    4. ioBroker hängt sich regelmäßig auf
    • DJMarc75
      DJMarc75 @kukli31 last edited by
      @kukli31 bitte in Codetags packen ... </>
      • Samson71
        Samson71 Global Moderator @kukli31 last edited by
        @kukli31
        Zusätzlich zu den Codetags das korrigieren
        *** nodejs is NOT correctly installed ***
          kukli31 @kukli31 last edited by
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypi4-master
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           15:35:57 up 7 min,  1 user,  load average: 3.17, 2.86, 1.46
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Tue 2023-10-17 15:35:57 CEST
                     Universal time: Tue 2023-10-17 13:35:57 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            3.8G        2.5G        499M        1.0M        822M        1.2G
          Swap:            99M          0B         99M
          Total:          3.9G        2.5G        599M
                   3793 M total memory
                   2472 M used memory
                   2945 M active memory
                    197 M inactive memory
                    499 M free memory
                     45 M buffer memory
                    776 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4      235G  5.8G  220G   3% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     759M  1.2M  758M   1% /run
          /dev/sda1      vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Tue Oct 17 15:28:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:71:9F:4D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=58e76898-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
          [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): write access will be enabled during recovery
          [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
          [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): 2 orphan inodes deleted
          [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): recovery complete
          [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue Oct 17 15:28:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Tue Oct 17 15:28:30 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.4G    /var/
          846M    /var/log
          793M    /var/log/journal/49f5cfb508e342378183307452dc5b73
          278M    /var/cache
          Archived and active journals take up 792.1M in the file system.
          /opt/iobroker/backups:
          125M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          489M    /opt/iobroker/iobroker-data/
          286M    /opt/iobroker/iobroker-data/files
          150M    /opt/iobroker/iobroker-data/backup-objects
          52M     /opt/iobroker/iobroker-data/files/javascript.admin
          43M     /opt/iobroker/iobroker-data/files/iot.admin
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          23M     /opt/iobroker/iobroker-data/objects.jsonl
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
          12M     /opt/iobroker/iobroker-data/states.jsonl
          8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /home/iobroker/.diag.sh: line 277: nodejs: command not found
          /usr/local/bin/node             v18.18.0
          /usr/local/bin/npm              9.8.1
          /usr/local/bin/npx              9.8.1
          /usr/local/bin/corepack         0.19.0
          /home/iobroker/.diag.sh: line 288: nodejs: command not found
          nodejs:
            Installed: 18.17.1-deb-1nodesource1
            Candidate: 18.17.1-deb-1nodesource1
            Version table:
           *** 18.17.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.12
          admin:          6.10.1
          javascript:     7.1.4
          Adapters from github:   3
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi4-master                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-master                      -  enabled
            system.adapter.alias-manager.0          : alias-manager         : raspberrypi4-master                      - disabled
          + system.adapter.backitup.0               : backitup              : raspberrypi4-master                      -  enabled
          + system.adapter.broadlink2.0             : broadlink2            : raspberrypi4-master                      -  enabled
          + system.adapter.cloud.0                  : cloud                 : raspberrypi4-master                      -  enabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi4-master                      -  enabled
          + system.adapter.device-reminder.1        : device-reminder       : raspberrypi4-master                      -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi4-master                      -  enabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi4-master                      -  enabled
          + system.adapter.email.0                  : email                 : raspberrypi4-master                      -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : raspberrypi4-master                      -  enabled
            system.adapter.feiertage.0              : feiertage             : raspberrypi4-master                      -  enabled
            system.adapter.flot.0                   : flot                  : raspberrypi4-master                      - disabled
          + system.adapter.history.0                : history               : raspberrypi4-master                      -  enabled
          + system.adapter.homepilot20.0            : homepilot20           : raspberrypi4-master                      -  enabled
            system.adapter.ical.0                   : ical                  : raspberrypi4-master                      -  enabled
            system.adapter.ical.1                   : ical                  : raspberrypi4-master                      -  enabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi4-master                      - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi4-master                      - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4-master                      - disabled
          + system.adapter.influxdb.0               : influxdb              : raspberrypi4-master                      -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : raspberrypi4-master                      -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypi4-master                      -  enabled
            system.adapter.jarvis.0                 : jarvis                : raspberrypi4-master                      - disabled
            system.adapter.jarvis.1                 : jarvis                : raspberrypi4-master                      - disabled
