    4. ioBroker hängt sich regelmäßig auf
    • Samson71
      Samson71 Global Moderator @kukli31 last edited by
      @kukli31
      Zusätzlich zu den Codetags das korrigieren
      *** nodejs is NOT correctly installed ***
        kukli31 @kukli31 last edited by
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi4-master
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         15:35:57 up 7 min,  1 user,  load average: 3.17, 2.86, 1.46
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Tue 2023-10-17 15:35:57 CEST
                   Universal time: Tue 2023-10-17 13:35:57 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            3.8G        2.5G        499M        1.0M        822M        1.2G
        Swap:            99M          0B         99M
        Total:          3.9G        2.5G        599M
                 3793 M total memory
                 2472 M used memory
                 2945 M active memory
                  197 M inactive memory
                  499 M free memory
                   45 M buffer memory
                  776 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      235G  5.8G  220G   3% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/sda1      vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Tue Oct 17 15:28:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:71:9F:4D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=58e76898-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): write access will be enabled during recovery
        [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
        [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): 2 orphan inodes deleted
        [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): recovery complete
        [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Tue Oct 17 15:28:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Tue Oct 17 15:28:30 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.4G    /var/
        846M    /var/log
        793M    /var/log/journal/49f5cfb508e342378183307452dc5b73
        278M    /var/cache
        Archived and active journals take up 792.1M in the file system.
        /opt/iobroker/backups:
        125M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        489M    /opt/iobroker/iobroker-data/
        286M    /opt/iobroker/iobroker-data/files
        150M    /opt/iobroker/iobroker-data/backup-objects
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        43M     /opt/iobroker/iobroker-data/files/iot.admin
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        23M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        12M     /opt/iobroker/iobroker-data/states.jsonl
        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /home/iobroker/.diag.sh: line 277: nodejs: command not found
        /usr/local/bin/node             v18.18.0
        /usr/local/bin/npm              9.8.1
        /usr/local/bin/npx              9.8.1
        /usr/local/bin/corepack         0.19.0
        /home/iobroker/.diag.sh: line 288: nodejs: command not found
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.10.1
        javascript:     7.1.4
        Adapters from github:   3
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi4-master                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-master                      -  enabled
          system.adapter.alias-manager.0          : alias-manager         : raspberrypi4-master                      - disabled
        + system.adapter.backitup.0               : backitup              : raspberrypi4-master                      -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi4-master                      -  enabled
        + system.adapter.cloud.0                  : cloud                 : raspberrypi4-master                      -  enabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi4-master                      -  enabled
        + system.adapter.device-reminder.1        : device-reminder       : raspberrypi4-master                      -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi4-master                      -  enabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi4-master                      -  enabled
        + system.adapter.email.0                  : email                 : raspberrypi4-master                      -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : raspberrypi4-master                      -  enabled
          system.adapter.feiertage.0              : feiertage             : raspberrypi4-master                      -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi4-master                      - disabled
        + system.adapter.history.0                : history               : raspberrypi4-master                      -  enabled
        + system.adapter.homepilot20.0            : homepilot20           : raspberrypi4-master                      -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi4-master                      -  enabled
          system.adapter.ical.1                   : ical                  : raspberrypi4-master                      -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi4-master                      - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi4-master                      - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4-master                      - disabled
        + system.adapter.influxdb.0               : influxdb              : raspberrypi4-master                      -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : raspberrypi4-master                      -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi4-master                      -  enabled
          system.adapter.jarvis.0                 : jarvis                : raspberrypi4-master                      - disabled
          system.adapter.jarvis.1                 : jarvis                : raspberrypi4-master                      - disabled
        + system.adapter.javascript.0             : javascript            : raspberrypi4-master                      -  enabled
        + system.adapter.life360.0                : life360               : raspberrypi4-master                      -  enabled
        + system.adapter.mercedesme.0             : mercedesme            : raspberrypi4-master                      -  enabled
          system.adapter.meross.0                 : meross                : raspberrypi4-master                      - disabled
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4neu                          -  enabled, port: 1884, bind: 0.0.0.0
          system.adapter.mqtt.1                   : mqtt                  : raspberrypi4-master                      - disabled, port: 1883, bind: 0.0.0.0
        + system.adapter.netatmo.0                : netatmo               : raspberrypi4-master                      -  enabled
