    4. JavaScript
    5. ecoflow-connector-Script zur dynamischen Leistungsanpassung
      Ralf77 @19bobby65 last edited by
      @19bobby65
      Es wäre super, wenn Du Dein Scrip teilen würdest. Bin daran sehr interessiert, da ich auch gerade daran bin das zu machen…komme aber schleppend mit meinen Fähigkeiten voran. Vielen Dank für Deine Hile.
      • 1
        19bobby65 @Buron last edited by 19bobby65
        @buron
          <variables>
            <variable id="z?RSsC$V#o)f[Uf=J_F.">pv</variable>
            <variable id="8jAy3,$^XwJf~/#-uIEU">eigenverbrauch</variable>
            <variable id="tANO5)Fws;PbejQI|6_K">ueberschus</variable>
          </variables>
          <block type="schedule" id="/.@G|5ZDL/g|}6Y(TVn^" x="-337" y="-362">
            <field name="SCHEDULE">{"time":{"start":"sunrise","end":"sunset","mode":"minutes","interval":1},"period":{"days":1},"valid":{"from":"19.09.2023","to":""}}</field>
              <block type="variables_set" id="g%2?UVY^7Q,sLL1uB4_@">
                <field name="VAR" id="z?RSsC$V#o)f[Uf=J_F.">pv</field>
                  <block type="get_value" id="cq%YBwfza@)f7ec{bAL^">
                    <field name="OID">fronius.0.powerflow.P_PV</field>
                  <block type="variables_set" id="%31}bYLyZ!@!T2pT;X|M">
                    <field name="VAR" id="8jAy3,$^XwJf~/#-uIEU">eigenverbrauch</field>
                      <block type="get_value" id="DCr~sOj3]h]G[t_W}:|j">
                        <field name="OID">0_userdata.0.Datenpunkte.Eigenverbrauch</field>
                      <block type="variables_set" id="PTjbb3PFLe}:!2|qt@=|">
                        <field name="VAR" id="tANO5)Fws;PbejQI|6_K">ueberschus</field>
                          <block type="math_arithmetic" id=".-xW]_d#vw]?s,Y.@Y4.">
                              <shadow type="math_number" id="*ODotjCrz/_1P[9tC0$z">
                                <field name="NUM">1</field>
                              <block type="variables_get" id="g6wh6Yc{iA)/i?wswu6K">
                              <shadow type="math_number" id="lY79g[Wo-C3Mh(A.GJAF">
                              <block type="variables_get" id="vKhaHdbCULV^MCID;HZ{">
                          <block type="controls_if" id="$KrntQhU)rR[{Jl?5~Xz">
                              <block type="logic_operation" id="s]bQU5IFZC9|A(rIHY|W" inline="false">
                                <field name="OP">AND</field>
                                  <block type="logic_compare" id="sA+ZhIk3`dX5ZF%R8yrt">
                                    <field name="OP">GT</field>
                                      <block type="variables_get" id="hQT_czZI~WzhPSQlHTv3">
                                      <block type="convert_tonumber" id="j^3{5)ge!1//_QlJcTM_">
                                          <block type="math_number" id=":`:9.H0~|4dJ+@#kgd@%">
                                            <field name="NUM">250</field>
                                  <block type="logic_compare" id="/V?/{9u*P-u%AU=KaaIO">
                                    <field name="OP">EQ</field>
                                      <block type="get_value" id="%RX?N$P;s_bGHl3b}Tp/">
                                        <field name="OID">tuya.0.0620008184f3eb85a03d.1</field>
                                      <block type="logic_boolean" id="x+(jxI:R]ArJwQsdn/oe">
                              <block type="control" id="zBiqXDkFElLS2X@0ci2Z">
                                  <block type="logic_boolean" id="4J:`UPTh(0N=6M2n1h8)">
                            <value name="IF1">
                              <block type="logic_operation" id="y7gFBI~Sl1;upLRsUfko" inline="false">
                                  <block type="logic_compare" id="i~dBl(E6XD=H.uRn~fBH">
                                    <field name="OP">LT</field>
                                      <block type="variables_get" id="wR3cwB)f;|^RJhFIZeC_">
                                      <block type="convert_tonumber" id="O6fR+|r!yr5q7?XTFZ?g">
                                          <block type="math_number" id="kG4Ph?*3F$q_[45V@Ku*">
                                            <field name="NUM">5</field>
                                  <block type="logic_compare" id="xVPLuD{`xomav}V_@RE3">
                                      <block type="get_value" id=".Oi//vv9Q:n6bWm(m#)n">
                                      <block type="logic_boolean" id="!KDe7nC{+kKlP6,Z^vmU">
                            <statement name="DO1">
                              <block type="control" id="TS5NneGqaTO|#E)kkB=O">
                                <field name="DELAY_MS">1</field>
                                  <block type="logic_boolean" id="%!q^MjX,:zdI+)nI8l2|">
                                  <block type="update" id="Z2D!Q](VIi/e3L=^Bn^@">
                                    <field name="OID">0_userdata.0.Datenpunkte.Neuer_Zustand1</field>
                                      <block type="convert_tonumber" id="N!9FHOuUmBWMRDQ`-LGu">
                                          <block type="math_number" id="Gj}@r![*8A4-*Ai$$ej-">