          + system.adapter.javascript.0             : javascript            : raspberrypi4-master                      -  enabled
          + system.adapter.life360.0                : life360               : raspberrypi4-master                      -  enabled
          + system.adapter.mercedesme.0             : mercedesme            : raspberrypi4-master                      -  enabled
            system.adapter.meross.0                 : meross                : raspberrypi4-master                      - disabled
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4neu                          -  enabled, port: 1884, bind: 0.0.0.0
            system.adapter.mqtt.1                   : mqtt                  : raspberrypi4-master                      - disabled, port: 1883, bind: 0.0.0.0
          + system.adapter.netatmo.0                : netatmo               : raspberrypi4-master                      -  enabled
            system.adapter.powerfox2.0              : powerfox2             : raspberrypi4-master                      -  enabled
          + system.adapter.pushover.0               : pushover              : raspberrypi4-master                      -  enabled
          + system.adapter.pushover.1               : pushover              : raspberrypi4-master                      -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-master                      -  enabled
          + system.adapter.rssfeed.0                : rssfeed               : raspberrypi4-master                      -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi4-master                      -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : raspberrypi4-master                      -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : raspberrypi4-master                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi4-master                      -  enabled
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi4neu                          -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.sonos.0                  : sonos                 : raspberrypi4-master                      -  enabled
            system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi4-master                      - disabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-master                      -  enabled
          + system.adapter.tr-064.0                 : tr-064                : raspberrypi4-master                      -  enabled
          + system.adapter.tr-064.1                 : tr-064                : raspberrypi4-master                      -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4-master                      -  enabled
            system.adapter.vis-bars.0               : vis-bars              : raspberrypi4-master                      - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi4-master                      - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4-master                      - disabled
            system.adapter.vis-history.0            : vis-history           : raspberrypi4-master                      - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4-master                      - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4-master                      - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi4-master                      -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4-master                      - disabled
            system.adapter.vis-map.0                : vis-map               : raspberrypi4-master                      - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi4-master                      - disabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi4-master                      - disabled
            system.adapter.vis-players.0            : vis-players           : raspberrypi4-master                      - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4-master                      - disabled
            system.adapter.vis-weather.0            : vis-weather           : raspberrypi4-master                      - disabled
            system.adapter.vis.0                    : vis                   : raspberrypi4-master                      -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi4-master                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi4-master                      -  enabled
          + system.adapter.wolf-smartset.0          : wolf-smartset         : raspberrypi4-master                      -  enabled
          + system.adapter.yahka.0                  : yahka                 : raspberrypi4-master                      -  enabled
          + system.adapter.yahka.1                  : yahka                 : raspberrypi4-master                      -  enabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi4neu                          -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_76e54d3c6f12ec118f7721c7bd930c07-if00-port0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.10.1   , installed 6.10.1
          Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
          Adapter    "backitup"     : 2.8.1    , installed 2.8.1
          Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "device-reminder": 1.2.9  , installed 1.2.9
          Adapter    "discovery"    : 3.1.0    , installed 3.2.0
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "history"      : 2.2.6    , installed 2.2.6
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "iot"          : 1.14.5   , installed 2.0.11
          Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "mercedesme"   : 0.1.1    , installed 0.1.3
          Adapter    "meross"       : 1.15.1   , installed 1.15.1
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
          Adapter    "pushover"     : 3.0.3    , installed 3.0.4
          Adapter    "rssfeed"      : 2.6.1    , installed 2.8.1
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
          Adapter    "sonos"        : 2.3.1    , installed 2.3.1
          Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "web"          : 6.1.2    , installed 6.1.2
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
          Adapter    "ws"           : 2.5.5    , installed 2.5.5
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
          Objects and States
          Objects:        19704
          States:         16161
          W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:4 https://apt.grafana.com stable InRelease
          Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:6 https://repos.influxdata.com/debian stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
          Hit:8 https://packages.grafana.com/oss/deb stable InRelease
          Reading package lists...