          system.adapter.powerfox2.0              : powerfox2             : raspberrypi4-master                      -  enabled
        + system.adapter.pushover.0               : pushover              : raspberrypi4-master                      -  enabled
        + system.adapter.pushover.1               : pushover              : raspberrypi4-master                      -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-master                      -  enabled
        + system.adapter.rssfeed.0                : rssfeed               : raspberrypi4-master                      -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi4-master                      -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : raspberrypi4-master                      -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : raspberrypi4-master                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi4-master                      -  enabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi4neu                          -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : raspberrypi4-master                      -  enabled
          system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi4-master                      - disabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-master                      -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi4-master                      -  enabled
        + system.adapter.tr-064.1                 : tr-064                : raspberrypi4-master                      -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4-master                      -  enabled
          system.adapter.vis-bars.0               : vis-bars              : raspberrypi4-master                      - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi4-master                      - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4-master                      - disabled
          system.adapter.vis-history.0            : vis-history           : raspberrypi4-master                      - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4-master                      - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4-master                      - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi4-master                      -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4-master                      - disabled
          system.adapter.vis-map.0                : vis-map               : raspberrypi4-master                      - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi4-master                      - disabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi4-master                      - disabled
          system.adapter.vis-players.0            : vis-players           : raspberrypi4-master                      - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4-master                      - disabled
          system.adapter.vis-weather.0            : vis-weather           : raspberrypi4-master                      - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi4-master                      -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi4-master                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi4-master                      -  enabled
        + system.adapter.wolf-smartset.0          : wolf-smartset         : raspberrypi4-master                      -  enabled
        + system.adapter.yahka.0                  : yahka                 : raspberrypi4-master                      -  enabled
        + system.adapter.yahka.1                  : yahka                 : raspberrypi4-master                      -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi4neu                          -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_76e54d3c6f12ec118f7721c7bd930c07-if00-port0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.10.1   , installed 6.10.1
        Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "device-reminder": 1.2.9  , installed 1.2.9
        Adapter    "discovery"    : 3.1.0    , installed 3.2.0
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "history"      : 2.2.6    , installed 2.2.6
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "iot"          : 1.14.5   , installed 2.0.11
        Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "mercedesme"   : 0.1.1    , installed 0.1.3
        Adapter    "meross"       : 1.15.1   , installed 1.15.1
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
        Adapter    "pushover"     : 3.0.3    , installed 3.0.4
        Adapter    "rssfeed"      : 2.6.1    , installed 2.8.1
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
        Adapter    "sonos"        : 2.3.1    , installed 2.3.1
        Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 6.1.2    , installed 6.1.2
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        Objects and States
        Objects:        19704
        States:         16161
        W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 https://apt.grafana.com stable InRelease
        Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:6 https://repos.influxdata.com/debian stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
        Hit:8 https://packages.grafana.com/oss/deb stable InRelease
        Reading package lists...
        Pending Updates: 12
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15303      822/iobroker.js-con
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15298      822/iobroker.js-con
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13632      521/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:41421           0.0.0.0:*               LISTEN      1001       22634      2042/io.yahka.0
        tcp        0      0 127.0.0.1:40265         0.0.0.0:*               LISTEN      1001       20073      2170/io.yahka.1
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15898      1483/io.shelly.1
        tcp        0      0 127.0.0.1:36815         0.0.0.0:*               LISTEN      1001       21674      2042/io.yahka.0
        tcp6       0      0 :::3000                 :::*                    LISTEN      110        13014      821/grafana
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13634      521/sshd: /usr/sbin
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22719      2151/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13942      979/io.admin.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        1897       707/influxd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20001      2084/io.simple-api.
        tcp6       0      0 :::34217                :::*                    LISTEN      1001       20065      2170/io.yahka.1
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       17845      1494/io.sonos.0
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       17715      1357/io.broadlink2.