                                            <field name="NUM">100</field>
                                      <block type="control" id="kqUQK7E]5%Qc)Y`{lFHJ">
                                        <field name="OID">0_userdata.0.ecoflow.app_1699446398039774562_DAEBZ5ZE6280131_thing_property_set.writeables.slowChgPower</field>
                                          <block type="convert_tonumber" id=",4gy=A:Gucd5W~JU?K_+">
                                              <block type="math_number" id="O0O[XjW*8?!$}muvC7hj">
              <block type="schedule" id="~{)0dhBI=@]Y^nrQTf)K">
                <field name="SCHEDULE">{"time":{"start":"17:02","end":"17:05","mode":"minutes","interval":1},"period":{"days":1}}</field>
                  <block type="controls_if" id="Rd7HrS?G6XhPgXriPoIO">
                      <block type="logic_compare" id="nd4@mxqyvYz#-CxSU#88">
                          <block type="get_value" id="VIv)[[iy9{$7N%qD{u:F">
                          <block type="logic_boolean" id="~*2HOA[RepI^2oO%wv%T">
                      <block type="control" id="X#+Ev)+/LOrm=5QCO+]v">
                          <block type="logic_boolean" id="559fu-Y1o!Ciw:r$Ls*_">
                  <block type="on_ext" id="wutz@-^x{JMv1l`jlU5`">
                    <value name="OID0">
                      <shadow type="field_oid" id="%30Ret=}C/HjSe^nO=4z">
                        <field name="oid">0_userdata.0.Datenpunkte.Netzeinspeisung</field>
                      <block type="controls_if" id="]Qzh`7w3Hd(vmR!4iYeU">
                          <block type="logic_operation" id="tNsYkXQH?w$cC%{)1,Z/" inline="false">
                              <block type="logic_operation" id="niQ#G|rZd^M.kQKAl8_m" inline="false">
                                  <block type="logic_compare" id=":NT?7+^;uNnF@LH([p!Y">
                                      <block type="get_value" id=";33=H?#xLD7y!8eM%ZnH">
                                        <field name="OID">0_userdata.0.Datenpunkte.Netzbezug</field>
                                      <block type="math_number" id="AW|n;ik=a`J;2Txhg,I3">
                                        <field name="NUM">0</field>
                                  <block type="logic_compare" id="FagzWE.m8B5QyG+5!gY$">
                                      <block type="get_value" id=".b|Y(p%046wHd5A~6?y3">
                                        <field name="OID">0_userdata.0.Datenpunkte.Netzeinspeisung</field>
                                      <block type="convert_tonumber" id="BZ-^=rd}H[V?uQP)4*4/">
                                          <block type="math_number" id=";^;mGkMF,Ma[v//vygh9">
                                            <field name="NUM">300</field>
                              <block type="logic_compare" id="zMf:t@c2.elAGPQJHsjL">
                                  <block type="get_value" id="Aja1vYWtDxXeY,M7kN~X">
                                  <block type="math_number" id="lpcpra$3)Ln;8xwEFDjq">
                                    <field name="NUM">2000</field>
                          <block type="update" id="@A@f9dw4zDQYVaPMPi~,">
                              <block type="math_arithmetic" id="Aa1m;N5wd~0,n}/aG(?q">
                                <field name="OP">ADD</field>
                                  <shadow type="math_number" id="BG`YHIr@apG4;{ai^!#n">
                                  <block type="get_value" id="C-~O$)|3[Yg2.9(,{eL.">
                                  <shadow type="math_number" id=":UC1-vH)-a_48Z(pp0-a">
                              <block type="control" id="RNsweT1begokmpsMdq/w">
                                  <block type="get_value" id="Jq[!jZ^e*aG*MhJj+%|9">
                          <block type="controls_if" id="Sk#tj]/H|wiuR3TNQQ0?">
                              <block type="logic_operation" id="ppG-mT7o6S^yJU-/K(3J" inline="false">
                                  <block type="logic_compare" id="lh3u!,H~291P%0I~gjpY">
                                      <block type="get_value" id="E|8**U~,O/Y9Y1{+dmm#">
                                      <block type="get_value" id="nPjG#kCa(Mo+`sG1o1z0">
                                  <block type="logic_compare" id="]5te~SMy|LG~0T{ZLI5_">
                                      <block type="get_value" id="LzjI?_DT{3iGm8Vn#_Yb">
                                      <block type="math_number" id="Pm7SQnN_W?H/vPZ!jC:*">
                              <block type="update" id="xI@#zAR~=)ym@z*Z2{xg">
                                  <block type="math_arithmetic" id="!5]fiu??C;YIR_NmlRH:">
                                      <block type="get_value" id="Lh;Q5v7_D7U^:JaV.ykA">
                                      <shadow type="math_number" id="q.pvW6a9KHRNBP-rAxpN">
                                  <block type="control" id="9Df$]g*A]Am#={;0kD08">
                                      <block type="get_value" id="6Y}-M|So/0nPL;2:nx.-">
        Der unter Teil im Script regelt die AC-Ladung in 100 Watt schritten von 0 bis 2000 Watt je nach vorhandenen Überschuss aber ob dir das so etwas hilft keine Ahnung müssen ja auch die Datenpunkte dazu passen bzw. musst du die erstellen.