          Pending Updates: 12
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15303      822/iobroker.js-con
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15298      822/iobroker.js-con
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13632      521/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:41421           0.0.0.0:*               LISTEN      1001       22634      2042/io.yahka.0
          tcp        0      0 127.0.0.1:40265         0.0.0.0:*               LISTEN      1001       20073      2170/io.yahka.1
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15898      1483/io.shelly.1
          tcp        0      0 127.0.0.1:36815         0.0.0.0:*               LISTEN      1001       21674      2042/io.yahka.0
          tcp6       0      0 :::3000                 :::*                    LISTEN      110        13014      821/grafana
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13634      521/sshd: /usr/sbin
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22719      2151/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13942      979/io.admin.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        1897       707/influxd
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20001      2084/io.simple-api.
          tcp6       0      0 :::34217                :::*                    LISTEN      1001       20065      2170/io.yahka.1
          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       17845      1494/io.sonos.0
          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       17715      1357/io.broadlink2.
          udp        0      0 0.0.0.0:45956           0.0.0.0:*                           1001       17785      1357/io.broadlink2.
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12772      394/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17074      1380/io.shelly.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15069      703/dhcpcd
          udp        0      0 0.0.0.0:47476           0.0.0.0:*                           108        12774      394/avahi-daemon: r
          udp        0      0 0.0.0.0:55764           0.0.0.0:*                           1001       21523      1380/io.shelly.0
          udp        0      0 0.0.0.0:51720           0.0.0.0:*                           1001       17742      1357/io.broadlink2.
          udp6       0      0 :::5353                 :::*                                108        12773      394/avahi-daemon: r
          udp6       0      0 :::40833                :::*                                108        12775      394/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          15080      703/dhcpcd
          2023-10-17 15:36:36.793  - warn: powerfox2.0 (3645) get state error: Connection is closed.
          2023-10-17 15:36:37.522  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
          2023-10-17 15:36:45.053  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 3783
          2023-10-17 15:36:49.275  - info: powerfox2.0 (3783) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
          2023-10-17 15:36:50.185  - info: powerfox2.0 (3783) Terminated (NO_ERROR): Without reason
          2023-10-17 15:36:50.760  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
          2023-10-17 15:36:56.629  - info: alexa2.0 (1299) No smart home devices to query
          2023-10-17 15:37:00.240  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 3828
          2023-10-17 15:37:08.688  - info: alexa2.0 (1299) Subscribing to states...
