    4. Neuer Befehl: "iob nodejs-update"
      Thomas Braun Most Active @Marc_el_K last edited by
      @marc_el_k
      Hmm. Dann sollte aber eigentlich eine recommend version gefunden werden. Lass das bitte nochmal laufen, bei laufendem ioBroker.
      Marc_el_K 1 Reply Last reply Reply Quote 0
      • Marc_el_K
        Marc_el_K @Thomas Braun last edited by
        @thomas-braun also ich hatte dann mit y bestätigt und bin jetzt bei 18.18.2
          Thomas Braun Most Active @Marc_el_K last edited by Thomas Braun
          @marc_el_k
          Zeig nochmal einen Lauf.
          • Marc_el_K
            ioBroker nodejs fixer 2023-10-09
            Recommended nodejs-version is: 18.18.2
            Checking your installation now. Please be patient!
            Your current setup is:
            /usr/bin/nodejs         v18.18.2
            /usr/bin/node           v18.18.2
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            /usr/bin/corepack       0.19.0
            We found these nodejs versions available for installation:
            nodejs:
              Installed: 18.18.2-1nodesource1
              Candidate: 18.18.2-1nodesource1
              Version table:
             *** 18.18.2-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                    100 /var/lib/dpkg/status
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package                                         s
            Nothing to do - Your installation is using the correct paths.
            Nothing to do - Your version is the recommended one.
            ***You can now keep your whole system up-to-date using the usual 'sudo apt updat                                         e && sudo apt full-upgrade' commands. ***
            *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. The                                         y will break your current installation! ***
             *** DO NOT use 'nodejs-update' as part of a regular update process! ***
              @marc_el_k
              Okay, jetzt passt's.
                Pali 0 last edited by Pali 0
                bei mir läuft IObroker auf Raspi 4B (bullseye). Den js-controller 5.0.12 habe ich am 19.09.23 updatet/installiert.
                IObroker zeigt jetzt, dass es neue node.js und NPM Versionen gibt:
                Wenn ich aber update durchführe: sudo apt update && sudo apt full-upgrade
                oder auch: sudo apt-get update && sudo apt-get upgrade
                passier nichts, es bleibt bei 18.17.1 und 9.6.7
                Dann habe ich diesen neuen Befehl hier im Forum entdeckt und gestartet (zuerst "iob fix" dann "iob nodejs-update") .
                Am Ende wurde gefragt, ob ich ver 18.18.2 installieren will, was ich mit Yes geantwortet habe.
                Die Versionen sind aber weiterhin unverändert bei 18.17.1 und 9.6.7 geblieben. Danach nochmal apt update && apt full-upgrade. Weiterhin keine Änderung.
                Hier der Ablauf bei iob nodejs-update:
                ioBroker nodejs fixer 2023-10-13
                /usr/bin/nodejs         v18.17.1
                /usr/bin/node           v18.17.1
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                /usr/bin/corepack       0.18.0
                nodejs:
                  Installed: 18.17.1-deb-1nodesource1
                  Version table:
                 *** 18.17.1-deb-1nodesource1 100
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                You are running nodejs v18.17.1. Do you want to install recommended version 18.18.2?
                Press <y> to continue or any other key to quit
                Trying to update your installation now. Please be patient.
                Waiting for ioBroker to shut down - Give me a minute...
                *** These repos are active on your system:
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:5 https://repos.influxdata.com/debian stable InRelease
                Get:6 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
                Err:6 https://packages.grafana.com/oss/deb stable InRelease
                  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                Reading package lists... Done
                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                W: Some index files failed to download. They have been ignored, or old ones used instead.
                *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                Package: nodejs
                Pin: origin deb.nodesource.com
                Pin-Priority: 1001
                *** These repos are active after the adjustments:
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:3 https://repos.influxdata.com/debian stable InRelease
                Hit:4 http://deb.debian.org/debian bullseye InRelease
                Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                Installing the recommended nodejs version now!
                Installing the recommended nodejs version!