        udp        0      0 0.0.0.0:45956           0.0.0.0:*                           1001       17785      1357/io.broadlink2.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12772      394/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17074      1380/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15069      703/dhcpcd
        udp        0      0 0.0.0.0:47476           0.0.0.0:*                           108        12774      394/avahi-daemon: r
        udp        0      0 0.0.0.0:55764           0.0.0.0:*                           1001       21523      1380/io.shelly.0
        udp        0      0 0.0.0.0:51720           0.0.0.0:*                           1001       17742      1357/io.broadlink2.
        udp6       0      0 :::5353                 :::*                                108        12773      394/avahi-daemon: r
        udp6       0      0 :::40833                :::*                                108        12775      394/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          15080      703/dhcpcd
        2023-10-17 15:36:36.793  - warn: powerfox2.0 (3645) get state error: Connection is closed.
        2023-10-17 15:36:37.522  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
        2023-10-17 15:36:45.053  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 3783
        2023-10-17 15:36:49.275  - info: powerfox2.0 (3783) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
        2023-10-17 15:36:50.185  - info: powerfox2.0 (3783) Terminated (NO_ERROR): Without reason
        2023-10-17 15:36:50.760  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
        2023-10-17 15:36:56.629  - info: alexa2.0 (1299) No smart home devices to query
        2023-10-17 15:37:00.240  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 3828
        2023-10-17 15:37:08.688  - info: alexa2.0 (1299) Subscribing to states...
        2023-10-17 15:37:08.696  - info: alexa2.0 (1299) Deleting the following states: ["Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece","Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f.#delete","Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f.#enabled","Smart-Home-Devices.103d720b-b360-41a8-9855-5f9fd411439f.active","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d.#delete","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d.#enabled","Smart-Home-Devices.168fdb55-d90b-467e-84c1-8a40bbb3436d.active","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8.#delete","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8.#enabled","Smart-Home-Devices.17cc4e8f-b942-4e03-b324-5f33c30052d8.powerState","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#delete","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#enabled","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#includeInAllQuery","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.#query","Smart-Home-Devices.2354edda-fa2e-4a93-9eb3-a9b5b5166986.Blind-Lift-rangeValue","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f.#delete","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f.#enabled","Smart-Home-Devices.284f062e-63a7-4a4a-94ec-79e7e5eb110f.powerState","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#delete","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#enabled","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#includeInAllQuery","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.#query","Smart-Home-Devices.2d303f93-5370-4c8b-9596-a5822369c264.percentage","Smart-Home-Devices.41a4fc68-0e9c-4b7e-b977-2fe6931bd520.Blind-Lift-rangeValue","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#delete","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#enabled","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#includeInAllQuery","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.#query","Smart-Home-Devices.50b83f57-6d4b-4d5e-9cfc-20bc5aec7c87.Blind-Lift-rangeValue","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#delete","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#enabled","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#includeInAllQuery","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.#query","Smart-Home-Devices.52c7f659-195d-49ed-9d48-0a2fb7591a60.Blind-Lift-rangeValue","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8.#delete","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8.#enabled","Smart-Home-Devices.57d188a1-d539-40cd-9938-248ca20c22c8.powerState","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e.#delete","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e.#enabled","Smart-Home-Devices.6b200c38-bdf3-4fbc-b8e7-f2339f4eea8e.powerState","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#delete","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#enabled","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#includeInAllQuery","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.#query","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.connectivity","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.connectivity-reason","Smart-Home-Devices.719b85f4-77b1-4a1c-aa04-5d68874b087b.powerState","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#delete","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#enabled","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#includeInAllQuery","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.#query","Smart-Home-Devices.7833e9fb-5ab7-4806-8644-b2d6077eee2b.powerState","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa.#delete","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa.#enabled","Smart-Home-Devices.7aabeeab-fa8a-450a-badc-ffe0038c3aaa.powerState","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d.#delete","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d.#enabled","Smart-Home-Devices.7d9cfd3d-403f-42eb-bec1-f1f8056e1f6d.active","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044.#delete","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044.