Skript v.2023-10-10
*** BASE SYSTEM ***
Static hostname: iobroker
Icon name: computer
Operating System: Debian GNU/Linux 11 (bullseye)
Kernel: Linux 6.1.21-v8+
Architecture: arm64
Model : Raspberry Pi 4 Model B Rev 1.5
Docker : false
Virtualization : none
Kernel : aarch64
Userland : arm64
Systemuptime and Load:
13:12:01 up 3:51, 1 user, load average: 0.63, 0.52, 0.60
CPU threads: 4
*** RASPBERRY THROTTLING ***
Current issues:
Previously detected issues:
*** Time and Time Zones ***
Local time: Wed 2023-10-18 13:12:01 CEST
Universal time: Wed 2023-10-18 11:12:01 UTC
RTC time: n/a
NTP service: active
RTC in local TZ: no
*** User and Groups ***
pi
/home/pi
pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
*** X-Server-Setup ***
X-Server: false
Desktop:
Terminal: tty
Boot Target: multi-user.target
*** MEMORY ***
total used free shared buff/cache available
Mem: 7.8G 2.8G 3.6G 1.0M 1.4G 4.9G
Swap: 99M 0B 99M
Total: 7.9G 2.8G 3.7G
7811 M total memory
2760 M used memory
3681 M active memory
357 M inactive memory
3606 M free memory
129 M buffer memory
1315 M swap cache
99 M total swap
0 M used swap
99 M free swap
Raspberry only:
oom events: 0
*** FAILED SERVICES ***
0 loaded units listed.
*** FILESYSTEM ***
Filesystem Type Size Used Avail Use% Mounted on
/dev/root ext4 59G 11G 46G 19% /
devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev
tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs tmpfs 1.6G 1.2M 1.6G 1% /run
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
/dev/sda1 vfat 255M 31M 225M 13% /boot
tmpfs tmpfs 782M 16K 782M 1% /run/user/1000
[Wed Oct 18 09:20:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[Wed Oct 18 09:20:55 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
[Wed Oct 18 09:20:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[Wed Oct 18 09:20:56 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
TARGET SOURCE FSTYPE OPTIONS
/ /dev/sda2 ext4 rw,noatime
`-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
1.8G /var/
1.1G /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
1.1G /var/log
525M /var/lib
Archived and active journals take up 1.0G in the file system.
/opt/iobroker/backups:
1.3G /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
384M /opt/iobroker/iobroker-data/
184M /opt/iobroker/iobroker-data/files
72M /opt/iobroker/iobroker-data/backup-objects
62M /opt/iobroker/iobroker-data/node-red/node_modules
50M /opt/iobroker/iobroker-data/objects.jsonl
33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
15M /opt/iobroker/iobroker-data/states.jsonl
8.5M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
*** NodeJS-Installation ***
/usr/bin/nodejs v18.18.2
/usr/bin/node v18.18.2
/usr/bin/npm 9.8.1
/usr/bin/npx 9.8.1
/usr/bin/corepack 0.19.0
nodejs:
Installed: 18.18.2-1nodesource1
Candidate: 18.18.2-1nodesource1
Version table:
*** 18.18.2-1nodesource1 1001
100 /var/lib/dpkg/status
18.18.1-1nodesource1 1001
18.18.0-1nodesource1 1001
18.17.1-1nodesource1 1001
18.17.0-1nodesource1 1001
18.16.1-1nodesource1 1001
18.16.0-1nodesource1 1001
18.15.0-1nodesource1 1001
18.14.2-1nodesource1 1001
18.14.1-1nodesource1 1001
18.14.0-1nodesource1 1001
18.13.0-1nodesource1 1001
18.12.0-1nodesource1 1001
18.11.0-1nodesource1 1001
18.10.0-1nodesource1 1001
18.9.1-1nodesource1 1001
18.9.0-1nodesource1 1001
18.8.0-1nodesource1 1001
18.7.0-1nodesource1 1001
18.6.0-1nodesource1 1001
18.5.0-1nodesource1 1001
18.4.0-1nodesource1 1001
18.3.0-1nodesource1 1001
18.2.0-1nodesource1 1001
18.1.0-1nodesource1 1001
18.0.0-1nodesource1 1001
12.22.12~dfsg-1~deb11u4 500
500 http://deb.debian.org/debian bullseye/main arm64 Packages
500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
No problems detected
Errors in npm tree:
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States type: jsonl
Core adapters versions
js-controller: 5.0.14
admin: 6.10.8
javascript: 7.1.5
Adapters from github: 2
Adapter State
+ system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.alexa2.0 : alexa2 : iobroker - enabled
system.adapter.alias-manager.0 : alias-manager : iobroker - disabled
+ system.adapter.backitup.0 : backitup : iobroker - enabled
+ system.adapter.cloud.0 : cloud : iobroker - enabled
+ system.adapter.discovery.0 : discovery : iobroker - enabled
+ system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker - enabled
+ system.adapter.fritzdect.0 : fritzdect : iobroker - enabled