                E: Failed to fetch https://packages.grafana.com/oss/deb/pool/main/g/grafana/grafana_10.1.0_arm64.deb  404  Not Found [IP: 2a04:4e42:6f::729 443]
                E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                We tried our best to fix your nodejs. Please run iob diag again to verify.
                *** RESTARTING ioBroker NOW! ***
                 Please refresh or restart your browser in a few moments.
                Ich sehe dort Probleme bei Grafana. Aber ich benutze die Grafana noch nicht aktiv, deswegen ignoriere ich diese Meldungen. Muss ich zuerst diese Grfana-Warnungen erledigen, damit der nodejs-update durchläuft?
                Danke im Voraus für Hilfe, bin nicht so fit in diesem Linux-Gebiet.
                  Thomas Braun Most Active @Pali 0 last edited by Thomas Braun
                  @pali-0 sagte in Neuer Befehl: "iob nodejs-update":
                  (Fehler)-Meldungen ignorieren ist immer falsch. Aktualisier das Repo.
                  iob nodejs-fix hat sein Werk getan, jetzt muss nur noch der Admin von dem System seinen Paketmanager auf die Reihe kriegen und die Quellen bereinigen.
                    nachdem ich das Problem mit Grafana Public-Key gelöst habe und anschließend apt-get update und upgrade durchdeführt habe, hat sich auch node.j und npm aktualisiert...
                    DANKE!
                      apollon77 @Marty56 last edited by
                      @marty56 Das kommt erst mit dem nächsten js-controller auch in "help", geht aber trotzdem
                      MartinP 1 Reply Last reply Reply Quote 1
                      • MartinP
                        MartinP @apollon77 last edited by MartinP
                        Scheint zu funktionieren, mit dem automatisierten Update über den update-Mechanismus von Linux...
                        Vor dem Update
                        Building dependency tree... Done
                        1 package can be upgraded. Run 'apt list --upgradable' to see it.
                        martin@iobroker-test-sicher:~$ sudo apt full-upgrade
                        Calculating upgrade... Done
                        The following packages will be upgraded:
                          nodejs
                        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        Need to get 29.5 MB of archives.
                        After this operation, 95.2 kB of additional disk space will be used.
                        Do you want to continue? [Y/n] Y
                        Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.18.2-1nodesource1 [29.5 MB]
                        Fetched 29.5 MB in 2s (18.1 MB/s)
                        Reading changelogs... Done
                        (Reading database ... 48973 files and directories currently installed.)
                        Preparing to unpack .../nodejs_18.18.2-1nodesource1_amd64.deb ...
                        Detected old npm client, removing...
                        Unpacking nodejs (18.18.2-1nodesource1) over (18.18.1-1nodesource1) ...
                        Setting up nodejs (18.18.2-1nodesource1) ...
                        Processing triggers for man-db (2.9.4-2) ...
                        So weit so gut, aber dann meldet ioBroker immer noch die alte Version aus dem obigen Screeshot?
                        Aber wahrscheinlich geht es ohne "iob stop" und "iob start" nicht aus, oder?
                          Thomas Braun Most Active @MartinP last edited by
                          @martinp sagte in Neuer Befehl: "iob nodejs-update":
                          Natürlich funktioniert das übliche systemseitige Update weiterhin. Und es sollte auch so verwendet werden, der nodejs-updater ist nur für die einmalige Umstellung des nodesource-Repos gedacht.
                          Das sollte man vor Updates von nodejs eh immer machen. nodejs ist sowas wie das Betriebssystem für den iobroker, das wechselt man nicht im Vollbetrieb.
                          • MartinP
                            MartinP @Thomas Braun last edited by MartinP
                            @thomas-braun also wäre der Entscheidungsprozess
                            FALLS ioBroker auf der Übersichtsseite einen Minor-Update anzeigt (z. B. den oben aus dem Screenshot):
                            1. iob stop
                            2. updaten:
                              2a) sudo apt update && sudo apt full-upgrade
                              2b) iob nodjs-update # (nur bei großem nodjs update!)
                              2b) iob fix
                            3. iob start
                            NUR FALLS der angezeigte nodejs Update-Schritt zu groß ist ggfs. dann noch 2b) iob nodjs-update einschieben
                            ist "iob fix" vor "iob start" dringend ratsam?