          2023-10-17 15:37:08.696  - info: alexa2.0 (1299) Deleting the following states: ["Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece","Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f.#delete","Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f.#enabled","Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f.active","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d.#delete","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d.#enabled","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d.active","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8.#delete","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8.#enabled","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8.powerState","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#delete","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#enabled","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#includeInAllQuery","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#query","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.Blind-Lift-rangeValue","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f.#delete","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f.#enabled","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f.powerState","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#delete","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#enabled","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#includeInAllQuery","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#query","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.percentage","Smart-Home-Devices.41a4fc68-0e9c-4b7e-b977-2fe6931bd520.Blind-Lift-rangeValue","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#delete","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#enabled","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#includeInAllQuery","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#query","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.Blind-Lift-rangeValue","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#delete","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#enabled","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#includeInAllQuery","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#query","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.Blind-Lift-rangeValue","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8.#delete","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8.#enabled","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8.powerState","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e.#delete","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e.#enabled","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e.powerState","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#delete","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#enabled","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#includeInAllQuery","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#query","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.connectivity","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.connectivity-reason","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.powerState","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#delete","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#enabled","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#includeInAllQuery","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#query","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.powerState","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa.#delete","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa.#enabled","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa.powerState","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d.#delete","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d.#enabled","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d.active","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044.#delete","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044.#enabled","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044.powerState","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#delete","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#enabled","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#includeInAllQuery","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#query","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.Blind-Lift-rangeValue","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#delete","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#enabled","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#includeInAllQuery","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#query","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.Blind-Lift-rangeValue","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#delete","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#enabled","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#includeInAllQuery","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#query","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.connectivity","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.connectivity-reason","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.powerState","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#delete","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#enabled","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#includeInAllQuery","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#query","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.Blind-Lift-rangeValue","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#delete","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#enabled","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#includeInAllQuery","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#query","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.connectivity","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.connectivity-reason","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.powerState","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#delete","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#enabled","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#includeInAllQuery","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#query","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.connectivity","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.connectivity-reason","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.powerState","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.#delete","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.#enabled","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.#query","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.connectivity","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.connectivity-reason","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.powerState","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57.#delete","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57.#enabled","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57.active","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#delete","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#enabled","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#includeInAllQuery","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#query","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.connectivity","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.connectivity-reason","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.powerState","Smart-Home-Devices.d3b1e404-cfa4-4b7f-9cf1-9ee838498889.Blind-Lift-rangeValue","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39.#delete","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39.#enabled","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39.powerState","Smart-Home-Devices.e9180145-e4c6-43f3-acf7-2bf7a54acc31.Blind-Lift-rangeValue","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#delete","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#enabled","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#includeInAllQuery","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#query","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.connectivity","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.connectivity-reason","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.powerState","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#delete","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#enabled","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#includeInAllQuery","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#query","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.Blind-Lift-rangeValue","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#delete","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#enabled","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#includeInAllQuery","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#query","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.Blind-Lift-rangeValue"]
          2023-10-17 15:37:08.722  - info: powerfox2.0 (3828) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
          2023-10-17 15:37:10.825  - info: alexa2.0 (1299) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2023-10-17 15:37:13.296  - info: powerfox2.0 (3828) Terminated (NO_ERROR): Without reason
          2023-10-17 15:37:13.993  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
          2023-10-17 15:37:16.699  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 3877
          2023-10-17 15:37:21.493  - info: smartcontrol.0 (2097) Trigger 'Bewegung.Flur' was already activated 0.05 seconds ago and is ignored. Must be at least 2 seconds.
          2023-10-17 15:37:23.059  - info: powerfox2.0 (3877) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
          2023-10-17 15:37:27.148  - info: powerfox2.0 (3877) Terminated (NO_ERROR): Without reason
          2023-10-17 15:37:28.559  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
          2023-10-17 15:37:30.520  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 4498
          2023-10-17 15:37:32.558  - info: alexa2.0 (1299) Initialization Done ...
          2023-10-17 15:37:36.004  - info: powerfox2.0 (4498) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
          2023-10-17 15:37:38.061  - info: powerfox2.0 (4498) Terminated (NO_ERROR): Without reason
          2023-10-17 15:37:38.613  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
          2023-10-17 15:37:45.058  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 5180
            kukli31 @Samson71 last edited by kukli31
            @samson71 Hallo Markus, wie kann ich das reparieren?
              kukli31 @DJMarc75 last edited by
              @djmarc75 said in ioBroker hängt sich regelmäßig auf:
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       3793 M total memory
                       2472 M used memory
                        499 M free memory
                         45 M buffer memory
                        776 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              1.4G    /var/
              846M    /var/log
              278M    /var/cache
              USB-Devices by-id:
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.10.1
              javascript:     7.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        19704
              States:         16161
              Pending Updates: 12
              • Samson71
                @kukli31
                Es gibt einer Fixer dafür von @Thomas-Braun
                  Thomas Braun Most Active @kukli31 last edited by Thomas Braun
                  @kukli31 sagte in ioBroker hängt sich regelmäßig auf:
                  Die Doublette in der Datei auch rauswerfen.