        • PaterDo glaser
          PaterDo glaser last edited by
          ist es möglich das anschalten des AC ausgangs bei der Delta 2 zu automatisieren? meine Idee war ein Blockly Script das bei Ladestand größer 90% Ac anschalten soll, allerdings schreibt das Script den wert nicht.
          Probiert habe ich 0_userdata.0.ecoflow.app_xxxxxx_xxxxxxx_thing_property_set.writeables.acOutCfg_D2
          als auch
          0_userdata.0.ecoflow.app_device_property_xxxxxxx.data.params.mppt.cfgAcEnabled
          Habt ihr da eine idee wie das funktioniert könnte?
          G W 2 Replies Last reply Reply Quote 0
            GerdSo @PaterDo glaser last edited by
            @paterdo-glaser Ich mach es nicht per Blockly sondern per Javascript und bei mir funktioniert es per
            0_userdata.0.ecoflow.app_xxx_DCxxx_thing_property_set.writeables.ACPower"); // ACPower on/off für Netzteile
            die Variable ACPower habe ich bei Dir jetzt nicht gesehen
            PaterDo glaser 1 Reply Last reply Reply Quote 0
            • PaterDo glaser
              PaterDo glaser @GerdSo last edited by PaterDo glaser
              @gerdso Hallo, welchen Akku Verwendest du? ACPower ist bei mir in den Instanzen keine Writeable, Du wirst eine Delta Max haben oder. Bei mir ist es aktuell so, dass ich die Werte in den Instanzen zwar ändern kann, aber es nicht ausgeführt wird
              R G 2 Replies Last reply Reply Quote 0
              • umele
                umele last edited by
                weiss jemand, welcher Parameter der DP die ungerundete Akkuladung angibt?
                Ich vermute, dass es "0_userdata.0.ecoflow.app_device_property_DCxxx.data.params.bmsMaster.f32ShowSoc"
                ist.
                Nehme bisher "batSoc" (PowerStream), bzw. "Soc"(Delta Pro direkt). Der gerundete Wert ist mir aber zu ungenau beim Kalibrieren der Delta Pro...
                  Ralf77 @PaterDo glaser last edited by
                  @paterdo-glaser genau so ist es bei mir auch (Delta Pro).
                  Ich kann die Überschusswerte automatisiert vom Smartmeter holen und auch in die writebale (0_userdata.0.ecoflow.app_XXXX_DCEBXXX_thing_property_set.writeables.slowChgPower eintragen lassen. Leider ändert sich die Ladeleistung am AC-EIgang dadurch nicht - ich vermute, dass diese Werte nicht vom IoBroker zum Delta Pro gesendet werden... da muss vermtulich noch das Passwort von der App in das Script eingebaut werden.
                  PaterDo glaser W 2 Replies Last reply Reply Quote 0
                  • PaterDo glaser
                    PaterDo glaser @Ralf77 last edited by
                    @ralf77 Ah okay, ich bin gerade auch am schauen ob man das in das bereits bestehende Script einbauen kann da gibt es ja den Wert const writeables = [
                    //Delta 2
                    { id: 0, name: 'acChgCfg_D2', ValueName: 'chgWatts', Typ: 'D2', MT: 5, AddParam: '{"chgWatts":600,"chgPauseFlag":255}' },
                    { id: 0, name: 'acOutCfg_D2', ValueName: 'enabled', Typ: 'D2', MT: 3 },
                    { id: 0, name: 'dcOutCfg_D2', ValueName: 'enabled', Typ: 'D2', MT: 1 },
                    { id: 0, name: 'quietMode_D2', ValueName: 'enabled', Typ: 'D2', MT: 5 },
                    { id: 0, name: 'dcChgCfg_D2', ValueName: 'dcChgCfg', Typ: 'D2', MT: 5 },
                    Nur leider ändert das nichts wenn ich diesen Wert anpasse. Wenn ich wieder in der App den "switch" betätige ändert sich auch der Wert in Iobroker. Ich denk auch das hier die Kommunikation einseitig ist
                      Waly_de @Ralf77 last edited by
                      @ralf77 also ich hab eine Delta Pro Max. Eingestellt auf DM.