#enabled","Smart-Home-Devices.864ae89d-0712-4d15-aeb8-f0bccecdd044.powerState","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#delete","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#enabled","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#includeInAllQuery","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.#query","Smart-Home-Devices.9e992642-207c-4ee8-b2eb-b51b9c7dbad2.Blind-Lift-rangeValue","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#delete","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#enabled","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#includeInAllQuery","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.#query","Smart-Home-Devices.9f14c2c3-cfbe-41ca-900b-bd87195ea13c.Blind-Lift-rangeValue","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#delete","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#enabled","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#includeInAllQuery","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.#query","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.connectivity","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.connectivity-reason","Smart-Home-Devices.a20892c5-60db-491e-9cfa-c8da0431f0c4.powerState","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#delete","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#enabled","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#includeInAllQuery","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.#query","Smart-Home-Devices.b072710b-5ec5-4e30-ba2f-ba2f270afc28.Blind-Lift-rangeValue","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#delete","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#enabled","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#includeInAllQuery","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.#query","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.connectivity","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.connectivity-reason","Smart-Home-Devices.b4b985b7-3d15-4501-b856-ad1efb617104.powerState","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#delete","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#enabled","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#includeInAllQuery","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.#query","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.connectivity","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.connectivity-reason","Smart-Home-Devices.b5235e48-11e7-4f9d-bd06-9ab4f60e7466.powerState","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.#delete","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.#enabled","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.#query","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.connectivity","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.connectivity-reason","Smart-Home-Devices.ba49eb34-5c85-4a0f-b61e-98afac18fe78.powerState","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57.#delete","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57.#enabled","Smart-Home-Devices.be2b7d84-118d-4613-9206-5b912cc8cd57.active","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#delete","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#enabled","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#includeInAllQuery","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.#query","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.connectivity","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.connectivity-reason","Smart-Home-Devices.d2944afc-a7b1-4e02-8130-6f92c03cc154.powerState","Smart-Home-Devices.d3b1e404-cfa4-4b7f-9cf1-9ee838498889.Blind-Lift-rangeValue","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39.#delete","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39.#enabled","Smart-Home-Devices.e65bfe9e-41d2-45b2-8341-8f63fbaa0b39.powerState","Smart-Home-Devices.e9180145-e4c6-43f3-acf7-2bf7a54acc31.Blind-Lift-rangeValue","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#delete","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#enabled","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#includeInAllQuery","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.#query","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.connectivity","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.connectivity-reason","Smart-Home-Devices.eed4e04e-7b0b-4680-bcb6-f279af0eeb07.powerState","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#delete","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#enabled","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#includeInAllQuery","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.#query","Smart-Home-Devices.fe967961-125d-44da-a991-0283f0dec20d.Blind-Lift-rangeValue","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#delete","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#enabled","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#includeInAllQuery","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.#query","Smart-Home-Devices.ff287859-81d6-4ae6-a4c8-666583ca8ece.Blind-Lift-rangeValue"]
        2023-10-17 15:37:08.722  - info: powerfox2.0 (3828) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
        2023-10-17 15:37:10.825  - info: alexa2.0 (1299) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2023-10-17 15:37:13.296  - info: powerfox2.0 (3828) Terminated (NO_ERROR): Without reason
        2023-10-17 15:37:13.993  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
        2023-10-17 15:37:16.699  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 3877
        2023-10-17 15:37:21.493  - info: smartcontrol.0 (2097) Trigger 'Bewegung.Flur' was already activated 0.05 seconds ago and is ignored. Must be at least 2 seconds.
        2023-10-17 15:37:23.059  - info: powerfox2.0 (3877) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
        2023-10-17 15:37:27.148  - info: powerfox2.0 (3877) Terminated (NO_ERROR): Without reason
        2023-10-17 15:37:28.559  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
        2023-10-17 15:37:30.520  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 4498
        2023-10-17 15:37:32.558  - info: alexa2.0 (1299) Initialization Done ...
