrypi4-master:~ $ ls -lAh /etc/apt/sources.list.d/
                                          total 16K
                                          -rw-r--r-- 1 root root 137 Oct 17 16:18 grafana.list
                                          -rw-r--r-- 1 root root 117 Sep  4 13:04 influxdata.list
                                          -rw-r--r-- 1 root root 100 Oct 17 16:05 nodesource.list
                                          -rw-r--r-- 1 root root 191 May  3 04:52 raspi.list
                                            Ich sag doch, das Verzeichnis ist nicht leer...
                                            cat /etc/apt/sources.list.d/grafana.list
                                            2912