+ system.adapter.hm-rega.0 : hm-rega : iobroker - enabled
+ system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 18701
+ system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 12001
+ system.adapter.hm-rpc.2 : hm-rpc : iobroker - enabled, port: 12010
+ system.adapter.hm-rpc.3 : hm-rpc : iobroker - enabled, port: 0
+ system.adapter.hue-extended.0 : hue-extended : iobroker - enabled
system.adapter.ical.0 : ical : iobroker - enabled
+ system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086
+ system.adapter.info.0 : info : iobroker - enabled
+ system.adapter.iot.0 : iot : iobroker - enabled
+ system.adapter.jarvis.0 : jarvis : iobroker - enabled
+ system.adapter.javascript.0 : javascript : iobroker - enabled
system.adapter.modbus.0 : modbus : iobroker - disabled
+ system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0
+ system.adapter.net-tools.0 : net-tools : iobroker - enabled
+ system.adapter.node-red.0 : node-red : iobroker - enabled, port: 1880, bind: 0.0.0.0
+ system.adapter.nuki.0 : nuki : iobroker - enabled
+ system.adapter.opendtu.0 : opendtu : iobroker - enabled
+ system.adapter.panasonic-viera.0 : panasonic-viera : iobroker - enabled
+ system.adapter.ping.0 : ping : iobroker - enabled
+ system.adapter.rpi2.0 : rpi2 : iobroker - enabled
+ system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0
+ system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 192.168.178.82, run as: admin
system.adapter.smartmeter.0 : smartmeter : iobroker - disabled
system.adapter.smartmeter.1 : smartmeter : iobroker - disabled
+ system.adapter.socketio.0 : socketio : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin
+ system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1886, bind: 0.0.0.0
+ system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0
+ system.adapter.tr-064.0 : tr-064 : iobroker - enabled
+ system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
+ instance is alive
ioBroker-Repositories
stable : http://download.iobroker.net/sources-dist.json
beta : http://download.iobroker.net/sources-dist-latest.json
Active repo(s): beta
Installed ioBroker-Instances
Used repository: beta
Adapter "admin" : 6.10.8 , installed 6.10.8
Adapter "alexa2" : 3.25.2 , installed 3.25.2
Adapter "alias-manager": 1.2.6 , installed 1.2.6
Adapter "backitup" : 2.8.6 , installed 2.8.6
Adapter "cloud" : 4.4.1 , installed 4.4.1
Adapter "discovery" : 4.2.0 , installed 4.2.0
Adapter "fritzdect" : 2.5.2 , installed 2.5.2
Adapter "hm-rega" : 4.0.0 , installed 4.0.0
Adapter "hm-rpc" : 1.15.19 , installed 1.15.19
Adapter "hue-extended" : 2.0.0 , installed 2.0.0
Adapter "ical" : 1.13.3 , installed 1.13.3
Adapter "influxdb" : 3.2.0 , installed 3.2.0
Adapter "info" : 2.0.0 , installed 2.0.0
Adapter "iot" : 2.0.11 , installed 2.0.11
Adapter "jarvis" : 3.1.8 , installed 3.1.9-beta.3
Adapter "javascript" : 7.1.5 , installed 7.1.5
Controller "js-controller": 5.0.14 , installed 5.0.14
Adapter "modbus" : 5.0.11 , installed 5.0.11
Adapter "mqtt" : 5.1.0 , installed 5.1.0
Adapter "net-tools" : 0.2.0 , installed 0.2.0
Adapter "node-red" : 4.0.3 , installed 4.0.3
Adapter "nuki" : 1.6.0 , installed 1.6.0
Adapter "opendtu" : 1.0.0 , installed 1.0.0
Adapter "panasonic-viera": 2.0.0 , installed 2.0.0
Adapter "ping" : 1.6.2 , installed 1.6.2
Adapter "rpi2" : 1.3.2 , installed 1.3.2
Adapter "shelly" : 6.6.0 , installed 6.6.0
Adapter "simple-api" : 2.7.2 , installed 2.7.2
Adapter "smartmeter" : 3.3.4 , installed 3.3.4
Adapter "socketio" : 6.6.0 , installed 6.6.0
Adapter "sonoff" : 3.0.3 , installed 3.0.3
Adapter "telegram" : 2.0.1 , installed 2.0.1
Adapter "tr-064" : 4.2.18 , installed 4.2.18
Adapter "web" : 6.1.10 , installed 6.1.10
Adapter "ws" : 2.5.8 , installed 2.5.8
Objects and States
Objects: 9872
States: 9225
Hit:1 http://deb.debian.org/debian bullseye InRelease
Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
Hit:4 https://repos.influxdata.com/debian stable InRelease
Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:6 https://apt.grafana.com stable InRelease
Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
Pending Updates: 0
*** Listening Ports ***
Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
tcp 0 0 192.168.178.82:12001 0.0.0.0:* LISTEN 1001 16702 1359/io.hm-rpc.1
tcp 0 0 192.168.178.82:12010 0.0.0.0:* LISTEN 1001 18469 1377/io.hm-rpc.2
tcp 0 0 192.168.178.82:8087 0.0.0.0:* LISTEN 1001 23723 2226/io.simple-api.
tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1001 18851 1508/io.sonoff.0
tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 15096 1273/node-red
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 116 15973 553/mosquitto
tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 18170 1568/io.shelly.0
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14621 574/sshd: /usr/sbin
tcp 0 0 0.0.0.0:8400 0.0.0.0:* LISTEN 1001 21994 1825/io.jarvis.0
tcp 0 0 192.168.178.82:18701 0.0.0.0:* LISTEN 1001 15083 1339/io.hm-rpc.0
tcp 0 0 192.168.178.82:2001 0.0.0.0:* LISTEN 1001 15239 1434/io.hm-rpc.3
tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 12966 538/cupsd
tcp 0 0 192.168.178.82:9092 0.0.0.0:* LISTEN 1001 22404 1965/io.nuki.0
tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 617 652/iobroker.js-con
tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 16283 652/iobroker.js-con
tcp6 0 0 :::1883 :::* LISTEN 116 15974 553/mosquitto
tcp6 0 0 :::22 :::* LISTEN 0 14623 574/sshd: /usr/sbin
tcp6 0 0 :::8084 :::* LISTEN 1001 21335 2260/io.socketio.0
tcp6 0 0 :::8086 :::* LISTEN 999 16011 542/influxd
tcp6 0 0 :::8081 :::* LISTEN 1001 16458 1120/io.admin.0
tcp6 0 0 :::8082 :::* LISTEN 1001 19364 1655/io.web.0
tcp6 0 0 :::3000 :::* LISTEN 117 659 651/grafana
tcp6 0 0 ::1:631 :::* LISTEN 0 12965 538/cupsd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 15747 401/avahi-daemon: r
udp 0 0 0.0.0.0:59127 0.0.0.0:* 108 15749 401/avahi-daemon: r
udp 0 0 0.0.0.0:68 0.0.0.0:* 0 520 466/dhcpcd
udp 0 0 0.0.0.0:631 0.0.0.0:* 0 12981 617/cups-browsed
udp6 0 0 :::5353 :::* 108 15748 401/avahi-daemon: r
udp6 0 0 :::546 :::* 0 16080 466/dhcpcd
udp6 0 0 :::54373 :::* 108 15750 401/avahi-daemon: r
2023-10-18 12:32:40.256 - info: fritzdect.0 (1635) glob state ["116570586980"]
2023-10-18 12:37:40.186 - info: fritzdect.0 (1635) glob state ["116570586980"]
2023-10-18 12:38:00.557 - info: nuki.0 (1965) status change received for NukiID 790083444: locked
2023-10-18 12:38:00.558 - info: nuki.0 (1965) battery status received for NukiID 790083444: false
2023-10-18 12:41:16.689 - info: admin.0 (1120) ==> Connected system.user.admin from ::ffff:192.168.178.63
2023-10-18 12:42:19.228 - info: admin.0 (1120) ==> Connected system.user.admin from ::ffff:192.168.178.63
2023-10-18 12:42:29.725 - info: admin.0 (1120) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
2023-10-18 12:42:40.038 - info: fritzdect.0 (1635) glob state ["116570586980"]
2023-10-18 12:47:40.088 - info: fritzdect.0 (1635) glob state ["116570586980"]
2023-10-18 12:52:39.921 - info: fritzdect.0 (1635) glob state ["116570586980"]
2023-10-18 12:57:40.278 - info: fritzdect.0 (1635) glob state ["116570586980"]
2023-10-18 13:00:00.165 - info: host.iobroker instance system.adapter.ical.0 started with pid 33359
2023-10-18 13:00:09.530 - info: ical.0 (33359) Terminated (NO_ERROR): Without reason
2023-10-18 13:00:10.070 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
2023-10-18 13:02:40.056 - info: fritzdect.0 (1635) glob state ["116570586980"]
2023-10-18 13:07:39.999 - info: fritzdect.0 (1635) glob state ["116570586980"]
2023-10-18 13:09:48.618 - info: admin.0 (1120) ==> Connected system.user.admin from ::ffff:192.168.178.63
2023-10-18 13:09:51.781 - info: javascript.0 (1232) Start javascript script.js.test.Bluetti_ein_ausschalten
2023-10-18 13:09:51.811 - info: javascript.0 (1232) script.js.test.Bluetti_ein_ausschalten: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2023-10-18 13:12:39.882 - info: fritzdect.0 (1635) glob state ["116570586980"]
iob diag has finished.
Press any key for a summary
