    3. Einsteigerfragen
    4. [GELÖST]Ring Adapter "Device XXX: Could't create livestream"
    • DJMarc75
      DJMarc75 @LXZ last edited by
      @lxz bitte die Langfassung davon
      LXZ 1 Reply Last reply Reply Quote 0
      • LXZ
        LXZ @DJMarc75 last edited by
        @djmarc75 said in [GELÖST]Ring Adapter "Device XXX: Could't create livestream":
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Architecture    : aarch64
        Docker          : false
        Virtualization  : none
        Distributor ID: Debian
        Description:    Debian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         17:37:09 up 12 days,  9:12,  3 users,  load average: 0.05, 0.21, 0.29
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=45.2'C
        volt=0.9460V
        *** Time and Time Zones ***
                       Local time: Tue 2023-08-22 17:37:09 BST
                   Universal time: Tue 2023-08-22 16:37:09 UTC
                         RTC time: n/a
                        Time zone: Europe/London (BST, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        lxz
        /home/lxz
        lxz adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        1.9G        446M         30M        1.4G        1.8G
        Swap:            99M         99M        0.0K
        Total:          3.9G        2.0G        446M
                 3794 M total memory
                 1926 M used memory
                 1921 M active memory
                  991 M inactive memory
                  446 M free memory
                   66 M buffer memory
                 1355 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4       59G  7.0G   49G  13% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M   24K  380M   1% /run/user/1000
        [Thu Aug 10 08:24:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:30:9E:B3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7a00e94b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Thu Aug 10 08:24:41 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Thu Aug 10 08:24:41 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Thu Aug 10 08:24:42 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
        [Thu Aug 10 08:24:42 2023] EXT4-fs (mmcblk0p2): 4 orphan inodes deleted
        [Thu Aug 10 08:24:42 2023] EXT4-fs (mmcblk0p2): recovery complete
        [Thu Aug 10 08:24:42 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Thu Aug 10 08:24:42 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Thu Aug 10 08:24:44 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        523M    /var/
        177M    /var/lib
        171M    /var/cache
        166M    /var/cache/apt
        123M    /var/lib/apt/lists
        Archived and active journals take up 72.0M in the file system.
        /opt/iobroker/backups:
        176M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        623M    /opt/iobroker/iobroker-data/
        341M    /opt/iobroker/iobroker-data/files
        213M    /opt/iobroker/iobroker-data/backup-objects
        95M     /opt/iobroker/iobroker-data/files/vis-2-beta
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        43M     /opt/iobroker/iobroker-data/states.jsonl
        27M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.3a4244b6.js.map
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.5.1
        /usr/bin/node           v20.5.1
        /usr/bin/npm            9.8.0
        /usr/bin/npx            9.8.0
        nodejs:
          Installed: 20.5.1-deb-1nodesource1
          Candidate: 20.5.1-deb-1nodesource1
          Version table:
         *** 20.5.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_20.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.8.0
        javascript:     7.0.3
        Adapters from github:   2
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
        + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
        + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
        + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
        + system.adapter.ring.0                   : ring                  : iobroker                                 -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
        + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          system.adapter.twinkly.0                : twinkly               : iobroker                                 - disabled
          system.adapter.vaillant.0               : vaillant              : iobroker                                 - disabled
        + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
        + system.adapter.xterm.0                  : xterm                 : iobroker                                 -  enabled, port: 8099, bind: 0.0.0.0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.8.0    , installed 6.8.0
        Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "bmw"          : 2.5.7    , installed 2.6.2
        Adapter    "device-reminder": 1.2.9  , installed 1.2.9
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
        Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
        Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "ring"         : 3.2.2    , installed 3.2.2
        Adapter    "socketio"     : 4.2.0    , installed 6.5.2
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
        Adapter    "vaillant"     : 0.1.2    , installed 0.1.2
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 4.3.0    , installed 6.1.0
        Adapter    "wled"         : 0.6.7    , installed 0.6.7
        Adapter    "ws"           : 1.3.0    , installed 2.5.3
        Adapter    "xterm"        : 1.1.0    , installed 1.1.0
        Objects and States
        Objects:        4583
        States:         3368
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_20.x bullseye InRelease
        Reading package lists...
        Pending Updates: 85
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          9097001    194733/cupsd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9515854    438160/iobroker.js-
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9518174    438160/iobroker.js-
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14119      558/sshd: /usr/sbin
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9518986    439786/io.terminal.