                  Zusätzlich halt das nodejs-Trümmerfeld aufräumen:
                  https://forum.iobroker.net/topic/69068/neuer-befehl-iob-nodejs-update
                    @samson71 said in ioBroker hängt sich regelmäßig auf:
                    @kukli31
                    Ich habe den Fixer laufen lassen. Danke schon mal für den Tipp.
                    Sieht es jetzt besser aus?
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                     16:10:31 up 42 min,  1 user,  load average: 4.03, 2.47, 2.04
                    CPU threads: 4
                    Current issues:
                                   Local time: Tue 2023-10-17 16:10:31 CEST
                               Universal time: Tue 2023-10-17 14:10:31 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            3.8G        2.6G        248M        0.0K        949M        1.1G
                    Swap:            99M        1.0M         98M
                    Total:          3.9G        2.6G        346M
                             3793 M total memory
                             2591 M used memory
                             3042 M active memory
                              164 M inactive memory
                              251 M free memory
                               11 M buffer memory
                              938 M swap cache
                               99 M total swap
                                1 M used swap
                               98 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/root      ext4      235G  5.9G  220G   3% /
                    /var:
                    1.6G    /var/
                    846M    /var/log
                    444M    /var/cache
                    493M    /opt/iobroker/iobroker-data/
                    16M     /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    /usr/bin/nodejs         v18.18.2
                    /usr/bin/node           v18.18.2
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    /usr/bin/corepack       0.19.0
                    nodejs:
                      Installed: 18.18.2-1nodesource1
                      Candidate: 18.18.2-1nodesource1
                      Version table:
                     *** 18.18.2-1nodesource1 1001
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.10.1
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        19704
                    States:         16161
                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                    Hit:6 https://apt.grafana.com stable InRelease
                    Hit:7 https://repos.influxdata.com/debian stable InRelease
                    Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       132141     14958/iobroker.js-c
                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       132134     14958/iobroker.js-c
                    tcp        0      0 127.0.0.1:45531         0.0.0.0:*               LISTEN      1001       135040     15730/io.yahka.0
                    tcp        0      0 0.0.0.0:36917           0.0.0.0:*               LISTEN      1001       135024     15730/io.yahka.0
                    tcp        0      0 127.0.0.1:33495         0.0.0.0:*               LISTEN      1001       135741     15779/io.yahka.1
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       132686     15264/io.shelly.1
                    tcp6       0      0 :::3000                 :::*                    LISTEN      110        129431     13931/grafana
                    tcp6       0      0 :::46621                :::*                    LISTEN      1001       135737     15779/io.yahka.1
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       136772     15710/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       131147     14979/io.admin.0
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       135544     15627/io.simple-api
                    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       132700     15279/io.sonos.0
                    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       130891     15357/io.broadlink2
                    udp        0      0 0.0.0.0:42105           0.0.0.0:*                           1001       129820     15204/io.shelly.0
                    udp        0      0 0.0.0.0:52763           0.0.0.0:*                           1001       132881     15357/io.broadlink2
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       129746     15204/io.shelly.0
                    udp        0      0 0.0.0.0:45468           0.0.0.0:*                           1001       131813     15357/io.broadlink2
                    udp6       0      0 :::546                  :::*                                0          127441     703/dhcpcd
                    2023-10-17 16:11:15.390  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16682
                    2023-10-17 16:11:19.473  - warn: shelly.0 (15204) State value to set for "shelly.0.SHDM-1#D3F1BE#1.temperatureF" has value "104.37" greater than max "100"
                    2023-10-17 16:11:21.407  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                    2023-10-17 16:11:21.458  - info: cloud.0 (15797) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                    2023-10-17 16:11:21.461  - info: cloud.0 (15797) Connection changed: disconnect
                    2023-10-17 16:11:26.630  - info: powerfox2.0 (16682) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                    2023-10-17 16:11:30.042  - warn: host.raspberrypi4-master instance system.adapter.powerfox2.0 already running with pid 16682
                    2023-10-17 16:11:31.113  - info: powerfox2.0 (16682) Terminated (NO_ERROR): Without reason
                    2023-10-17 16:11:31.695  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                    2023-10-17 16:11:45.070  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16749
                    2023-10-17 16:11:49.638  - warn: shelly.0 (15204) State value to set for "shelly.0.SHDM-1#D3F1BE#1.temperatureF" has value "104.49" greater than max "100"
                    2023-10-17 16:11:49.966  - info: powerfox2.0 (16749) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                    2023-10-17 16:11:52.217  - info: powerfox2.0 (16749) Terminated (NO_ERROR): Without reason
                    2023-10-17 16:11:52.760  - warn: powerfox2.0 (16749) get state error: Connection is closed.