                            Thomas Braun X 2 Replies Last reply Reply Quote 0
                              @martinp
                              iob fix
                              ist nie falsch.
                              Minor Updates innerhalb eines Versionszweigs von nodejs wie gehabt über den üblichen apt update / apt full-upgrade
                              Wenn mal irgendwann nodejs 20 zur Empfehlung wird dann reicht ein (wiederum einmaliges) 'iob nodejs-upgrade' aus, um auf diesen Versionszweig zu wechseln.
                                Willi-Wunder @Thomas Braun last edited by
                                iob nodejs-update xx
                                Mega, vielen Dank dafür, Problem gelöst, jetzt geht's 👍 👍 👍
                                • mickym
                                  mickym Most Active last edited by mickym
                                  iob nodejs-update
                                  So habe ich ausgeführt - hat auch soweit geklappt und nun habe ich nodistro als Quelle - warum ist das notwendig? Wird das andere Repository nicht mehr gepflegt?
                                    Thomas Braun Most Active @mickym last edited by
                                    @mickym sagte in Neuer Befehl: "iob nodejs-update":
                                    Richtig, wurde seitens nodesource alles vereinfacht und die müssen nun nicht mehr für jedes Debian-Derivat alles neubauen. Die ganzen Ableitungen wie Ubuntu, Raspberry OS usw. greifen jetzt alle auf die gleiche deb-Datei zu.
                                    • mickym
                                      mickym Most Active @Thomas Braun last edited by mickym
                                      @thomas-braun OK ich hab jetzt Dein Skript bzw. halt iob nodejs-update durchgeführt - das Editieren hätte wahrscheinlich wegen irgendwelcher Schlüssel nicht geklappt.
                                      Muss man nun bei Major Updates den Befehl ausführen oder kann ich wie früher
                                      einfach die Versionsnummer ändern (also zum Beispiel auf 20.x) ?
                                        @mickym
                                        Kannst du weiterhin mit einem Edit der nodesource.list machen.
                                        An der grundsätzlichen Funktionsweise von apt hat sich natürlich nichts geändert, nur die .list-Datei muss umgestellt werden.
                                        Alternativ geht auch
                                        iob nodejs-update XY
                                        XY = veröffentlichter Major-Release-Zweig
                                        • mickym
                                          @thomas-braun Ok danke - dann weiß ich Bescheid. 🙂
                                          • X
                                            xelarep @MartinP last edited by
                                            Ich erlaube mir mal diese Liste für ein grösseres Update auf einem Raspberry zu ergänzen 🙂
                                            1. iob stop
                                            2. updaten:
                                              2b) iob fix
                                            3. iob start
                                            Da ich nur ein Gelegenheit-Linuxer bin, brauch ich immer möglichst vollständige Ablauflisten - ich vermute mal viele andere hier auch 😉
                                            1. Auf der Weboberfläche oder mit iob backup erstmal ne aktuelle Sicherung schaffen...
                                            2. iob stop - dann alles anhalten...
                                            3. sudo apt update && sudo apt full-upgrade - Grundsystem aktualisieren...
                                            4. iob fix - sonst hat man das nodejs-update nicht zur Verfügung...
                                            5. iob nodejs-update - Jetzt das Update anstossen und die Rückfrage zum Minor update mit 'y' beantworten...
                                            6. Kaffee holen, Zeitung lesen, Kaffee trinken...
                                            7. sudo reboot - wie aufgefordert Systemneustart durchführen
                                            8. Kaffee Teil 2...
                                            9. Auf Admin-Oberfläche einloggen, Versionen und Logs checken und sich freuen, dass alles geklappt hat
                                            Mein System ist jetzt jedenfalls wieder chic.
                                            Vielen Dank @apollon77, @Thomas-Braun und alle anderen Aktiven. Diese Art ein System zu pflegen ist deutlich einfacher und entspannter als vorher! Gerade, wenn man sich nicht jeden Tag damit beschäftigt.
                                            1 Reply Last reply Reply Quote 4
                                            93
                                            25455