        2023-10-17 15:37:36.004  - info: powerfox2.0 (4498) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.0, js-controller: 5.0.12
        2023-10-17 15:37:38.061  - info: powerfox2.0 (4498) Terminated (NO_ERROR): Without reason
        2023-10-17 15:37:38.613  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
        2023-10-17 15:37:45.058  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 5180
          kukli31 @Samson71 last edited by kukli31
          @samson71 Hallo Markus, wie kann ich das reparieren?
            kukli31 @DJMarc75 last edited by
            @djmarc75 said in ioBroker hängt sich regelmäßig auf:
            @kukli31 bitte in Codetags packen ... </>
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     3793 M total memory
                     2472 M used memory
                      499 M free memory
                       45 M buffer memory
                      776 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            1.4G    /var/
            846M    /var/log
            278M    /var/cache
            USB-Devices by-id:
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.10.1
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        19704
            States:         16161
            Pending Updates: 12
            • Samson71
              @kukli31
              Es gibt einer Fixer dafür von @Thomas-Braun
                Thomas Braun Most Active @kukli31 last edited by Thomas Braun
                @kukli31 sagte in ioBroker hängt sich regelmäßig auf:
                Die Doublette in der Datei auch rauswerfen.
                Zusätzlich halt das nodejs-Trümmerfeld aufräumen:
                https://forum.iobroker.net/topic/69068/neuer-befehl-iob-nodejs-update
                  @samson71 said in ioBroker hängt sich regelmäßig auf:
                  @kukli31
                  Ich habe den Fixer laufen lassen. Danke schon mal für den Tipp.
                  Sieht es jetzt besser aus?
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                   16:10:31 up 42 min,  1 user,  load average: 4.03, 2.47, 2.04
                  CPU threads: 4
                  Current issues:
                                 Local time: Tue 2023-10-17 16:10:31 CEST
                             Universal time: Tue 2023-10-17 14:10:31 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            3.8G        2.6G        248M        0.0K        949M        1.1G
                  Swap:            99M        1.0M         98M
                  Total:          3.9G        2.6G        346M
                           3793 M total memory
                           2591 M used memory
                           3042 M active memory
                            164 M inactive memory
                            251 M free memory
                             11 M buffer memory
                            938 M swap cache
                             99 M total swap
                              1 M used swap
                             98 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /dev/root      ext4      235G  5.9G  220G   3% /
                  /var:
                  1.6G    /var/
                  846M    /var/log
                  444M    /var/cache
                  493M    /opt/iobroker/iobroker-data/
                  16M     /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  /usr/bin/nodejs         v18.18.2
                  /usr/bin/node           v18.18.2
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  /usr/bin/corepack       0.19.0
                  nodejs:
                    Installed: 18.18.2-1nodesource1
                    Candidate: 18.18.2-1nodesource1
                    Version table:
                   *** 18.18.2-1nodesource1 1001
                       18.18.1-1nodesource1 1001
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.10.1
                  javascript:     7.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        19704
                  States:         16161
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                  Hit:6 https://apt.grafana.com stable InRelease
                  Hit:7 https://repos.influxdata.com/debian stable InRelease
                  Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       132141     14958/iobroker.js-c
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       132134     14958/iobroker.js-c
                  tcp        0      0 127.0.0.1:45531         0.0.0.0:*               LISTEN      1001       135040     15730/io.yahka.0
                  tcp        0      0 0.0.0.0:36917           0.0.0.0:*               LISTEN      1001       135024     15730/io.yahka.0
                  tcp        0      0 127.0.0.1:33495         0.0.0.0:*               LISTEN      1001       135741     15779/io.yahka.1
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       132686     15264/io.shelly.1
                  tcp6       0      0 :::3000                 :::*                    LISTEN      110        129431     13931/grafana
                  tcp6       0      0 :::46621                :::*                    LISTEN      1001       135737     15779/io.yahka.1
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       136772     15710/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       131147     14979/io.admin.0
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       135544     15627/io.simple-api
                  tcp6       0      0 :::3500                 :::*                    LISTEN      1001       132700     15279/io.sonos.0
                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       130891     15357/io.broadlink2
                  udp        0      0 0.0.0.0:42105           0.0.0.0:*                           1001       129820     15204/io.shelly.0
                  udp        0      0 0.0.0.0:52763           0.0.0.0:*                           1001       132881     15357/io.broadlink2
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       129746     15204/io.shelly.0