                    2023-10-17 16:11:52.904  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                    2023-10-17 16:12:00.068  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16835
                    2023-10-17 16:12:03.990  - info: smartcontrol.0 (15638) Trigger 'Bewegung.Flur' was already activated 0.27 seconds ago and is ignored. Must be at least 2 seconds.
                    2023-10-17 16:12:06.244  - info: powerfox2.0 (16835) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                    2023-10-17 16:12:11.486  - info: powerfox2.0 (16835) Terminated (NO_ERROR): Without reason
                    2023-10-17 16:12:12.048  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                    2023-10-17 16:12:15.215  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 17434
                    2023-10-17 16:12:20.635  - info: powerfox2.0 (17434) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                    2023-10-17 16:12:21.623  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                    2023-10-17 16:12:24.250  - info: powerfox2.0 (17434) Terminated (NO_ERROR): Without reason
                    2023-10-17 16:12:25.251  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                      kukli31 @Thomas Braun last edited by
                      @thomas-braun said in ioBroker hängt sich regelmäßig auf:
                      So, ich habe beides bereinigt und sieht jetzt so aus:
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                       16:19:40 up 51 min,  1 user,  load average: 1.87, 2.28, 2.20
                      CPU threads: 4
                      Current issues:
                                     Local time: Tue 2023-10-17 16:19:40 CEST
                                 Universal time: Tue 2023-10-17 14:19:40 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        2.4G        716M        0.0K        637M        1.2G
                      Swap:            99M         95M        4.0M
                      Total:          3.9G        2.5G        721M
                               3793 M total memory
                               2439 M used memory
                                601 M active memory
                               2196 M inactive memory
                                716 M free memory
                                  5 M buffer memory
                                632 M swap cache
                                 99 M total swap
                                 95 M used swap
                                  4 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      1.6G    /var/
                      846M    /var/log
                      444M    /var/cache
                      518M    /opt/iobroker/iobroker-data/
                      33M     /opt/iobroker/iobroker-data/objects.jsonl
                      30M     /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.10.1
                      javascript:     7.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        19704
                      States:         16161
                      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:2 http://deb.debian.org/debian bullseye InRelease
                      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:5 https://apt.grafana.com stable InRelease
                      Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Hit:8 https://repos.influxdata.com/debian stable InRelease
                      Pending Updates: 0
                      2023-10-17 16:20:19.759  - info: powerfox2.0 (19266) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                      2023-10-17 16:20:21.899  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                      2023-10-17 16:20:23.268  - info: powerfox2.0 (19266) Terminated (NO_ERROR): Without reason
                      2023-10-17 16:20:23.805  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                      2023-10-17 16:20:30.125  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19323
                      2023-10-17 16:20:38.246  - info: powerfox2.0 (19323) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                      2023-10-17 16:20:39.263  - info: powerfox2.0 (19323) Terminated (NO_ERROR): Without reason
                      2023-10-17 16:20:40.056  - warn: powerfox2.0 (19323) get state error: Connection is closed.