                      da funktioniert des Writable 0_userdata.0.ecoflow.app_xxxxxxxxxxxxxxx_DAxxxxxxxxxxxxxxx_thing_property_set.writeables.slowChgPower ohne Probleme...
                      Bitte teste das mal mit Typ DM
                        @paterdo-glaser ja, so vermute ich es auch. Ich gehe davon aus, dass man in die "Autehntifzierung" die neuen Objekte/Writables einfügen muss, damit die Werte direkt in den Ecoflow-Server geschrieben werden und von dort an den Delta Pro gesendet werden (der IoBroker muss quasi wie eine 2. App fungieren).
                        Die Werte für das automaitisierte/geregelte AC-Laden werden aber vom iobroker nicht gesendet und damit funktioniert es nicht.
                        Leider reichen meine Fähigkeiten für das bei weitem nicht aus...
                          @ralf77 sagte in ecoflow-connector-Script zur dynamischen Leistungsanpassung:
                          Nein... das muss man nicht. Es wird gesendet... Es kann nur sein, das ein anderer Parameter gesendet werden muss. (Definition) Da ich nur ein gerät habe, kann ich das hier nicht selbst testen. Gesendet wird aber
                            Waly_de @PaterDo glaser last edited by Waly_de
                            @paterdo-glaser sagte in ecoflow-connector-Script zur dynamischen Leistungsanpassung:
                            versuch bitte mal als Typ: D2M und sag mir ob es geht....
                            Paramenter: slowChgWatts ...
                              @paterdo-glaser ich habe eine Delta Pro als DM konfiguriert im Script:
                                Ralf77 @Waly_de last edited by Ralf77
                                @waly_de vielen Dank für Deine Hilfe. Nur, dass ich aufgrund meiner geringen Kenntnisse kein Fehler mache...
                                Ich habe ein 2. Script im iobroker angelegt
                                (PowerStream ist das von Dir -klappt sehr gut 🙂
                                Geregelte AC Überschussladung ist welches die Werte vom Smartmeter (bei mir Fronius) alle 60 Sekunden holt und dann in "0_userdata.0.ecoflow.app_1695XXX_DCEBZXXX_thing_property_set.writeables.slowChgPower" ablegt.
                                Das Ablegen klappt problemlos.
                                Leider ändert sich der Wert für die AC-Ladung in der App aber nicht auf den Wert, welcher abgelegt wird.
                                  Waly_de @Ralf77 last edited by Waly_de
                                  @ralf77 der wert sieht ungültig aus. versuch es mal ohne Komma als Ganzzahl. ( Zum testen kannst du den wert ja manuell setzten. vorher Dein eigenes Script stoppen)
                                  Die Änderung müsste in der App sofort sichtbar werden
                                    @waly_de Leider passiert in der App nichts, wenn ich das Script stoppe und den Wert im Writable z.B. auf 800 setze...
                                    umele W 2 Replies Last reply Reply Quote 0
                                    • umele
                                      umele @Ralf77 last edited by umele
                                      @ralf77
                                      Hast Du schon mal versucht rauszufinden, welcher Parameter in
                                      • app_device_property_DCxxx
                                      anzeigt wieviel aktuell via AC-Anschluss geladen wird?
                                      Vielleicht lässt die Nomenklatur Rückschlüsse darauf zu, ob "slowChgPower" überhaupt der richtige Parameter ist.
                                        Ralf77 @umele last edited by
                                        @umele Die AC-Ladeleistung ist bei mir unter "app_device_property_DCxxx" nicht zu finden...
                                          Also mein Script muss laufen. Deins nicht.
                                            @waly_de Ja, so habe ich es gemacht... Dein Script aktiv, meines ausgeschalten, dann in "0_userdata.0.ecoflow.app_169XXX_DCEXXX_thing_property_set.writeables.slowChgPower" und mit "Wert Bearbeiten" zB: 500 eingegeben ...
                                            500 steht dann als Wert drin...in der App ändert sicht aber nichts 😞
                                            Eventuell ist das problem, dass ich einen Delta Pro habe. So habe ich es eingegeben in Deinem Script:
                                            1644
                                            730590