                  udp        0      0 0.0.0.0:45468           0.0.0.0:*                           1001       131813     15357/io.broadlink2
                  udp6       0      0 :::546                  :::*                                0          127441     703/dhcpcd
                  2023-10-17 16:11:15.390  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16682
                  2023-10-17 16:11:19.473  - warn: shelly.0 (15204) State value to set for "shelly.0.SHDM-1#D3F1BE#1.temperatureF" has value "104.37" greater than max "100"
                  2023-10-17 16:11:21.407  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                  2023-10-17 16:11:21.458  - info: cloud.0 (15797) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                  2023-10-17 16:11:21.461  - info: cloud.0 (15797) Connection changed: disconnect
                  2023-10-17 16:11:26.630  - info: powerfox2.0 (16682) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                  2023-10-17 16:11:30.042  - warn: host.raspberrypi4-master instance system.adapter.powerfox2.0 already running with pid 16682
                  2023-10-17 16:11:31.113  - info: powerfox2.0 (16682) Terminated (NO_ERROR): Without reason
                  2023-10-17 16:11:31.695  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                  2023-10-17 16:11:45.070  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16749
                  2023-10-17 16:11:49.638  - warn: shelly.0 (15204) State value to set for "shelly.0.SHDM-1#D3F1BE#1.temperatureF" has value "104.49" greater than max "100"
                  2023-10-17 16:11:49.966  - info: powerfox2.0 (16749) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                  2023-10-17 16:11:52.217  - info: powerfox2.0 (16749) Terminated (NO_ERROR): Without reason
                  2023-10-17 16:11:52.760  - warn: powerfox2.0 (16749) get state error: Connection is closed.
                  2023-10-17 16:11:52.904  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                  2023-10-17 16:12:00.068  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16835
                  2023-10-17 16:12:03.990  - info: smartcontrol.0 (15638) Trigger 'Bewegung.Flur' was already activated 0.27 seconds ago and is ignored. Must be at least 2 seconds.
                  2023-10-17 16:12:06.244  - info: powerfox2.0 (16835) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                  2023-10-17 16:12:11.486  - info: powerfox2.0 (16835) Terminated (NO_ERROR): Without reason
                  2023-10-17 16:12:12.048  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                  2023-10-17 16:12:15.215  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 17434
                  2023-10-17 16:12:20.635  - info: powerfox2.0 (17434) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                  2023-10-17 16:12:21.623  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                  2023-10-17 16:12:24.250  - info: powerfox2.0 (17434) Terminated (NO_ERROR): Without reason
                  2023-10-17 16:12:25.251  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                    kukli31 @Thomas Braun last edited by
                    @thomas-braun said in ioBroker hängt sich regelmäßig auf:
                    So, ich habe beides bereinigt und sieht jetzt so aus:
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                     16:19:40 up 51 min,  1 user,  load average: 1.87, 2.28, 2.20
                    CPU threads: 4
                    Current issues:
                                   Local time: Tue 2023-10-17 16:19:40 CEST
                               Universal time: Tue 2023-10-17 14:19:40 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            3.8G        2.4G        716M        0.0K        637M        1.2G
                    Swap:            99M         95M        4.0M
                    Total:          3.9G        2.5G        721M
                             3793 M total memory
                             2439 M used memory
                              601 M active memory
                             2196 M inactive memory
                              716 M free memory
                                5 M buffer memory
                              632 M swap cache
                               99 M total swap
                               95 M used swap
                                4 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.6G    /var/
                    846M    /var/log
                    444M    /var/cache
                    518M    /opt/iobroker/iobroker-data/
                    33M     /opt/iobroker/iobroker-data/objects.jsonl
                    30M     /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.10.1
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        19704
                    States:         16161
                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:5 https://apt.grafana.com stable InRelease
                    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:8 https://repos.influxdata.com/debian stable InRelease
                    Pending Updates: 0
                    2023-10-17 16:20:19.759  - info: powerfox2.0 (19266) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                    2023-10-17 16:20:21.899  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                    2023-10-17 16:20:23.268  - info: powerfox2.0 (19266) Terminated (NO_ERROR): Without reason
                    2023-10-17 16:20:23.805  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                    2023-10-17 16:20:30.125  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19323
                    2023-10-17 16:20:38.246  - info: powerfox2.0 (19323) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                    2023-10-17 16:20:39.263  - info: powerfox2.0 (19323) Terminated (NO_ERROR): Without reason
                    2023-10-17 16:20:40.056  - warn: powerfox2.0 (19323) get state error: Connection is closed.