                      2023-10-17 16:20:40.180  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                      2023-10-17 16:20:45.069  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19371
                      2023-10-17 16:20:50.071  - info: powerfox2.0 (19371) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                      2023-10-17 16:20:52.169  - info: wolf-smartset.0 (15320) Initialization with Login and new Session done!
                      2023-10-17 16:20:52.404  - info: powerfox2.0 (19371) Terminated (NO_ERROR): Without reason
                      2023-10-17 16:20:53.477  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                      2023-10-17 16:21:00.064  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19455
                      2023-10-17 16:21:06.027  - info: powerfox2.0 (19455) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                      2023-10-17 16:21:08.498  - info: smartcontrol.0 (15638) Trigger 'Bewegung.Flur' was already activated 0.04 seconds ago and is ignored. Must be at least 2 seconds.
                      2023-10-17 16:21:11.620  - info: powerfox2.0 (19455) Terminated (NO_ERROR): Without reason
                      2023-10-17 16:21:12.157  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                      2023-10-17 16:21:15.245  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19998
                      2023-10-17 16:21:20.020  - info: powerfox2.0 (19998) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                      2023-10-17 16:21:21.136  - info: powerfox2.0 (19998) Terminated (NO_ERROR): Without reason
                      2023-10-17 16:21:21.735  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                      2023-10-17 16:21:21.797  - warn: powerfox2.0 (19998) get state error: Connection is closed.
                      2023-10-17 16:21:21.992  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                        Dein Dateisystem ist löchrig.
                        K Homoran 2 Replies Last reply Reply Quote 0
                          Was heißt das, bzw. wie und wo muss ich was fixen?
                            @thomas-braun sagte in ioBroker hängt sich regelmäßig auf:
                            Ich muss den Raspberry aus- und einschalten
                            aka Stecker ziehen.
                            killt Dateisysteme
                              @kukli31
                              Das heißt, das zwei inodes nicht mehr zugeordnet werden konnten und gelöscht wurden.
                              Konkret kann das alles mögliche verursachen, hängt davon ab was da drin stand.
                              Bei grafana ist immer noch was krumm:
                              Da sollte nur eine Zeile erscheinen.
                                @kukli31
                                Und nun? Hast du einen Tipp?
                                  Schau in /etc/apt/sources.list.d ob es etweder zwei .list-Dateien zu grafana gibt oder ob die bestehende Datei zwei entsprechende Zeilen hat.
                                    kukli31 @Thomas Braun last edited by kukli31
                                    pi@raspberrypi4-master:~ $ ls /etc/apt/
                                    apt.conf.d  auth.conf.d  keyrings  listchanges.conf  listchanges.conf.d  preferences.d  sources.list  sources.list.d  trusted.gpg  trusted.gpg.d
                                    sources.list.d ist leer
                                      @kukli31 Das kann/soll nicht sein.
                                      ls -lAh /etc/apt/sources.list.d/
                                        pi@raspberrypi4-master:~ $ ls -lAh /etc/apt/sources.list.d/
                                        total 16K
                                        -rw-r--r-- 1 root root 137 Oct 17 16:18 grafana.list
                                        -rw-r--r-- 1 root root 117 Sep  4 13:04 influxdata.list
                                        -rw-r--r-- 1 root root 100 Oct 17 16:05 nodesource.list
                                        -rw-r--r-- 1 root root 191 May  3 04:52 raspi.list
                                          Ich sag doch, das Verzeichnis ist nicht leer...
                                          cat /etc/apt/sources.list.d/grafana.list
                                            pi@raspberrypi4-master:~ $ cat /etc/apt/sources.list.d/grafana.list
                                            deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main
                                            deb https://packages.grafana.com/oss/deb stable main
                                            2912