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       9516528    438207/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9518522    439152/io.web.0
        tcp6       0      0 :::8099                 :::*                    LISTEN      1001       9519542    438616/io.xterm.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14121      558/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          9097000    194733/cupsd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          9097907    194735/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       9518952    439663/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14006      397/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13155      538/dhcpcd
        udp        0      0 0.0.0.0:49523           0.0.0.0:*                           108        14008      397/avahi-daemon: r
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       9517439    438562/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       9517440    438562/io.tuya.0
        udp6       0      0 :::5353                 :::*                                108        14007      397/avahi-daemon: r
        udp6       0      0 :::33165                :::*                                108        14009      397/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          6424633    538/dhcpcd
        2023-08-22 17:30:06.088  - info: dwd.0 (475514) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-08-22 17:30:06.449  - info: ical.0 (475545) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v20.5.1, js-controller: 4.0.24
        2023-08-22 17:30:06.629  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-08-22 17:30:07.105  - info: ical.0 (475545) processing URL: GoogleKalenderAbfall https://calendar.google.com/calendar/ical/19ln2ejcc6gu8b41q7fd6q5t00bjq2j1%40import.calendar.google.com/public/basic.ics
        2023-08-22 17:30:07.201  - warn: trashschedule.0 (439358) no events matches type "Papiertonne" with match "Papier"
        2023-08-22 17:30:07.868  - info: admin.0 (438207) ==> Connected system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:12.205  - info: ical.0 (475545) Terminated (NO_ERROR): Without reason
        2023-08-22 17:30:12.740  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2023-08-22 17:30:14.309  - info: admin.0 (438207) <== Disconnect system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:14.438  - info: admin.0 (438207) ==> Connected system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:15.339  - info: admin.0 (438207) <== Disconnect system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:15.590  - info: admin.0 (438207) ==> Connected system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:18.352  - info: admin.0 (438207) <== Disconnect system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:18.648  - info: admin.0 (438207) ==> Connected system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:20.227  - info: admin.0 (438207) <== Disconnect system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:20.324  - info: admin.0 (438207) ==> Connected system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:21.276  - info: admin.0 (438207) <== Disconnect system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:21.371  - info: admin.0 (438207) ==> Connected system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:22.137  - info: admin.0 (438207) <== Disconnect system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:22.213  - info: admin.0 (438207) ==> Connected system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:30:31.013  - info: admin.0 (438207) <== Disconnect system.user.admin from ::ffff:192.168.0.133
        2023-08-22 17:35:00.043  - info: host.iobroker instance system.adapter.dwd.0 started with pid 476973
        2023-08-22 17:35:02.229  - info: dwd.0 (476973) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.5.1, js-controller: 4.0.24
        2023-08-22 17:35:04.239  - info: dwd.0 (476973) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-08-22 17:35:04.780  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        iob diag has finished.
        Press any key for a summary
        • DJMarc75
          @lxz sagte in [GELÖST]Ring Adapter "Device XXX: Could't create livestream":
          X-Server: true
          ausschalten
          v20.5.1
          wie schon geschrieben - ist nicht empfohlen und kann zu Problemen führen (!)
          Pending Updates: 85
          schon lange nix mehr wichtiges am System gemacht !
          • LXZ
            LXZ last edited by
            X-Server: true
            ausschalten
            v20.5.1
            Pending Updates: 85
            Wie deaktiviere ich x-server und wofür ist das? Womöglich war das damals fürs aufsetzen nötig?
            Ich schaue wie gesagt wenn bei mir irgendwelche fehler auftreten setzte ich das system zurück auf das backup von heute morgen.
            Und wie starte ich die pending updates?
            Stehe wohl gerade dümmer da als ich dachte 🙄
            T DJMarc75 2 Replies Last reply Reply Quote 0
              ticaki Developer @LXZ last edited by ticaki
              @lxz sagte in [[GELÖST]Ring Adapter "Device XXX: Could't create livestream"]
              sudo apt update && sudo apt upgrade
              • DJMarc75
                DJMarc75 @LXZ last edited by DJMarc75
                Nein.
                Das ist eine Desktopoberfläche welche man nicht für Server braucht.
                Musst Du schauen wie das über
                raspi config
                deaktiviert wird.Gibt aber bestimmt genug Anleitungen hier.
                • LXZ
                  LXZ @ticaki last edited by
                  @ticaki said in [GELÖST]Ring Adapter "Device XXX: Could't create livestream":
                  Vielen dank, hat funktioniert
                  Nein.
                  raspi config
                  Achso ja gut ich schaue mal wie ich das deaktiviert bekomme.
                  Vielen dank für deine hilfe 🙂
                  • DJMarc75
                    @lxz
                    sudo raspi-config
                    dann irgendwo dort mal nachsehen 😉
                      TobiB last edited by TobiB
                      Hallo zusammen @DJMarc75 @LXZ ,
                      ich bekomme den Adapter nicht zum laufen. Ich bekomme den Token und tragen diesen ein aber dennoch bleibt der Adapter Rot...
                      Das habe ich im Log:
                      Jemand eine Idee woran es liegen könnte?
                      Fehler gefunden: Beim kopieren wurden die Zeichen nicht richtig übertragen wodurch aus L ein | wurde usw.
                        biker1602 last edited by
                        @lxz said in [GELÖST]Ring Adapter "Device XXX: Could't create livestream":
                        Habs hinbekommen.
                        Habs den Ring Adapter nochmal gelöscht und dann node.js auf 20.x geupdated.
                        Danach auf der Ring Seite die verbindung zu iobroker gelöscht und dann alles ganz normal von vorne.
                        Nun gehts vorerst 😁
                        Kurze Frage wo bekommst du jetzt den Livestream her? Hast du andere Datenpunkte bekommen nach der neuen Installation? Ich habe den Livestream auch nur im Datenpunkt History, aber den letzten, keinen aktuellen. Ich habe auch schon den Ring Adapter 5.0.1 beta installiert.
                        772