                    2023-10-17 16:20:40.180  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                    2023-10-17 16:20:45.069  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19371
                    2023-10-17 16:20:50.071  - info: powerfox2.0 (19371) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                    2023-10-17 16:20:52.169  - info: wolf-smartset.0 (15320) Initialization with Login and new Session done!
                    2023-10-17 16:20:52.404  - info: powerfox2.0 (19371) Terminated (NO_ERROR): Without reason
                    2023-10-17 16:20:53.477  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                    2023-10-17 16:21:00.064  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19455
                    2023-10-17 16:21:06.027  - info: powerfox2.0 (19455) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                    2023-10-17 16:21:08.498  - info: smartcontrol.0 (15638) Trigger 'Bewegung.Flur' was already activated 0.04 seconds ago and is ignored. Must be at least 2 seconds.
                    2023-10-17 16:21:11.620  - info: powerfox2.0 (19455) Terminated (NO_ERROR): Without reason
                    2023-10-17 16:21:12.157  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                    2023-10-17 16:21:15.245  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19998
                    2023-10-17 16:21:20.020  - info: powerfox2.0 (19998) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
                    2023-10-17 16:21:21.136  - info: powerfox2.0 (19998) Terminated (NO_ERROR): Without reason
                    2023-10-17 16:21:21.735  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
                    2023-10-17 16:21:21.797  - warn: powerfox2.0 (19998) get state error: Connection is closed.
                    2023-10-17 16:21:21.992  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                      Dein Dateisystem ist löchrig.
                      K Homoran 2 Replies Last reply Reply Quote 0
                        Was heißt das, bzw. wie und wo muss ich was fixen?
                          @thomas-braun sagte in ioBroker hängt sich regelmäßig auf:
                          Ich muss den Raspberry aus- und einschalten
                          aka Stecker ziehen.
                          killt Dateisysteme
                            @kukli31
                            Das heißt, das zwei inodes nicht mehr zugeordnet werden konnten und gelöscht wurden.
                            Konkret kann das alles mögliche verursachen, hängt davon ab was da drin stand.
                            Bei grafana ist immer noch was krumm:
                            Da sollte nur eine Zeile erscheinen.
                              @kukli31
                              Und nun? Hast du einen Tipp?
                                Schau in /etc/apt/sources.list.d ob es etweder zwei .list-Dateien zu grafana gibt oder ob die bestehende Datei zwei entsprechende Zeilen hat.
                                  kukli31 @Thomas Braun last edited by kukli31
                                  pi@raspberrypi4-master:~ $ ls /etc/apt/
                                  apt.conf.d  auth.conf.d  keyrings  listchanges.conf  listchanges.conf.d  preferences.d  sources.list  sources.list.d  trusted.gpg  trusted.gpg.d
                                  sources.list.d ist leer
                                    @kukli31 Das kann/soll nicht sein.
                                    ls -lAh /etc/apt/sources.list.d/
                                      pi@raspberrypi4-master:~ $ ls -lAh /etc/apt/sources.list.d/
                                      total 16K
                                      -rw-r--r-- 1 root root 137 Oct 17 16:18 grafana.list
                                      -rw-r--r-- 1 root root 117 Sep  4 13:04 influxdata.list
                                      -rw-r--r-- 1 root root 100 Oct 17 16:05 nodesource.list
                                      -rw-r--r-- 1 root root 191 May  3 04:52 raspi.list
                                        Ich sag doch, das Verzeichnis ist nicht leer...
                                        cat /etc/apt/sources.list.d/grafana.list
                                          pi@raspberrypi4-master:~ $ cat /etc/apt/sources.list.d/grafana.list
                                          deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main
                                          deb https://packages.grafana.com/oss/deb stable main
                                            @kukli31
                                            Lösch die zweite Zeile.
                                            2912
